UJ471M450O450A
UJ471M450O450A
    CAPXON(台湾丰宾)
    插件,D30xL45mm
    直插铝电解电容 插件,D30xL45mm 470µF ±20% Ф30.00 x 45.00mm 450V 310mΩ 2.05A 5000Hrs@105℃
UJ471M450O450A 数据手册
UJ Series UJ Series 105℃ Features Standard capacitors Applications ◆ Professional power supplies ◆ Frequency converters ◆ Uninterruptible power supplies ◆ Used for air conditioner,generalpurpose inverter Features ◆ High reliability ◆ Long useful life ◆ High ripple current capability ◆ Aluminum case designed explosion-proof vent ◆ RoHS-compatible Construction ◆ Charge-discharge proof, polar ◆ Aluminum case with insulating sleeve ◆ Aluminum case designed explosion-proof vent ◆ Snap-in solder pins to hold component in place on PC-board Specifications Performance Characteristics Item For inverter Operating Temperature Range -40 to +105℃ -25 to +105℃ Rated voltage VR 200 to 450 V DC 500 to 550 V DC Surge voltage VS VR 315V 1.10 VR 82 ~ 3300 µF Rated capacitance CR I≦3 CV (µA)After 5minutes with rated working voltage applied Less than the value under table(%) W.V.(V) D.F.(%) max 160~420 450~550 15 20 approx. 20 nH Requirements: Useful life 105℃; VR,IAC,R >5000 h ≤±20% of initial value ≤2 times initial specified limit ≤ initial specified limit △C/C tanδ Ileak Post test requirements: Voltage Endurance test 105℃; VR 2000 h ≤±10% of initial value ≤1.3 times initial specified limit ≤ initial specified limit △C/C tanδ Ileak Post test requirements: Shelf Life 105℃ 1000 h ≤±10% of initial value ≤1.3 times initial specified limit ≤ initial specified limit △C/C tanδ Ileak To IEC 60068-2-6, test Fc: Vibration Resistance test Displacement amplitude 0.75 mm, frequency range 10 ... 55 Hz, acceleration max. 10 g, duration 3x2 h. Capacitor mounted by its body which is rigidly clamped to the work surface. Max. impedance ratio at 120 Hz Characteristics at low temperature Sectional specification VR(V) Z-25℃ / Z 20℃ Z-40℃ / Z 20℃ 200-250 V 4 7 315-450 V 5 10 500~550 V 6 - IEC 60384-4 and JIS-C-5101 Multiplier for Ripple Current vs. Frequency VR(V)/Frequency(Hz) 160≤VR≤250 315≤VR≤600 50(60) 0.81 0.77 120 1 1 300 1.17 1.16 1K 1.32 1.30 10K 1.45 1.41 334 50K-100K 1.5 1.43 UJ Series Dimensional drawings 1. Standard 2 terminals Standard snap-in terminals:length(6.0±1)mm Also available with length of(4.0±1)mm H 6 4 h 2.5 1.5 2. Vibration proof terminal T type Standard terminals:Length 4.5±1mm.Also available with length of 5.5±1mm Packing Capacitor diameter D(mm) 20 22 22 25 25 30 30 30 35 35 35 35 40 40 40 40 40 45 45 Length L(mm) all <55 ≧55 <65 ≧65 ≤36 35≤L≤65 >65 ≤25 25<L<45 45≤L≤85 >85 35 35 40≤L≤45 45<L≤75 >75 40≤L≤65 65<L≤100 Terminal length H(mm) / / / / / <6(L=35、36) ≧6(L=35、36) / / / / / <6 ≧6 / / / / / Each carton packing Qty units(pcs.) 720 600 400 500 400 400 300 200 400 300 200 100 200 160 160 120 80 140 70 335 Box/carton units(pcs.) 6 6 4 5 4 8 6 4 8 6 4 2 5 4 4 3 2 4 2 Each box packing Qty units(pcs.) 120 100 100 100 100 50 50 50 50 50 50 50 40 40 40 40 40 35 35 UJ Series Packing of snap-in Case Size WV (Vdc) Cap (uF) Size (mm) 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 200 250 250 250 250 250 250 250 330 390 390 390 470 470 470 560 560 560 680 680 680 820 820 820 1000 1000 1000 