FXC1360-121M
FXC1360-121M
    CJIANG(长江微电)
    SMD,13.5x12.6mm
    SMD,13.5*12.6*5.7mm(1206) 电感值:120µH 精度:±20% 饱和电流(isat):7A 温升电流(irms):3.5A 直流电阻(DCR):235mΩ 羰基,一体成型电感
FXC1360-121M 数据手册
深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD FXC1360 Series Introduction • 100% Lead(Pb)-Free and RoHS compliant. • High current,low DCR,high efficiency. • 14.0×12.9×6.0mm maximum surface mount package . • Operating temperature -40℃~+125℃(Including self - temperature rise) . Applications • Note PC power system . • DC/DC converter . Product Identification FXC ① 1360 ② -1R5 ③ M ④ ① FXC ---------- Series name ② 1360 ---------- Dimension ③ 1R5 ----------- Inductance Value (1R5 = 1.5μH) ④ M -----------Inductance Tolerance ( M= ± 20% ) Dimensions (unit:mm) A C b E B c D a Recommend Land Pattern A B C D E a typ b typ c typ 13.5±0.5 12.6±0.3 5.7±0.3 2.0±0.5 See remark 8 14.2 5.0 Remarks E Dimensions 3.85±0.5 R47/R68/1R0/1R5 4.7±0.5 2R2/3R3/4R7/6R8/8R2/100/150/220/330/470/680/820/101/121/151 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD Marking The inductor is marked with a 3-digit code Nominal Inductance Example Nominal Value 1R0 1.0 μH 100 10 μH 101 100 μH Note:Using Ink for marking 1R0 Structure and Components NO Components Material 1 CORE Carbonyl Powder 2 WIRE Polyester Wire or equivalent. 3 Clip 100% Pb free solder(Ni+Sn---Plating) 4 paint Epoxy resin 5 Ink Halogen-free ketone 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD Saturation Saturation Heating Rating Current Current Current DCR (mΩ) Isat 1(A) Isat 2(A) Irms (A) ±20 %, 100 kHz, 1V MAX. TYP. TYP. TYP. FXC1360-R47M 0.47 1.3 64 60 38 FXC1360-R68M 0.68 1.7 57 53 33 FXC1360-1R0M 1.0 2.4 53 45 29 FXC1360-1R5M 1.5 3.2 50 43 26 FXC1360-2R2M 2.2 4.7 43 34 21 FXC1360-3R3M 3.3 7.1 35 28 17 FXC1360-4R7M 4.7 11.5 30 25 16 FXC1360-6R8M 6.8 13.8 25 19 15 FXC1360-8R2M 8.2 16 23 17 11 FXC1360-100M 10 20.7 21 15.5 11 FXC1360-150M 15 29 16 13 9 FXC1360-220M 22 39.5 14 11 8 FXC1360-330M 33 75 12 8 6 FXC1360-470M 47 90 11 7 5.5 FXC1360-680M 68 140 9 6 5 FXC1360-820M 82 161 8.5 5.5 4.5 FXC1360-101M 100 200 8 5 4 FXC1360-121M 120 235 7 4.5 3.5 FXC1360-151M 150 350 6 4 3 Part No. Inductance DC Resistance L0 (μH) Notes 1. All test data is referenced to 25 °C ambient 2. Irms (A):DC current (A) that will cause an approximate ΔT of 40 °C(reference ambient temperature is 25 °C) 3. Isat 1(A):DC current (A) that will cause L0 to drop approximately 30 % Isat 2(A):DC current (A) that will cause L0 to drop approximately 20 % 4. The part temperature (ambient + temp rise) should not exceed 125 °C under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD Mechanical Reliability Item Specification and Requirement 1. No case deformation or change in apperarance Solderability 2. New solder coverage Test Method 1.Preheat:155℃±5℃ ,60S±2S 2.Tin: lead-free. 3.Temperature:240℃±5℃,flux 3.0S±0.5S. More than 95% Mechanical 1. No case deformation 1. Acceleration: 100G or change in apperarance 2. Pulse time::6ms shock 3. 