P1
TAIPAQ
SMD Power Inductor
TMPC1004H-Series-D
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
11/12/22
新發行
張龍旺
羅宜春
李芳
1.1
11/12/28
增加 150MG 規格
張龍旺
羅宜春
李芳
1.2
12/01/03
增加 R27MG 規格
張龍旺
羅宜春
李芳
1.3
12/01/06
增加 8R2MG 規格
張龍旺
羅宜春
李芳
1.4
13/03/20
增加 220MG 規格
張龍旺
羅宜春
甘歡歡
1.5
增加
R15YG/R19YG/R24MG/R30MG/R47MG/
R68MG/R75MG/R88MG/1R2MG/1R8MG/
14/09/12
2R5MG/3R0MG/3R9MG/4R0MG/5R6MG/
6R2MG/6R5MG/7R3MG/180MG/270MG/
470MG/680MG/820MG 規格
羅宜春
張光
陳凱燕
備
注
P2
TAIPAQ
TMPC1004H-Series-D
SMD Power Inductor
1. Features
1. Carbonyl Powder.
2. Compact design.
3. High current,low DCR,high efficiency.
Halogen
Pb
Halogen-free
Pb-free
4. Very low acoustic noise and very low leakage flux noise.
5. High reliability.
6. 100% Lead(Pb)-Free and RoHS compliant.
2. Applications
Note PC power system,incl. IMVP-6
DC/DC converter .
3. Dimensions
Recommend PC Board Pattern
Dr. MOS application
L
H
D
100
1150
E
B
A
C
G
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
G(mm)
H(mm)
TMPC1004H
11.0±0.5
10.0±0.3
3.8±0.2
2.3±0.3
3.0±0.3
13.6
5.4
3.5
4. Part Numbering
TMPC
1004
H
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: 印 D/C
100
MG
D
E
D
F
BxC
Carbonyl Powder.
100=10.0uH
M=±20%
印字:黑色.100 及 D/C 1150 (11 年,50 週期)(依實際生產日期而定)
P3
TAIPAQ
5. Specification
Part Number
Inductance
L0 (uH)±20% @ 0 A
I rms (A)
Typ.
I sat (A)
Typ.
DCR
(mΩ) Typ.
@25℃
DCR
(mΩ) Max.
@25℃
TMPC1004H-R15YG-D
0.15±30%
43
75
0.5
0.6
TMPC1004H-R19YG-D
0.19±30%
36
70
0.6
0.9
TMPC1004H-R22MG-D
0.22
35
60
0.8
1.0
TMPC1004H-R24MG-D
0.24
34
60
0.8
1.0
TMPC1004H-R27MG-D
0.27
33
60
0.82
1.0
TMPC1004H-R30MG-D
0.30
32
60
0.94
1.1
TMPC1004H-R36MG-D
0.36
31
60
1.05
1.2
TMPC1004H-R39MG-D
0.39
30
60
1.1
1.3
TMPC1004H-R45MG-D
0.45
29
45
1.3
1.5
TMPC1004H-R47MG-D
0.47
28
43
1.3
1.5
TMPC1004H-R56MG-D
0.56
25
40
1.6
1.8
TMPC1004H-R68MG-D
0.68
22
39
2.4
2.7
TMPC1004H-R75MG-D
0.75
22
39
2.4
2.7
TMPC1004H-R88MG-D
0.88
2.5
2.9
TMPC1004H-1R0MG-D
1.00
18
36
3.0
3.3
TMPC1004H-1R2MG-D
1.20
17
33
3.3
3.8
TMPC1004H-1R5MG-D
1.50
16
33
4.0
4.6
TMPC1004H-1R8MG-D
1.80
14
30
5.3
6.4
TMPC1004H-2R2MG-D
2.20
12
27
6.5
7.0
TMPC1004H-2R5MG-D
2.50
11.5
23
7.9
8.7
TMPC1004H-3R0MG-D
3.00
11.5
21
10
11.5
TMPC1004H-3R3MG-D
3.30
11
11.8
TMPC1004H-3R9MG-D
3.90
10.5
19
12.6
14.5
TMPC1004H-4R0MG-D
4.00
10.2
18
13
15
TMPC1004H-4R7MG-D
4.70
10
17
15.0
15.5
TMPC1004H-5R6MG-D
5.60
9.0
14
17
19.3
TMPC1004H-6R2MG-D
6.20
8.7
13.7
17.2
21.3
TMPC1004H-6R5MG-D
6.50
8.6
13.6
17.3
22.3
TMPC1004H-6R8MG-D
6.80
8.5
13.5
17.5
23.3
TMPC1004H-7R3MG-D
7.30
8.3
13.0
19.0
21.8
TMPC1004H-8R2MG-D
8.20
8.0
12.5
TMPC1004H-100MG-D
10.0
7.5
12.0
27.0
30
TMPC1004H-150MG-D
15.0
6.25
10
40
45
TMPC1004H-180MG-D
18.0
5.5
9.0
56
62
TMPC1004H-220MG-D
22.0
5.0
7.0
64
74
TMPC1004H-270MG-D
27.0
4.0
6.0
86
100
TMPC1004H-330MG-D
33.0
3.5
5.0
92
112
TMPC1004H-470MG-D
47.0
3.0
4.5
145
167
TMPC1004H-680MG-D
68.0
2.0
3.0
205
240
TMPC1004H-820MG-D
82.0
1.5
2.5
265
320
Note:
