CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 1 OF 9
The history of revision change for the specification
Document
REV.
Modified date
CYNVC-175-016
A0
2017.5.19
CYNVC-175-016
A1
2017.6.19
CYNVC-175-016
A2
2017.10.31
CYNVC-175-016
A3
2018.3.13
CYNVC-175-016
A4
2018.10.23
CYNVC-175-016
A5
2019.9.20
CYNVC-175-016
A6
2020.1.22
CYNVC-175-016
A7
2020.6.15
CYNVC-175-016
A8
2020.9.9
CYNVC-175-016
A9
2020.12.2
CYNVC-175-016
B0
2021.6.17
Description
New approval
1. May -> Jun.
2. Add spec & curve of R47, R68
1. Jun. -> Oct.
2. Add spec & curve of R33
1. Oct., 2017 -> Mar., 2018
2. Add “AEC-Q200” logo on page 2
1. Mar. -> Oct.
2. Remove spec & curve of R40, R60
1. Oct., 2018 -> Sep., 2019
2. Add spec & curve of R40, R60
1. Sep., 2019 -> Jan., 2020
2. Year code: 2019 = 9 -> 2020 = 0
1. Jan. -> Jun.
2. Add rated voltage
1. Jun. -> Sep.
2. Update Land Pattern B: 2.2 -> 1.5 ; C: 5.2 -> 5.18
1. Sep. -> Dec.
2. Add spec & curve of R22
1. Dec.,2020 -> Jun., 2021
2. Add spec & curve of R10
3. Update R22, R33, R40, R47, R68 curve
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 2 OF 9
Power Choke Coil VCHA042A MS6 type
AEC-Q200
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 2.1mm
Low loss realized with low DCR
Compliance with RoHS and Halogen Free
AEC-Q200 qualified
Application
Automotive applications
Outline Dimensions
L
Code
W
B
A1
H
Dimensions (mm)
L
4.2 0.3
W
4.0 0.3
T
2.1 Max.
A1
0.8 0.3
B
3.0 0.3
H
0 ~ + 0.15
T
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
3.50
B
1.50
C
5.18
Unit : mm
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 3 OF 9
Marking
The point on the top surface represents winding direction of choke.
Marking
The inductor is marked with a 3-digit code
Example – – 4.7H 4R7
Upside of Chip
PIN 2
4R7
PIN 1
Coil clockwise around
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 4 OF 9
Specifications
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
Maximum
1.90
2.28
21.0
18.9
25.0
21.4
50
0.22
5.3
6.4
11.4
10.3
13.7
11.7
50
VCHA042A-R33MS6
0.33
5.8
7.0
10.9
9.8
13.5
11.5
50
VCHA042A-R40MS6
0.40
6.0
7.2
10.7
9.6
12.6
10.8
50
VCHA042A-R47MS6
0.47
6.3
7.6
10.6
9.5
10.9
9.4
50
VCHA042A-R60MS6
0.60
8.1
9.3
12.1
10.9
10.4
8.9
50
VCHA042A-R68MS6
0.68
8.6
10.3
9.1
8.2
9.5
8.1
50
VCHA042A-1R0MS6
1.0
9.1
10.5
8.9
8.0
7.9
6.7
50
VCHA042A-1R5MS6
1.5
13.4
15.4
7.3
6.5
6.2
5.3
50
VCHA042A-2R2MS6
2.2
20.9
23.0
5.8
5.3
5.3
4.5
50
VCHA042A-3R3MS6
3.3
33.4
36.8
4.6
4.1
4.0
3.4
50
VCHA042A-4R7MS6
4.7
48.6
53.8
4.0
3.6
3.7
3.2
40
VCHA042A-5R6MS6
5.6
61.8
71.1
3.4
3.0
2.9
2.5
40
VCHA042A-6R8MS6
6.8
80.5
92.5
2.9
2.6
2.6
2.2
40
VCHA042A-8R2MS6
8.2
103.0
118.5
2.6
2.3
2.5
2.1
40
VCHA042A-100MS6
10.0
112.0
129.0
2.5
2.2
2.4
2.0
40
L0 ◇
Inductance
( H )
@ (0A)
Typical
VCHA042A-R10MS6
0.10
VCHA042A-R22MS6
Part Number
Rdc ( m ) ◇
Rated Voltage
(V)
◇:Significant Characteristic
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to +165℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 165℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other
cooling provision all affect the part temperature. Part temperature should be verified in the end
application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which
value is lower.
