CMLB063T-R68MS
CMLB063T-R68MS
    CYNTEC(乾坤)
    SMD,6.95x6.6mm
    功率电感 680nH ±20% IND_6.95X6.6MM_SM 2.80mm 6.95 x 6.60mm 4.75mΩ 14.5A
CMLB063T-R68MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB063T-000 REVISION : A4 PAGE : 1 OF 5 Power Choke Coil CMLB063T type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 3.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' A B W B' H  Code Dimensions (mm) L 6.95 ± 0.35 W 6.6 ± 0.2 T 2.8 ± 0.2 A 1.6 ± 0.3 A’ 2.0 ± 0.1 B 3.0 ± 0.3 B’ 3.6 ± 0.2 H 0 ~ +0.15 T Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A A 3.5 B 3.7 C 8.4 C Unit : mm Jun., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB063T-000 REVISION : A4 PAGE : 2 OF 5 Specifications L0 Inductance ( µH ) @ (0A) Typical CMLB063T-R10MS 0.10 CMLB063T-R15MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 0.81 0.99 40.0 35.0 60.2 48.0 0.15 1.8 2.4 30.0 25.0 41.0 35.0 CMLB063T-R20MS 0.20 2.2 3.0 26.0 22.0 38.0 33.0 CMLB063T-R22MS 0.22 2.3 3.0 25.0 21.0 35.0 32.0 CMLB063T-R33MS 0.33 2.7 3.3 22.0 20.0 26.0 22.0 CMLB063T-R36MS 0.36 3.2 3.8 20.0 18.0 24.5 22.0 CMLB063T-R47MS 0.47 3.48 4.1 18.0 16.0 21.0 17.8 CMLB063T-R56MS 0.56 3.88 4.5 16.5 15.0 20.0 16.0 CMLB063T-R68MS 0.68 4.75 5.3 16.0 14.5 19.0 15.0 CMLB063T-R82MS 0.82 5.38 6.0 14.0 13.0 17.0 14.0 CMLB063T-1R0MS 1.0 6.6 7.25 13.0 11.2 16.5 13.5 CMLB063T-1R2MS 1.2 7.7 8.6 11.7 10.1 14.5 12.5 CMLB063T-1R5MS 1.5 9.1 10.5 11.0 9.5 14.2 12.0 CMLB063T-2R2MS 2.2 13.4 15.0 8.5 8.0 12.5 10.5 CMLB063T-3R3MS 3.3 17.9 22.0 7.2 6.2 9.6 8.5 CMLB063T-4R7MS 4.7 27.9 33.0 6.0 5.5 6.55 5.5 CMLB063T-5R6MS 5.6 39.0 42.0 5.7 5.0 6.35 5.05 CMLB063T-6R8MS 6.8 42.0 48.0 4.7 4.2 6.3 5.0 CMLB063T-8R2MS 8.2 53.9 60.0 4.5 3.8 6.05 4.92 CMLB063T-100MS 10.0 60.0 68.0 4.0 3.5 5.6 4.9 CMLB063T-150MS 15.0 132.5 150.0 2.7 2.4 3.8 3.3 CMLB063T-220MS 22.0 179.5 200.0 2.3 2.0 3.1 2.5 CMLB063T-330MS 33.0 274.0 284.0 2.1 1.8 2.3 2.0 Part Number Rdc ( mΩ) *: If you require another part number please contact with us. **: Inductance Tolerance ± 20% : Note 2.: Note 3.: Note 4.: Note 5.: Note 6.: Note 1. All test data is referenced to 25 ℃ ambient. Test Condition:100KHz, 1.0Vrms Idc : DC current (A) that will cause an approximate △T of 40 ℃ Isat : DC current (A) that will cause L0 to drop approximately 30% Operating Temperature Range -55 ℃ to + 125℃ The part temperature (ambient + temp rise) should not exceed 125 ℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling Note 7. : provision all affect the part temperature. Part temperature should be verified in the end application. The rated current as listed is either the saturation current or the heating current depending on which value is lower. Jun., 2018 CYNTEC CO., LTD. 