1. Test frequency : L : 100KHz /1.0V;
2. All test data referenced to 25℃ ambient.
3. Testing Instrument : L: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃ (keep 1min.).
5. Saturation Current (Isat) will cause L0
to drop
20% typical. (keep quickly).
6. The part temperature (ambient + temp rise) should not exceed 155℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
P4
TAIPAQ
6. Material List
5
NO
Items
Materials
1
Core
Carbonyl Powder.
2
Wire
Polyester Wire or equivalent.
3
Solder Plating
100% Pb free solder
4
Ink
Halogen-free ketone
5
paint
Epoxy resin
7. Reliability and Test Condition
Item
Performance
Operating temperature
-55~+155℃
Storage temperature and
Humidity range
-10~+40℃,50~60%RH (Product without taping)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
△L20% typical.
Saturation DC Current (Isat) will cause L0
to drop △L(%)(keep quickly).
Approximately △T≦40℃
rise △T(℃) without core loss.
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
High Temperature Exposure Test
Temperature:155±2℃.
Duration:1000±12hrs.
Measured at room temperature after placing for 2 to 3hrs.
(MIL-PRF-27)
Low Temperature Life Test
Temperature:-55±2℃.
Duration:500±12hrs.
Biased Humidity Test
Humidity:85±3%RH.
Temperature:85±2℃.
(AEC-Q200-REV C)
Thermal shock test
Condition for 1 cycle
Step1:-55+0 / -2℃
15±1 min.
Step2:Room temperature within ≦0.2 min.
Step3:+155+2 / -0℃ 15±1min.
Number of cycles:300
Measured at room temperature after placing for 2 to 3 hrs.
(AEC-Q200-REV C)
Electric specifications should be satisfied
Vibration test
Frequency: 10-2000-10Hz for 20 min.
Amplitude: Parts mounted within 2" from any secure point.
Directions and times: X, Y, Z directions for 20 min.
This cycle shall be performed 12 times in each of three
mutually perpendicular directions
(Total 12hours).
(MIL-STD-202 Method 204 D Test condition B)
Reflow test
Pre-heat:150±5℃
Duration:5 minutes
Temperature:260±5℃,20~40 seconds
(IPC/JEDEC J-STD-020C)
Solder test
Terminals should be covered by over 95% solder on visual inspection
After dip into flux,dip into solder
235±5℃,4±1seconds
Flux 、solder for lead free
(ANSI /J-STD-002C Method B)
P5
TAIPAQ
8. Soldering and Mounting
(1) Soldering
Mildly activated rosin fluxes are preferred. The minimum amount of solder can lead to damage from the stresses caused
by the difference in coefficients of expansion between solder, chip and substrate. TAIPAQ terminations are suitable for
re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air
soldering tools.
(2) Solder re-flow:
Recommended temperature profiles for re-flow soldering in Figure 1.
(3) Soldering Iron:
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that
a soldering iron must be employed the following precautions are recommended.
‧Preheat circuit and products to 150℃
‧Never contact the ceramic with the iron tip
‧Use a 20 watt soldering iron with tip diameter of 1.0mm
‧355℃ tip temperature (max)
‧1.0mm tip diameter (max)
‧Limit soldering time to 4~5sec.
Iron Soldering
Reflow Soldering
SOLDERING
20~40s
TEMPERATURE(¢X
C)
TP(260¢X
C / 40s max.)
217
60~150s
200
150
PRE-HEATING
NATURAL
COOLING
60~180s
SOLDERING
within 4~5s
TEMPERATURE(¢X
C)
PRE-HEATING
350
150
Gradual cooling
Over 60s
480s max.
NATURAL
COOLING
25
TIME( sec.)
Reflow times: 3 times max.
