VCUW064E-330MS5
VCUW064E-330MS5
    CYNTEC(乾坤)
    SMD,6.95x6.6mm
    功率电感 33µH ±20% IND_6.95X6.6MM_SM 4.30mm 6.95 x 6.60mm 145.2mΩ 2.4A
VCUW064E-330MS5 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 1 OF 9 The history of revision change for the specification Document REV. Modified date CYNVC-205-046 A0 2020.5.22 CYNVC-205-046 A1 2020.9.6 CYNVC-205-046 A2 2020.9.21 CYNVC-205-046 A3 2020.10.05 CYNVC-205-046 A4 2020.10.20 CYNVC-205-046 A5 2020.11.13 CYNVC-205-046 A6 2020.12.23 CYNVC-205-046 A7 2020.12.28 CYNVC-205-046 A8 2021.3.19 CYNVC-205-046 A9 2021.6.11 CYNVC-205-046 B0 2021.7.23 CYNVC-205-046 B1 2021.12.13 CYNVC-205-046 B2 2022.4.22 Description New approval 1. May -> Sep. 2. Update Land Pattern B: 3.3 -> 2.8 3. Add spec R47, 4R7, 6R8, 220, 330, 470 4. Remove spec 101 Update 470 DCR(Typ.): 177 -> 203 ; DCR(Max.): 212 -> 225 1. Sep. -> Oct. 2. Update 470 DCR(Max.): 225 -> 240 3. Add curve R47, 220 1. Update 6R8 DCR(Typ.): 30.3 -> 33.0 ; DCR(Max.): 36.0 -> 39.6 ; Idc(Typ.): 5.4 -> 5.2 ; Idc(Max.): 4.9 -> 4.7 2. Update 330 DCR(Typ.): 132 -> 121 ; Idc(Max.): 2.3 -> 2.4 1. Oct. -> Nov. 2. Update 4R7 Isat(Max.): 12.1 -> 11.2 3. Update 330 Isat(Max.): 3.8 -> 3.5 1. Nov. -> Dec. 2. Update Outline Dimensions H: 0 ~ + 0.15 -> 0.05 ~ 0.20 3. Add spec 3R3, 100, 150, 101 4. Add curve 470, 680 Update Outline Dimensions H: 0.05 ~ 0.20 -> 0.05 Min. 1. Dec., 2020 -> Mar.,2021 2. Remove Notice ”Preliminary specification” 3. Add notice ” Compliance with AEC-Q200” in Features 4. Add curve R22, 3R3, 4R7, 6R8, 150 1. Mar. -> Jun. 2. Add spec 1R0 3. Add curve 100, 330, 101 Add Rated Voltage 1. Jul. -> Dec. 2. Remove Notice ” Compliance with AEC-Q200” in Features 3. Add notice ”AEC-Q200 qualified” in Features 4. Add “AEC-Q200” logo 1. Dec., 2021 -> Apr., 2022 2. Add spec 1R5, 2R2 Apr., 2022 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 2 OF 9 Power Choke Coil VCUW064E MS5 type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 4.5mm Low loss realized with low DCR Capable of corresponding high frequency Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions L A' W B' B B1 A1 H  T Code Dimensions (mm) L 6.95  0.35 W 6.6  0.2 T 4.3  0.2 A1 1.5  0.3 A’ 2.6  0.1 B 3.0  0.3 B1 4.3  0.3 B’ 3.6  0.2 H 0.05 Min. Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 3.5 B 2.8 C 8.4 Unit : mm Apr., 2022 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 3 OF 9 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 0.22H  R22 (2) Date Code Upside of Chip X XX (1) (2) XXX (3) Where PIN 2 R22 XXX XXX (1) Year Code Ex : 2022 = 2 PIN 1 Coil clockwise around (2) Weekly Code Serial number : 01 ~ 53 (3) Taping No. Serial number : 001 ~ ZZZ Apr., 2022 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 4 OF 9 Specifications Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum Maximum 2.0 2.4 22.2 20.0 57.2 49.0 70 0.47 3.0 3.6 18.1 16.3 25.0 21.0 70 VCUW064E-1R0MS5 1.0 5.2 6.2 13.3 12.0 23.9 16.5 70 VCUW064E-1R5MS5 1.5 6.7 8.1 11.6 10.4 19.7 15.0 70 VCUW064E-2R2MS5 2.2 9.5 11.4 9.8 8.8 19.4 14.0 70 VCUW064E-3R3MS5 3.3 15.7 18.8 7.6 6.8 17.7 13.5 70 VCUW064E-4R7MS5 4.7 20.2 24.2 6.7 6.1 14.8 11.2 70 VCUW064E-6R8MS5 6.8 33.0 39.6 5.2 4.7 12.1 10.1 70 VCUW064E-100MS5 10.0 47.9 57.5 4.3 3.9 9.6 8.2 70 VCUW064E-150MS5 15.0 66.0 79.2 3.7 3.4 6.2 5.3 70 VCUW064E-220MS5 22.0 86.7 104.0 3.2 2.9 5.2 4.1 70 VCUW064E-330MS5 33.0 121.0 145.2 2.7 2.4 4.4 3.5 70 VCUW064E-470MS5 47.0 203.0 240.0 2.3 2.1 4.2 3.3 70 VCUW064E-680MS5 68.0 312.0 374.0 1.8 1.6 3.9 3.0 70 VCUW064E-101MS5 100.0 413.0 496.0 1.50 1.35 2.4 2.1 70 L0 ◇ Inductance ( H ) @ (0A) Typical VCUW064E-R22MS5 0.22 VCUW064E-R47MS5 Part Number Rdc ( m ) ◇ Rated Voltage (V) ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +155℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Apr., 2022 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 0.16 60 0.12 40 INDUCTANCE(μH) PAGE : 5 OF 9 TEMP. RISE(℃) 20 20 30 40 50 60 TEMP. RISE(℃) 20 0.00 0 0 70 5 10 INDUCTANCE(μH) 60 TEMP. RISE(℃) 40 0.40 0.20 0.00 6 9 12 15 18 21 24 INDUCTANCE(μH) 0.80 TEMP. RISE(℃) 80 3 80 60 INDUCTANCE(μH) 0.9 0.3 0 0.0 20 0 0 4 8 20 0.4 INDUCTANCE(μH) 40 TEMP. RISE(℃) TEMP. RISE(℃) 60 INDUCTANCE(μH) 9 12 15 80 TEMP. RISE(℃) 40 1.0 0.0 10 DC BIAS(Amps) 13 15 INDUCTANCE(μH) TEMP. RISE(℃) 2.0 TEMP. RISE(℃) 60 INDUCTANCE(μH) 8 40 1.4 20 0.7 0 3 6 9 12 15 18 VCUW064E-6R8MS5 8.4 100 4.0 5 60 INDUCTANCE(μH) 2.1 0 80 3 100 DC BIAS(Amps) 5.0 0 24 2.8 18 VCUW064E-4R7MS5 3.0 20 3.5 DC BIAS(Amps) 6.0 16 0.0 0 0.0 6 12 VCUW064E-3R3MS5 4.2 100 1.6 3 40 TEMP. RISE(℃) 0.6 20 80 0 100 DC BIAS(Amps) 2.0 0.8 30 1.2 27 VCUW064E-2R2MS5 1.2 25 1.5 DC BIAS(Amps) 2.4 20 VCUW064E-1R5MS5 1.8 100 1.00 0 15 DC BIAS(Amps) VCUW064E-1R0MS5 0.60 40 0.20 DC BIAS(Amps) 1.20 60 INDUCTANCE(μH) 0.30 TEMP. RISE(℃) 10 80 0.40 TEMP. RISE(℃) 0 0.50 0.10 0 0.00 100 100 7.0 80 5.6 60 INDUCTANCE(μH) 4.2 TEMP. RISE(℃) 40 2.8 20 1.4 0 0.0 TEMP. RISE(℃) 0.08 INDUCTANCE(μH) INDUCTANCE(μH) 80 0.04 INDUCTANCE(μH) : B2 VCUW064E-R47MS5 0.60 