CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 1 OF 9
The history of revision change for the specification
Document
REV.
Modified date
CYNVC‐19X‐030
A0
2019.10.17
CYNVC‐19X‐030
A1
2019.11.12
CYNVC‐19X‐030
A2
2020.1.13
CYNVC‐19X‐030
A3
2020.3.31
CYNVC‐19X‐030
A4
2020.4.7
CYNVC‐19X‐030
A5
2020.4.10
CYNVC‐19X‐030
A6
2021.9.17
Description
New approval
1. Oct. ‐> Nov
2. Remove R47 spec and curve
3. Add 1R0, 1R5, 3R3 spec and curve
4. Update 220 spec
Idc(Typ./Max.): 2.5/2.3 ‐> 2.8/2.5
1. Nov., 2019 ‐> Jan., 2020
2. Year Code: 2019 = 9 ‐> 2020 = 0
3. Remove frequency: (1MHz) from Features
1. Jan. ‐> Mar.
2. Add 2R2 spec and curve
1. Mar., ‐> Apr.,
2. Add R47 spec and curve
1. Add “AEC‐Q200” logo
2. Add notice ”AEC‐Q200 qualified” in Features
3. Remove Notice ”Preliminary specification”
1. Apr.,2020‐> Sep. ,2021
2. Year Code: 2020 = 0 ‐> 2021 = 1
3. Add R68 spec and curve
Sep., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 2 OF 9
Power Choke Coil VCMT063T MN5TM type
AEC-Q200
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 3.0mm
Low loss realized with low DCR
Capable of corresponding high frequency
Compliance with RoHS and Halogen Free
AEC-Q200 qualified
Application
Automotive applications
Outline Dimensions
L
A'
W
B'
B
B1
A1
H
T
Code
Dimensions (mm)
L
6.95 0.35
W
6.6 0.2
T
2.8 0.2
A1
1.27 0.30
A’
2.0 0.1
B
3.18 0.30
B1
4.3 0.3
B’
3.6 0.2
H
0 ~ + 0.15
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
3.429
B
3.429
C
8.255
Unit : mm
Sep., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 3 OF 9
Marking and Date Code
The point on the top surface represents winding direction of choke.
(1) Marking
The inductor is marked with a 3-digit code
Example – – 4.7H 4R7
(2) Date Code
Upside of Chip
X
XX
(1)
(2)
XXX
(3)
Where
PIN 2
4R7
XXX
XXX
(1) Year Code
Ex : 2021 = 1
PIN 1
Coil clockwise around
(2) Weekly Code
Serial number : 01 ~ 53
(3) Taping No.
Serial number : 001 ~ ZZZ
Sep., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 4 OF 9
Specifications
L0 ◇
Inductance
( H )
@ (0A)
Typical
VCMT063T-R47MN5TM
0.47
VCMT063T-R68MN5TM
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
Maximum
3.85
4.62
17.0
15.3
16.3
14.0
75
0.68
4.5
5.3
16.5
14.1
13.0
11.0
75
VCMT063T-1R0MN5TM
1.0
6.5
7.8
13.0
11.7
13.0
11.1
75
VCMT063T-1R5MN5TM
1.5
10.9
12.5
10.6
9.5
11.6
9.9
75
VCMT063T-2R2MN5TM
2.2
15.0
16.5
9.0
8.1
8.0
6.9
75
VCMT063T-3R3MN5TM
3.3
22.5
26.0
7.5
6.8
8.3
7.1
75
VCMT063T-4R7MN5TM
4.7
31.5
33.4
6.0
5.4
6.0
5.1
75
VCMT063T-6R8MN5TM
6.8
41.5
46.8
5.5
5.0
4.5
3.9
75
VCMT063T-100MN5TM
10.0
61.0
70.5
4.0
3.6
3.5
3.0
75
VCMT063T-150MN5TM
15.0
96.0
110.0
3.2
2.9
2.8
2.4
75
VCMT063T-220MN5TM
22.0
163.0
174.0
2.8
2.5
2.4
2.1
75
Part Number
Rdc ( m ) ◇
Rated Voltage
(V)
◇:Significant Characteristic
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 20%
Note 5.: Operating Temperature Range -55℃ to +155℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Note 8.: Cleaning Process Note
(a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether
system, there is a possibility that the performance decreases greatly
(b) The high power ultrasonic washing may damage the choke body.
(c) Please contact us if you need the cleaning via the above agents or ultrasonic washing.
