FH471M050I200A
FH471M050I200A
    CAPXON(台湾丰宾)
    插件,D13xL20mm
    直插铝电解电容 插件,D13xL20mm 470µF ±20% Ф13.00 x 20.00mm 50V 45mΩ 1.74A 10000Hrs@105℃
FH471M050I200A 数据手册
Updated Series Preliminary Data FH series )+6HULHVႏKLJKULSSOHFXUUHQWDWIUHTXHQF\UDQJH Feature ƹNew innovative electrolyte is employed to minimize ESR ƹLong life 4000 to 10000 hours at 105ć ƹNon solvent proof type ƹ6.3 to 100VDC newly type ƹRoHS compliance. Specificatio Item Operating Temperature Rated Voltage Range capacitance range Capacitance Tolerance Performance Characteristics -40 to +105ć 6.3~100V.DC 6.8~18000uF ±20% (120Hz, +20ć) Leakage Current (+20ć,max.) Ḭ0.01CV or 3μA whichever is greater, with rated working voltage applied(After 2 minutes). I= Leakage Current(μA) C= Rated Capacitance V= Rated voltage(V) working voltage(VDC) D.F.(%)max Dissipation Factor (tanδˈat 20ćˈ120Hz) 6.3 22 10 19 16 16 25 14 35 12 50 10 63 9 100 8 25 2 3 35 2 3 50 2 3 63 2 3 100 2 3 For capacitance ˚1000μF,add 2% per another 1000μF Low Temperature Characteristics (at 120Hz) Impedance ratio max Working Voltage(VDC) Z-25ćˋZ+20ć Z-40ćˋZ+20ć 6.3 4 8 Test conditions Duration time: size voltage Endurance 6.3~10WV 16~100WV 10 3 6 16 2 4 ΦD=8,10 6000hrs 7000hrs φD̰6.3 4000hrs 5000hrs φDı13 8000hrs 10000hrs Ambient temperature :+105ć Applied voltage :Rated DC working voltage After test requirement at +20ć Capacitance change : within±25% of the initial measured value Dissipation factor :̰ 200% of the initial specified value Leakage current :̰ The initial specified value Test conditions Duration time :1000Hrs Ambient temperature :+105ć Applied voltage :None After test requirement at +20ć:Same limits as Endurance. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. Shelf Life Multiplier for Ripple Current vs. CAP(μ CAP̰10 10˘CAP̰100 100˘CAP̰1000 1000˘CAP 50(60) 0.47 0.52 0.58 0.63 120 0.59 0.62 0.72 0.78 400 0.76 0.80 0.84 0.87 1K 0.85 0.89 0.90 0.91 10K 0.97 0.97 0.98 0.98 100K 1.00 1.00 1.00 1.00 Diagram of Dimensions:(unit:mm) Dφ F P.E.T.Sleeve dφ α LƲα 5 2 0.5 Dζ18 1.5 167 8 3.5 6.3 2.5 L˘20 Lı20 0.5 0.6 D=18 Lζ35.5 Ḻ35.5 1.5 2.0 10 13 5.0 16 18 7.5 0.6 0.8 Dη18 2.0 FH series Case Size WV (Vdc) Cap (uF) Size mm 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 16 150 220 330 470 680 820 1000 1200 1200 1500 1800 2200 2700 3300 3900 3900 4700 5600 5600 6800 6800 6800 8200 10000 10000 12000 12000 15000 18000 100 220 330 470 680 680 820 1000 1000 1200 1500 1500 2200 2200 2200 2700 3300 3900 3900 4700 5600 5600 5600 6800 6800 8200 8200 10000 10000 12000 56 5×11 6.3×11 6.3×11 8×11.5 8×11.5 10×12.5 8×16 8×20 10×16 10×20 13×16 10×25 16×16 13×20 13×25 18×16 13×30 13×35 16×21 13×40 16×25 18×21 16×31.5 16×35.5 18×25 16×41 18×31.5 18×35.5 18×41 5×11 6.3×11 6.3×11 8×11.5 8×16 10×12.5 10×16 8×20 10×16 10×20 10×25 13×16 10×30 13×20 16×16 18×16 13×25 