CMLB051H-4R7MS
CMLB051H-4R7MS
    CYNTEC(乾坤)
    SMD,5.4x5.2mm
    功率电感 4.7µH ±20% IND_5.4X5.2MM_SM 1.60mm 5.40 x 5.20mm 70mΩ 3.2A
CMLB051H-4R7MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB051H-000 REVISION : A4 PAGE : 1 OF 4 Power Choke Coil CMLB051H MS type  Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 1.8mm Low loss realized with low DCR Capable of corresponding high frequency (3MHz) 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions A' L A B W B' H  T Code Dimensions (mm) L 5.40  0.35 W 5.2  0.2 T 1.6  0.2 A 1.0  0.3 A’ 1.5  0.1 B 2.0  0.3 B’ 2.5  0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.5 B 2.2 C 5.99 Unit : mm Jun., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB051H-000 REVISION : A4 PAGE : 2 OF 4 Specifications L0 Inductance ( H ) @ (0A) Typical CMLB051H-R22MS 0.22 CMLB051H-R33MS  Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 4.0 4.8 19.0 17.0 21.5 19.0 0.33  5.7  6.8  16.0  15.0  19.1  17.1  CMLB051H-R47MS  0.47  7.6  8.5  11.0  10.0  16.0  15.5  CMLB051H-R68MS 0.68 12.0 13.8 9.0 8.0 13.0 11.2 CMLB051H-1R0MS 1.0 15.0 17.0 8.5 7.5 10.0 8.6 CMLB051H-1R5MS 1.5 23.0 28.0 6.2 5.5 9.0 7.2 CMLB051H-2R2MS 2.2 30.0 35.0 5.2 4.7 7.0 6.0 CMLB051H-3R3MS 3.3 45.0 52.0 4.7 4.5 5.5 4.8 CMLB051H-4R7MS 4.7 70.0 81.0 3.5 3.2 4.5 3.9 CMLB051H-6R8MS 6.8 103.0 125.0 2.9 2.6 3.6 3.4 CMLB051H-100MS 10.0 139.0 154.0 2.5 2.3 3.3 2.8 Part Number Rdc ( m ) * : If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Jun., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司  : A4 PAGE : 3 OF 4 40 20 0.05 0 0.00 3 6 9 12 15 18 DC BIAS(Amps) 21 24 40 0.18 INDUCTANCE(μH) 0.09 TEMP. RISE (℃) 20 TEMP. RISE(℃) 60 0.27 0 2 4 1.20 6 8 10 12 14 16 DC BIAS(Amps) 18 20 22 3 6 9 12 15 18 DC BIAS(Amps) 21 24 27 CMLB051H-R68MS 0.84 100 0.70 80 0.56 60 INDUCTANCE(μH) 0.42 TEMP. RISE(℃) 40 0.28 20 0.14 0.00 0 0.00 0 0 80 0.36 20 0.07 100 0.45 40 0.00 27 CMLB051H-R47MS 0.54 TEMP RISE(℃) 0.14 INDUCTANCE(μH) 0 TEMP RISE(℃) TEMP. RISE(℃) 60 INDUCTANCE(μH) 0.21 0 0 24 2 4 6 8 10 12 14 16 18 DC BIAS(Amps) 1.80 100 CMLB051H-1R0MS 100 CMLB051H-1R5MS 1.50 1.00 80 60 INDUCTANCE(μH) 0.40 40 TEMP. RISE(℃) 20 0.20 0.00 0 2 4 6 8 10 DC BIAS(Amps) 12 14 CMLB051H-2R2MS 3.00 2.50 2.00 4.20 40 1.00 INDUCTANCE(μH) 20 TEMP. RISE (℃) 0.00 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 10 40 TEMP. RISE(℃) 20 0.30 100 60 INDUCTANCE(μH) 0.60 0.00 1.50 60 0.90 0 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 10 CMLB051H-3R3MS 100 3.50 80 0.50 1.20 16 INDUCTANCE(μH) 0.60 INDUCTANCE(μH) 0.80 TEMP. RISE(℃) 80 TEMP. RISE(℃) 0.10 80 0.28 80 2.80 60 2.10 INDUCTANCE(μH) 1.40 TEMP. RISE (℃) 40 20 0.70 0.00 TEMP. RISE(℃) INDUCTANCE(μH) 100 CMLB051H-R33MS TEMP. RISE(℃) 0.35 INDUCTANCE(μH) 80 60 0.15 INDUCTANCE(μH) 0.42 TEMP. RISE(℃) INDUCTANCE(μH) 0.20 100 TEMP. RISE(℃) CMLB051H-R22MS 0.25 INDUCTANCE(μH) REVISION Current Characteristic 0.30 INDUCTANCE(μH) DOCUMENT : CMLB051H-000 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 DC BIAS(Amps) Jun., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司 80 7.50 60 3.00 INDUCTANCE(μH) 2.00 TEMP. RISE (℃) 40 20 1.00 0.00 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 CMLB051H-100MS PAGE : 4 OF 4 CMLB051H-6R8MS 100 80 6.00 60 4.50 40 3.00 INDUCTANCE(μH) 1.50 20 TEMP. RISE (℃) 0 0 1 2 3 4 DC BIAS(Amps) 5 6 100 10.0 80 8.0 60 6.0 40 4.0 INDUCTANCE(μH) 2.0 TEMP. RISE (℃) 20 0.0 TEMP. RISE(℃) INDUCTANCE(μH) : A4 0.00 5.5 DC BIAS(Amps) 12.0 REVISION TEMP. RISE(℃) 4.00 9.00 INDUCTANCE(μH) INDUCTANCE(μH) 5.00 100 TEMP. RISE(℃) CMLB051H-4R7MS 6.00 DOCUMENT : CMLB051H-000 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 DC BIAS(Amps) Jun., 2020
CMLB051H-4R7MS 价格&库存
很抱歉,暂时无法提供与“CMLB051H-4R7MS”相匹配的价格&库存,您可以联系我们找货
