PESD5V0U5BF,115
PESD5V0U5BF,115
    NEXPERIA(安世)
    SOT886
    ESD VRWM=5 V VBR(Min)=5.5 V SOT886
PESD5V0U5BF,115 数据手册
PESD5V0U5BF Ultra low capacitance bidirectional fivefold ESD protection array 28 December 2022 Product data sheet 1. General description Ultra low capacitance bidirectional fivefold ElectroStatic Discharge (ESD) protection array in a leadless ultra small XSON6 (SOT886) Surface-Mounted Device (SMD) plastic package, designed to protect up to five signal lines from the damage caused by ESD and other transients. 2. Features and benefits • • • • • • Bidirectional ESD protection of up to five lines ESD protection up to 10 kV Ultra low diode capacitance: Cd = 2.9 pF IEC 61000-4-2; level 4 (ESD) Ultra low leakage current: IRM = 5 nA AEC-Q101 qualified 3. Applications • • • • • Computers and peripherals Portable electronics Audio and video equipment Cellular handsets and accessories Communication systems 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 5 V Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 2.9 3.5 pF [1] Measured from pin 1, 3, 4, 5 or 6 to pin 2. [1] PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K1 cathode (diode 1) 2 CC common cathode 3 K2 cathode (diode 2) 4 K3 cathode (diode 3) 5 K4 cathode (diode 4) 6 K5 cathode (diode 5) Simplified outline 6 1 5 Graphic symbol 4 2 3 Transparent top view 1 6 2 5 3 4 006aab346 XSON6 (SOT886) 6. Ordering information Table 3. Ordering information Type number Package PESD5V0U5BF Name Description Version XSON6 plastic, leadless extremely thin small outline package; 6 terminals; 0.5 mm pitch; 1 mm x 1.45 mm x 0.5 mm body SOT886 7. Marking Table 4. Marking codes Type number Marking code PESD5V0U5BF B2 PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 2 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Tj Conditions Min Max Unit junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C ESD maximum ratings VESD [1] [2] electrostatic discharge voltage IEC 61000-4-2; contact discharge [1] [2] - 10 kV MIL-STD-883; human body model (HBM) [1] [2] - 8 V Device stressed with ten non-repetitive ESD pulses. Measured from pin 1, 3, 4, 5 or 6 to pin 2. IPP 100 % 90 % 10 % t tr = 0.6 ns to 1 ns 30 ns 60 ns Fig. 1. 001aaa631 ESD pulse waveform according to IEC 61000-4-2 PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 3 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 5 V VBR breakdown voltage IR = 5 mA; Tamb = 25 °C [1] 5.5 6.5 9.5 V IRM reverse leakage current VRWM = 5 V; Tamb = 25 °C [1] - 5 100 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C [1] - 2.9 3.5 pF f = 1 MHz; VR = 5 V; Tamb = 25 °C [1] - 1.9 - pF IR = 1 mA; Tamb = 25 °C [1] - - 100 Ω Rdiff [1] differential resistance Measured from pin 1, 3, 4, 5 or 6 to pin 2. 006aab036 3.0 IPP Cd (pF) 2.6 -VCL -VBR -VRWM IR IRM -IRM -IR VRWM VBR VCL 2.2 - 1.8 0 1 2 3 4 VR (V) -IPP 5 006aaa676 Fig. 3. f = 1 MHz; Tamb = 25 °C Fig. 2. Diode capacitance as a function of reverse voltage; typical values PESD5V0U5BF Product data sheet + V-I characteristics for a bidirectional ESD protection diode All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 4 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed. 2 network Cs = 150 pF; Rd = 330 Ω vertical scale = 10 V/div horizontal scale = 15 ns/div vertical scale = 10 V/div horizontal scale = 100 ns/div GND GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) vertical scale = 10 V/div horizontal scale = 15 ns/div GND GND vertical scale = 10 V/div horizontal scale = 100 ns/div unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig. 4. clamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) 006aab037 ESD clamping test setup and waveforms PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 5 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 10. Application information The device is designed for the protection of up to five bidirectional data or signal lines from the damage caused by ESD and surge pulses. The device may be used on lines where the signal polarities are both, positive and negative with respect to ground. data- or transmission lines 1 6 2 5 3 4 ESD protection device aaa-035939 Fig. 5. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. 2. 3. 4. 5. 6. 7. 8. Place the device as close to the input terminal or connector as possible. The path length between the device and the protected line should be minimized. Keep parallel signal paths to a minimum. Avoid running protected conductors in parallel with unprotected conductors. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. Minimize the length of the transient return path to ground. Avoid using shared transient return paths to a common ground point. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 6 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 12. Package outline SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 Fig. 6. sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Package outline XSON6 (SOT886) PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 7 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 13. Soldering Footprint information for reflow soldering of XSON6 package SOT886 1.30 0.50 (6x) 0.40 (6x) 0.35 (6x) 0.40 0.30 0.25 (6x) (6x) (6x) 0.50 1.30 1.70 0.20 0.10 0.10 0.20 0.60 1.00 recommended stencil thickness: 0.1 mm occupied area solder resist solder lands solder paste Dimensions in mm Issue date Fig. 7. 22-05-11 sot886_fr Reflow soldering footprint for XSON6 (SOT886) PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 8 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array 14. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PESD5V0U5BF v.2 20221228 Product data sheet - PESD5V0U5BF_PESD 5V0U5BV_1 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia Legal texts have been adapted to the new company name where appropriate Family data sheet reduced to single type data sheet PESD5V0U5BF_PESD 20080815 5V0U5BV_1 PESD5V0U5BF Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. 28 December 2022 - © Nexperia B.V. 2022. All rights reserved 9 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 10 / 11 PESD5V0U5BF Nexperia Ultra low capacitance bidirectional fivefold ESD protection array Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Characteristics.............................................................. 4 10. Application information............................................. 6 11. Test information.......................................................... 6 12. Package outline.......................................................... 7 13. Soldering..................................................................... 8 14. Revision history..........................................................9 15. Legal information......................................................10 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 December 2022 PESD5V0U5BF Product data sheet All information provided in this document is subject to legal disclaimers. 28 December 2022 © Nexperia B.V. 2022. All rights reserved 11 / 11
PESD5V0U5BF,115 价格&库存
很抱歉,暂时无法提供与“PESD5V0U5BF,115”相匹配的价格&库存,您可以联系我们找货
PESD5V0U5BF,115
  • 5000+1.276675000+0.16516
  • 10000+1.1718410000+0.15160
  • 15000+1.1184315000+0.14469
  • 25000+1.0584125000+0.13692
  • 35000+1.0228835000+0.13233
  • 50000+0.9883350000+0.12786
PESD5V0U5BF,115
  • 1+6.014581+0.77808
  • 10+3.6997110+0.47862
  • 100+2.36388100+0.30581
  • 500+1.78849500+0.23137
  • 1000+1.602721000+0.20734
  • 2000+1.446202000+0.18709