13×30 16×21 13×35 13×40 16×25 18×21 16×31.5 18×25 16×35.5 18×31.5 16×41 18×35.5 18×41 5×11 Rated Ripple Max ESR( Ω) current at 20ć (Arms/105ć /100kHz /100KHz) 220 300 350 440 650 870 850 1060 1220 1410 1460 1660 1950 1910 2240 2220 2660 2890 2540 3360 2940 2870 3460 3620 3150 4090 4180 4230 4290 220 350 450 650 850 870 950 1060 1220 1410 1560 1460 1920 1910 1950 2220 2240 2660 2540 2890 3360 2940 2870 3460 3150 3620 4180 4090 4230 4290 220 0.550 0.260 0.210 0.140 0.130 0.090 0.080 0.075 0.064 0.050 0.049 0.046 0.042 0.038 0.029 0.040 0.027 0.024 0.027 0.017 0.021 0.026 0.017 0.015 0.019 0.013 0.015 0.014 0.012 0.580 0.230 0.220 0.130 0.096 0.085 0.075 0.072 0.064 0.045 0.043 0.049 0.030 0.035 0.042 0.043 0.029 0.025 0.027 0.020 0.017 0.021 0.026 0.017 0.019 0.015 0.015 0.013 0.014 0.012 0.560 168 WV (Vdc) Cap (uF) Size mm 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 100 120 220 330 470 470 470 680 680 820 1000 1000 1200 1500 1500 1500 1500 1800 1800 2200 2200 2700 2700 3300 3900 3900 3900 4700 4700 5600 5600 6800 8200 10000 47 56 100 220 330 330 470 470 470 680 680 820 1000 1000 1000 1200 1500 1800 1800 2200 2200 2200 2700 2700 3300 3300 6.3×11 6.3×11 8×11.5 8×11.5 8×11.5 8×16 10×12.5 8×20 10×16 10×20 10×20 13×16 10×25 10×25 10×30 13×20 16×16 10×25 13×25 13×25 18×16 13×30 16×21 13×35 13×40 16×25 18×21 16×31.5 18×25 16×35.5 18×31.5 16×41 18×35.5 18×41 5×11 5×11 6.3×11 8×11.5 8×16 10×12.5 8×20 10×12.5 10×16 10×20 13×16 10×25 10×30 13×20 16×16 18×16 13×25 13×30 16×21 13×30 13×35 18×21 13×40 16×25 16×31.5 18×25 Rated Ripple Max ESR( Ω) current at 20ć (Arms/105ć /100kHz /100KHz) 300 350 500 650 740 850 870 1060 1220 1300 1410 1460 1660 1770 1920 1910 1950 1800 2080 2240 2220 2660 2540 2890 3360 2940 2870 3460 3150 3620 4180 4090 4230 4290 220 260 350 650 850 870 1060 1100 1220 1410 1460 1660 1920 1910 1950 2220 2240 2660 2540 2695 2890 2870 3360 2940 3460 3150 0.220 0.215 0.180 0.140 0.100 0.095 0.085 0.080 0.060 0.052 0.046 0.050 0.044 0.036 0.031 0.037 0.042 0.036 0.030 0.026 0.043 0.023 0.027 0.022 0.017 0.021 0.026 0.017 0.020 0.015 0.015 0.013 0.014 0.012 0.560 0.560 0.250 0.150 0.092 0.082 0.074 0.074 0.068 0.050 0.049 0.041 0.032 0.036 0.042 0.043 0.028 0.024 0.027 0.025 0.023 0.026 0.017 0.022 0.017 0.019 FH series Case Size WV (Vdc) Cap (uF) Size mm 25 25 25 25 25 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 3900 3900 4700 4700 5600 33 47 56 100 150 220 220 220 270 330 470 470 560 680 680 680 1000 1000 1000 1200 1200 1500 1800 1800 1800 2200 2200 2200 2700 2700 3300 3300 3900 22 47 56 100 120 150 180 220 270 270 330 470 470 470 560 560 680 820 820 1000 1000 1000 16×35.5 18×31.5 16×41 18×35.5 18×41 5×11 5×11 6.3×11 6.3×11 8×11.5 8×11.5 8×16 10×12.5 8×20 10×16 10×20 13×16 10×25 10×30 13×20 16×16 13×20 13×25 18×16 13×30 16×21 13×35 13×40 16×25 18×21 16×31.5 