Fig.1
TIME(sec.)
Iron Soldering times: 1 times max.
Fig.2
P6
TAIPAQ
9. Packaging Information
(1) Reel Dimension
COVER TAPE
Type
A(mm)
B(mm)
C(mm)
D(mm)
13”x24mm
24.0±0.5
100±2
13.5±0.5
330
C
B
D
2.0¡ Ó
0.5
A
EMBOSSED CARRIER
(2) Tape Dimension
Series Size Bo(mm) Ao(mm) Ko(mm) P(mm) W(mm) F(mm)
TMPC
11.6±0.1
1004
10.4±0.1
4.5±0.1
16.0±0.1
24±0.3
11.5±0.1
t(mm)
D(mm)
0.35±0.05
1.5±0.1
(3) Packaging Quantity
TMPC
1004
Chip / Reel
500
Inner box
1000
Carton
4000
(4) Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 10 to 130 grams in the arrow
direction under the following conditions(referenced
ANSI/EIA-481-C-2003 of 4.11 stadnard).
165¢Xto180¢X
Base tape
Room Temp.
Room Humidity
Room atm
(hPa)
Tearing Speed
mm/min
5~35
45~85
860~1060
300
Application Notice
‧Storage Conditions
To maintain the solderability of terminal electrodes:
1. TAIPAQ products meet IPC/JEDEC J-STD-020D standard-MSL, level 1.
2. Temperature and humidity conditions: Less than 40℃ and 60% RH.
3. Recommended products should be used within 12 months form the time of delivery.
4. The packaging material should be kept where no chlorine or sulfur exists in the air.
‧Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are minimized.
P7
TAIPAQ
10. Typical Performance Curves
TMPC1004H-R15
0.3
120
0.3
96
0.24
TMPC1004H-R19
100
TMPC1004H-R22
0.4
100
90
0.24
80
80
0.12
48
0.06
24
0.18
60
0.12
40
0.06
TEMP. RISE(oC)
72
TEMP. RISE(oC)
INDUCTANCE (uH)
0.18
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
0.3
60
0.2
50
40
30
0.1
24
36
48
28
DC CURRENT(A)
0.32
100
0.4
80
0.32
TMPC1004H-R27
60
0.16
40
45
60
TMPC1004H-R30
0.5
80
TEMP. RISE(oC)
INDUCTANCE (uH)
0.24
30
DC CURRENT(A)
60
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
56
DC CURRENT(A)
TMPC1004H-R24
0.4
42
0.24
40
0.16
100
0.4
80
0.3
60
0.2
40
0.1
TEMP. RISE(oC)
24
36
48
12
24
36
48
100
TMPC1004H-R39
0.8
100
80
0.4
50
40
30
0.2
70
60
0.4
50
40
30
10
60
0.4
50
40
30
10
30
45
18
DC CURRENT(A)
TMPC1004H-R47
0.8
70
DC CURRENT(A)
100
TMPC1004H-R56
1
27
36
45
DC CURRENT(A)
TMPC1004H-R68
1.5
80
90
100
70
80
0.8
1.2
80
0.9
60
0.6
40
0.3
40
30
50
0.6
40
0.4
30
0.2
TEMP. RISE(oC)
60
0.4
TEMP. RISE(oC)
INDUCTANCE (uH)
60
70
TEMP. RISE(oC)
INDUCTANCE (uH)
0.6
INDUCTANCE (uH)
80
0.2
100
90
0.2
0.6
TEMP. RISE(oC)
INDUCTANCE (uH)
60
48
80
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
70
36
TMPC1004H-R45
0.8
0.6
30
24
90
0.6
15
12
DC CURRENT(A)
90
DC CURRENT(A)
TMPC1004H-R36
0.8
DC CURRENT(A)
TEMP. RISE(oC)
0.08
10
10
18
27
36
8
16
24
32
7.8
15.6
100
1.5
80
1.2
23.4
31.2
39
DC CURRENT(A)
DC CURRENT(A)
TMPC1004H-R75
1
DC CURRENT(A)
TMPC1004H-R88
120
TMPC1004H-1R0
2
100
90
80
60
0.4
40
0.9
60
0.6
1.5
TEMP. RISE(oC)
INDUCTANCE (uH)
0.6
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
90
30
0.2
60
1
50
40
30
TEMP. RISE(oC)
