AMWSA1003S-8R2MT
AMWSA1003S-8R2MT
    SUNLORD(顺络)
    SMD,11.5x10mm
    功率电感 8.2µH ±20% 1003 3.00mm 11.50 x 10.00mm 45mΩ 4.42A
AMWSA1003S-8R2MT 数据手册
SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 1 of 18 for Automotive Electronics S P E C I F I C AT I O N S Customer Product Name Wire Wound Molded SMD Power Inductors Sunlord Part Number AMWSA -S Series Customer Part Number [ New Released, Revised] SPEC No.: AMWSA03210000 【This SPEC is total 18 pages including specifications and appendix.】 【ROHS, Halogen-Free and SVHC Compliant Parts】 Approved By Checked By Issued By Shenzhen Sunlord Electronics Co., Ltd. Address: Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com 【For Customer approval Only】 Qualification Status: Full Approved By Verified By Comments: Date: Restricted Rejected Re-checked By Checked By SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 2 of 18 【Version change history】 Rev. Effective Date Changed Contents Change Reasons Approved By 01 / New release / Simei Yu SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 3 of 18 Caution: All products listed in this specification are developed, designed and intended for use in general electronics equipment. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require especially high reliability, or whose failure, malfunction or trouble might directly cause damage to society, person, or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below. Please contact us for more details if you intend to use our products in the following applications. 1. Aircraft equipment 2. Aerospace equipment 3. Undersea equipment 4. nuclear control equipment 5. military equipment 6. Power plant equipment 7. Medical equipment 8. Transportation equipment (automobiles, trains, ships,etc.) 9. Traffic signal equipment 10. Disaster prevention / crime prevention equipment 11. Data-processing equipment 12. Applications of similar complexity or with reliability requirements comparable to the applications listed in the above SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 4 of 18 1. 2. Scope This specification applies to AMWSA series of wire wound molded SMD power Inductors Product Description and Identification (Part Number) 1) Description Wire Wound Molded SMD Type Power Inductor. 2) Product Identification (Part Number) AMWSA XXXX -XXX □ T XXX ① ② ③ ④ ⑤ ⑥ ① Type AMWSA ③ ② External Dimensions (mm) Wire wound molded SMD power Inductors 0412S~1707S Nominal Inductance Example 1R0 1.0μH 100 10μH 101 100μH ⑥ ④ Nominal Value Inductance Tolerance M ±20% N ±30% ⑤ Packing T Tape Carrier Package Special code XXX 3. 4. Electrical Characteristics Please refer to Appendix A. 1) Operating temperature range (Including self-heating): -55℃~+155℃. 2) Storage temperature and humidity range (product with tapping ): -10℃~+40℃, RH 70% Max. Shape and Dimensions 1) Dimensions and recommended PCB pattern for reflow soldering: See Fig.4-1 and Table 4-1. Unit: mm Series A B C D E I Typ. J Typ. H Typ. AMWSA0412S 4.2±0.25 4.4±0.35 1.0±0.2 0.8±0.3 2.0±0.3 1.5 2.2 2.5 AMWSA0402S 4.2±0.25 4.4±0.35 1.8±0.2 0.8±0.3 2.0±0.3 1.5 2.2 2.5 AMWSA0518S 5.2±0.2 5.4±0.35 1.6±0.2 1.20±0.2 2.2±0.3 1.9 2.2 2.5 AMWSA0503S 5.2±0.2 5.4±0.35 2.8±0.2 1.20±0.2 2.2±0.3 1.9 2.2 2.5 AMWSA0618S 6.6±0.2 7.0±0.3 1.6±0.2 1.60±0.3 3.0±0.3 2.35 3.7 3.5 AMWSA0602S 6.6±0.2 7.0±0.3 1.8±0.2 1.60±0.3 3.0±0.3 2.35 3.7 3.5 AMWSA0624S 6.6±0.2 7.0±0.3 2.2±0.2 1.60±0.3 3.0±0.3 2.35 3.7 3.5 AMWSA0603S 6.6±0.2 7.0±0.3 2.8±0.2 1.60±0.3 3.0±0.3 2.35 3.7 3.5 AMWSA0604S 6.6±0.2 7.0±0.3 3.8±0.2 1.60±0.3 3.0±0.3 2.35 3.7 3.5 AMWSA0605S 6.6±0.2 7.0±0.3 4.8±0.2 1.60±0.3 