18×21 18×25 16×35.5 18×31.5 16×41 18×35.5 18×41 5×11 6.3×11 6.3×11 8×11.5 8×16 10×12.5 8×20 10×16 10×20 13×16 10×25 10×30 13×20 16×16 13×25 18×16 13×30 13×35 16×21 13×35 13×40 16×25 Rated Ripple Max ESR( Ω) current at 20ć (Arms/105ć /100kHz /100KHz) 3620 4180 4090 4230 4290 230 300 360 480 680 870 1000 1060 1180 1380 1800 1560 1900 2000 2100 2050 2180 2400 2220 2800 2800 3000 3360 2940 2870 3460 2930 3150 3620 4180 4090 4230 4300 220 270 300 680 760 800 1000 1300 1350 1270 1600 1800 1740 1710 1960 1940 2320 2520 2220 2650 2930 2565 0.015 0.015 0.013 0.014 0.012 0.550 0.450 0.210 0.180 0.140 0.095 0.090 0.080 0.070 0.062 0.048 0.049 0.042 0.035 0.034 0.042 0.038 0.028 0.043 0.024 0.028 0.022 0.017 0.020 0.026 0.017 0.025 0.019 0.018 0.016 0.013 0.014 0.012 0.650 0.370 0.290 0.160 0.120 0.120 0.090 0.082 0.060 0.061 0.057 0.048 0.045 0.055 0.042 0.054 0.030 0.025 0.034 0.024 0.021 0.025 169 WV (Vdc) Cap (uF) Size mm 50 50 50 50 50 50 50 50 50 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 1000 1200 1200 1500 1800 1800 2200 2700 3300 15 33 47 56 82 82 100 120 120 180 180 220 220 270 270 270 330 390 470 470 560 560 680 680 820 820 1000 1000 1000 1200 1200 1200 1500 6.8 15 27 39 47 56 68 82 82 100 120 120 150 150 180 180 220 220 18×21 16×31.5 18×25 16×35.5 16×41 18×31.5 18×35.5 18×41 18×41 5×11 6.3×11 8×11.5 8×11.5 8×16 10×12.5 10×12.5 8×20 10×16 10×20 13×16 10×20 10×25 10×30 13×20 16×16 13×25 18×16 13×30 16×21 13×35 16×25 13×40 18×21 16×31.5 18×25 16×35.5 18*25 18×31.5 16×41 18×31.5 18×35.5 18×41 5×11 6.3×11 8×11.5 8×16 10×12.5 8×20 10×16 10×20 13×16 10×25 10×30 13×20 13×20 16×16 13×25 18×16 13×30 16×21 Rated Ripple Max ESR( Ω) current at 20ć (Arms/105ć /100kHz /100KHz) 2500 3020 2750 3160 3720 3645 3690 3810 3810 65 260 360 380 460 500 640 700 760 880 800 995 1100 1200 1200 1200 1600 1610 1800 1500 2000 2000 2200 1600 2400 1800 2500 2290 2800 2920 2850 3000 3200 65 130 300 340 400 410 460 600 540 800 830 900 1000 1000 1010 1180 1210 1140 0.036 0.030 0.026 0.019 0.016 0.021 0.017 0.014 0.014 1.800 1.200 0.660 0.600 0.440 0.430 0.340 0.320 0.300 0.190 0.180 0.188 0.185 0.120 0.160 0.110 0.120 0.096 0.100 0.077 0.070 0.073 0.070 0.072 0.054 0.052 0.048 0.052 0.047 0.040 0.045 0.039 0.036 1.800 1.000 0.610 0.360 0.420 0.260 0.300 0.210 0.180 0.200 0.120 0.160 0.110 0.110 0.096 0.096 0.080 0.077 FH series Case Size WV (Vdc) Cap (uF) Size mm 100 100 100 100 100 100 100 100 100 100 100 100 270 270 330 330 390 390 470 470 560 680 820 1000 13×35 16×25 13×40 18×21 16×31.5 18×25 16×35.5 18×31.5 16×41 18×35.5 18×41 18×41 Rated Ripple Max ESR( Ω) current at 20ć /100kHz (Arms/105ć /100KHz) 1450 1480 1600 1400 1700 1740 1910 1730 2140 2000 2480 2580 0.070 0.073 0.071 0.072 0.055 0.054 0.047 0.047 0.036 0.042 0.040 0.038 170
FH471M050I200A 价格&库存
很抱歉,暂时无法提供与“FH471M050I200A”相匹配的价格&库存,您可以联系我们找货