0.8
0.5
0.3
16
24
32
DC CURRENT(A)
22.8
30.4
DC CURRENT(A)
TMPC1004H-1R2
2
15.2
150
3
120
18
27
36
DC CURRENT(A)
TMPC1004H-1R5
TMPC1004H-1R8
150
2.7
150
2.4
120
2.16
120
1.8
90
1.62
90
1.2
60
1.08
60
0.6
30
0.54
30
0.5
30
13.2
19.8
DC CURRENT(A)
26.4
33
13.2
19.8
DC CURRENT(A)
26.4
33
12
18
DC CURRENT(A)
24
30
TEMP. RISE(oC)
60
TEMP. RISE(oC)
INDUCTANCE (uH)
90
1
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
1.5
P8
TAIPAQ
TMPC1004H-2R2
4
TMPC1004H-2R5
TMPC1004H-3R0
70
5
4
56
4
56
3
42
3
42
2
28
2
28
1
14
1
14
80
70
50
2
40
30
1
TEMP. RISE(oC)
INDUCTANCE (uH)
60
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
3
TEMP. RISE(oC)
70
13.5
20.25
5
10
TMPC1004H-3R3
6
15
4.2
TMPC1004H-3R9
6
80
8.4
12.6
16.8
21
DC CURRENT(A)
DC CURRENT(A)
DC CURRENT(A)
150
TMPC1004H-4R0
6
150
70
3
40
30
1.5
120
120
4.5
3.6
90
2.4
60
TEMP. RISE(oC)
50
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
60
TEMP. RISE(oC)
INDUCTANCE (uH)
4.8
4.5
90
3
60
1.5
30
30
10
10
15
7.6
TMPC1004H-4R7
8
11.4
15.2
TMPC1004H-5R6
10
80
40
30
2
50
6
40
4
30
2
8
80
6
60
4
40
2
3.5
7
10.5
2.74
TMPC1004H-6R5
100
TMPC1004H-6R8
12
5.48
8.22
10.96
13.7
DC CURRENT(A)
DC CURRENT(A)
DC CURRENT(A)
11
100
10
10
8.5
18
60
TEMP. RISE(oC)
INDUCTANCE (uH)
50
4
10.8
70
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
60
7.2
TMPC1004H-6R2
10
80
8
6
4.25
3.6
DC CURRENT(A)
70
DC CURRENT(A)
DC CURRENT(A)
TEMP. RISE(oC)
TMPC1004H-7R3
10
80
100
70
80
60
4.4
40
50
6
40
30
3
2.2
80
6
60
4
40
2
TEMP. RISE(oC)
6.6
8
60
TEMP. RISE(oC)
INDUCTANCE (uH)
9
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
8.8
3
6
9
12
3.375
6.75
10.125
2.8
80
TMPC1004H-100
8.4
11.2
80
70
TMPC1004H-150
30
100
90
70
24
50
8
40
30
4
15
60
50
10
40
30
5
TEMP. RISE(oC)
INDUCTANCE (uH)
60
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
12
70
18
60
50
12
40
30
10
6.25
9.375
3
6
9
TMPC1004H-180
50
12
40
30
50
30
10
6
6.75
9
100
40
80
30
60
10
10
DC CURRENT(A)
10
60
TEMP. RISE(oC)
INDUCTANCE (uH)
60
TEMP. RISE(oC)
INDUCTANCE (uH)
18
6
70
30
70
4
TMPC1004H-270
50
80
80
2.25
2
DC CURRENT(A)
TMPC1004H-220
40
100
24
DC CURRENT(A)
90
INDUCTANCE (uH)
10
DC CURRENT(A)
30
DC CURRENT(A)
DC CURRENT(A)
TMPC1004H-8R2
16
DC CURRENT(A)
TEMP. RISE(oC)
3.5
DC CURRENT(A)
5.25
7
2.4
3.6
DC CURRENT(A)
4.8
6
TEMP. RISE(oC)
P9
TAIPAQ
80
TMPC1004H-470
60
70
100
48
56
80
36
42
24
28
12
14
TMPC1004H-680
80
70
70
40
40
60
TEMP. RISE(oC)
INDUCTANCE (uH)
50
30
TEMP. RISE(oC)
INDUCTANCE (uH)
INDUCTANCE (uH)
60
50
60
40
40
30
10
2
3
4
DC CURRENT(A)
96
60
72
40
48
1.4
2.1
DC CURRENT(A)
2.8
3.5
TEMP. RISE(oC)
INDUCTANCE (uH)
120
80
3
DC CURRENT(A)
TMPC1004H-820
100
1
4
5
1.2
1.8
DC CURRENT(A)
2.4
3
TEMP. RISE(oC)
TMPC1004H-330
50
很抱歉,暂时无法提供与“TMPC1004H-5R6MG-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.82172
- 50+2.28420
- 150+2.05384