乾坤科技股份有限公司  PAGE : 3 OF 5 40 0.04 20 0.02 10 15 0.24 20 25 30 35 40 DC BIAS(Amps) 45 50 55 60 0.20 0.12 40 INDUCTANCE(µH) 0.04 TEMP. RISE( ℃) ℃ TEMP. RISE( ) 60 0.08 20 0.00 15 20 25 30 35 DC BIAS(Amps) 40 45 CMLB063T-R33MS 0.42 0.35 ℃) ℃ 10 0.60 15 20 DC BIAS(Amps) 25 30 0.50 ℃) 20 0.00 0 6 9 12 15 18 DC BIAS(Amps) 10 15 20 25 DC BIAS(Amps) 30 35 40 CMLB063T-R36MS 100 80 60 INDUCTANCE(µH) TEMP. RISE ( ℃) 40 20 0.07 0.00 ℃ 0 0 0.60 40 0.10 3 0 5 0.14 80 INDUCTANCE(µH) 0 40 ℃ 20 0.21 0.72 60 0.20 ℃) 0.28 100 0.40 TEMP. RISE( 100 3 6 9 12 15 18 21 24 27 30 DC BIAS(Amps) CMLB063T-R47MS 0.30 50 0.05 35 21 24 27 30 ℃ INDUCTANCE(µH) 5 TEMP. RISE ( 0.35 0 0 INDUCTANCE(µH) 80 20 0.00 45 60 0.10 0.42 40 0.07 40 80 0.15 100 60 TEMP. RISE ( 35 CMLB063T-R22MS 0 INDUCTANCE(µH) 0.14 20 25 30 DC BIAS(Amps) 0.00 0.28 0.21 15 0.20 50 INDUCTANCE(µH) 10 TEMP. RISE( ) 5 10 0.25 0 0 0 5 0.30 80 0.16 40 20 0 100 CMLB063T-R20MS ℃) 0.03 65 INDUCTANCE(µH) 5 TEMP. RISE ( 0.06 0.00 0 0 0.09 ℃ TEMP. RISE( ) ℃) 60 INDUCTANCE(µH) TEMP. RISE( ) TEMP. RISE( 80 0.12 CMLB063T-R56MS 100 80 0.48 60 0.36 INDUCTANCE(µH) 0.24 TEMP. RISE( ℃) 40 20 0.12 0.00 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 DC BIAS(Amps) Jun., 2018 ℃ TEMP. RISE( ) 0.06 ℃ INDUCTANCE(µH) 60 INDUCTANCE(µH) TEMP. RISE( ) 0.08 100 0.15 80 TEMP. RISE( ) INDUCTANCE(µH) : A4 CMLB063T-R15MS 0.18 100 0.00 INDUCTANCE(µH) REVISION TEMP. RISE( ) CMLB063T-R10MS 0.10 INDUCTANCE(µH) : CMLB063T-000 Current Characteristic 0.12 INDUCTANCE(µH) DOCUMENT 0.60 80 0.75 60 INDUCTANCE(µH) ℃) 20 0.20 8 10 12 14 16 DC BIAS(Amps) 18 20 22 100 0.80 60 0.40 TEMP. RISE ( ℃) 40 0.00 ℃ 4 6 8 10 12 0.45 TEMP. RISE ( 14 16 18 0 2 4 6 8 INDUCTANCE(µH) TEMP. RISE( 0.00 12 14 CMLB063T-3R3MS ℃) 40 1.40 20 0.70 0.00 0 1 2 3 4 5 6 7 8 DC BIAS(Amps) 40 ℃ 0 2 4 6 8 10 12 14 16 18 9 10 11 12 INDUCTANCE(µH) 100 CMLB063T-2R2MS 80 60 INDUCTANCE(µH) 1.35 ℃ TEMP. RISE ( ) 0.90 40 ℃ ℃ 20 0.45 0 2 4 6 8 DC BIAS(Amps) 6.00 INDUCTANCE(µH) 60 INDUCTANCE(µH) 0 ℃) 0.00 100 2.80 TEMP. RISE ( 100 20 0 80 2.10 22 1.80 16 3.50 INDUCTANCE(µH) ℃ 0 4.20 20 0.25 2.25 20 8 10 DC BIAS(Amps) 18 60 0.50 80 40 0.30 6 16 80 0.75 2.70 TEMP. RISE( ) ℃) 0.60 4 14 1.00 100 60 INDUCTANCE(µH) 2 12 