CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLB177T-000
REVISION
: A5
PAGE
: 1 OF 4
Power Choke Coil CMLB177T type
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 7.0mm
Low loss realized with low DCR
Capable of corresponding high frequency (1MHz)
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Thin type on-board power supply module for exchanger
VRM for server
Outline Dimensions
A'
L
B B'
W
H
A
T
Code
Dimensions (mm)
L
17.15 0.35
W
17.15max
T
6.8 0.2
A
2.5 0.5
A’
3.5 0.1
B
12.0 0.3
B’
13.0 0.5
H
0 ~ +0.3
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
12.8
B
11.2
C
18.2
Unit : mm
Jan., 2022
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLB177T-000
REVISION
: A5
PAGE
: 2 OF 4
Specifications
L0
Inductance
( H )
@ (0A)
Typical
Maximum
Typical
Maximum
Typical
Maximum
CMLB177T-2R2MS
2.2
2.10
2.50
37.0
30.0
38.0
33.0
CMLB177T-3R3MS
3.3
3.40
3.95
29.0
26.0
30.0
26.0
CMLB177T-4R7MS
4.7
4.00
4.60
27.0
24.0
28.0
24.0
CMLB177T-6R8MS
6.8
6.50
7.50
21.0
19.0
25.0
22.0
CMLB177T-8R2MS
8.2
8.00
8.60
16.0
15.0
22.0
20.0
CMLB177T-100MS
10.0
9.20
9.90
14.0
13.0
20.0
18.5
CMLB177T-150MS
15.0
13.8
15.3
12.0
11.0
15.5
13.5
CMLB177T-200MS
20.0
19.4
21.9
9.7
8.7
13.0
11.0
CMLB177T-220MS
22.0
20.0
23.0
9.7
8.7
12.0
10.5
CMLB177T-330MS
33.0
32.0
37.0
9.2
8.0
10.5
8.6
CMLB177T-470MS
47.0
40.0
47.0
6.8
6.0
8.5
7.5
CMLB177T-680MS
68.0
73.0
85.0
5.2
4.7
8.0
6.8
CMLB177T-101MS
100.0
110.0
130.0
3.7
3.3
6.0
5.0
Part Number
Rdc ( m )
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
*: If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △ T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to +125℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Jan., 2022
CYNTEC CO., LTD.
乾坤科技股份有限公司
: CMLB177T-000
REVISION
: A5
PAGE
: 3 OF 4
Current Characteristic
80
3.50
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
0.00
10
15
30
35
40
45
50
60
2.10
INDUCTANCE(μH)
1.40
0.00
55
10
15
DC BIAS(Amps)
100
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
0.00
INDUCTANCE(μH)
4.00
4
8
12
16
28
32
100
60
INDUCTANCE(μH)
TEMP. RISE(℃)
40
2.80
4
6
8 10 12 14 16 18 20 22 24 26 28 30 32
DC BIAS(Amps)
CMLB177T-8R2MS
CMLB177T-100MS
12.0
100
100
80
6.80
5.10
INDUCTANCE(μH)
60
TEMP. RISE(℃)
40
3.40
INDUCTANCE(μH)
10.0
8.50
TEMP. RISE(℃)
INDUCTANCE(μH)
45
80
4.20
36
0.00
4
8
12
16
80
8.0
60
6.0
40
4.0
INDUCTANCE(μH)
2
4
6
8
10
CMLB177T-150MS
12.0
60
9.0
40
INDUCTANCE(μH)
TEMP. RISE (℃)
0.0
4
6
8
10
12
14
16
DC BIAS(Amps)
18
24
26
TEMP. RISE(℃)
80
INDUCTANCE(μH)
15.0
3.0
14
16
18
24
26
CMLB177T-200MS
24.0
100
6.0
12
DC BIAS(Amps)
DC BIAS(Amps)
18.0
TEMP. RISE(℃)
2.0
0.0
INDUCTANCE(μH)
40
5.60
DC BIAS(Amps)
10.20
35
0.00
7.00
80
2.00
25
CMLB177T-6R8MS
8.40
TEMP. RISE(℃)
INDUCTANCE(μH)
5.00
3.00
DC BIAS(Amps)
CMLB177T-4R7MS
6.00
40
TEMP. RISE(℃)
TEMP. RISE(℃)
2.80
TEMP. RISE(℃)
0.90
100
100
20.0
80
16.0
60
INDUCTANCE(μH)
12.0
TEMP. RISE (℃)
40
8.0
TEMP. RISE(℃)
1.35
CMLB177T-3R3MS
TEMP. RISE(℃)
1.80
4.20
INDUCTANCE(μH)
2.25
100
TEMP. RISE(℃)
CMLB177T-2R2MS
2.70
INDUCTANCE(μH)
DOCUMENT
0.0
2
3
4
5
6
7 8 9 10 11 12 13 14 15 16 17
DC BIAS(Amps)
Jan., 2022
TEMP. RISE (℃)
40
9.0
0.0
2
4
6
8
10
DC BIAS(Amps)
12
14
CMLB177T-470MS
60.0
INDUCTANCE(μH)
50.0
0.0
1
2
3
4
5
6
7
8
9
10
40
3.0
4.5
6.0
7.5
DC BIAS(Amps)
9.0
10.5
12.0
CMLB177T-680MS
100
80
56.0
60
INDUCTANCE(μH)
42.0
TEMP. RISE(℃)
40
28.0
0.0
1
2
3
4
5
6
7
8
9
10
DC BIAS(Amps)
CMLB177T-101MS
100
100.0
80
80.0
60
60.0
40
40.0
INDUCTANCE(μH)
20.0
TEMP. RISE(℃)
INDUCTANCE(μH)
60
70.0
DC BIAS(Amps)
120.0
100
80
0.0
CMLB177T-330MS
TEMP. RISE (℃)
84.0
40
TEMP. RISE (℃)
20.0
: 4 OF 4
14.0
100
INDUCTANCE(μH)
PAGE
INDUCTANCE(μH)
0.0
60
30.0
: A5
21.0
40.0
REVISION
28.0
16
INDUCTANCE(μH)
: CMLB177T-000
TEMP. RISE(℃)
60
INDUCTANCE(μH)
13.5
80
35.0
INDUCTANCE(μH)
18.0
42.0
TEMP. RISE(℃)
INDUCTANCE(μH)
22.5
100
TEMP. RISE(℃)
CMLB177T-220MS
27.0
DOCUMENT
TEMP. RISE(℃)
CYNTEC CO., LTD.
乾坤科技股份有限公司
TEMP. RISE(℃)
0.0
2
3
4
5
6
7
8
DC BIAS(Amps)
Jan., 2022
很抱歉,暂时无法提供与“CMLB177T-4R7MS”相匹配的价格&库存,您可以联系我们找货
