CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLB135T-000
REVISION
: A6
PAGE
: 1 OF 4
Power Choke Coil CMLB135T type
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 5.0mm
Low loss realized with low DCR
Capable of corresponding high frequency (1MHz)
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Thin type on-board power supply module for exchanger
VRM for server
Outline Dimensions
A'
L
A
B
W
B'
Dimensions (mm)
Code R47/R68/R82/1R0 2R2/3R3/4R7/6R8
100/150/220
L
13.45 0.35
W
12.6 0.2
T
4.8 0.2
A
2.0 0.5
A'
2.5 0.1
4.0 0.5
B
H
T
3.0 0.5
B'
6.0 0.2
H
0 ~ +0.15
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
5.0
B
8.0
C
14.5
Unit : mm
Apr, 2021
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLB135T-000
REVISION
: A6
PAGE
: 2 OF 4
Specifications
L0
Inductance
( H )
@ (0A)
Typical
CMLB135T-R47MS
0.47
CMLB135T-R68MS
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
0.90
1.05
38.5
34.2
55.0
47.4
0.68
1.34
1.55
35.0
30.5
54.0
46.0
CMLB135T-R82MS
0.82
1.45
1.65
34.2
30.2
42.0
39.0
CMLB135T-1R0MS
1.0
1.80
2.20
30.0
27.0
36.0
32.5
CMLB135T-2R2MS
2.2
3.98
5.00
20.5
19.0
25.0
22.0
CMLB135T-3R3MS
3.3
5.50
7.00
15.5
14.0
22.5
19.5
CMLB135T-4R7MS
4.7
8.50
10.3
13.0
11.5
17.2
14.5
CMLB135T-6R8MS
6.8
13.0
15.0
11.5
10.0
15.0
12.0
CMLB135T-100MS
10.0
18.9
22.0
9.0
8.1
13.0
10.5
CMLB135T-150MS
15.0
30.0
35.0
7.0
6.3
8.0
6.8
CMLB135T-220MS
22.0
50.0
58.0
5.5
5.0
6.6
5.7
Part Number
Rdc ( m )
*: If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to +125℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other
cooling provision all affect the part temperature. Part temperature should be verified in the end
application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Apr, 2021
CYNTEC CO., LTD.
乾坤科技股份有限公司
: A6
PAGE
: 3 OF 4
TEMP. RISE(℃)
40
0.20
0.42
40
0.28
INDUCTANCE(μH)
0.14
CMLB135T-R82MS
100
1.20
0.80
INDUCTANCE(μH)
0.48
TEMP. RISE(℃)
40
0.32
0.00
10
15
30
35
40
45
10 15 20 25 30 35 40 45 50 55 60 65 70
DC BIAS(Amps)
CMLB135T-1R0MS
80
0.80
60
INDUCTANCE(μH)
0.60
2.00
80
3.50
60
INDUCTANCE(μH)
1.50
4.20
TEMP. RISE(℃)
40
1.00
0.00
INDUCTANCE(μH)
2.50
100
TEMP. RISE(℃)
CMLB135T-2R2MS
4
6
8
5
10
15
30
DC BIAS(Amps)
40
0.00
6
8
10
12
14
DC BIAS(Amps)
16
18
INDUCTANCE(μH)
60
2
60
INDUCTANCE(μH)
2.10
TEMP. RISE(℃)
40
1.40
4
6
8
10
12
14
16
18
24
CMLB135T-6R8MS
100
7.50
TEMP. RISE(℃)
4.00
80
9.00
80
TEMP. RISE(℃)
50
2.80
5.00
2.00
45
DC BIAS(Amps)
CMLB135T-4R7MS
INDUCTANCE(μH)
40
CMLB135T-3R3MS
DC BIAS(Amps)
3.00
35
0.00
10 12 14 16 18 20 22 24 26 28
6.00
40
TEMP. RISE(℃)
0.40
DC BIAS(Amps)
3.00
100
0.00
5
1.00
80
0.64
TEMP. RISE(℃)
10 15 20 25 30 35 40 45 50 55 60 65 70 75
DC BIAS(Amps)
0.96
0.56
80
6.00
60
4.50
INDUCTANCE(μH)
3.00
TEMP. RISE(℃)
40
0.00
TEMP. RISE(℃)
5
INDUCTANCE(μH)
INDUCTANCE(μH)
60
INDUCTANCE(μH)
0.30
0.70
TEMP. RISE(℃)
0.40
100
TEMP. RISE(℃)
80
TEMP. RISE(℃)
0.50
CMLB135T-R68MS
0.84
T EMP. RISE(℃)
INDUCTANCE(μH)
100
0.00
INDUCTANCE(μH)
REVISION
TEMP. RISE(℃)
CMLB135T-R47MS
0.10
INDUCTANCE(μH)
: CMLB135T-000
Current Characteristic
0.60
INDUCTANCE(μH)
DOCUMENT
4
6
8
10
12
14
DC BIAS(Amps)
16
18
Apr, 2021
TEMP. RISE(℃)
40
4.0
0.0
4
27.0
INDUCTANCE(μH)
15.0
60
INDUCTANCE(μH)
6.0
80
6
8
DC BIAS(Amps)
10
12
: A6
PAGE
: 4 OF 4
CMLB135T-150MS
100
80
12.0
60
INDUCTANCE(μH)
9.0
TEMP. RISE(℃)
40
6.0
2
3
4
5
6
7
DC BIAS(Amps)
8
9
10
11
100
22.5
80
18.0
60
INDUCTANCE(μH)
13.5
REVISION
0.0
14
CMLB135T-220MS
INDUCTANCE(μH)
8.0
18.0
: CMLB135T-000
TEMP. RISE(℃)
40
9.0
0.0
TEMP. RISE(℃)
INDUCTANCE(μH)
10.0
100
TEMP. RISE(℃)
CMLB135T-100MS
12.0
DOCUMENT
TEMP. RISE(℃)
CYNTEC CO., LTD.
乾坤科技股份有限公司
2
3
4
5
6
DC BIAS(Amps)
7
8
9
Apr, 2021
很抱歉,暂时无法提供与“CMLB135T-R68MS”相匹配的价格&库存,您可以联系我们找货
