MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
RZ series
Miniaturized,long life, low impedance
High ripple current, high reliability
Endurance: +105°C 6,000~10,000 hours
1808
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
6.3~50 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
I≤0.01CV or 3μA, whichever is greater.
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
Dissipation Factor (tanδ)
6.3
10
16
25
35
0.22 0.19 0.16 0.14 0.12
tanδ (max.)
(at 20°C after 2 minutes)
50
0.10
When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase.
Low Temperature
Characteristics
(Max. Impedance Ratio)
6.3
10
6
4
2
Z(-25°C)/Z(+20°C)
Z(-40°C)/Z(+20°C)
(at 20°C,120Hz)
16~50
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20°C after DC voltage plus the rated
ripple current is applied for a specified period of time at 105 °C.
Endurance
Capacitance Change
≤±25% of the initial value (6.3,10V:≤±30%)
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
Case Dia.(mm)
ØD≤6.3
ØD=8
ØD≥10
Load life (hours)
6,000
8,000
10,000
The following specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000
hours at 105°C without voltage applied.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Sleeve(Vioelt)
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 5~ Ø 18)
ØD
5
6.3
Ød
0.5
0.5
F
ØD'
L'
2.0
2.5
8
0.5
0.6
3.5
10
12.5
16
18
0.6
0.6
0.8
0.8
5.0
5.0
7.5
7.5
Ø D+0.5max.
L+2max.
E
RZ 1H
M 220 D12 O- -
Radial Type
PART NUMBERING SYSTEM
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Cap.(μF)
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“ERZ1EM151E12OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34582
- 100+0.28188
- 300+0.25002
- 1000+0.22605
- 5000+0.20693
- 10000+0.19732
