Updated Series
Preliminary Data Sheet
GH series
*+VHULHV
Features
ƹLow impedance
ƹHigh temperature,long life 5000 to 10000 hours at 105ć
ƹAEC-Q200 qualified
Specifications
Item
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Performance Characteristics
-55to +105ć
6.3 to 100 VDC
0.47 to 12000 μF
±20% (120Hz, +20ć)
Ḭ0.01CV or 3(uA)(After 2 minute with rated working voltage applied.)
Leakage Current (+20ć,max.)
Dissipation Factor
(tanδˈat 20ćˈ120Hz)
Working Voltage(VDC)
6.3 10
16
25
D.F. (%)max.
22
19
16
14
For capacitance>1000uF,add 2% per another 1000uF.
35
12
50
10
63
9
80
9
100
8
Impedance ratio max
Working Voltage
Low Temperature Characteristics
(at 120Hz)
Endurance
Shelf Life
6.3 10
16
25
35
50
63
80 100
Z-25ćˋZ+20ć
4
3
2
2
1.5 1.5 1.5 1.5 1.5
Z-40ćˋZ+20ć
6
4
3
3
2
2
2
2
2
Z-55ćˋZ+20ć
8
6
5
5
4
4
4
4
4
For capacitance>1000uF,add 0.5 per another 1000uF for -25ć/+20ć
add 1 per another 1000uF for -40ć/+20ć
add 1.5 per another 1000uF for -55ć/+20ć
Test condition
Duration time:
Dφ
5-6.3φ
8-12φ
̱13φ
5000 hours
7000 hours
10000 hours
+105ćLife hours
Ambient temperature
:+105ć
Applied voltage
:Rated DC working voltage
After test requirement at +20ć
Capacitance change
:̰±25% of the initial measured value
Dissipation factor
:̰ 200% of the initial specified value
Leakage current
:̰ The initial specified value
Test conditions
Duration time
:1000Hrs
Ambient temperature
:+105ć
Applied voltage
:None
After test requirement at +20ć:Same limits as Endurance.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
Multiplier for Ripple Current vs.
CAP(uF)ˋFrequency(Hz)
CAP̰10
10˘CAP̰100
100˘CAP̰1000
1000˘CAP
120
0.40
0.67
0.75
0.82
400
0.52
0.80
0.84
0.87
1K
0.60
0.83
0.88
0.92
10K
0.92
0.94
0.95
0.95
100K
1.00
1.00
1.00
1.00
Diagram of Dimensions:(unit:mm)
Dφ
F
dφ
α
159
5
2.0
8
3.5
6.3
2.5
0.5
D˘18
1.5
10
13 16
5.0 5.0 7.5
L˘20
0.5
Ḻ20
0.6
D=18
L˘35.5
1.5
Ḻ35.5
2.0
0.6
D˚18
2.0
18
7.5
0.8
GH series
Case Size
Rated Ripple Max ESR( Ω)
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
WV
(Vdc)
Cap
(uF)
Size
mm
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
10
10
10
10
10
10
10
10
10
10
10
10
82
100
120
150
180
220
270
330
330
330
390
390
470
470
470
560
560
560
680
680
680
820
820
1000
1000
1000
1200
1200
1500
1500
1500
1800
1800
2200
2200
2700
2700
2700
3300
3300
3900
4700
4700
5600
5600
6800
6800
22
27
33
39
47
56
68
82
100
100
120
120
5×11
5×11
5×11
6.3×11
6.3×11
6.3×11
6.3×11
6.3×11
6.3×15
8×11.5
6.3×15
8×11.5
6.3×15
8×11.5
10×12.5
8×11.5
8×16
10×12.5
8×11.5
8×16
10×12.5
8×11.5
10×12.5
8×16
8×20
10×12.5
8×20
10×16
8×20
10×16
10×20
8×25
10×20
10×20
10×25
10×25
10×30
13×20
10×30
13×20
13×25
13×25
13×30
13×30
16×25
13×30
16×25
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
6.3×11
5×11
6.3×11
198
210
222
240
282
378
396
396
426
444
462
480
504
534
564
570
600
612
582
618
642
666
720
690
756
708
840
888
1056
1128
1176
1230
1308
1350
1362
1488
1560
1512
1620
1584
1860
1938
1992
1992
2196
2520
2718
66
72
72
120
