VCMT063T-2R2MN5TM
VCMT063T-2R2MN5TM
    CYNTEC(乾坤)
    SMD,6.95x6.6mm
    功率电感 2.2µH ±20% IND_6.95X6.6MM_SM 2.80mm 6.95 x 6.60mm 16.5mΩ 6.9A
VCMT063T-2R2MN5TM 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 1 OF 9 The history of revision change for the specification Document  REV.  Modified date  CYNVC‐19X‐030  A0  2019.10.17  CYNVC‐19X‐030  A1  2019.11.12  CYNVC‐19X‐030  A2  2020.1.13  CYNVC‐19X‐030  A3  2020.3.31  CYNVC‐19X‐030  A4  2020.4.7  CYNVC‐19X‐030  A5  2020.4.10  CYNVC‐19X‐030  A6  2021.9.17  Description  New approval  1. Oct. ‐> Nov  2. Remove R47 spec and curve  3. Add 1R0, 1R5, 3R3 spec and curve  4. Update 220 spec  Idc(Typ./Max.): 2.5/2.3 ‐> 2.8/2.5  1. Nov., 2019 ‐> Jan., 2020  2. Year Code: 2019 = 9 ‐> 2020 = 0  3. Remove frequency: (1MHz) from Features  1. Jan. ‐> Mar.  2. Add 2R2 spec and curve  1. Mar., ‐> Apr.,  2. Add R47 spec and curve  1. Add “AEC‐Q200” logo  2. Add notice ”AEC‐Q200 qualified” in Features  3. Remove Notice ”Preliminary specification”  1. Apr.,2020‐> Sep. ,2021  2. Year Code: 2020 = 0 ‐> 2021 = 1  3. Add R68 spec and curve  Sep., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 2 OF 9 Power Choke Coil VCMT063T MN5TM type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 3.0mm Low loss realized with low DCR Capable of corresponding high frequency Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions L A' W B' B B1 A1 H  T Code Dimensions (mm) L 6.95  0.35 W 6.6  0.2 T 2.8  0.2 A1 1.27  0.30 A’ 2.0  0.1 B 3.18  0.30 B1 4.3  0.3 B’ 3.6  0.2 H 0 ~ + 0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 3.429 B 3.429 C 8.255 Unit : mm Sep., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 3 OF 9 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 4.7H  4R7 (2) Date Code Upside of Chip X XX (1) (2) XXX (3) Where PIN 2 4R7 XXX XXX (1) Year Code Ex : 2021 = 1 PIN 1 Coil clockwise around (2) Weekly Code Serial number : 01 ~ 53 (3) Taping No. Serial number : 001 ~ ZZZ Sep., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 4 OF 9 Specifications L0 ◇ Inductance ( H ) @ (0A) Typical VCMT063T-R47MN5TM 0.47 VCMT063T-R68MN5TM Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum Maximum 3.85 4.62 17.0 15.3 16.3 14.0 75 0.68 4.5 5.3 16.5 14.1 13.0 11.0 75 VCMT063T-1R0MN5TM 1.0 6.5 7.8 13.0 11.7 13.0 11.1 75 VCMT063T-1R5MN5TM 1.5 10.9 12.5 10.6 9.5 11.6 9.9 75 VCMT063T-2R2MN5TM 2.2 15.0 16.5 9.0 8.1 8.0 6.9 75 VCMT063T-3R3MN5TM 3.3 22.5 26.0 7.5 6.8 8.3 7.1 75 VCMT063T-4R7MN5TM 4.7 31.5 33.4 6.0 5.4 6.0 5.1 75 VCMT063T-6R8MN5TM 6.8 41.5 46.8 5.5 5.0 4.5 3.9 75 VCMT063T-100MN5TM 10.0 61.0 70.5 4.0 3.6 3.5 3.0 75 VCMT063T-150MN5TM 15.0 96.0 110.0 3.2 2.9 2.8 2.4 75 VCMT063T-220MN5TM 22.0 163.0 174.0 2.8 2.5 2.4 2.1 75 Part Number Rdc ( m ) ◇ Rated Voltage (V) ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 20% Note 5.: Operating Temperature Range -55℃ to +155℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Sep., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  REVISION : A6 PAGE : 5 OF 9 40 20 0.10 0 0.00 2 4 6 1.20 8 VCMT063T-1R0MN5TM 1.00 0.80 TEMP. RISE(℃) 4 6 8 10 12 14 16 18 20 