CMLB136T-680MS
CMLB136T-680MS
    CYNTEC(乾坤)
    IND_13.45X12.6MM_SM
    功率电感 68µH ±20% IND_13.45X12.6MM_SM 5.80mm 13.45 x 12.60mm 140mΩ 3A
CMLB136T-680MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB136T-000 REVISION : A1 PAGE : 1 OF 4 Power Choke Coil CMLB136T type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 6.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' A B W B' H  T Code Dimensions (mm) L 13.45 ± 0.35 W 12.6 ± 0.2 T 5.8 ± 0.2 A 2.0 ± 0.5 A’ 2.5 ± 0.1 B 5.0 ± 0.5 B’ 6.0 ± 0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 5.5 B 8.0 C 14.5 Unit : mm Sep., 2017 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB136T-000 REVISION : A1 PAGE : 2 OF 4 Specifications L0 Inductance ( µH ) @ (0A) Typical CMLB136T-8R2MS 8.2 13.5 16.0 11.0 10.0 16.0 13.5 CMLB136T-100MS 10.0 17.7 20.7 10.0 9.5 13.5 11.5 CMLB136T-120MS 12.0 19.8 23.0 9.0 8.0 13.0 11.0 CMLB136T-150MS 15.0 24.0 27.5 8.0 7.0 10.0 9.0 CMLB136T-220MS 22.0 33.0 39.0 7.0 6.5 7.6 6.9 CMLB136T-330MS 33.0 60.0 70.0 5.0 4.7 6.1 5.4 CMLB136T-470MS 47.0 78.0 88.0 4.5 4.0 5.7 5.2 CMLB136T-680MS 68.0 119.5 140.0 3.5 3.0 5.5 4.7 CMLB136T-101MS 100.0 178.0 198.0 3.0 2.7 4.0 3.5 CMLB136T-151MS 150.0 300.0 347.0 2.5 2.2 3.0 2.7 Part Number Rdc ( mΩ) Maximum Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Typical Typical Maximum Maximum *: If you require another part number please contact with us. **:Inductance Tolerance ± 20% : Note 2.: Note 3.: Note 4.: Note 5.: Note 6.: Note 1. All test data is referenced to 25 ℃ ambient. Test Condition:100KHz, 1.0Vrms Idc : DC current (A) that will cause an approximate △T of 40 ℃ Isat : DC current (A) that will cause L0 to drop approximately 30% Operating Temperature Range -55 ℃ to + 125℃ The part temperature (ambient + temp rise) should not exceed 125 ℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end Note 7. : application. The rated current as listed is either the saturation current or the heating current depending on which value is lower. Sep., 2017 CYNTEC CO., LTD. 乾坤科技股份有限公司  REVISION : A1 PAGE : 3 OF 4 3.20 TEMP. RISE( ℃) 40 20 1.60 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 18 CMLB136T-120MS 15.0 ℃ 60 INDUCTANCE(µH) ℃) 40 5.0 20 2.5 0.0 3 4 5 CMLB136T-220MS 27.0 TEMP. RISE( TEMP. RISE( ) 60 INDUCTANCE(µH) 13.5 ℃ ℃) 40 9.0 20 4.5 0.0 0 1.5 3.0 4.5 6.0 7.5 DC BIAS(Amps) 60.0 9.0 10.5 50.0 60 INDUCTANCE(µH) 30.0 TEMP. RISE( 20.0 ℃) 40 20 10.0 0.0 0 0 1 2 3 4 5 DC BIAS(Amps) 6 7 8 4 5 6 7 8 9 10 11 12 13 14 15 16 DC BIAS(Amps) CMLB136T-150MS 100 80 60 9.0 INDUCTANCE(µH) 6.0 TEMP. RISE( ℃) 40 20 3.0 0 1 2 3 4 5 6 7 8 DC BIAS(Amps) 9 10 11 12 13 CMLB136T-330MS 100 35.0 80 28.0 21.0 INDUCTANCE(µH) TEMP. RISE( 14.0 ℃) 40 20 7.0 0 1 2 3 4 5 DC BIAS(Amps) 6 7 8 100 CMLB136T-680MS 70.0 80 56.0 42.0 28.0 ℃ 60 84.0 ℃ ℃ 12.0 0 80 40.0 3 0.0 100 CMLB136T-470MS 2 15.0 12.0 INDUCTANCE(µH) 0.0 ℃ 0 1 42.0 80 18.0 40 20 0 100 22.5 ℃) 2.0 6 7 8 9 10 11 12 13 14 15 DC BIAS(Amps) INDUCTANCE(µH) 2 TEMP. RISE( 0.0 0 1 4.0 18.0 TEMP. RISE( ) 10.0 0 INDUCTANCE(µH) 0 80 TEMP. RISE( 6.0 0.0 100 12.5 7.5 60 20 INDUCTANCE(µH) 0 8.0 TEMP. RISE( ) INDUCTANCE(µH) 80 TEMP. RISE( ) 4.80 ℃ 100 60 INDUCTANCE(µH) TEMP. RISE( ℃) 40 20 14.0 0.0 ℃ TEMP. RISE( ) 60 CMLB136T-100MS TEMP. RISE( ) 10.0 INDUCTANCE(µH) 80 TEMP. RISE( ) INDUCTANCE(µH) 12.0 6.40 0.00 INDUCTANCE(µH) 100 TEMP. RISE( ) CMLB136T-8R2MS 8.00 INDUCTANCE(µH) : CMLB136T-000 Current Characteristic 9.60 INDUCTANCE(µH) DOCUMENT 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 DC BIAS(Amps) Sep., 2017 CYNTEC CO., LTD. 乾坤科技股份有限公司 80 150.0 80.0 60 INDUCTANCE(µH) 60.0 TEMP. RISE( ℃) 40 40.0 20 20.0 0.0 0 0.0 0.6 1.2 1.8 2.4 3.0 DC BIAS(Amps) 3.6 4.2 4.8 ℃ : CMLB136T-000 REVISION : A1 PAGE : 4 OF 4 CMLB136T-151MS 100 80 120.0 60 90.0 40 60.0 INDUCTANCE(µH) 30.0 TEMP. RISE( 20 ℃) 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 DC BIAS(Amps) 3.5 4.0 ℃ TEMP. RISE( ) 180.0 INDUCTANCE(µH) INDUCTANCE(µH) 100.0 100 TEMP. RISE( ) CMLB136T-101MS 120.0 DOCUMENT 4.5 Sep., 2017
CMLB136T-680MS 价格&库存
很抱歉,暂时无法提供与“CMLB136T-680MS”相匹配的价格&库存,您可以联系我们找货