132
144
162
192
222
240
246
258
10
150
6.3×11
282
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
WV
(Vdc)
Cap
(uF)
Size
mm
1.63
1.45
1.28
1.16
1.04
0.89
0.77
0.77
0.68
0.68
0.58
0.52
0.41
0.38
0.38
0.36
0.36
0.36
0.33
0.33
0.33
0.25
0.25
0.22
0.22
0.22
0.18
0.18
0.15
0.12
0.12
0.11
0.11
0.10
0.10
0.09
0.09
0.09
0.085
0.085
0.080
0.075
0.070
0.068
0.068
0.063
0.063
3.08
2.67
2.33
2.02
1.71
1.47
1.30
1.15
1.02
1.02
1.02
1.02
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
180
220
220
270
270
330
330
330
390
390
470
470
560
560
560
680
680
680
820
820
820
820
1000
1000
1000
1000
1200
1200
1200
1500
1500
1800
1800
2200
2200
2200
2200
2700
2700
2700
2700
3300
3300
3300
3900
3900
3900
3900
4700
4700
4700
5600
5600
5600
5600
6800
6800
8200
8200
6.3×11
6.3×11
6.3×15
6.3×15
8×11.5
6.3×11
6.3×15
8×11.5
6.3×15
8×11.5
6.3×15
8×11.5
8×11.5
8×16
10×12.5
8×16
8×20
10×12.5
8×16
8×20
10×12.5
10×16
8×16
8×20
10×12.5
10×16
8×20
10×16
10×20
10×20
13×16
10×25
13×20
10×25
10×30
13×20
16×16
10×30
13×20
13×25
18×16
10×30
13×25
16×25
13×25
13×30
16×21
16×25
13×30
13×35
16×25
13×35
16×25
16×31.5
18×21
16×31.5
18×25
16×35.5
18×31.5
318
366
390
414
420
402
462
492
456
516
480
552
588
636
636
660
684
684
732
828
876
936
1020
1122
1032
1140
1248
1272
1368
1536
1620
1650
1704
1776
1860
1872
1926
2076
2028
2124
2241
2232
2268
2316
2304
2376
2362
2544
2484
2568
2634
2640
2473
2736
2460
2964
2866
3350
3392
0.68
0.60
0.58
0.56
0.53
0.50
0.47
0.45
0.42
0.42
0.37
0.30
0.28
0.25
0.25
0.21
0.20
0.20
0.20
0.18
0.16
0.16
0.16
0.14
0.14
0.13
0.13
0.13
0.12
0.106
0.110
0.102
0.098
0.095
0.093
0.093
0.093
0.084
0.084
0.084
0.084
0.070
0.070
0.070
0.065
0.065
0.070
0.065
0.065
0.060
0.057
0.054
0.054
0.050
0.057
0.046
0.052
0.043
0.044
0.95
10
10000
16×41
3850
0.040
160
GH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
10
10
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
10000
12000
10
15
22
27
33
39
47
56
68
82
100
100
120
150
150
180
180
220
220
270
270
330
330
330
390
390
390
470
470
470
560
560
560
560
680
680
820
820
820
1000
1000
1200
1200
1500
1500
1500
1800
1800
1800
2200
2200
2200
2700
2700
2700
2700
3300
3300
18×35.5
18×41
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
6.3×11
5×11
6.3×11
6.3×11
6.3×11
6.3×15
6.3×15
8×11.5
6.3×15
8×11.5
6.3×15
8×11.5
6.3×15
8×11.5
8×16
8×11.5
8×16
10×12.5
8×16
8×20
10×12.5
8×16
8×20
10×12.5
10×16
8×20
10×16
8×20
10×16
10×20
10×16
10×20
10×20
10×25
10×25
13×20
16×16
10×30
13×20
13×25
13×20
13×25
18×16
13×25
13×30
16×21
16×25
13×30
13×35
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
3850
4150
36
72
72
132
144
168
186
210
228
264
228
264
312
336
396
420
426
504
540
540
582
588
588
618
612
654
648
846
900
882
864
936
882
960
960
1044
1104
1254
1320
1404
1476
1500
1578
1620
1728
1778
1776
1854
1956
2082
2340
2300
2436
2496
2362
2544
2562
2628
0.041
0.037
3.90
3.32
2.64
2.37
2.00
1.61
1.35
1.24
1.18
1.03
1.10
0.86
0.66
0.58
0.58
0.56
0.54
0.52
0.46
0.42
0.38
0.34
0.37
0.35
0.33