1000 1200 1200 1200 1500 1500 1500 1800 1800 2200 2200 2700 3300 220 270 330 390 390 470 470 22x25 22x25 22x30 25x25 22x30 25x25 25x30 22x35 25x30 30x25 22x40 25x30 30x25 22x45 25x35 30x30 22x50 25x40 30x30 35x25 25x45 30x35 35x30 25x55 30x40 35x35 30x45 35x35 30x55 35x45 35x50 35x55 22x25 22x25 22x30 22x35 25x25 22x35 25x30 Rated Ripple Typ. ESR MAX ESR current 20℃ 120Hz 20℃ 120Hz (Arms/105℃ (mΩ) (mΩ) /120Hz) 1.13 330 600 1.21 280 510 1.25 280 510 1.31 280 510 1.40 230 420 1.40 230 420 1.52 230 420 1.61 200 360 1.61 200 360 1.62 200 360 1.86 160 290 1.69 160 290 1.98 160 290 2.14 130 240 2.14 130 240 2.29 130 240 2.48 110 200 2.48 110 200 2.52 110 200 2.44 110 200 2.89 94 170 2.89 94 170 3.03 94 170 3.52 72 130 3.59 72 130 3.52 72 130 4.09 61 110 3.77 61 110 4.82 50 90 4.82 50 90 5.16 41 74 5.85 33 60 0.91 500 900 1.03 410 740 1.20 330 600 1.37 280 510 1.26 280 510 1.53 230 420 1.53 230 420 336 WV (Vdc) Cap (uF) Size (mm) 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 350 350 350 350 350 350 350 350 350 350 350 350 350 350 350 350 350 350 350 350 470 560 560 680 680 680 680 820 820 820 1000 1000 1000 1200 1200 1500 1500 1800 2200 100 120 120 150 180 180 220 220 220 220 270 270 270 330 330 330 390 470 560 560 30x25 22x40 25x35 22x45 25x40 30x30 35x25 25x45 30x35 35x30 25x50 30x40 35x30 30x45 35x35 30x50 35x40 35x45 35x55 22x25 22x30 25x25 22x35 25x30 30x25 22x40 25x40 30x30 35x25 25x45 30x35 35x25 25x50 30x35 35x30 35x40 35x45 35x45 40x40 Rated Ripple Typ. ESR MAX ESR current 20℃ 120Hz 20℃ 120Hz (Arms/105℃ (mΩ) (mΩ) /120Hz) 1.69 230 420 1.76 200 360 1.68 200 360 2.04 160 290 2.13 160 290 2.13 160 290 2.12 160 290 2.23 130 240 2.45 130 240 2.62 130 240 2.57 110 200 2.85 110 200 2.77 110 200 3.42 94 170 3.26 94 170 3.72 72 130 3.78 72 130 4.09 61 110 5.04 50 90 0.59 1110 1990 0.69 920 1660 0.69 920 1660 0.80 740 1330 0.85 620 1110 0.89 620 1110 0.99 500 900 1.10 500 900 1.08 500 900 1.08 500 900 1.28 410 740 1.25 410 740 1.25 410 740 1.55 330 600 1.46 330 600 1.46 330 600 1.92 280 510 2.17 230 420 2.41 200 360 2.46 200 360 UJ Series WV (Vdc) Cap (uF) Size (mm) 350 350 350 350 350 350 350 350 350 350 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 680 680 820 820 820 1000 1000 1200 1500 1800 100 120 150 180 180 220 220 270 270 270 330 330 330 330 390 390 390 390 470 470 470 560 560 560 680 680 820 820 1000 1000 1200 1200 1500 1800 82 100 100 120 150 150 150 180 180 180 220 220 220 330 330 330 35x55 40x45 35x60 40x50 45x40 35x60 40x50 40x55 40x65 40x75 22x25 22x25 22x30 22x30 25x25 22x35 25x30 22x40 25x35 30x25 22x50 25x40 30x30 35x25 22x55 25x45 30x35 35x30 25x50 30x40 35x30 25x60 30x45 35x35 30x50 35x40 30x60 35x45 35x55 40x50 35x60 40x55 45x70 45x80 22x25 22x30 25x25 22x35 22x35 25x30 30x25 22x40 25x30 30x25 22x45 25x35 30x30 22x60 25x50 30x35 Rated Ripple Typ. ESR MAX ESR current 20℃ 120Hz 20℃ 120Hz (Arms/105℃ (mΩ) (mΩ) /120Hz) 2.79 160 290 2.79 160 290 3.21 130 240 3.15 130 240 3.11 130 240 3.23 110 200 3.26 110 200 3.68 94 170 4.56 72 130 5.67 61 110 0.65 1110 1990 0.92 920 1660 1.08 740 1330 1.15 620 1110 1.12 620 1110 1.32 500 900 1.30 500 900 1.50 410 740 1.49 410 740 1.33 410 740 1.76 330 600 1.68 330 600 1.55 330 600 