CMLB104T-150MS
CMLB104T-150MS
    CYNTEC(乾坤)
    SMD,10.85x10mm
    功率电感 15µH ±20% IND_10.85X10MM_SM 3.80mm 10.85 x 10.00mm 45mΩ 5A
CMLB104T-150MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB104T-000 REVISION : A9 PAGE : 1 OF 5 Power Choke Coil CMLB104T type  Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 4.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions A' L A B W B' H  T Dimensions (mm) Code R15/R22/R36/R47/ 2R2/3R3/4R7/5R6 R56/1R0/1R5 6R8/8R2/100/150 220/330/470 L 11.15  0.35 10.85  0.35 W 10.0  0.3 T 3.8  0.2 A 2.0  0.5 A’ 2.5  0.1 B 3.0  0.5 B’ 5.0  0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 4.1 B 5.4 C 13.6 Unit : mm Mar., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB104T-000 REVISION : A9 PAGE : 2 OF 5 Specifications L0 Inductance ( H ) @ (0A) Typical CMLB104T-R15MS 0.15 CMLB104T-R22MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 0.45 0.55 50.0 45.0 76.0 64.0 0.22 0.82 0.93 36.0 32.0 63.0 60.0 CMLB104T-R36MS 0.36 1.05 1.18 33.0 29.0 51.0 42.0 CMLB104T-R47MS 0.47 1.3 1.5 32.0 28.0 46.0 40.0 CMLB104T-R56MS 0.56 1.59 1.8 25.0 23.0 33.5 28.0 CMLB104T-1R0MS 1.0 2.85 3.3 19.0 17.0 29.0 26.0 CMLB104T-1R5MS 1.5 3.8 4.2 16.0 15.0 22.0 18.0 CMLB104T-2R2MS 2.2 6.0 7.0 12.0 11.0 20.0 16.0 CMLB104T-3R3MS 3.3 10.5 12.0 10.0 9.0 16.2 13.5 CMLB104T-4R7MS 4.7 16.8 20.0 8.5 7.6 15.2 13.0 CMLB104T-5R6MS 5.6 19.8 23.0 8.0 7.2 14.1 11.5 CMLB104T-6R8MS 6.8 22.0 24.5 7.8 6.5 12.0 9.5 CMLB104T-8R2MS 8.2 24.0 26.5 7.6 6.2 9.0 8.0 CMLB104T-100MS 10.0 27.0 30.0 7.5 5.8 8.6 7.2 CMLB104T-150MS 15.0 39.5 45.0 6.3 5.0 8.0 6.9 CMLB104T-220MS 22.0 59.0 66.0 5.0 4.0 6.2 5.4 CMLB104T-330MS 33.0 84.0 91.0 4.4 3.5 5.5 5.0 CMLB104T-470MS 47.0 129.0 143.0 3.3 2.8 4.0 3.7 Part Number Rdc ( m ) *:If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Mar., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司  PAGE : 3 OF 5 40 20 40 0.16 0 0.00 0 5 10 15 20 25 30 35 40 DC BIAS(Amps) 45 50 55 60 0.24 30 0.12 15 0.00 0 10 15 20 25 DC BIAS(Amps) 30 35 1.50 1.20 TEMP. RISE(℃) 0.00 3 6 9 12 15 18 DC BIAS(Amps) 21 24 27 30 45 50 55 100 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 0.40 80 2.25 0 0 40 80 0.60 2.70 20 0.30 20 25 30 35 DC BIAS(Amps) 0.80 100 40 0.60 15 CMLB104T-1R0MS 20 0 0 60 INDUCTANCE(μH) 0.90 10 0.00 40 CMLB104T-1R5MS 1.80 0 5 0.20 INDUCTANCE(μH) 5 INDUCTANCE(μH) 1.00 0.48 TEMP. RISE (℃) 75 0 20 0 45 40 0.10 0.60 TEMP. RISE(℃) TEMP. RISE(℃) 0.20 1.20 INDUCTANCE(μH) 60 INDUCTANCE(μH) 0.30 90 0.36 80 0.40 0.00 60 CMLB104T-R56MS 0.72 100 0.50 20 0.08 CMLB104T-R47MS TEMP. RISE (℃) TEMP. RISE(℃) 10 15 20 25 30 35 40 45 50 55 60 65 70 0.60 TEMP. RISE(℃) 60 INDUCTANCE(μH) 0.24 5 DC BIAS(Amps) 80 0.32 0 0 100 0.40 20 TEMP. RISE(℃) CMLB104T-R36MS 40 0.05 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 DC BIAS(Amps) 0.48 TEMP. RISE(℃) 0.10 INDUCTANCE(μH) 0 60 INDUCTANCE(μH) 0.15 0.00 0 0.00 80 0.20 5 10 15 20 DC BIAS(Amps) 25 30 35 100 CMLB104T-2R2MS 