0.33
0.33
0.29
0.28
0.28
0.26
0.24
0.24
0.20
0.20
0.18
0.17
0.15
0.15
0.14
0.12
0.13
0.11
0.096
0.095
0.095
0.097
0.094
0.090
0.090
0.085
0.090
0.076
0.072
0.074
0.072
0.068
0.066
161
WV
(Vdc)
Cap
(uF)
Size
mm
16
16
16
16
16
16
16
16
16
16
16
16
16
16
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
3300
3900
3900
3900
3900
4700
4700
5600
5600
5600
6800
6800
8200
10000
10
15
22
27
33
39
47
47
56
68
82
100
100
120
120
150
150
180
180
220
220
270
270
270
330
330
470
470
470
560
560
680
680
820
820
1000
1000
1000
1200
1200
1500
1500
1800
1800
1800
2200
16×25
13×35
16×25
16×31.5
18×21
16×31.5
18×25
16×35.5
18×31.5
18×35.5
16×41
18×35.5
18×35.5
18×41
5×11
5×11
5×11
5×11
5×11
5×11
5×11
6.3×11
5×11
6.3×11
6.3×11
6.3×11
8×11.5
6.3×11
6.3×15
6.3×15
8×11.5
6.3×15
8×11.5
8×11.5
8×16
8×11.5
8×16
10×12.5
8×16
10×12.5
8×20
10×12.5
10×16
8×20
10×16
10×20
13×16
10×20
10×25
10×25
13×20
16×16
13×20
18×16
13×20
13×25
13×30
16×21
16×25
13×30
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
2700
2664
2736
2856
2721
2886
2844
2968
3084
3168
3252
3252
3750
4150
66
120
144
156
174
174
222
240
264
300
312
360
516
402
462
510
528
546
552
618
642
750
756
816
960
924
1056
1020
1080
1224
1260
1470
1550
1668
1704
1812
1872
1926
2028
2241
2124
2190
2310
2173
2340
2592
0.064
0.050
0.060
0.058
0.060
0.050
0.055
0.046
0.048
0.045
0.040
0.040
0.038
0.036
3.01
2.64
2.30
2.03
1.72
1.50
1.37
1.28
1.25
0.97
0.79
0.68
0.54
0.58
0.56
0.54
0.52
0.51
0.46
0.42
0.40
0.34
0.32
0.32
0.25
0.24
0.23
0.21
0.21
0.17
0.15
0.11
0.10
0.11
0.10
0.093
0.090
0.088
0.082
0.080
0.067
0.065
0.058
0.056
0.058
0.052
GH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
25
25
25
25
25
25
25
25
25
25
25
25
25
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
2200
2200
2700
2700
2700
3300
3300
3300
3900
3900
4700
4700
5600
10
15
22
27
27
33
33
39
47
47
56
56
68
68
82
82
100
100
100
120
120
150
150
150
180
180
220
220
220
270
270
270
330
330
470
470
470
470
560
560
680
680
680
820
820
1000
1000
16×25
18×21
13×35
16×25
16×31.5
16×31.5
16×35.5
18×25
16×35.5
18×31.5
16×41
18×35.5
18×41
5×11
5×11
5×11
5×11
6.3×11
5×11
6.3×11
6.3×11
5×11
6.3×11
6.3×11
6.3×15
6.3×11
6.3×15
6.3×15
8×11.5
6.3×11
6.3×15
8×11.5
8×11.5
8×16
8×11.5
8×16
10×12.5
8×16
10×12.5
8×16
8×20
10×12.5
8×20
10×12.5
10×16
8×20
10×16
10×20
10×25
13×16
13×20
10×25
13×20
10×25
13×20
16×16
13×20
13×25
10×30
13×25
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
2712
2697
2850
2674
2958
3204
3288
3156
3500
3544
3800
3800
4100
84
144
162
174
198
222
240
252
232
264
282
306
312
348
354
384
329
378
414
546
612
618
714
720
792
804
864
936
888
1056
984
1068
1140
1176
1302
1398
1272
1398
1572
1584
1680
1692
1741
1818
1944
2136
2184
0.050
0.052
0.050
0.048
0.046
0.038
0.036
0.041
0.036
0.036
0.034
0.034
0.030
2.65
2.29
1.90
1.58
1.42
1.25
1.25
1.10
0.10
0.92
0.75
0.68
0.62
0.55
0.51
0.47
0.49
0.47
0.45
0.42
0.38
0.38
0.35
0.35
0.32
0.32
0.26
0.24
0.24
0.22
0.24
0.21
0.16
0.15
0.11
0.10
0.11
0.10
0.096
0.096