3.0±0.3 2.35 3.7 3.5 AMWSA1003S 10.0±0.3 11.5 Max 2.8±0.2 2.0±0.5 3.0±0.3 4.1 5.4 4.1 AMWSA1004S 10.0±0.3 11.0±0.5 3.8±0.2 2.0±0.5 3.0±0.5 4.1 5.4 4.1 AMWSA1005S 10.0±0.3 11.5 Max 4.8±0.2 2.0±0.5 3.0±0.5 4.1 5.4 4.1 AMWSA1204S 12.8±0.5 13.45±0.35 4.0Max. 2.0±0.5 See Remarks 3.25 8.0 5.5 AMWSA1205S 12.6±0.3 13.45±0.35 4.8±0.2 2.0±0.5 See Remarks 3.25 8.0 5.5 AMWSA1206S 12.6±0.3 13.45±0.35 5.8±0.2 2.0±0.5 See Remarks 3.25 8.0 5.5 SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 5 of 18 AMWSA1265S 12.6±0.3 13.45±0.35 6.5Max. 2.0±0.5 5.0±0.3 3.25 8.0 5.5 AMWSA1707S 17.15Max 17.15±0.35 7.0Max 2.5±0.5 12.0±0.3 3.50 11.2 12.8 Remarks: Series E(mm) Dimensions 3.85±0.5 R22/R47 5.0±0.3 R68/R82/1R0/1R5/2R2/3R3/4R7/6R8/100/150/220 3.85±0.5 R22/R36/R50/R68/R82/1R0/1R5/2R2 5.0±0.3 3R3/4R7/6R8/100/150/220/330/470 3.85±0.5 1R5/2R2 5.0±0.3 3R3/4R7/5R6/6R8/8R2/100/120/150/180/220/270/330/470/680/101/121/151 AMWSA1204S AMWSA1205S AMWSA1206S Structure and Components: See Table 4-2 [ Table 4-2 Components Material INK Ink(black) CORE Alloy Sponge Powder WIRE Polyurethane copper wire BASE Copper plated with Sn Thickness of BASE coating:See Table 4-3 [ Table 4-3 5. Coating material Thickness (μm) Nickel bottom 0.125~0.625 Tin layer 5~7 Test and Measurement Procedures 5.1 Test Conditions 5.1.1 Unless otherwise specified, the standard atmospheric conditions for measurement/test as: a. Ambient Temperature: 20±15℃ b. Relative Humidity: 65±20% c. Air Pressure: 86 KPa to 106 KPa 5.1.2 If any doubt on the results, measurements/tests should be made within the following limits: a. Ambient Temperature: 20±2℃ b. Relative Humidity: 65±5% c. Air Pressure: 86KPa to 106 KPa 5.2 Visual Examination a. Inspection Equipment: 10 X magnifier 5.3 Electrical Test 5.3.1 DC Resistance (DCR) a. Refer to Appendix A. b. Test equipment (Analyzer): HIOKI3540 or equivalent. 5.3.2 Inductance (L) a. Refer to Appendix A. b. Test equipment: Wayne kerr3260+3265B or equivalent. 5.3.3 Rated Current a. Refer to Appendix A. b. Test equipment: Wayne kerr3260+3265B, Agilent E3633A, R2M-2H3 or equivalent. c. Definition of Rated Current (Ir): With the condition of the DC current pass, the inductance decrease approximate 30% of the standard value, compare to the temperature rise approximate 40℃, the smaller is Rated Current.(reference environment temperature:20℃) 5.4 Reliability Test SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 6 of 18 Mechanical Reliability Item Solderability Specification and Requirement Test Method The surface of terminal immersed shall be Solder heat proof: minimum of 95% covered with a new coating of 1. Preheating: 160 ± 10 ℃ solder 2. Retention time: 245 ± 5 ℃ for 2 ± 0.5 seconds 1. Vibration frequency: (10 Hz to 55 Hz to 10Hz) in 60 seconds as a period Inductance change: Within ± 10% Without 2. Vibration time: Vibration mechanical damage such as break Period cycled for 2 hours in each of 3 mutual perpendicular directions. Inductance change: Within ± 10% Without 3. Amplitude: 1.5 mm max. 1. Peak value: 100 G 2. Duration of pulse: 11ms 3. 3 times in each positive and negative direction of 3 mutual Shock mechanical damage such as break perpendicular directions Insulating Over 100MΩ 4. Over 100MΩ at 100V D.C. between coil and core Resistance Endurance Reliability Item Specification and Requirement Test Method 1. Repeat 100 cycles as follow: (-55 ± 2 ℃; 30 ± 3 min) →(Room temp., 5 min) Inductance change: Within ± 10% Without distinct → (+155 ± 2 ℃, 30 ± 3 min) Thermal Shock damage in appearance → (Room temp., 5 min) 2. Recovery: 48 + 4 / -0 hours of recovery under the standard