CXHP2R7705R
CXHP2R7705R
    CDA(智烽维)
    插件,D10xL20mm
    直插铝电解电容 插件,D10xL20mm 7F 20~+80% Ф10.00 x 20.00mm 2.7V 75mΩ
CXHP2R7705R 数据手册
CXHP(2.7V)Series www.cda-cap.com FEATURES ● Low leakage current, long life ● High power,high energy density ● Small size and low-resistance ● Long cycle life,maintenance-free ● RoHS Directive Compliant APPLICATIONS ● Consumer electronics,Ride thru power support,Back up power,Stand alone or augment existing,energy/power source. OPERATING TEMPERATURE RANGE ● -40℃ to +65℃ @2.7V ● -40℃ to +85℃ @2.3V GENERAL SPECIFICATIONS Item Performance Storage temperature -40°C to +70°C Capacitance range 0.5F to 120F Capacitance tolerance -0%to+100%;-20%to+20%:-20%to+50% Rated voltage 2.7 V Surge voltage 2.85 V Temperature characteristics Capacitance change: Within ±30% of initial measured value at +25°C Internal resistance: Within ±200% of initial measured value at +25°C High temperature load time After 85°C 1000 hours (at2.3V): Capacitance change: ±30% of initial rated value Internal resistance: Within 3 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity characteristic Vibration resistance Shelf life Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-07-05 CXHP(2.7V)Series www.cda-cap.com DIMENSIONS RADIAL LEAD TYPE Size(mm) ФD P Фd 8 3.5 0.6 10 5.0 0.6 13 5.0 0.6 16 7.5 0.8 18 7.5 0.8 RADIAL BENT LEAD TYPE 3.0 ±0.5mm Style B(mm) A1 4.0 C1 2.0 STANDARD PRODUCTS Working Rated Part Number Dimensions (mm) Max.ESR Maximum Maximum Maximum Voltage Cap. (V DC) (F) D*L CXHP2R7504R- TW 2.7 0.5 6.3x12 240 1600 0.006 0.52 0.14 CXHP2R7105R-TWX 2.7 1 6.3x12 300 1500 0.006 0.54 CXHP2R7105R- TW 2.7 1 8x12 160 240 0.006 CXHP2R7205R- TW 2.7 2 8x12 100 280 CXHP2R7205R- TWQ 2.7 2 8x20 100 CXHP2R7255R- TW 2.7 2.5 8x16 CXHP2R7305R- TWX 2.7 3 CXHP2R7305R- TW 2.7 CXHP2R7335R- TW Energy Endurance Density Energy Density (W.h) (Wh/kg) 1003 0.0010 1.86 0.16 1108 0.0012 1.92 1.09 0.47 4050 0.0010 1.13 0.010 1.73 0.49 2924 0.0020 1.90 120 0.012 2.15 0.55 2924 0.0020 2.15 130 180 0.025 2.27 0.59 4115 0.0025 2.32 8x16 130 195 0.012 2.56 0.59 4116 0.0030 2.79 3 8x20 100 120 0.012 2.79 0.65 4486 0.0030 2.34 2.7 3.3 8x20 100 150 0.012 2.98 0.74 4486 0.0033 2.57 CXHP2R7405R- TW 2.7 4 10x20 70 170 0.015 3.65 0.79 2339 0.0040 2.40 CXHP2R7475R- TW 2.7 4.7 10x20 72 170 0.017 3.60 0.75 2340 0.0047 2.50 CXHP2R7505R-TWX 2.7 5 8x25 90 135 0.015 4.03 0.87 3857 0.0051 3.01 ESRDC (1kHz/mΩ) (mΩ) Peak Maximum (72hrs/mA) Current(A) Current(A) (W/Kg) ESRAC Leakage Power No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-07-05 CXHP(2.7V)Series www.cda-cap.com CXHP2R7505R- TW 2.7 