3 times in each positive and negative direction of 3 2. △L/Lo≦±10% 1. No case deformation Mechanical or change in apperarance vibration 2. △L/Lo≦±10% mutual perpendicular directions 1. Reflow: 2times 2. Frequency: 10HZ~55HZ~10HZ,20 Min/Cycles 3. Amplitude: 1.52 mm 4. Directions: X,Y,Z 5. Time: 12 cycle / direction Endurance Reliability Item Specification and Requirement Inductance change: Thermal Shock Within ± 10% Without distinct damage in appearance Test Method 1. First -40℃ for 30 minutes,last 125℃ for 30 minutes as 1 cycle. Go through 1000 cycles. 2. Max transfer time is 3 minutes. 3. Measured at room temperature after placing for 24±2 hours Humidity Resistance Inductance change: 1.Reflow 2 times, Within ± 10% Without distinct damage 2.85℃,85%RH,1000 hours in appearance 3.Measured at room temperature after placing for 24±2 hours Low temperature storage High temperature storage Inductance change: 1. Temperature:-40 ± 2℃ Within ± 10% Without distinct damage 2. Time:1000 hours in appearance 3. Measured at room temperature after placing for 24±2 hours Inductance change: Within ± 10% Without distinct damage in appearance 1. Temperature:+125 ± 2℃ 2. Time:1000 hours 3. Measured at room temperature after placing for 24±2 hours 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD Recommended Soldering Technologies (1)Re-flowing Profile Preheat condition: 150 ~200℃/60~180sec. Allowed time above 217℃: 80~120sec. Max temp: 260℃ Max time at max temp: 10 sec. Solder paste: Sn/3.0Ag/0.5Cu Allowed Reflow time: 2x max (2)Iron Soldering Profile Iron soldering power: Max. 30W Pre-heating: 150℃/60sec. 3sec. Max. 350℃ Soldering Tip temperature: 350℃ Max. Power: max. 30W Soldering time: 3sec. Max. Diameter of Soldering Solder paste: Sn/3.0Ag/0.5Cu Max.1 times for iron soldering Soldering Iron Iron 1.0mm max. Tc ℃ 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD Packaging Information (1) Tape Packaging Dimensions(Unit:mm) Tape dimensions (mm) W P P0 P2 D0 D1 T A0 B0 K0 E F 24 ±0.3 16 ±0.1 4.0 ±0.1 2.0 ±0.1 1.5 ±0.1 1.5 ±0.1 0.5 ±0.05 13.1 ±0.1 14 ±0.1 6.3 ±0.1 1.75 ±0.1 11.5 ±0.1 Taping Drawings (UNIT:mm) 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD (2) Reel Dimensions(Unit:mm) B N D C W A W N B C D 330+2.0 24±0.5 97±0.5 2.2+0.5 13.0±0.2 10.75±0.25 (3) Packaging Quantity(PCS) Standard Quantity Type FXC1360 Reel Inner box 500 pcs / reel 2Reel / box (1000 pcs) (4) Peel force of top cover tape The peel speed shall be about 300mm/minute The peel force of top cover tape shall be between 0.1 to 1.3 N Carton box 4 Middle boxes, (4000 pcs) A 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD (5) Reel Label Label on the reel • Customer's part Number • Lot Number • Quantity • date code Shipping Label • Customer's part Number • Manufacturer's part Number • Quantity • date code (6) Inner Box (7) Carton
FXC1360-121M
物料型号:FXC1360系列
器件简介: - 100%无铅和符合RoHS标准。 - 高电流、低直流电阻(DCR)、高效率。 - 最大尺寸为14.0×12.9×6.0mm的表面贴装封装。 - 工作温度范围为-40℃至+125℃(包括自温升)。
引脚分配:文档中未明确列出引脚分配,但通常电感器会有至少两个引脚用于连接电路。
参数特性: - 产品识别码中包含系列名称、尺寸、电感值和电感容差。 - 尺寸参数包括A、B、C、D、E,具体数值见文档表格。
功能详解: - 应用于PC电源系统和DC/DC转换器。
应用信息: - 电感器的典型应用包括PC电源系统和DC/DC转换器。
封装信息: - 提供了推荐的焊盘图案尺寸,以确保电感器的焊接可靠性。
结构和组件: - 包括芯材、线材、夹子、漆层和油墨,具体材料见文档表格。
标记: - 电感器使用三位数字代码进行标记,示例包括1R0表示1.0μH,100表示10μH等。
性能参数: - 提供了不同型号电感器的电感值、最大直流电阻、典型饱和电流、额定电流和电感变化等参数。
机械可靠性和耐久性测试: - 包括焊接性、机械冲击、机械振动、热冲击、湿度抵抗力、低温存储和高温存储等测试方法和要求。
推荐焊接技术: - 提供了回流焊接和烙铁焊接的详细参数,包括预热条件、峰值温度、焊接时间等。
包装信息: - 包括胶带包装尺寸、卷轴尺寸、包装数量、卷轴标签、内盒和纸箱尺寸等信息。
FXC1360-121M 价格&库存
很抱歉,暂时无法提供与“FXC1360-121M”相匹配的价格&库存,您可以联系我们找货