CMLB063T-1R2MS 0 TEMP. RISE( ) INDUCTANCE(µH) 1.20 0 10 DC BIAS(Amps) 1.50 TEMP. RISE ( ℃ 20 1.25 20 CMLB063T-1R5MS 0.90 40 0.15 DC BIAS(Amps) 1.80 ℃) 0.30 0.00 0 2 60 INDUCTANCE(µH) 1.50 20 0.20 0 80 0 80 INDUCTANCE(µH) 100 DC BIAS(Amps) 1.00 0.60 CMLB063T-R82MS 0.60 24 CMLB063T-1R0MS 1.20 : 4 OF 5 TEMP. RISE( ) 6 PAGE ) 4 INDUCTANCE(µH) 2 : A4 0.00 0 0 REVISION TEMP. RISE( TEMP. RISE ( 40 ℃ : CMLB063T-000 10 12 14 100 CMLB063T-4R7MS 5.00 80 4.00 60 INDUCTANCE(µH) 3.00 TEMP. RISE( 2.00 ℃) 40 20 1.00 0.00 0 0 1 2 3 4 5 6 7 8 9 10 DC BIAS(Amps) Jun., 2018 ℃ TEMP. RISE( ) 0.40 0.00 INDUCTANCE(µH) 0.90 INDUCTANCE(µH) 0.80 100 TEMP. RISE( ) CMLB063T-R68MS TEMP. RISE( ) INDUCTANCE(µH) 1.00 DOCUMENT TEMP. RISE( ) CYNTEC CO., LTD. 乾坤科技股份有限公司 INDUCTANCE(µH) 2.60 ℃) 20 1.30 0.00 0 1 2 3 4 5 DC BIAS(Amps) 9.60 6 7 INDUCTANCE(µH) INDUCTANCE(µH) TEMP. RISE ( 3.20 ℃) 40 20 1.60 0.00 1 2 3 4 2.80 TEMP. RISE( 5 6 ℃) 0 1 2 3 4 DC BIAS(Amps) 80 TEMP. RISE( ℃) 0.0 TEMP. RISE( ) ℃ 0 1 2 3 4.5 5.0 80 60 14.0 TEMP. RISE ( 100 CMLB063T-220MS 80 18.0 60 INDUCTANCE(µH) 13.5 TEMP. RISE ( ℃) 40 9.0 20 0 0.0 28.0 INDUCTANCE(µH) 6 0.5 1.0 1.5 2.0 2.5 DC BIAS(Amps) 3.0 3.5 4.0 100 35.0 21.0 5 0.0 5.5 CMLB063T-330MS 42.0 4 4.5 0 2.5 3.0 3.5 4.0 DC BIAS(Amps) INDUCTANCE(µH) 22.5 20 0.0 INDUCTANCE(µH) 80 40 2.0 ℃) 40 ℃ 20 7.0 0.0 0 0.0 0.5 1.0 1.5 2.0 ℃ 20 2.0 TEMP. RISE( ) INDUCTANCE(µH) ℃) 3.0 1.5 40 4.0 27.0 6.0 1.0 60 INDUCTANCE(µH) 6.0 100 60 INDUCTANCE(µH) 0.5 100 CMLB063T-100MS 0 12.0 0.0 7 DC BIAS(Amps) 15.0 TEMP. RISE( 6 8.0 7 CMLB063T-150MS 9.0 5 10.0 ℃ ℃ 20 DC BIAS(Amps) 18.0 40 1.40 12.0 0 0 INDUCTANCE(µH) 0 60 4.80 80 0.00 80 6.40 100 CMLB063T-6R8MS 4.20 100 8.00 : 5 OF 5 60 8 CMLB063T-8R2MS PAGE 5.60 INDUCTANCE(µH) 0 : A4 2.5 3.0 3.5 DC BIAS(Amps) Jun., 2018 ℃ TEMP. RISE( ) TEMP. RISE ( 40 REVISION TEMP. RISE( ) 60 ℃ TEMP. RISE( ) 5.20 : CMLB063T-000 7.00 80 TEMP. RISE( ) INDUCTANCE(µH) 6.50 3.90 8.40 100 CMLB063T-5R6MS INDUCTANCE(µH) 7.80 DOCUMENT TEMP. RISE( ) CYNTEC CO., LTD. 乾坤科技股份有限公司
CMLB063T-R68MS
物料型号:CMLB063T-R10MS, CMLB063T-R15MS, CMLB063T-R20MS, 等,每个型号都有不同的电感值。
器件简介:该电源扼流圈采用金属粉末芯,具有高性能、低外形厚度最大3.0mm、低直流电阻损耗、能够应对高达1MHz的高频,并符合RoHS标准的100%无铅。
引脚分配:文档中未明确提供引脚分配信息,但提供了推荐焊盘图案尺寸。
参数特性:包括电感值、直流电阻、直流电流额定值、饱和电流等,不同型号的扼流圈有各自的典型值和最大值。
功能详解:扼流圈适用于笔记本电脑CPU的DC/DC转换器、薄型交换器的车载电源模块、服务器的VRM等。
应用信息:主要应用于笔记本电脑CPU的DC/DC转换器、薄型交换器的车载电源模块、服务器的VRM等。
封装信息:提供了扼流圈的外形尺寸和推荐焊盘图案尺寸。
CMLB063T-R68MS 价格&库存
很抱歉,暂时无法提供与“CMLB063T-R68MS”相匹配的价格&库存,您可以联系我们找货