condition after the test. 1. High Temperature Environment condition: 85 ± 2 ℃ Inductance change: Within ± 10% Without distinct Applied Current: Rated current Resistance Humidity Resistance damage in appearance 2. Duration: 1000 + 4 / -0 hours 1. Environment condition: 60 ± 2 ℃ Inductance change: Within ±10% Without distinct Humidity: 90–95% damage in appearance Applied Current: Rated current 2. Low Temperature Store High Temperature Store 6. Duration: 1000 + 4 / -0 hours Inductance change: Within ± 10% Without distinct Store temperature: damage in appearance -55 ± 2 ℃,1000 + 4 / -0 hours Inductance change: Within ± 10% Without distinct Store temperature: damage in appearance +155 ± 2 ℃,1000 + 4 / -0 hours Packaging, Storage and Transportation 6.1 Tape Carrier Packaging: Packaging code: T (1) Tape carrier packaging are specified in attached figure Fig.6.1-1~2 (2) Tape carrier packaging quantity: Type Standard Quantity (pcs/reel) Type Standard Quantity (pcs/reel) SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 7 of 18 AMWSA0412S AMWSA0402S AMWSA0518S AMWSA0503S AMWSA0618S 3000 AMWSA0603S 1500 3000 AMWSA0604S 1000 2000 AMWSA0605S 1000 2000 AMWSA1004S 500 500 1500 AMWSA1204S AMWSA0602S 1500 AMWSA1205S 500 AMWSA0624S 1500 AMWSA1206S 500 AMWSA1265S 500 AMWSA1707S 200 AMWSA1003S 800 AMWSA1005S 500 a. Taping Drawings (Unit: mm) Fig.6.1-1 b.Reel and Taping Dimensions (Unit: mm) Fig.6.1-2 Remark: (AMWSA0412S- AMWSA1265S)- Fig.6.1-1/2 Fig.6.1-3 Remark: (AMWSA1707S) -Fig.6.1-3 SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 8 of 18 Reel dimensions (mm) Tape dimensions (mm) Type A N C W W0 P P0 H T A0 B0 AMWSA0412S 330±2.0 100±2.0 13±1.0 12.4± 2.0 12±0.3 8±0.1 4±0.1 1.5± 0.05 0.30± 0.05 4.4±0.1 4.9±0.1 AMWSA0402S 330±2.0 100±2.0 13±1.0 12.4± 2.0 12±0.3 8±0.1 4±0.1 2.3± 0.05 0.35± 0.05 4.4±0.1 4.9±0.1 AMWSA0518S 330±2.0 100±2.0 13±1.0 12.4± 2.0 12±0.3 8±0.1 4±0.1 2.1± 0.05 0.35± 0.05 5.4±0.1 5.9±0.1 AMWSA0503S 330±2.0 100±2.0 13±1.0 12.4± 2.0 12±0.3 8±0.1 4±0.1 3.3± 0.05 0.35± 0.05 5.4±0.1 5.9±0.1 AMWSA0618S 330±2.0 100±2.0 13±1.0 16.4± 2.0 16±0.3 12±0.1 4±0.1 2.1± 0.05 0.35± 0.05 6.9±0.1 7.5±0.1 AMWSA0602S 330±2.0 100±2.0 13±1.0 16.4± 2.0 16±0.3 12±0.1 4±0.1 2.2±0.1 0.35± 0.05 6.9±0.1 7.5±0.1 AMWSA0624S 330±2.0 100±2.0 13±1.0 16.4± 2.0 16±0.3 12±0.1 4±0.1 2.7± 0.05 0.35± 0.05 6.9±0.1 7.5±0.1 AMWSA0603S 330±2.0 100±2.0 13±1.0 16.4± 2.0 16±0.3 12±0.1 4±0.1 3.3± 0.05 0.35± 0.05 6.9±0.1 7.5±0.1 AMWSA0604S 330±2.0 97±0.5 13.2± 0.2 16.8± 2.0 16±0.3 12±0.1 4±0.1 4.2± 0.10 0.35± 0.05 6.9±0.1 7.5±0.1 AMWSA0605S 330±2.0 100±2.0 13±1.0 16.4± 2.0 16±0.3 12±0.1 4±0.1 5.2± 0.10 0.4± 0.05 6.9±0.1 7.5±0.1 AMWSA1003S 330±2.0 100±2.0 13±1.0 24.4± 2.0 24±0.3 16±0.1 4±0.1 3.3± 0.10 0.35± 0.05 10.4± 0.1 11.6± 0.1 AMWSA1004S 330±2.0 100±2.0 13±1.0 24.4± 2.0 24±0.3 16±0.1 4±0.1 4.3± 0.10 0.35± 0.05 10.4± 0.1 11.5± 0.1 AMWSA1204S 330±2.0 100±2.0 13±1.0 24.4± 2.0 24±0.3 16±0.1 4±0.1 4.3± 0.10 0.5± 0.05 13.4± 0.1 14.4± 0.1 AMWSA1005S 330±2.0 100±2.0 13±1.0 24.4± 2.0 24±0.3 16±0.1 4±0.1 5.4± 0.10 0.5± 0.05 10.4± 0.1 11.6± 0.1 AMWSA1205S 330±2.0 100±2.0 13±1.0 24.4± 2.0 24±0.3 16±0.1 4±0.1 5.3± 0.10 0.5± 0.05 13.2± 0.1 14.4± 0.1 AMWSA1206S 330±2.0 100±2.0 13±1.0 24.4± 2.0 24±0.3 16±0.1 4±0.1 6.3± 0.10 0.5± 0.05 13.2± 0.1 14.4± 0.1 AMWSA1265S 330±2.0 97±0.5 13±0.2 24.0± 0.5 24±0.3 16±0.1 4±0.1 6.8± 0.10 0.5± 0.05 13.1± 0.1 14.0± 0.1 AMWSA1707S 330±2.0 97±0.5 13±0.2 24.4± 2.0 32±0.3 24±0.1 4±0.1 7.3± 0.10 0.5± 0.05 17.5± 0.1 18.1± 0.1 c.Peeling off force: 10gf to 130gf in the direction show below. Top tape or cover tape 1650~ 1800 Base tape Fig. 6.1-4 6.2 Storage (1) The