5 10x20 75 113 0.015 4.32 0.97 3535 0.0051 2.30 CXHP2R7705R- TW 2.7 7 10x20 75 113 0.020 5.29 0.97 3535 0.0071 3.22 CXHP2R7705R- TWX 2.7 7 8x25 90 135 0.015 4.86 0.87 3600 0.0071 3.94 CXHP2R7805R- TW 2.7 8 10x25 60 150 0.020 4.61 0.93 2303 0.0081 2.80 CXHP2R7805R- TWX 2.7 8 12.5x20 60 150 0.020 7.58 1.35 3557 0.0081 2.94 CXHP2R7106R- TW 2.7 10 10x25 65 98 0.030 6.84 1.15 3451 0.0101 3.89 CXHP2R7106R- TWQ 2.7 10 10x30 50 75 0.030 7.71 1.43 3800 0.0101 3.30 CXHP2R7106R-TWX 2.7 10 12.5x20 45 68 0.030 8.06 1.42 3757 0.0101 2.94 CXHP2R7126R- TW 2.7 12 12.5x20 50 75 0.036 8.53 1.35 3381 0.0122 3.52 CXHP2R7156R- TW 2.7 15 12.5x26 40 60 0.050 10.66 1.80 3359 0.0152 3.50 CXHP2R7156R- TWX 2.7 15 12.5x20 45 68 0.040 10.06 1.42 3550 0.0152 4.16 CXHP2R7186R- TW 2.7 18 12.5x26 40 60 0.055 12.27 1.66 3645 0.0183 5.06 CHXP2R7206R- TW 2.7 20 12.5x26 30 60 0.060 13.50 2.70 2692 0.0203 3.10 CHXP2R7206R- TWQ 2.7 20 12.5x30 35 53 0.055 13.17 1.93 3920 0.0203 4.76 CXHP2R7256R- TW 2.7 25 16x25 27 50 0.060 15.00 2.09 2419 0.0253 3.50 CXHP2R7306R- TW 2.7 30 16x30 20 40 0.070 18.41 2.53 2664 0.0304 3.70 CXHP2R7306R- TWX 2.7 30 16x25 25 38 0.072 19.06 2.41 3049 0.0304 3.97 CXHP2R7356R-TWX 2.7 35 16x30 22 33 0.080 21.93 2.79 3194 0.0354 4.27 CXHP2R7356R-TW 2.7 35 16x35 19 42 0.086 23.86 3.24 3220 0.0354 3.65 CXHP2R7406R-TW 2.7 40 12.5x46 20 45 0.080 23.68 3.01 3694 0.0405 5.47 CXHP2R7506R- TW 2.7 50 18x40 16 24 0.105 30.68 3.96 2848 0.0506 3.96 CXHP2R7506R- TWQ 2.7 50 12.5x50 18 35 0.105 28.72 3.40 3640 0.0506 5.69 CXHP2R7506R- TWX 2.7 50 18x35 18 27 0.110 30.92 3.52 2700 0.0506 5.06 CXHP2R7606R- TW 2.7 60 18x40 15 23 0.150 34.47 4.09 2880 0.0608 4.28 CXHP2R7107R-TWV 2.7 100 18x60 13 20 0.240 45.76 5.30 2136 0.1013 4.82 CXHP2R7127R- TWV 2.7 120 18x60 13 20 0.280 48.50 5.30 2039 0.1215 5.52 *with appropriate voltage derating operating temperature can be extended to 85°C SAFETY RECOMMENDATIONS WARNINGS REGULATORY • To Avoid Short Circuit, after usage or test, SuperCapacitor voltage needs to discharge to ≤ 0.1V • Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than 150°C, explosion-proof valve may break open • Do not Press, Damage or disassemble the SuperCapacitors, housing could heat to high temperature causing Burns • If you observe Overheating or Burning Smell from the capacitor disconnect Power immediately, and do not touch • MSDS • RoHS Compliant • Reach Compliant TRANSPORTATION Not subjected to US DOT or IATA regulations UN3499,
CXHP2R7705R 价格&库存
很抱歉,暂时无法提供与“CXHP2R7705R”相匹配的价格&库存,您可以联系我们找货
CXHP2R7705R
  • 1+6.52495
  • 30+6.29995
  • 100+5.84996
  • 500+5.39996
  • 1000+5.17496