Note 8.: Cleaning Process Note
(a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether
system, there is a possibility that the performance decreases greatly
(b) The high power ultrasonic washing may damage the choke body.
(c) Please contact us if you need the cleaning via the above agents or ultrasonic washing.
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
: CYNVC-175-016
REVISION
: B0
PAGE
: 5 OF 9
Current Characteristic
80
0.08
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
3
6
9
0.16
TEMP. RISE(℃)
12 15 18 21 24 27 30 33 36 39
4
6
8
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
INDUCTANCE(μH)
0.28
TEMP. RISE(℃)
INDUCTANCE(μH)
80
3
6
9
12
15
0.40
60
0.30
INDUCTANCE(μH)
0.20
2
4
6
8
INDUCTANCE(μH)
40
TEMP. RISE(℃)
INDUCTANCE(μH)
60
4
6
8
10
12
14
60
TEMP. RISE(℃)
40
4
6
8
10
DC BIAS(Amps)
18
14
16
100
80
60
0.36
INDUCTANCE(μH)
0.24
TEMP. RISE(℃)
40
4
6
8
10
12
DC BIAS(Amps)
14
16
18
VCHA042A-1R0MS6
1.20
INDUCTANCE(μH)
0.56
TEMP. RISE(℃)
INDUCTANCE(μH)
80
0.28
16
0.48
0.70
INDUCTANCE(μH)
14
0.00
16
VCHA042A-R68MS6
0.42
12
0.60
DC BIAS(Amps)
0.84
10
VCHA042A-R60MS6
0.72
100
0.40
TEMP. RISE(℃)
40
TEMP. RISE(℃)
0.20
100
DC BIAS(Amps)
0.50
INDUCTANCE(μH)
18
80
18
VCHA042A-R47MS6
0.30
16
0.50
DC BIAS(Amps)
0.60
14
0.10
VCHA042A-R40MS6
0.60
100
0.35
0.14
10
DC BIAS(Amps)
VCHA042A-R33MS6
0.21
40
0.08
DC BIAS(Amps)
0.42
60
INDUCTANCE(μH)
0.12
TEMP. RISE(℃)
0.04
0.20
TEMP. RISE(℃)
0.04
100
100
1.00
80
0.80
60
0.60
INDUCTANCE(μH)
0.40
TEMP. RISE(℃)
40
TEMP. RISE(℃)
0.06
INDUCTANCE(μH)
TEMP. RISE(℃)
0.10
VCHA042A-R22MS6
0.24
100
TEMP. RISE(℃)
VCHA042A-R10MS6
0.12
INDUCTANCE(μH)
DOCUMENT
0.00
4
6
8
10
DC BIAS(Amps)
12
14
16
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
TEMP. RISE(℃)
40
2
3
4
4.20
5
6 7 8 9
DC BIAS(Amps)
3.50
2.80
INDUCTANCE(μH)
1.40
TEMP. RISE(℃)
0.00
6.00
80
5.00
0.6
1.2
1.8
2.4
3.0
3.6
4.2
4.8
5.4
6.0
2.40
TEMP. RISE(℃)
1.0
1.5
2.5 3.0 3.5
DC BIAS(Amps)
4.0
4.5
5.0
80
6.40
60
4.80
INDUCTANCE(μH)
3.20
TEMP. RISE(℃)
40
0.0
0.5
1.0
1.5
2.0
2.5
DC BIAS(Amps)
3.0
3.5
4.0
10
100
80
60
40
VCHA042A-6R8MS6
80
5.60
60
4.20
INDUCTANCE(μH)
2.80
TEMP. RISE(℃)
40
0.5
1.0
12.0
100
8.00
9
0.00
5.5
VCHA042A-8R2MS6
9.60
INDUCTANCE(μH)
2.0
INDUCTANCE(μH)
0.5
8
1.40
7
VCHA042A-4R7MS6
TEMP. RISE(℃)
7.00