100 0.20 INDUCTANCE(μH) REVISION TEMP. RISE(℃) VCUW064E-R22MS5 0.24 INDUCTANCE(μH) : CYNVC-205-046 Current Characteristic TEMP. RISE(℃)  DOCUMENT 20 0 0 2 4 6 8 10 12 DC BIAS(Amps) Apr., 2022 Issued VCUW064E-100MS5 80 8.0 60 INDUCTANCE(μH) 40 TEMP. RISE(℃) 2.0 0.0 0 1 2 3 4 5 6 7 8 80 TEMP. RISE(℃) 0 0.0 20 0 0 100 42.0 80 35.0 40 4.5 0.0 4 5 INDUCTANCE(μH) TEMP. RISE(℃) 9.0 3 1 2 3 0 0.0 60 20 0 0.5 1.0 1.5 2.0 40 18.0 9.0 0.0 2.5 3.0 3.5 4.0 4.0 4.5 5.0 100 80 60 INDUCTANCE(μH) 42.0 TEMP. RISE(℃) 40 28.0 0 0.0 20 0 0.0 0.6 1.2 1.8 2.4 3.0 3.6 DC BIAS(Amps) 100 100.0 80 80.0 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 40.0 TEMP. RISE(℃) INDUCTANCE(μH) 3.5 56.0 14.0 4.5 VCUW064E-101MS5 60.0 3.0 70.0 20 DC BIAS(Amps) 120.0 2.5 VCUW064E-680MS5 84.0 INDUCTANCE(μH) TEMP. RISE(℃) INDUCTANCE(μH) TEMP. RISE(℃) 2.0 40 TEMP. RISE(℃) 0.0 60 INDUCTANCE(μH) 1.5 100 INDUCTANCE(μH) 14.0 7.0 80 1.0 7 80 21.0 20 100 36.0 0.5 6 DC BIAS(Amps) 45.0 0.0 5 28.0 6 VCUW064E-470MS5 27.0 4 VCUW064E-330MS5 DC BIAS(Amps) 54.0 40 6.0 3.0 60 INDUCTANCE(μH) 2 60 INDUCTANCE(μH) 9.0 20 TEMP. RISE(℃) INDUCTANCE(μH) 18.0 1 100 DC BIAS(Amps) 22.5 0 : 6 OF 9 12.0 9 VCUW064E-220MS5 13.5 PAGE 15.0 DC BIAS(Amps) 27.0 : B2 TEMP. RISE(℃) 4.0 REVISION TEMP. RISE(℃) 6.0 INDUCTANCE(μH) 10.0 : CYNVC-205-046 VCUW064E-150MS5 18.0 100 TEMP. RISE(℃) INDUCTANCE(μH) 12.0 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 20.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 DC BIAS(Amps) Apr., 2022 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 7 OF 9 Packaging (1) Tape packaging dimensions t 4.0 ± 0.1 2.0 ± 0.1 +0.1 1.5 -0.0 Sprocket hole 1.75 ± 0.10 7.5 ± 0.1 16.0 ± 0.3 B0 A0 K0 Carrier cavity 12.0 ± 0.1 Pulling direction Dimensions Code (mm) A0 B0 K0 t 7.0  0.1 7.4  0.1 5.1  0.1 0.50  0.05 UNITS/REEL 500 (2) Tape Direction The direction shall be seen from the top cover tape side. XXX XXX R22 XXX XXX R22 Pulling direction Apr., 2022 Issued XXX XXX R22 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 8 OF 9 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (3) Reel dimensions A 13.0 ± 1.0 mm A B 16.0  0.5 2.0  0.2 (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 1.3N. Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape Apr., 2022 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-205-046 REVISION : B2 PAGE : 9 OF 9 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds Apr., 2022 Issued
VCUW064E-330MS5 价格&库存
很抱歉,暂时无法提供与“VCUW064E-330MS5”相匹配的价格&库存,您可以联系我们找货
