CMLB177T-680MS
CMLB177T-680MS
    CYNTEC(乾坤)
    IND_17.15X17.15MM_SM
    功率电感 68µH ±20% IND_17.15X17.15MM_SM 6.80mm 13.45 x 12.60mm 85mΩ 4.7A
CMLB177T-680MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB177T-000 REVISION : A5 PAGE : 1 OF 4 Power Choke Coil CMLB177T type  Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 7.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions A' L B B' W H  A T Code Dimensions (mm) L 17.15  0.35 W 17.15max T 6.8  0.2 A 2.5  0.5 A’ 3.5  0.1 B 12.0  0.3 B’ 13.0  0.5 H 0 ~ +0.3 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 12.8 B 11.2 C 18.2 Unit : mm Jan., 2022 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB177T-000 REVISION : A5 PAGE : 2 OF 4 Specifications L0 Inductance ( H ) @ (0A) Typical Maximum Typical Maximum Typical Maximum CMLB177T-2R2MS 2.2 2.10 2.50 37.0 30.0 38.0 33.0 CMLB177T-3R3MS 3.3 3.40 3.95 29.0 26.0 30.0 26.0 CMLB177T-4R7MS 4.7 4.00 4.60 27.0 24.0 28.0 24.0 CMLB177T-6R8MS 6.8 6.50 7.50 21.0 19.0 25.0 22.0 CMLB177T-8R2MS 8.2 8.00 8.60 16.0 15.0 22.0 20.0 CMLB177T-100MS 10.0 9.20 9.90 14.0 13.0 20.0 18.5 CMLB177T-150MS 15.0 13.8 15.3 12.0 11.0 15.5 13.5 CMLB177T-200MS 20.0 19.4 21.9 9.7 8.7 13.0 11.0 CMLB177T-220MS 22.0 20.0 23.0 9.7 8.7 12.0 10.5 CMLB177T-330MS 33.0 32.0 37.0 9.2 8.0 10.5 8.6 CMLB177T-470MS 47.0 40.0 47.0 6.8 6.0 8.5 7.5 CMLB177T-680MS 68.0 73.0 85.0 5.2 4.7 8.0 6.8 CMLB177T-101MS 100.0 110.0 130.0 3.7 3.3 6.0 5.0 Part Number Rdc ( m ) Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) *: If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △ T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Jan., 2022 CYNTEC CO., LTD. 乾坤科技股份有限公司  : CMLB177T-000 REVISION : A5 PAGE : 3 OF 4 Current Characteristic 80 3.50 60 INDUCTANCE(μH) 40 TEMP. RISE(℃) 20 0.45 0.00 0 5 10 15 20 25 30 35 40 45 50 60 2.10 INDUCTANCE(μH) 1.40 20 0.70 0.00 55 0 0 5 10 15 DC BIAS(Amps) 100 60 INDUCTANCE(μH) 40 TEMP. RISE(℃) 20 1.00 0.00 INDUCTANCE(μH) 4.00 4 8 12 16 20 24 28 32 100 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 2.80 20 1.40 0 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 DC BIAS(Amps) CMLB177T-8R2MS CMLB177T-100MS 12.0 100 100 80 6.80 5.10 INDUCTANCE(μH) 60 TEMP. RISE(℃) 40 3.40 20 1.70 INDUCTANCE(μH) 10.0 8.50 TEMP. RISE(℃) INDUCTANCE(μH) 45 80 4.20 36 0.00 4 8 12 16 20 24 80 8.0 60 6.0 40 4.0 INDUCTANCE(μH) 0 0 28 2 4 6 8 10 CMLB177T-150MS 12.0 60 9.0 40 INDUCTANCE(μH) 20 TEMP. RISE (℃) 0.0 0 0 2 4 6 8 10 12 14 16 DC BIAS(Amps) 18 20 22 24 26 TEMP. RISE(℃) 80 INDUCTANCE(μH) 15.0 3.0 14 16 18 20 22 24 26 CMLB177T-200MS 24.0 100 6.0 12 DC BIAS(Amps) DC BIAS(Amps) 18.0 20 TEMP. RISE(℃) 2.0 0.0 0 0 INDUCTANCE(μH) 40 5.60 DC BIAS(Amps) 10.20 35 0.00 0 0 30 7.00 80 2.00 25 CMLB177T-6R8MS 8.40 TEMP. RISE(℃) INDUCTANCE(μH) 5.00 3.00 20 DC BIAS(Amps) CMLB177T-4R7MS 6.00 40 TEMP. RISE(℃) TEMP. RISE(℃) 0 80 2.80 TEMP. RISE(℃) 0.90 100 100 20.0 80 16.0 60 INDUCTANCE(μH) 12.0 TEMP. RISE (℃) 40 8.0 TEMP. RISE(℃) 1.35 CMLB177T-3R3MS TEMP. RISE(℃) 1.80 4.20 INDUCTANCE(μH) 2.25 100 TEMP. RISE(℃) CMLB177T-2R2MS 2.70 INDUCTANCE(μH) DOCUMENT 20 4.0 0.0 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 DC BIAS(Amps) Jan., 2022 TEMP. RISE (℃) 40 9.0 20 4.5 0.0 2 4 6 8 10 DC BIAS(Amps) 12 14 CMLB177T-470MS 60.0 INDUCTANCE(μH) 50.0 20 10.0 0.0 1 2 3 4 5 6 7 8 9 10 40 20 7.0 0 1.5 3.0 4.5 6.0 7.5 DC BIAS(Amps) 9.0 10.5 12.0 CMLB177T-680MS 100 80 56.0 60 INDUCTANCE(μH) 42.0 TEMP. RISE(℃) 40 28.0 20 14.0 0.0 0 0 11 1 2 3 4 5 6 7 8 9 10 DC BIAS(Amps) CMLB177T-101MS 100 100.0 80 80.0 60 60.0 40 40.0 INDUCTANCE(μH) 20.0 TEMP. RISE(℃) INDUCTANCE(μH) 60 70.0 DC BIAS(Amps) 120.0 100 80 0.0 0 0 CMLB177T-330MS TEMP. RISE (℃) 84.0 40 TEMP. RISE (℃) 20.0 : 4 OF 4 14.0 100 INDUCTANCE(μH) PAGE INDUCTANCE(μH) 0.0 60 30.0 : A5 21.0 0 80 40.0 REVISION 28.0 16 INDUCTANCE(μH) 0 : CMLB177T-000 TEMP. RISE(℃) 60 INDUCTANCE(μH) 13.5 80 35.0 INDUCTANCE(μH) 18.0 42.0 TEMP. RISE(℃) INDUCTANCE(μH) 22.5 100 TEMP. RISE(℃) CMLB177T-220MS 27.0 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 TEMP. RISE(℃) 0.0 0 0 1 2 3 4 5 6 7 8 DC BIAS(Amps) Jan., 2022
CMLB177T-680MS 价格&库存
很抱歉,暂时无法提供与“CMLB177T-680MS”相匹配的价格&库存,您可以联系我们找货