0.084
0.082
0.080
0.068
0.062
0.060
0.060
162
WV
(Vdc)
Cap
(uF)
Size
mm
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
1000
1000
1200
1200
1200
1500
1500
1800
1800
1800
1800
2200
2200
2700
2700
3300
3300
3900
0.47
1
2.2
3.3
4.7
5.6
6.8
8.2
10
15
22
22
27
33
33
39
39
47
47
47
56
56
68
82
82
82
100
100
120
150
150
150
150
180
180
220
220
270
270
270
330
330
13×30
18×16
13×25
16×21
16×25
13×35
16×31.5
13×35
16×25
16×31.5
18×21
16×31.5
18×25
16×35.5
18×31.5
16×41
18×35.5
18×41
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
5×11
6.3×11
6.3×11
6.3×11
6.3×15
6.3×11
6.3×15
6.3×11
6.3×15
8×11.5
6.3×11
8×11.5
8×11.5
6.3×15
8×11.5
8×16
8×11.5
8×16
8×16
8×16
8×20
10×12.5
10×16
8×20
10×16
10×16
10×20
10×20
10×25
13×16
10×25
13×20
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
2280
2189
2292
2384
2568
2820
2928
2976
2722
3012
2708
3228
3132
3295
3336
3800
3800
4100
12
24
36
48
66
96
96
108
120
150
162
168
192
282
296
306
330
303
348
366
324
378
420
462
492
528
540
576
630
696
756
702
780
864
912
1056
1122
1212
1284
1278
1404
1500
0.058
0.056
0.052
0.052
0.050
0.048
0.048
0.045
0.048
0.045
0.048
0.036
0.036
0.032
0.032
0.029
0.029
0.026
7.23
4.31
3.60
3.50
3.30
3.20
3.00
2.80
2.60
1.87
1.60
1.27
1.02
0.87
0.85
0.72
0.70
0.06
0.55
0.55
0.05
0.47
0.36
0.35
0.32
0.28
0.28
0.25
0.25
0.24
0.24
0.25
0.24
0.24
0.24
0.24
0.20
0.10
0.10
0.10
0.095
0.082
GH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
470
470
470
470
560
560
560
680
680
820
820
820
1000
1000
1000
1000
1200
1200
1200
1500
1800
1800
2200
2700
3300
10
15
22
22
27
33
39
47
47
56
68
68
82
82
82
100
100
120
120
120
120
150
150
180
180
180
220
220
220
220
270
270
330
330
330
10×30
13×20
13×25
16×16
13×20
13×25
18×16
13×25
16×25
13×30
16×21
16×31.5
13×40
16×25
16×31.5
18×21
16×31.5
16×35.5
18×25
16×35.5
16×41
18×31.5
18×35.5
18×41
18×41
5×11
5×11
5×11
6.3×11
6.3×11
6.3×11
6.3×11
6.3×11
8×11.5
8×11.5
8×11.5
8×16
8×11.5
8×16
10×12.5
8×16
10×12.5
8×16
8×20
10×12.5
10×16
8×20
10×16
8×25
10×16
10×20
8×25
10×16
10×20
13×16
10×20
13×20
10×25
13×16
13×20
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
1750
1776
1860
1827
2094
2172
2314
2304
2376
2412
2085
2484
2750
2676
2736
2662
2952
3048
2854
3216
3550
3368
3550
3790
3810
116
131
151
194
202
228
243
264
313
320
378
477
390
477
481
515
515
512
604
528
639
604
666
742
662
757
789
730
892
911
986
1241
1242
1086
1282
WV
(Vdc)
Cap
(uF)
Size
mm
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
80
330
390
470
470
470
470
560
560
560
680
680
680
820
820
820
1000
1000
1000
1200
1200
1500
1500
1800
1800
2200
10
15
22
27
33
39
47
56
56
68
68
82
82
100
100
100
120
150
150
180
180
180
220
220
270
270
330
330
390
470
470
470
470
560
560
13×25
13×25
13×20
13×25
13×30
16×21
13×25
13×30
16×21
13×30
13×35
16×21
13×40
16×25
18×21
13×45
16×31.5
18×25
16×31.5
18×25
18×31.5
18×35.5
16×41
18×35.5
18×41
5×11
5×11
6.3×11
6.3×11
6.3×11
8×11.5
8×11.5
8×11.5
8×16
8×16
10×12.5
8×16
10×12.5
8×20
10×16
13×16
10×16
10×20
13×16