solderability of the external electrodes may deteriorate if packages are stored in high humidity. Besides, to ensure packing material’s good state, packages must be stored at -10℃ to 40℃ and 70% RH Max. (2) The solderability of the external electrodes may deteriorate if packages are exposed to dust of harmful gas (e.g. HCl, sulfurous gas of H2S). (3) Packaging materials may deform if packages are exposed directly to sunlight. (4) Minimum packages, such as polyvinyl heat-seal packages shall not be opened until they are used. If opened, use the reels as soon as possible. (5) Solderability shall be guaranteed for a period of time from the date of delivery on condition that they are stored at the specified environment. For those parts, which passed more than the time shall be checked solderability before using. (6) For magnetic products, keep clear of anything that may generate magnetic fields to avoid change of products performance. (7) To avoid any damage to products, do not load mechanic force on products or place heavy goods on products, and exclude strong vibration or drop. (8)In case of storage over 12 months, solderability shall be checked before actual usage. SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 9 of 18 7. Warning and Attentions 7.1 Precautions on Use (1) Always wear static control bands to protect against ESD. (2) Any devices used with the products (soldering irons, measuring instruments) should be properly grounded. (3) Keep bare hands and metal conductors (i.e., metal desk) away from electrodes or conductive areas that lead to electrodes. (4) Preheat when soldering. (5) Don’t apply current in excess of the rated current value. It may reduce the impedance or inductance, or cause damage to components due to over-current. (6) For magnetic products, keep clear of anything that may generate magnetic fields such as speakers and coils. Use non-magnetic tweezers when handing the chips. (7) When soldering, the electrical characteristics may be varied due to hot energy and mechanical stress. (8) When coating products with resin, the relatively high resin curing stress may change the electrical characteristics. For exterior coating, select resin carefully so that electrical and mechanical performance of the product is not affected. Before using, please evaluate reliability with the product mounted in your application set. (9) When mount chips with adhesive in preliminary assembly, do appropriate check before the soldering stage, i.e., the size of land pattern, type of adhesive, amount applied, hardening of the adhesive on proper usage and amounts of adhesive to use. (10) Mounting density: Add special attention to radiating heat of products when mounting other components nearby. The excessive heat by other products may cause deterioration at joint of this product with substrate. (11) Since some products are constructed like an open magnetic circuit, narrow spacing between components may cause magnetic coupling. (12) Please do not give the product any excessive mechanical shocks in transportation. (13) Please do not touch wires by sharp terminals such as tweezers to avoid causing any damage to wires. (14) Please do not add any shock and power to the soldered product to avoid causing any damage to chip body. (15) Please do not touch the electrodes by naked hand as the solderability of the external electrodes may deteriorate by grease or oil on the skin. 7.2 PCB Bending Design The following shall be considered when designing and laying out PCB’s. (1) PCB shall be designed so that products are not subjected to the mechanical stress