TAI-TECH
P1
SMD Power Inductor
TMPC0603H-Series(G)-D
D
1. Features
1. Carbonyl Powder.
2. Compact design.
Halogen
3. High current,low DCR,high efficiency.
4. Very low acoustic noise and very low leakage flux noise.
Halogen-free
5. High reliability.
6. 100% Lead(Pb)-Free and RoHS compliant.
7. Operating temperature -40~+125℃(Including self - temperature rise)
2. Applications
Note PC power system,incl. IMVP-6
DC/DC converter .
3. Dimensions
A
Recommend PC Board Pattern
C
H
L
E
B
8R2
2019
D
G
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
TMPC0603H
7.3±0.3
6.6±0.3
2.8±0.2
1.8±0.3
3.0±0.3
4. Part Numbering
TMPC
0603
H
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: D/C
8R2
MG
D
E
L(mm)
G(mm)
H(mm)
8.4
2.5
3.5
Note: 1. The above PCB layout reference only.
2. Recommend solder paste thickness at
0.15mm and above.
D
F
BxC
Carbonyl Powder.
8R2=8.20uH
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%.
Marking: Black.8R2 and 2019(20 YY, 19 WW,follow production date).
TAI-TECH
P2
5. Specification
Part Number
Inductance
L0 (uH)±20%
I rms ( A )
I sat ( A )
DCR
(mΩ) Typ.
@25℃
DCR
(mΩ) Max.
@25℃
TMPC0603H-R10YG-D
0.10±30%
32.5
60.0
1.2
1.7
TMPC0603H-R22YG-D
0.22±30%
23.0
40.0
2.1
2.8
TMPC0603H-R33MG-D
0.33
20.0
32.0
3.5
3.9
TMPC0603H-R36MG-D
0.36
19.0
32.0
3.6
4.2
TMPC0603H-R47MG-D
0.47
17.5
26.0
4.0
4.2
TMPC0603H-R56MG-D
0.56
16.5
25.5
4.7
5.0
TMPC0603H-R68MG-D
0.68
15.5
25.0
4.8
5.5
TMPC0603H-R82MG-D
0.82
13.0
24.0
6.7
8.0
TMPC0603H-1R0MG-D
1.00
11.0
22.0
8.3
10
TMPC0603H-1R5MG-D
1.50
9.00
18.0
13
15
TMPC0603H-2R2MG-D
2.20
8.00
14.0
18
TMPC0603H-3R3MG-D
3.30
6.00
13.5
28
30
TMPC0603H-4R7MG-D
4.70
5.50
10.0
37
40
TMPC0603H-5R6MG-D
5.60
5.00
9.00
43
48
TMPC0603H-6R8MG-D
6.80
4.50
8.00
54
60
TMPC0603H-8R2MG-D
8.20
4.00
7.50
64
68
TMPC0603H-100MG-D
10.0
3.50
6.00
75
85
TMPC0603H-150MG-D
15.0
3.00
4.00
107
123
TMPC0603H-220MG-D
22.0
2.00
3.50
165
190
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
6. Typical Performance Curves
P3
TAI-TECH
P4
很抱歉,暂时无法提供与“TMPC0603H-1R0MG-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.21414
- 50+0.97546
- 150+0.87329
- 国内价格
- 10+2.46530
- 100+1.47060
- 500+1.02950
- 1000+0.73530
- 2000+0.73530
- 10000+0.73530
- 国内价格 香港价格
- 1+6.884251+0.89067
- 10+5.4817910+0.70922
- 25+5.0241225+0.65001
- 50+4.7045650+0.60866
- 100+4.40795100+0.57029
- 250+4.04645250+0.52352
- 500+3.79452500+0.49093
- 国内价格 香港价格
- 1000+3.559651000+0.46054
- 2000+3.340672000+0.43221
- 3000+3.219393000+0.41652
- 5000+3.073435000+0.39763
- 7000+2.981267000+0.38571
- 10000+2.8868410000+0.37349