40
1.20
4
5
6
DC BIAS(Amps)
2.00
80
INDUCTANCE(μH)
INDUCTANCE(μH)
3
INDUCTANCE(μH)
8.40
60
3.60
2
3.00
100
TEMP. RISE(℃)
4.80
0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
DC BIAS(Amps)
TEMP. RISE(℃)
INDUCTANCE(μH)
6.00
6.6
VCHA042A-5R6MS6
40
4.00
DC BIAS(Amps)
7.20
TEMP. RISE(℃)
1.00
60
INDUCTANCE(μH)
0.40
100
80
100
0.80
0.00
60
2.10
VCHA042A-2R2MS6
1.20
10 11 12 13 14
VCHA042A-3R3MS6
: 6 OF 9
1.60
PAGE
TEMP. RISE(℃)
0.60
: B0
TEMP. RISE(℃)
INDUCTANCE(μH)
INDUCTANCE(μH)
0.90
REVISION
TEMP. RISE(℃)
2.00
60
0.30
INDUCTANCE(μH)
80
: CYNVC-175-016
1.5
2.0
2.5
DC BIAS(Amps)
3.0
3.5
4.0
100
VCHA042A-100MS6
10.0
80
8.0
60
6.0
INDUCTANCE(μH)
4.0
TEMP. RISE(℃)
40
TEMP . RISE(℃)
1.20
2.40
INDUCTANCE(μH)
1.50
100
TEMP. RISE(℃)
VCHA042A-1R5MS6
TEMP. RISE(℃)
INDUCTANCE(μH)
1.80
DOCUMENT
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
DC BIAS(Amps)
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 7 OF 9
Packaging
(1) Tape packaging dimensions
t
+0.1
1.5-0.0
4.0 ± 0.1
Sprocket hole
2.0 ± 0.1
1.75 ± 0.10
5.5 ± 0.1
B0
8.0 ± 0.1
A0
Carrier cavity
K0
12.0 ± 0.3
Pulling direction
Dimensions Code (mm)
UNITS/REEL
A0
B0
K0
t
4.4 0.1
4.7 0.1
2.50 0.15
0.30 0.05
2,000
(2) Tape Direction
The direction shall be seen from the top cover tape side.
4R7
4R7
Pulling direction
Jun., 2021 Issued
4R7
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 8 OF 9
2.0 ± 0.5
20.0 ± 0.5
B
330.0 ± 2.0
100.0 ± 1.0
(3) Reel dimensions
A
13.0 ± 1.0
mm
A
B
12.5 0.5
2.0 0.2
(4) Peel force of top cover tape
The peel speed shall be about 300 mm/minute.
The peel force of top cover tape shall be between 0.1 to 1.3N.
Top Cover Tape
165 ~ 180°
0.1 ~ 1.3N
Carrier tape
Jun., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-016
REVISION
: B0
PAGE
: 9 OF 9
Reflow Profile
Power Choke Coil Type
Tp
Temperature
260℃
tp:30 Sec max.
Max. Ramp Up Rate =3℃/s
Max. Ramp Down Rate =6℃/s
217℃
60~150 Sec
Preheat Area
200℃
150℃
60~120 Sec
25℃
25°C to Peak ( 8 minutes max.)
Time
(1) Reflow Soldering Method :
Reflow Soldering
Tp:255~260℃
Max.30 seconds ( tp )
217℃
60~150 seconds
Pre-Heat
150 ~ 200℃
60~120 seconds
Time 25℃ to peak temperature
8 minutes max.
(2) Soldering iron Method : 350 5℃ max.3 seconds
Jun., 2021 Issued
很抱歉,暂时无法提供与“VCHA042A-R10MS6”相匹配的价格&库存,您可以联系我们找货