80 1.80 60 INDUCTANCE(μH) 1.35 TEMP. RISE(℃) 40 0.90 TEMP. RISE(℃) 0.03 INDUCTANCE(μH) TEMP . RISE(℃) 0.06 TEMP. RISE(℃) 60 INDUCTANCE(μH) 0.09 100 0.25 TEMP. RISE(℃) INDUCTANCE(μH) : A9 CMLB104T-R22MS 0.30 80 0.12 INDUCTANCE(μH) REVISION TEMP. RISE(℃) 100 CMLB104T-R15MS 0.15 INDUCTANCE(μH) : CMLB104T-000 Current Characteristic 0.18 INDUCTANCE(μH) DOCUMENT 20 0.45 0 0.00 0 3 6 9 12 15 DC BIAS(Amps) 18 21 24 Mar., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司 40 1.40 20 0.70 0 0.00 0 2 4 6 8 10 12 14 16 18 PAGE : 4 OF 5 80 4.00 TEMP. RISE(℃) 20 1.00 0 0 7.00 40 2.00 20 1.00 INDUCTANCE(μH) TEMP. RISE(℃) 0.00 2 4 6 8 10 12 DC BIAS(Amps) 4 6 8 10 DC BIAS(Amps) 9.60 12 14 CMLB104T-8R2MS 8.00 6.40 TEMP. RISE(℃) 0.00 1 2 3 4 5 6 7 8 9 80 10.0 TEMP. RISE(℃) 40 6.0 20 3.0 0 0.0 1 2 3 4 5 6 7 DC BIAS(Amps) 8 9 10 INDUCTANCE(μH) 60 INDUCTANCE(μH) 2 3 4 5 6 7 8 9 10 11 12 13 14 15 DC BIAS(Amps) CMLB104T-100MS 100 80 60 INDUCTANCE(μH) 6.0 TEMP. RISE(℃) 40 4.0 20 2.0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 10 CMLB104T-220MS 90 22.5 TEMP. RISE(℃) INDUCTANCE(μH) 12.0 1 27.0 80 0 0 0 100 15.0 9.0 20 0.0 10 11 12 13 CMLB104T-150MS 40 8.0 DC BIAS(Amps) 18.0 TEMP. RISE(℃) 2.80 12.0 0 0 60 INDUCTANCE(μH) 0.00 20 1.60 100 80 4.20 100 40 3.20 18 5.60 0 60 INDUCTANCE(μH) 4.80 16 CMLB104T-6R8MS 16 INDUCTANCE(μH) 2 14 1.40 0 0 INDUCTANCE(μH) 80 60 INDUCTANCE(μH) 3.00 8.40 TEMP. RISE(℃) 4.00 100 TEMP. RISE(℃) INDUCTANCE(μH) 5.00 40 2.00 0.00 20 CMLB104T-5R6MS 60 INDUCTANCE(μH) 3.00 DC BIAS(Amps) 6.00 100 CMLB104T-4R7MS TEMP. RISE(℃) TEMP. RISE(℃) : A9 TEMP. RISE(℃) 5.00 60 INDUCTANCE(μH) 2.10 80 REVISION TEMP. RISE(℃) 2.80 6.00 : CMLB104T-000 75 18.0 60 INDUCTANCE(μH) 13.5 45 TEMP. RISE(℃) 9.0 30 4.5 15 0.0 TEMP. RISE(℃) INDUCTANCE(μH) 3.50 100 INDUCTANCE(μH) CMLB104T-3R3MS TEMP. RISE(℃) 4.20 DOCUMENT 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 Mar., 2020 CYNTEC CO., LTD. 乾坤科技股份有限公司 60 21.0 INDUCTANCE(μH) 14.0 TEMP. RISE(℃) 40 20 7.0 0.0 0 0.0 0.7 1.4 2.1 2.8 3.5 4.2 4.9 DC BIAS(Amps) 5.6 6.3 7.0 INDUCTANCE(μH) 28.0 : A9 PAGE : 5 OF 5 100 48.0 80 TEMP. RISE(℃) INDUCTANCE(μH) 35.0 REVISION CMLB104T-470MS 56.0 100 : CMLB104T-000 80 40.0 32.0 INDUCTANCE(μH) 24.0 TEMP. RISE(℃) 60 40 16.0 TEMP. RISE(℃) CMLB104T-330MS 42.0 DOCUMENT 20 8.0 0 0.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 4.0 4.5 5.0 Mar., 2020
CMLB104T-150MS
物料型号: CMLB104T
器件简介: - 乾坤科技股份有限公司生产的高性能共模扼流圈。 - 采用金属粉末芯,具有低直流电阻(DCR)和高饱和电流(Isat)。 - 适用于高达1MHz的高频应用。 - 符合RoHS标准的100%无铅。
引脚分配: - 引脚分配的具体信息未在文档中明确列出,但通常这类器件会有相应的引脚图或说明。
参数特性: - 提供了不同型号的电感值(LO Inductance)、直流电阻(Rde)、额定电流(Heat Rating Current, Ide)和饱和电流(Isat)。 - 所有测试数据以25℃环境温度为基准。 - 测试条件为100KHz, 1.0Vrms。
功能详解: - 该器件适用于笔记本电脑CPU的DC/DC转换器、薄型电源模块、服务器的VRM等。
应用信息: - 主要应用于笔记本电脑CPU的DC/DC转换器、薄型电源模块、服务器的VRM。
封装信息: - 提供了详细的外形尺寸,包括长度(L)、宽度(W)、厚度(T)、顶部宽度(A)、底部宽度(A')、引脚宽度(B)、引脚间距(B')和高度(H)。 - 还推荐了焊盘图案尺寸,以确保安全和可靠性。
CMLB104T-150MS 价格&库存
很抱歉,暂时无法提供与“CMLB104T-150MS”相匹配的价格&库存,您可以联系我们找货