Sep., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
REVISION
: A6
PAGE
: 5 OF 9
40
2
4
6
1.20
8
VCMT063T-1R0MN5TM
1.00
0.80
TEMP. RISE(℃)
4
6
8
10
12
14
16
18
100
1.80
80
1.50
4
6
8
10 12 14 16 18 20 22 24 26 28
VCMT063T-1R5MN5TM
80
1.20
60
0.90
INDUCTANCE(μH)
0.60
TEMP. RISE(℃)
VCMT063T-2R2MN5TM
2
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
0.80
INDUCTANCE(μH)
1.60
TEMP. RISE(℃)
80
1.20
4.20
100
2.00
4
6
2
4
5.40
6
8
10
DC BIAS(Amps)
12
14
60
INDUCTANCE(μH)
TEMP. RISE(℃)
40
1.80
0.00
4
5
6
7
DC BIAS(Amps)
8
9
10
11
TEMP. RISE(℃)
3.60
2
100
80
2.80
60
2.10
INDUCTANCE(μH)
1.40
TEMP. RISE(℃)
40
2
3
8.40
80
1
16
VCMT063T-3R3MN5TM
4.50
4
5
6
7
8
9
10 11 12 13 14
DC BIAS(Amps)
VCMT063T-4R7MN5TM
2.70
12
3.50
16
INDUCTANCE(μH)
10
DC BIAS(Amps)
0.00
40
0.30
DC BIAS(Amps)
2.40
100
0.00
40
0.00
2
TEMP. RISE(℃)
DC BIAS(Amps)
40
0.40
INDUCTANCE(μH)
0.60
INDUCTANCE(μH)
10 12 14 16 18 20 22 24 26 28 30
DC BIAS(Amps)
INDUCTANCE(μH)
0.42
TEMP. RISE(℃)
TEMP. RISE(℃)
80
0.56
TEMP. RISE(℃)
0.20
100
100
VCMT063T-6R8MN5TM
7.00
80
5.60
60
4.20
INDUCTANCE(μH)
2.80
TEMP. RISE(℃)
40
TEMP. RISE(℃)
INDUCTANCE(μH)
VCMT063T-R68MN5TM
TEMP. RISE(℃)
0.70
INDUCTANCE(μH)
80
60
0.30
INDUCTANCE(μH)
0.84
TEMP. RISE(℃)
0.40
100
TEMP. RISE(℃)
INDUCTANCE(μH)
VCMT063T-R47MN5TM
0.50
INDUCTANCE(μH)
: CYNVC-19X-030
Current Characteristic
0.60
INDUCTANCE(μH)
DOCUMENT
0.00
2
3
4
5
6
DC BIAS(Amps)
7
8
9
Sep., 2021 Issued
10.0
8.0
18.0
80
15.0
60
INDUCTANCE(μH)
6.0
100
TEMP. RISE(℃)
40
4.0
0.0
PAGE
: 6 OF 9
VCMT063T-150MN5TM
100
80
12.0
60
INDUCTANCE(μH)
9.0
TEMP. RISE(℃)
40
6.0
0.5
1.0
1.5
2.0
2.5 3.0 3.5 4.0
DC BIAS(Amps)
4.5
5.0
5.5
80
16.0
60
INDUCTANCE(μH)
TEMP. RISE(℃)
40
8.0
TEMP. RISE(℃)
INDUCTANCE(μH)
: A6
100
20.0
12.0
REVISION
0.0
DC BIAS(Amps)
VCMT063T-220MN5TM
: CYNVC-19X-030
3.0
0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0
24.0
INDUCTANCE(μH)
VCMT063T-100MN5TM
TEMP. RISE(℃)
INDUCTANCE(μH)
12.0
DOCUMENT
TEMP. RISE(℃)
CYNTEC CO., LTD.
乾坤科技股份有限公司
0.0
0.5
1.0
1.5
2.0 2.5 3.0 3.5
DC BIAS(Amps)
4.0
4.5
5.0
Sep., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 7 OF 9
Packaging
(1) Tape packaging dimensions
t
4.0 ± 0.1
Sprocket hole 1.75 ± 0.10
2.0 ± 0.1
+0.1
1.5 -0.0
7.5 ± 0.1
16.0 ± 0.3
B0
A0
K0
Carrier cavity
Pulling direction
8.0 ± 0.1
Dimensions Code (mm)
A0
B0
K0
t
7.10 0.15
7.5 0.1
3.6 0.1
0.35 0.05
UNITS/REEL
2,000
(2) Tape Direction
The direction shall be seen from the top cover tape side.
XXX
XXX
4R7
XXX
XXX
4R7
Pulling direction
Sep., 2021 Issued
XXX
XXX
4R7
XXX
XXX
4R7
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 8 OF 9
2.0 ± 0.5
20.0 ± 0.5
B
330.0 ± 2.0
100.0 ± 1.0
(3) Reel dimensions
A
13.0 ± 1.0
mm
A
B
16.0 0.5
2.0 0.2
(4) Peel force of top cover tape
The peel speed shall be about 300 mm/minute.
The peel force of top cover tape shall be between 0.1 to 1.3N.
Top Cover Tape
165 ~ 180°
0.1 ~ 1.3N
Carrier tape
Sep., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-19X-030
REVISION
: A6
PAGE
: 9 OF 9
Reflow Profile
Power Choke Coil Type
Tp
Temperature
260℃
tp:30 Sec max.
Max. Ramp Up Rate =3℃/s
Max. Ramp Down Rate =6℃/s
217℃
60~150 Sec
Preheat Area
200℃
150℃
60~120 Sec
25℃
25°C to Peak ( 8 minutes max.)
Time
(1) Reflow Soldering Method :
Reflow Soldering
Tp:255~260℃
Max.30 seconds ( tp )
217℃
60~150 seconds
Pre-Heat
150 ~ 200℃
60~120 seconds
Time 25℃ to peak temperature
8 minutes max.
(2) Soldering iron Method : 350 5℃ max.3 seconds
Sep., 2021 Issued
很抱歉,暂时无法提供与“VCMT063T-R68MN5TM”相匹配的价格&库存,您可以联系我们找货