22 20 0.14 100 1.80 80 1.50 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 VCMT063T-1R5MN5TM 80 1.20 60 0.90 INDUCTANCE(μH) 0.60 TEMP. RISE(℃) 20 0 0 24 VCMT063T-2R2MN5TM 2 60 INDUCTANCE(μH) 40 TEMP. RISE(℃) 0.80 20 0.40 INDUCTANCE(μH) 1.60 TEMP. RISE(℃) 80 1.20 4.20 100 2.00 4 6 2 4 5.40 6 8 10 DC BIAS(Amps) 12 14 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 1.80 20 0.90 0.00 0 3 4 5 6 7 DC BIAS(Amps) 8 9 10 11 TEMP. RISE(℃) 3.60 2 100 80 2.80 60 2.10 INDUCTANCE(μH) 1.40 TEMP. RISE(℃) 40 20 0.70 0 1 2 3 8.40 80 1 16 VCMT063T-3R3MN5TM 0 100 4.50 0 14 4 5 6 7 8 9 10 11 12 13 14 DC BIAS(Amps) VCMT063T-4R7MN5TM 2.70 12 3.50 16 INDUCTANCE(μH) 0 8 10 DC BIAS(Amps) 0.00 0 0.00 40 0.30 DC BIAS(Amps) 2.40 100 0.00 0 0.00 40 0.00 20 0.20 2 TEMP. RISE(℃) DC BIAS(Amps) 40 0.40 0 0.28 0 60 INDUCTANCE(μH) 0.60 INDUCTANCE(μH) 10 12 14 16 18 20 22 24 26 28 30 DC BIAS(Amps) INDUCTANCE(μH) 0 60 0.42 TEMP. RISE(℃) TEMP. RISE(℃) 80 0.56 TEMP. RISE(℃) 0.20 100 100 VCMT063T-6R8MN5TM 7.00 80 5.60 60 4.20 INDUCTANCE(μH) 2.80 TEMP. RISE(℃) 40 TEMP. RISE(℃) INDUCTANCE(μH) VCMT063T-R68MN5TM TEMP. RISE(℃) 0.70 INDUCTANCE(μH) 80 60 0.30 INDUCTANCE(μH) 0.84 TEMP. RISE(℃) 0.40 100 TEMP. RISE(℃) INDUCTANCE(μH) VCMT063T-R47MN5TM 0.50 INDUCTANCE(μH) : CYNVC-19X-030 Current Characteristic 0.60 INDUCTANCE(μH) DOCUMENT 20 1.40 0.00 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 Sep., 2021 Issued 10.0 8.0 18.0 80 15.0 60 INDUCTANCE(μH) 6.0 100 TEMP. RISE(℃) 40 4.0 20 2.0 0.0 0 PAGE : 6 OF 9 VCMT063T-150MN5TM 100 80 12.0 60 INDUCTANCE(μH) 9.0 TEMP. RISE(℃) 40 6.0 20 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 DC BIAS(Amps) 4.5 5.0 5.5 80 16.0 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 8.0 TEMP. RISE(℃) INDUCTANCE(μH) : A6 100 20.0 12.0 REVISION 0.0 DC BIAS(Amps) VCMT063T-220MN5TM : CYNVC-19X-030 3.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 24.0 INDUCTANCE(μH) VCMT063T-100MN5TM TEMP. RISE(℃) INDUCTANCE(μH) 12.0 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 4.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 4.0 4.5 5.0 Sep., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 7 OF 9 Packaging (1) Tape packaging dimensions t 4.0 ± 0.1 Sprocket hole 1.75 ± 0.10 2.0 ± 0.1 +0.1 1.5 -0.0 7.5 ± 0.1 16.0 ± 0.3 B0 A0 K0 Carrier cavity Pulling direction 8.0 ± 0.1 Dimensions Code (mm) A0 B0 K0 t 7.10  0.15 7.5  0.1 3.6  0.1 0.35  0.05 UNITS/REEL 2,000 (2) Tape Direction The direction shall be seen from the top cover tape side. XXX XXX 4R7 XXX XXX 4R7 Pulling direction Sep., 2021 Issued XXX XXX 4R7 XXX XXX 4R7 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 8 OF 9 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (3) Reel dimensions A 13.0 ± 1.0 mm A B 16.0  0.5 2.0  0.2 (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 1.3N. Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape Sep., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19X-030 REVISION : A6 PAGE : 9 OF 9 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds Sep., 2021 Issued
VCMT063T-2R2MN5TM 价格&库存
很抱歉,暂时无法提供与“VCMT063T-2R2MN5TM”相匹配的价格&库存,您可以联系我们找货