10×20
10×25
13×16
10×25
13×20
13×20
13×25
13×20
16×21
13×30
13×30
13×35
16×25
18×21
13×40
16×25
0.078
0.078
0.078
0.078
0.075
0.070
0.073
0.057
0.057
0.052
0.054
0.052
0.048
0.050
0.048
0.050
0.045
0.042
0.047
0.038
0.035
0.035
0.032
0.030
0.028
3.02
2.37
1.77
1.39
1.29
1.01
0.89
0.75
0.73
0.70
0.50
0.42
0.47
0.42
0.43
0.36
0.38
0.36
0.32
0.36
0.30
0.32
0.28
0.26
0.28
0.26
0.23
0.23
0.20
0.20
0.16
0.13
0.13
0.15
0.13
163
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
1611
1618
1516
1698
1863
1857
1727
1942
1857
2082
2273
1835
2454
2229
2108
2653
2690
2307
2727
2470
2997
3256
3760
3481
3938
100
113
167
174
196
244
265
275
326
380
388
389
388
509
522
634
534
657
665
677
755
721
767
830
890
1019
1060
1253
1427
1533
1711
1432
1471
1685
1479
0.100
0.093
0.093
0.090
0.088
0.082
0.087
0.081
0.082
0.071
0.068
0.084
0.066
0.066
0.073
0.063
0.056
0.071
0.054
0.062
0.051
0.048
0.036
0.042
0.035
4.07
3.20
1.88
1.74
1.37
1.20
1.02
0.95
0.90
0.66
0.66
0.63
0.66
0.45
0.45
0.44
0.43
0.35
0.40
0.33
0.32
0.34
0.31
0.31
0.27
0.25
0.19
0.18
0.15
0.13
0.12
0.16
0.15
0.14
0.15
GH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
80
80
80
80
80
80
80
80
80
80
80
80
80
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
560
680
680
820
820
1000
1000
1000
1200
1200
1500
1500
1800
4.7
5.6
6.8
8.2
10
10
15
22
22
27
33
39
47
47
47
56
56
56
68
68
82
82
100
100
100
100
100
120
120
120
120
150
150
150
180
180
220
220
220
220
270
270
270
330
330
330
390
18×21
16×31.5
18×25
16×35.5
18×25
16×35.5
16×41
18×31.5
16×41
18×35.5
16×41
18×41
18×41
5×11
5×11
5×11
5×11
6.3×11
8×11.5
6.3×11
6.3×11
8×11.5
8×11.5
8×11.5
8×16
8×16
10×12.5
10×16
8×16
8×20
10×12.5
8×20
10×16
8×20
10×16
8×30
10×16
10×20
13×16
13×20
8×35
10×20
10×25
13×16
10×25
10×30
13×20
13×20
13×25
13×20
13×25
16×16
16×21
10×40
13×30
16×25
13×30
13×35
16×25
13×40
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
1471
1757
1582
1929
1699
1929
2151
2041
2378
2315
2461
2641
2657
84
90
96
105
141
180
151
168
228
234
240
282
335
350
357
354
414
364
424
425
474
486
636
522
596
641
750
738
611
702
665
743
834
805
858
963
890
1019
915
1063
1107
1236
1281
1382
1584
1531
1748
0.15
0.13
0.15
0.12
0.13
0.12
0.11
0.11
0.09
0.095
0.084
0.083
0.082
5.75
5.00
4.36
3.68
2.63
2.20
2.31
1.85
1.38
1.31
1.24
1.20
0.85
0.81
0.78
0.76
0.68
0.75
0.65
0.68
0.52
0.52
0.42
0.45
0.42
0.43
0.38
0.36
0.40
0.37
0.40
0.33
0.31
0.33
0.29
0.28
0.27
0.25
0.27
0.25
0.23
0.20
0.20
0.16
0.14
0.14
0.13
164
WV
(Vdc)
Cap
(uF)
Size
mm
100
100
100
100
100
100
100
100
100
100
100
390
470
470
470
560
560
680
680
820
820
1000
18×25
16×25
16×31.5
18×25
16×35.5
18×31.5
16×35.5
18×35.5
18×35.5
18×41
18×41
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
1582
1479
1910
1637
1854
1877
1929
2151
2202
2406
2469
0.15
0.15
0.11
0.14
0.13
0.13
0.12
0.11
0.105
0.100
0.095
很抱歉,暂时无法提供与“GH100M050C110A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37590
- 100+0.22420
- 500+0.15700
- 1000+0.11210
- 2000+0.10650
- 10000+0.09870
