PESD5V0L2UMB,315
PESD5V0L2UMB,315
    NEXPERIA(安世)
    DFN1006B-3
    ESD VRWM=5 V VBR(Min)=6.46 V VC=15 V IPP=2.5 A DFN1006B-3
PESD5V0L2UMB,315 数据手册
PESD5V0L2UMB Low capacitance unidirectional double ESD protection array Rev. 1 — 21 February 2012 Product data sheet 1. Product profile 1.1 General description Low capacitance unidirectional double ElectroStatic Discharge (ESD) protection array designed to protect up to two signal lines from the damage caused by ESD and other transients. The device is housed in a leadless ultra small SOT883B Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits     ESD protection of up to two lines Low diode capacitance Cd = 16 pF Low clamping voltage VCL = 10 V Ultra low leakage current IRM = 5 nA     ESD protection up to 15 kV IEC 61000-4-2; level 4 (ESD) IEC 61000-4-5 (surge); IPPM = 2.5 A AEC-Q101 qualified 1.3 Applications  Computers and peripherals  Audio and video equipment  Cellular handsets and accessories  Portable electronics  SIM card protection  Communication systems 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 5 V - 16 19 pF Per diode VRWM reverse standoff voltage Cd diode capacitance f = 1 MHz; VR = 0 V PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 cathode 1 3 common anode 2 Simplified outline Graphic symbol 3 3 Transparent top view 1 2 006aac923 3. Ordering information Table 3. Ordering information Type number Package PESD5V0L2UMB Name Description Version - leadless ultra small plastic package; 3 solder lands; body 1.0  0.6  0.37 mm SOT883B 4. Marking Table 4. Marking codes Type number Marking code[1] PESD5V0L2UMB 0001 1011 [1] For SOT883B binary marking code description, see Figure 1. 4.1 Binary marking code description PIN 1 INDICATION READING DIRECTION READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac673 Fig 1. PESD5V0L2UMB Product data sheet SOT883B binary marking code description All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 2 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions rated peak pulse current tp = 8/20 s Min Max Unit - 2.5 A Per diode IPPM [1][2] Per device Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] Device stressed with ten non-repetitive current pulses (8/20 s exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321). [2] Measured from pin 1 or 2 to 3. Table 6. ESD maximum ratings Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions electrostatic discharge voltage IEC 61000-4-2 (contact discharge) Min Max Unit [1][2] - 15 kV [2] - 400 V - 10 kV Per diode VESD machine model MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 or 2 to 3. Table 7. ESD standards compliance Standard Conditions Per diode PESD5V0L2UMB Product data sheet IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3B (human body model) > 8 kV All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 3 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 μs IPP (%) 80 e−t 50 % IPP; 20 μs 40 10 % 0 10 20 30 30 ns 40 t (μs) Fig 2. t tr = 0.7 ns to 1 ns 0 60 ns 8/20 s pulse waveform according to IEC 61000-4-5 and IEC 61643-321 Fig 3. ESD pulse waveform according to IEC 61000-4-2 6. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - - 5 V Per diode VRWM reverse standoff voltage IRM reverse leakage current VRWM = 5 V - 5 25 nA VBR breakdown voltage IR = 1 mA 6.46 6.80 7.14 V Cd diode capacitance f = 1 MHz; VR = 0 V - 16 19 pF f = 1 MHz; VR = 5 V VCL clamping voltage IPP = 1 A IPPM = 2.5 A rdyn PESD5V0L2UMB Product data sheet dynamic resistance IR = 10 A - 8 11 pF [1][2] - - 10 V [1][3] - - 11 V [1][2] - - 13 V [1][3] - - 15 V [4] - 0.9 -  [1] Device stressed with 8/20 s exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321. [2] Measured from pin 1 or 2 to 3. [3] Measured from pin 1 to 2. [4] Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANS/IESD STM5-1-2008. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 4 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array I 006aac924 16 Cd (pF) 12 −VCL −VBR −VRWM V −IRM −IR 8 − 4 + P-N −IPP 0 0 1 2 3 4 5 −IPPM VR (V) 006aab324 f = 1 MHz; Tamb = 25 C Fig 4. Diode capacitance as a function of reverse voltage; typical values PESD5V0L2UMB Product data sheet Fig 5. V-I characteristics for a unidirectional ESD protection diode All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 5 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array ESD TESTER Rd 450 Ω RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10x ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 network Cs = 150 pF; Rd = 330 Ω vertical scale = 20 V/div horizontal scale = 10 ns/div vertical scale = 2 kV/div horizontal scale = 10 ns/div GND GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) vertical scale = 20 V/div horizontal scale = 10 ns/div vertical scale = 2 kV/div horizontal scale = 10 ns/div GND GND unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig 6. clamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) 006aac926 ESD clamping test setup and waveforms PESD5V0L2UMB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 6 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 7. Application information The device is designed for the protection of up to two unidirectional data or signal lines from the damage caused by ESD and surge pulses. The device may be used on lines where the signal polarities are either positive or negative with respect to ground. line 1 to be protected line 1 to be protected line 2 to be protected PESDxL2UMB PESDxL2UMB ground ground unidirectional protection of two lines bidirectional protection of one line 006aac925 Fig 7. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the device as close to the input terminal or connector as possible. 2. Minimize the path length between the device and the protected line. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Use ground planes whenever possible. For multilayer PCBs, use ground vias. 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PESD5V0L2UMB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 7 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 9. Package outline 0.65 0.55 0.40 0.34 0.35 0.20 0.12 1 0.04 max 2 0.30 0.22 1.05 0.65 0.95 0.30 0.22 3 0.55 0.47 Dimensions in mm Fig 8. 11-11-02 Package outline SOT883B 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 10000 PESD5V0L2UMB [1] PESD5V0L2UMB Product data sheet SOT883B 2 mm pitch, 8 mm tape and reel -315 For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 8 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 11. Soldering Footprint information for reflow soldering SOT883B 1.3 0.7 R0.05 (8x) 0.9 0.6 0.7 0.25 (2x) 0.3 (2x) 0.3 0.4 (2x) 0.4 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sot883b_fr Reflow soldering is the only recommended soldering method. Fig 9. Reflow soldering footprint SOT883B PESD5V0L2UMB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 9 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PESD5V0L2UMB v.1 20120221 Product data sheet - - PESD5V0L2UMB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 10 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PESD5V0L2UMB Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 11 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PESD5V0L2UMB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 February 2012 © Nexperia B.V. 2017. All rights reserved 12 of 13 PESD5V0L2UMB Nexperia Low capacitance unidirectional double ESD protection array 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 4.1 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Binary marking code description. . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 7 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Quality information . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Packing information . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 February 2012
PESD5V0L2UMB,315 价格&库存
很抱歉,暂时无法提供与“PESD5V0L2UMB,315”相匹配的价格&库存,您可以联系我们找货