from board warp or deflection. Products shall be located in the sideways direction to the mechanical stress (Poor example) (Good example) (2) Products location on PCB separation. C Seam A B Product shall be located carefully because they may be subjected to the mechanical stress in order of A>C=B>D. D (3) When splitting the PCB board, or insert (remove) connector, or fasten thread after mounting components, care is required so as not to give any stress of deflection or twisting to the board. Because mechanical force may cause deterioration of the bonding strength of electrode and solder, even crack of product body. Board separation should not be done manually, but by using appropriate devices. 7.3 Recommended PCB Design for SMT Land-Patterns When chips are mounted on a PCB, the amount of solder used (size of fillet) can directly affect chip performance. Therefore, the following items must be carefully considered in the design of solder land patterns: (1) The amount of solder applied can affect the ability of chips to withstand mechanical stresses which may lead to breaking or cracking. Therefore, when designing land-patterns it is necessary to consider the appropriate size and configuration of the solder pads which in turn determines the amount of solder necessary to form the fillets. (2) When more than one part is jointly soldered onto the same land or pad, the pad must be designed that each component’s soldering point is separated by solder-resist. Recommended land dimensions please refer to product specification. 8 Recommended Soldering Technologies 8.1Re-flowing Profile: △ Preheat condition: 150 ~200℃/60~120sec. △ Allowed time above 217℃: 60~90sec. △ Max temp: 260℃ △ Max time at max temp: 10sec. △ Solder paste: Sn/3.0Ag/0.5Cu △ Allowed Reflow time: 2x max Please refer to Fig. 8.1 [Note: The reflow profile in the above table is only for qualification and is not meant to specify board assembly Peak 260℃ max 260℃ Max Ramp Up Rate=3℃/sec. 217℃ Max Ramp Down Rate=6℃/sec. 60~90sec. 200℃ 150℃ 60~120sec. 25℃ Time 25℃ to Peak =8 min max Fig. 8.1 SunlordBusiness categories:Level 0(general confidential) Specifications for Wire Molded SMD Power Inductors Page 10 of 18 profiles. Actual board assembly profiles must be based on the customer's specific board design, solder paste and process, and should not exceed the parameters as the Reflow profile shows.] 8.2 Iron Soldering Profile △ Iron soldering power: Max. 30W △ Pre-heating: 150℃/60sec. 350℃ △ Soldering Tip temperature: 350℃ Max. 3sec. Max. Soldering Iron △ △ △ Soldering time: 3sec. Max. Solder paste: Sn/3.0Ag/0.5Cu Max.1 times for iron soldering Please refer to Fig. 8.2. [Note: Take care not to apply the tip of Tc ℃ the soldering iron to the terminal electrodes.] 8.3 Recommended Soldering Technologies Heat Gun Profile △ Soldering tip temperature: 350℃ Max. △ Hot air time:
AMWSA1003S-8R2MT
物料型号:Sunlord AMWSA-S系列,包括多种尺寸和电感值的型号。
器件简介:AMWSA系列是绕线型封装的SMD功率电感器,适用于汽车电子等领域。
引脚分配:文档中未明确提供引脚分配图,但提到了Tape Carrier Package(胶带载体封装)。
参数特性: - 工作温度范围(含自热):-55℃至+155℃。 - 存储温度和湿度范围:-10℃至+40℃,最大相对湿度70%。 - 电性特性详见附录A。
功能详解: - 电感器的直流电阻(DCR)、标称电流(Isat)、额定电流(Irms)等参数根据不同型号有具体数值。 - 电感器在不同电流下的电感值变化,以及在特定温度下的电流承受能力。
应用信息: - 该系列产品不适用于需要特别高可靠性或故障可能导致社会、人身或财产损害的应用,如飞机、航天、水下设备等。
封装信息: - 提供了不同系列的尺寸和推荐的PCB布线图案,包括A、B、C、D、E等尺寸参数。
测试和测量程序: - 包括视觉检查、电气测试(直流电阻、电感、额定电流)、可靠性测试(焊接性、振动、冲击、绝缘电阻、耐久性)。
包装、存储和运输: - 详细描述了胶带载体包装的规格和数量,以及存储条件和注意事项。
使用注意事项: - 包括防静电措施、焊接和测量设备的接地、避免直接接触电极等。
PCB设计推荐: - 考虑机械应力、产品位置、焊接后的操作等对电感器性能的影响。
焊接技术推荐: - 提供了回流焊接和烙铁焊接的详细参数,包括预热条件、最大温度、焊接时间等。
AMWSA1003S-8R2MT 价格&库存
很抱歉,暂时无法提供与“AMWSA1003S-8R2MT”相匹配的价格&库存,您可以联系我们找货
