PESD3V3L4UG,115
PESD3V3L4UG,115
    NEXPERIA(安世)
    SOT-353-5(SC-70-5)
    ESD VRWM=3.3 V VBR(Min)=5.32 V VC=12 V IPP=3 A Ppp=30 W SOT353
PESD3V3L4UG,115 数据手册
PESDxL4UF; PESDxL4UG; PESDxL4UW Low capacitance unidirectional quadruple ESD protection diode arrays Rev. 04 — 28 February 2008 Product data sheet 1. Product profile 1.1 General description Low capacitance unidirectional quadruple ElectroStatic Discharge (ESD) protection diode arrays in small Surface-Mounted Device (SMD) plastic packages designed to protect up to four signal lines from the damage caused by ESD and other transients. Table 1. Product overview Type number Package Package configuration Nexperia JEITA JEDEC PESD3V3L4UF SOT886 - MO-252 leadless ultra small PESD5V0L4UF SOT886 - MO-252 leadless ultra small PESD3V3L4UG SOT353 SC-88A - very small PESD5V0L4UG SOT353 SC-88A - very small PESD3V3L4UW SOT665 - - ultra small and flat lead PESD5V0L4UW SOT665 - - ultra small and flat lead 1.2 Features n n n n ESD protection of up to four lines Low diode capacitance Max. peak pulse power: PPP = 30 W Low clamping voltage: VCL = 12 V n n n n Ultra low leakage current: IRM = 5 nA ESD protection up to 20 kV IEC 61000-4-2; level 4 (ESD) IEC 61000-4-5 (surge); IPP = 2.5 A 1.3 Applications n Computers and peripherals n Audio and video equipment n Cellular handsets and accessories n Communication systems n Portable electronics n Subscriber Identity Module (SIM) card protection PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - - 3.3 V PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - - 5.0 V PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - 22 28 pF PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - 16 19 pF Per diode VRWM Cd reverse standoff voltage diode capacitance f = 1 MHz; VR = 0 V 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol PESD3V3L4UF; PESD5V0L4UF 1 cathode (diode 1) 2 common anode 3 1 2 3 1 6 cathode (diode 2) 2 5 4 cathode (diode 3) 3 4 5 common anode 6 cathode (diode 4) 6 5 bottom view 006aaa156 4 PESD3V3L4UG; PESD5V0L4UG 1 cathode (diode 1) 2 common anode 3 cathode (diode 2) 4 cathode (diode 3) 5 cathode (diode 4) 5 4 1 5 2 3 1 2 4 3 006aaa157 PESD3V3L4UW; PESD5V0L4UW 1 cathode (diode 1) 2 common anode 3 cathode (diode 2) 2 4 cathode (diode 3) 3 5 cathode (diode 4) 5 1 1 2 Rev. 04 — 28 February 2008 5 4 006aaa157 3 © PESDXL4UF_G_W_4 Product data sheet 4 Nexperia B.V. 2017. All rights reserved 2 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 3. Ordering information Table 4. Ordering information Type number Package PESD3V3L4UF Name Description Version XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 SC-88A plastic surface-mounted package; 5 leads SOT353 - plastic surface-mounted package; 5 leads SOT665 PESD5V0L4UF PESD3V3L4UG PESD5V0L4UG PESD3V3L4UW PESD5V0L4UW 4. Marking Table 5. Marking codes Type number Marking code[1] PESD3V3L4UF A5 PESD5V0L4UF A6 PESD3V3L4UG L1* PESD5V0L4UG L2* PESD3V3L4UW A2 PESD5V0L4UW A1 [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit PPP peak pulse power tp = 8/20 µs [1][2][3] IPP peak pulse current tp = 8/20 µs [1][2][3] - 30 W PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - 3.0 A PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - 2.5 A - 3.5 A Per diode IFSM non-repetitive peak forward square wave; current tp = 1 ms © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 3 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays Table 6. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit IZSM non-repetitive peak reverse square wave; current tp = 1 ms PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - 0.9 A PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - 0.8 A non-repetitive peak reverse square wave; power dissipation tp = 1 ms - 6 W Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C PZSM Conditions Per device [1] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [2] For PESDxL4UF measured from pin 1, 3, 4 or 6 to pin 2 or 5. [3] For PESDxL4UG and PESDxL4UW measured from pin 1, 3, 4 or 5 to pin 2. Table 7. ESD maximum ratings Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions electrostatic discharge voltage IEC 61000-4-2 (contact discharge) Min Max Unit - 20 kV - 10 kV Per diode VESD [1][2][3] MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] For PESDxL4UF measured from pin 1, 3, 4 or 6 to pin 2 or 5. [3] For PESDxL4UG and PESDxL4UW measured from pin 1, 3, 4 or 5 to pin 2. Table 8. ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 4 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 µs IPP (%) 80 e−t 50 % IPP; 20 µs 40 10 % t tr = 0.7 ns to 1 ns 0 0 10 20 30 30 ns 40 t (µs) 60 ns Fig 1. 8/20 µs pulse waveform according to IEC 61000-4-5 Fig 2. ESD pulse waveform according to IEC 61000-4-2 6. Characteristics Table 9. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - - 3.3 V PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - - 5.0 V Per diode VRWM IRM VBR reverse standoff voltage reverse leakage current PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW VRWM = 3.3 V - 75 300 nA PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW VRWM = 5.0 V - 5 25 nA PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW 5.32 5.6 5.88 V PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW 6.46 6.8 7.14 V breakdown voltage IR = 1 mA © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 5 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays Table 9. Characteristics …continued Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Cd f = 1 MHz; VR = 0 V VCL rdif Min Typ Max Unit PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - 22 28 pF PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - 16 19 pF diode capacitance [1][2][3] clamping voltage PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW IPP = 1 A - - 8 V PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW IPP = 3 A - - 12 V PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW IPP = 1 A - - 10 V PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW IPP = 2.5 A - - 13 V differential resistance IR = 1 mA PESD3V3L4UF PESD3V3L4UG PESD3V3L4UW - - 200 Ω PESD5V0L4UF PESD5V0L4UG PESD5V0L4UW - - 100 Ω [1] Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5. [2] For PESDxL4UF measured from pin 1, 3, 4 or 6 to pin 2 or 5. [3] For PESDxL4UG and PESDxL4UW measured from pin 1, 3, 4 or 5 to pin 2. © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 6 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 006aab134 10 IZSM (A) 006aab135 102 PZSM (W) (1) 1 10 (1) (2) (2) 10−1 10−2 10−1 1 1 10−2 10 10−1 1 10 tp (ms) tp (ms) Tamb = 25 °C Tamb = 25 °C (1) PESD3V3L4UF; PESD3V3L4UG; PESD3V3L4UW (1) PESD3V3L4UF; PESD3V3L4UG; PESD3V3L4UW (2) PESD5V0L4UF; PESD5V0L4UG; PESD5V0L4UW (2) PESD5V0L4UF; PESD5V0L4UG; PESD5V0L4UW Fig 3. Non-repetitive peak reverse current as a function of pulse duration; maximum values Fig 4. Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values 006aab136 26 006aab137 10 Cd (pF) 22 IR IR(25°C) 18 1 (1) 14 (2) 10 6 0 1 2 3 4 5 10−1 −75 −25 25 75 125 VR (V) 175 Tj (°C) f = 1 MHz; Tamb = 25 °C (1) PESD3V3L4UF; PESD3V3L4UG; PESD3V3L4UW (2) PESD5V0L4UF; PESD5V0L4UG; PESD5V0L4UW Fig 5. Diode capacitance as a function of reverse voltage; typical values Fig 6. Relative variation of reverse current as a function of junction temperature; typical values © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 7 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays I −VCL −VBR −VRWM V −IRM −IR − + P-N −IPP 006aaa407 Fig 7. V-I characteristics for a unidirectional ESD protection diode © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 8 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays ESD TESTER RZ 450 Ω RG 223/U 50 Ω coax DIGITIZING OSCILLOSCOPE 10× ATTENUATOR (1) CZ IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω 50 Ω DUT DEVICE UNDER TEST (1): attenuator is only used for open socket high voltage measurements vertical scale = 200 V/div horizontal scale = 50 ns/div vertical scale = 5 V/div horizontal scale = 50 ns/div PESD5V0L4UF/G/W GND2 PESD3V3L4UF/G/W GND GND1 unclamped +1 kV ESD voltage waveform (IEC 61000-4-2 network) clamped +1 kV ESD voltage waveform (IEC 61000-4-2 network) GND GND vertical scale = 200 V/div horizontal scale = 50 ns/div unclamped −1 kV ESD voltage waveform (IEC 61000-4-2 network) vertical scale = 5 V/div horizontal scale = 50 ns/div clamped −1 kV ESD voltage waveform (IEC 61000-4-2 network) 006aab138 Fig 8. ESD clamping test setup and waveforms © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 9 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 7. Application information The devices are designed for the protection of up to four unidirectional data or signal lines from the damage caused by ESD and surge pulses. The devices may be used on lines where the signal polarities are both, positive and negative with respect to ground. The devices provide a surge capability of 30 W per line for an 8/20 µs waveform each. data- or transmission lines DUT 1 DUT 5 5 n.c. 2 2 3 1 4 unidirectional protection of 4 lines 3 4 bidirectional protection of 3 lines 006aab126 Fig 9. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the device as close to the input terminal or connector as possible. 2. The path length between the device and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 10 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 8. Package outline 0.50 max 1.05 0.95 2.2 1.8 0.04 max 0.6 3 4 2 5 1 6 0.40 0.32 0.35 0.27 5 0.45 0.15 4 0.25 0.17 0.5 1.5 1.4 1.1 0.8 2.2 1.35 2.0 1.15 0.5 1 2 3 0.25 0.10 0.3 0.2 0.65 1.3 Dimensions in mm 04-07-22 Dimensions in mm Fig 10. Package outline PESDxL4UF (SOT886) 04-11-16 Fig 11. Package outline PESDxL4UG (SOT353/SC-88A) 1.7 1.5 0.6 0.5 5 4 0.3 0.1 1.7 1.5 1.3 1.1 1 2 3 0.27 0.17 0.5 0.18 0.08 1 Dimensions in mm 04-11-08 Fig 12. Package outline PESDxL4UW (SOT665) © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 11 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 9. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PESD3V3L4UF PESD5V0L4UF PESD3V3L4UG PESD5V0L4UG PESD3V3L4UW PESD5V0L4UW Package SOT886 SOT886 SOT353 SOT353 SOT665 SOT665 Description Packing quantity 3000 4000 5000 8000 10000 4 mm pitch, 8 mm tape and reel; T1 [2] - - -115 - - 4 mm pitch, 8 mm tape and reel; T4 [3] - - -132 - - 4 mm pitch, 8 mm tape and reel; T1 [2] - - -115 - - 4 mm pitch, 8 mm tape and reel; T4 [3] - - -132 - - 4 mm pitch, 8 mm tape and reel; T1 [2] -115 - - - -135 4 mm pitch, 8 mm tape and reel; T2 [4] -125 - - - -165 4 mm pitch, 8 mm tape and reel; T1 [2] -115 - - - -135 4 mm pitch, 8 mm tape and reel; T2 [4] -125 - - - -165 2 mm pitch, 8 mm tape and reel - - - -315 - 4 mm pitch, 8 mm tape and reel - -115 - - - 2 mm pitch, 8 mm tape and reel - - - -315 - 4 mm pitch, 8 mm tape and reel - -115 - - - [1] For further information and the availability of packing methods, see Section 13. [2] T1: normal taping [3] T4: 90° rotated reverse taping [4] T2: reverse taping 10. Soldering 1.250 0.675 0.370 (6×) 0.500 1.700 solder lands 0.500 solder paste 0.270 (6×) occupied area Dimensions in mm 0.325 (6×) 0.425 (6×) sot886_fr Reflow soldering is the only recommended soldering method. Fig 13. Reflow soldering footprint PESDxL4UF (SOT886) © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 12 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 2.65 0.60 (1×) 0.40 0.90 2.10 2.35 0.50 (4×) solder lands 0.50 (4×) solder paste 1.20 solder resist 2.40 occupied area Dimensions in mm sot353_fr Fig 14. Reflow soldering footprint PESDxL4UG (SOT353/SC-88A) 2.25 2.65 0.30 1.00 4.00 4.50 2.70 0.70 solder lands 1.15 3.75 solder resist transport direction during soldering occupied area Dimensions in mm Fig 15. Wave soldering footprint PESDxL4UG (SOT353/SC-88A) © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 13 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 2.45 2.10 1.60 0.15 (2x) 0.70 (2×) 0.40 (5×) 0.45 (2×) 2.00 1.70 1.00 0.30 0.55 0.375 (2×) 1.25 1.375 1.20 2.20 solder lands placement area solder resist occupied area 0.075 Dimensions in mm Reflow soldering is the only recommended soldering method. Fig 16. Reflow soldering footprint PESDxL4UW (SOT665) © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 14 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes PESDXL4UF_G_W_4 20080228 Product data sheet - PESDXL4UF_G_W_3 Modifications: • Figure 8 “ESD clamping test setup and waveforms”: amended PESDXL4UF_G_W_3 20080114 Product data sheet - PESDXL4UW_SER_2 PESDXL4UG_SERIES_1 PESDXL4UW_SER_2 20040406 Product specification - PESDXL4UW_SERIES_1 PESDXL4UG_SERIES_1 20040323 Product specification - - © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 15 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © PESDXL4UF_G_W_4 Product data sheet Rev. 04 — 28 February 2008 Nexperia B.V. 2017. All rights reserved 16 of 17 PESDxL4UF/G/W Nexperia Low capacitance unidirectional quadruple ESD protection diode arrays 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Packing information. . . . . . . . . . . . . . . . . . . . . 12 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 February 2008
PESD3V3L4UG,115 价格&库存
很抱歉,暂时无法提供与“PESD3V3L4UG,115”相匹配的价格&库存,您可以联系我们找货
PESD3V3L4UG,115
  • 1+1.54112
  • 100+1.45152
  • 300+1.36192
  • 500+1.27232
  • 2000+1.22752
  • 5000+1.20064
库存:3000
PESD3V3L4UG,115
  • 1+0.777011+0.10065
  • 10+0.7116310+0.09218
库存:62878
PESD3V3L4UG,115
  • 1+5.375131+0.69627
  • 10+3.3072010+0.42840
  • 100+2.10697100+0.27293
  • 500+1.58750500+0.20564
  • 1000+1.419851000+0.18392
库存:42109
