CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 1 OF 9
The history of revision change for the specification
Document
REV.
Modified date
CYNVC-201-033
A0
2020.1.31
CYNVC-201-033
A1
2020.7.24
CYNVC-201-033
A2
2020.11.2
CYNVC-201-033
A3
2020.12.24
CYNVC-201-033
A4
2021.1.25
CYNVC-201-033
A5
2021.5.24
Description
New approval
1. Jan. -> Jul.
2. Add 2R2, 4R7, 220 spec and curve
1. Jul. -> Nov.
2. Add 3R3, 6R8 spec and curve
1. Nov. -> Dec.
2. Add R47, 1R5, 100, 150 spec
3. Add 1R5, 100 curve
1. Dec.,2020 -> Jan., 2021
2.Add R47,150 curve
1. Jan. -> May.
2. Add R68 spec and curve
May., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 2 OF 9
Power Choke Coil VCUW053T MS5 type
AEC-Q200
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 3.0mm
Low loss realized with low DCR
Capable of corresponding high frequency
Compliance with RoHS and Halogen Free
AEC-Q200 qualified
Application
Automotive applications
Outline Dimensions
A'
L
Code
B B'
W
A1
H
T
Dimensions (mm)
L
5.45 0.35
W
5.25 0.20
T
2.8 0.2
A1
1.4 0.3
A’
1.5 0.1
B
2.3 0.3
B’
3.5 0.2
H
0 ~ + 0.15
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
2.6
B
2.2
C
6.5
Unit : mm
May., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 3 OF 9
Marking and Date Code
The point on the top surface represents winding direction of choke.
(1) Marking
The inductor is marked with a 3-digit code
Example – – 1.0H 1R0
(2) Date Code
Upside of Chip
X
XX
(1)
(2)
XXX
(3)
Where
PIN 2
1R0
XXX
XXX
(1) Year Code
Ex : 2021 = 1
PIN 1
Coil clockwise around
(2) Weekly Code
Serial number : 01 ~ 53
(3) Taping No.
Serial number : 001 ~ ZZZ
May., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 4 OF 9
Specifications
L0 ◇
Inductance
( H )
@ (0A)
Typical
VCUW053T-R10MS5
0.10
VCUW053T-R47MS5
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
Maximum
1.8
2.1
24.0
22.0
35.0
30.0
40
0.47
6.0
7.2
13.0
11.7
12.8
11.0
40
VCUW053T-R68MS5
0.68
8.0
9.6
11.0
9.9
11.2
9.6
40
VCUW053T-1R0MS5
1.0
10.0
11.5
10.2
9.2
10.8
9.3
40
VCUW053T-1R5MS5
1.5
13.0
15.6
8.9
8.0
9.0
7.7
40
VCUW053T-2R2MS5
2.2
20.0
23.0
7.1
6.4
7.5
6.4
40
VCUW053T-3R3MS5
3.3
33.0
38.0
5.5
5.0
6.6
5.6
40
VCUW053T-4R7MS5
4.7
51.0
59.0
4.4
3.9
6.2
5.3
40
VCUW053T-6R8MS5
6.8
75.0
90.0
3.6
3.2
5.3
4.6
40
VCUW053T-100MS5
10.0
95.8
115.0
3.2
2.9
3.3
2.8
40
VCUW053T-150MS5
15.0
139.5
158.0
2.7
2.4
2.4
2.1
40
VCUW053T-220MS5
22.0
195.0
232.0
2.2
2.0
2.2
1.9
40
Part Number
Rdc ( m ) ◇
Rated Voltage
(V)
◇:Significant Characteristic
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to +155℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Note 8.: Cleaning Process Note
(a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether
system, there is a possibility that the performance decreases greatly
(b) The high power ultrasonic washing may damage the choke body.
(c) Please contact us if you need the cleaning via the above agents or ultrasonic washing.
May., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
80
0.50
60
INDUCTANCE(μH)
: A5
PAGE
: 5 OF 9
TEMP. RISE(℃)
40
0.04
30
35
40
45
TEMP. RISE(℃)
3
6
9
60
INDUCTANCE(μH)
TEMP. RISE(℃)
40
0.00
INDUCTANCE(μH)
0.56
TEMP. RISE(℃)
80
4
6
8
10
12
14
80
0.80
60
0.60
INDUCTANCE(μH)
0.40
TEMP. RISE(℃)
4
6
40
INDUCTANCE(μH)
60
TEMP. RISE(℃)
80
TEMP. RISE(℃)
1
2
3
4
5
6
7
8
9
10
60
INDUCTANCE(μH)
1.20
0.00
4
5
DC BIAS(Amps)
40
TEMP. RISE(℃)
0.80
2
3
4
5
6
7
8
9
10
6
7
8
VCUW053T-4R7MS5
6.00
INDUCTANCE(μH)
40
TEMP. RISE(℃)
TEMP. RISE(℃)
60
INDUCTANCE(μH)
2
100
80
1
18
0.00
100
2.80
DC BIAS(Amps)
3.50
1.40
14
1.60
11
VCUW053T-3R3MS5
2.10
12
2.00
DC BIAS(Amps)
4.20
10
0.40
VCUW053T-2R2MS5
2.40
100
1.20
0.60
40
DC BIAS(Amps)
VCUW053T-1R5MS5
INDUCTANCE(μH)
100
0.00
16
1.50
0.90
18
1.00
DC BIAS(Amps)
1.80
15
VCUW053T-1R0MS5
1.20
100
0.70
0.28
12
DC BIAS(Amps)
VCUW053T-R68MS5
0.42
40
0.20
DC BIAS(Amps)
0.84
60
INDUCTANCE(μH)
0.30
TEMP. RISE(℃)
10
80
0.40
TEMP. RISE(℃)
5
100
0.10
VCUW053T-R47MS5
100
5.00
80
4.00
60
INDUCTANCE(μH)
3.00
40
TEMP. RISE(℃)
2.00
TEMP. RISE(℃)
0.06
0.00
INDUCTANCE(μH)
REVISION
TEMP. RISE(℃)
0.08
0.60
INDUCTANCE(μH)
0.10
100
TEMP. RISE(℃)
INDUCTANCE(μH)
VCUW053T-R10MS5
0.02
INDUCTANCE(μH)
: CYNVC-201-033
Current Characteristic
0.12
INDUCTANCE(μH)
DOCUMENT
0.00
2
3
4
DC BIAS(Amps)
5
6
7
May., 2021 Issued
VCUW053T-6R8MS5
80
5.60
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
2.80
1.40
0.00
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
TEMP. RISE(℃)
TEMP. RISE(℃)
100
27.00
80
22.50
40
6.0
0.0
2.0
DC BIAS(Amps)
40
4.0
0.0
60
INDUCTANCE(μH)
1.0
60
INDUCTANCE(μH)
6.0
3.0
3.5
INDUCTANCE(μH)
12.0
0.5
100
8.0
2.0
TEMP. RISE(℃)
INDUCTANCE(μH)
15.0
0.0
: 6 OF 9
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
DC BIAS(Amps)
VCUW053T-150MS5
9.0
PAGE
80
DC BIAS(Amps)
18.0
: A5
10.0
REVISION
VCUW053T-220MS5
100
80
18.00
60
13.50
40
9.00
INDUCTANCE(μH)
4.50
TEMP. RISE(℃)
4.20
INDUCTANCE(μH)
7.00
: CYNVC-201-033
VCUW053T-100MS5
12.0
100
TEMP. RISE(℃)
INDUCTANCE(μH)
8.40
DOCUMENT
TEMP. RISE(℃)
CYNTEC CO., LTD.
乾坤科技股份有限公司
TEMP. RISE(℃)
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
DC BIAS(Amps)
May., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 7 OF 9
Packaging
(1) Tape packaging dimensions
t
4.0 ± 0.1
+0.1
1.5 -0.0
2.0 ± 0.1
Sprocket hole
1.75 ± 0.10
7.5 ± 0.1
16.0 ± 0.3
B0
K0
Carrier cavity
A0
8.0 ± 0.1
Pulling direction
Dimensions Code (mm)
UNITS/REEL
A0
B0
K0
t
5.75 0.10
6.05 0.10
3.6 0.1
0.35 0.05
2,000
(2) Tape Direction
The direction shall be seen from the top cover tape side.
XXX
XXX
1R0
XXX
XXX
1R0
Pulling direction
May., 2021 Issued
XXX
XXX
1R0
XXX
XXX
1R0
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 8 OF 9
2.0 ± 0.5
20.0 ± 0.5
B
330.0 ± 2.0
100.0 ± 1.0
(3) Reel dimensions
A
13.0 ± 1.0
mm
A
B
16.0 0.5
2.0 0.2
(4) Peel force of top cover tape
The peel speed shall be about 300 mm/minute.
The peel force of top cover tape shall be between 0.1 to 1.3N.
Top Cover Tape
165 ~ 180°
0.1 ~ 1.3N
Carrier tape
May., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-033
REVISION
: A5
PAGE
: 9 OF 9
Reflow Profile
Power Choke Coil Type
Tp
Temperature
260℃
tp:30 Sec max.
Max. Ramp Up Rate =3℃/s
Max. Ramp Down Rate =6℃/s
217℃
60~150 Sec
Preheat Area
200℃
150℃
60~120 Sec
25℃
25°C to Peak ( 8 minutes max.)
Time
(1) Reflow Soldering Method :
Reflow Soldering
Tp:255~260℃
Max.30 seconds ( tp )
217℃
60~150 seconds
Pre-Heat
150 ~ 200℃
60~120 seconds
Time 25℃ to peak temperature
8 minutes max.
(2) Soldering iron Method : 350 5℃ max.3 seconds
May., 2021 Issued
很抱歉,暂时无法提供与“VCUW053T-R10MS5”相匹配的价格&库存,您可以联系我们找货