1.44 330 600 1.94 280 510 1.86 280 510 1.75 280 510 1.75 280 510 2.07 230 420 1.97 230 420 1.91 230 420 2.37 200 360 2.18 200 360 1.92 200 360 2.41 160 290 2.35 160 290 2.76 130 240 2.67 130 240 3.16 110 200 3.24 110 200 3.56 94 170 3.64 94 170 4.68 72 130 5.29 61 110 0.59 1790 3230 0.69 1470 2650 0.69 1470 2650 0.72 1230 2210 0.92 980 1770 0.91 980 1770 0.97 980 1770 1.28 820 1470 1.20 820 1470 1.18 820 1470 1.44 670 1210 1.37 670 1210 1.36 670 1210 1.86 440 800 1.82 440 800 1.64 440 800 337 WV (Vdc) Cap (uF) Size (mm) 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 450 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 500 550 550 550 550 550 550 550 550 550 550 550 550 550 550 550 330 390 390 390 470 470 470 560 560 680 680 820 820 1000 1000 1200 56 82 82 120 120 120 150 150 150 150 180 180 180 180 220 220 220 270 270 270 330 330 390 390 470 560 680 820 1000 47 56 68 68 82 82 100 100 100 120 120 120 150 150 150 35x30 25x55 30x40 35x35 25x60 30x45 35x40 30x50 35x45 30x60 35x50 35x60 40x50 35x65 40x55 40x70 22x25 22x35 25x25 22x45 25x35 30x25 22x50 25x40 30x30 35x25 22x60 25x45 30x35 35x30 25x50 30x40 35x35 25x60 30x45 35x35 30x50 35x40 30x60 35x50 35x55 35x60 40x60 40x70 40x80 25x25 25x30 25x35 30x25 25x35 30x30 25x40 30x35 35x25 25x50 30x35 35x30 25x55 30x45 35x35 Rated Ripple Typ. ESR MAX ESR current 20℃ 120Hz 20℃ 120Hz (Arms/105℃ (mΩ) (mΩ) /120Hz) 1.64 440 800 2.01 380 680 1.83 380 680 1.83 380 680 2.21 310 560 2.05 310 560 2.05 310 560 2.26 260 470 2.18 260 470 2.59 220 390 2.58 220 390 2.80 180 320 2.80 180 320 3.21 150 270 3.21 150 270 3.54 120 220 0.63 2630 4740 0.82 1790 3230 0.78 1790 3230 1.05 1230 2210 1.02 1230 2210 0.97 1230 2210 1.20 980 1770 1.17 980 1770 1.13 980 1770 1.09 980 1770 1.37 820 1470 1.31 820 1470 1.28 820 1470 1.26 820 1470 1.46 670 1210 1.45 670 1210 1.44 670 1210 1.70 540 980 1.63 540 980 1.63 540 980 1.81 440 800 1.71 440 800 2.06 380 680 2.06 380 680 2.19 310 560 2.65 260 470 3.00 220 390 4.00 180 320 4.68 150 270 0.47 3130 5640 0.54 2630 4740 0.62 2170 3900 0.65 2170 3900 0.69 1790 3230 0.73 1790 3230 0.80 1470 2650 0.84 1470 2650 0.87 1470 2650 0.92 1230 2210 0.94 1230 2210 1.04 1230 2210 1.09 980 1770 1.17 980 1770 1.21 980 1770 UJ Series I I WV (Vdc) Cap (uF) Size (mm) 550 550 550 550 550 550 180 180 180 220 220 220 30x50 35x35 35x40 30x55 35x35 35x45 Rated Ripple Typ. ESR MAX ESR current 20℃ 120Hz 20℃ 120Hz (Arms/105℃ (mΩ) (mΩ) /120Hz) 1.33 820 1470 1.29 820 1470 1.36 820 1470 1.54 670 1210 1.40 670 1210 1.56 670 1210 WV (Vdc) Cap (uF) Size (mm) 550 550 550 550 550 270 270 330 390 470 35x40 35x50 35x50 35x55 35x60 R C .f R C .1 2 0 H z CapXon UJ Series Useful life Useful life I I a R 2.0 1.5 1.0 0.5 0.0 2.5 2.5 Frequency Impedancecharacteristics Z versus frequency of ESR f Typical behavior Ia IR 2.0 1.5 40 50 60 70 80 Ta(℃) 90 5000H 10000H 20000H 50000H 250000H 0.5 0.0 100000H 1.0 100 110 depending on ambient temperature Ta versus under ripple current operating conditions 338 Rated Ripple Typ. ESR MAX ESR current 20℃ 120Hz 20℃ 120Hz (Arms/105℃ (mΩ) (mΩ) /120Hz) 1.63 540 980 1.79 540 980 1.66 440 800 1.85 380 680 2.10 310 560
UJ471M450O450A 价格&库存
很抱歉,暂时无法提供与“UJ471M450O450A”相匹配的价格&库存,您可以联系我们找货
