VCHA075D-5R6MS6
VCHA075D-5R6MS6
    CYNTEC(乾坤)
    IND_7.7X7.2MM_SM
    功率电感 5.6µH ±20% IND_7.7X7.2MM_SM 5.20mm 7.70 x 7.20mm 24mΩ 5.9A
VCHA075D-5R6MS6 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 1 OF 9 The history of revision change for the specification Document  CYNVC‐175‐017  REV.  A0  Modified date  2017.5.16  CYNVC‐175‐017  A1  2017.6.19  CYNVC‐175‐017  A2  2018.3.13  CYNVC‐175‐017  A3  2018.10.23  CYNVC‐175‐017  A4  2020.1.21  CYNVC‐175‐017  A5  2020.6.15  CYNVC‐175‐017  A6  2020.9.9  Description  New approval  1. May ‐> Jun.  2. Add spec of 1R5, 3R3, 5R6, 8R2  3. Add curve of 1R5, 3R3, 5R6, 8R2  1. Add “AEC‐Q200” logo on page 2  2. Jun., 2017 ‐> Mar., 2018  3. Year code 2017 = 7 ‐> 2018 = 8  1. Mar. ‐> Oct.  2. Remove spec & curve of 560  1. Oct., 2018 ‐> Jan., 2020  2. Year code 2018 = 8 ‐> 2020 = 0  3. Add 560 spec and curve  1. Jan. ‐> Jun.  2. Add rated voltage  1. Jun. ‐> Sep.  2. Update Land Pattern B: 2.6 ‐> 2.55 ; C: 8.6 ‐> 9.26  Sep., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 2 OF 9 Power Choke Coil VCHA075D MS6 type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 5.4 mm Low loss realized with low DCR Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions L A' Code W B' B B1 A1 H  T Dimensions (mm) L 7.70  0.35 W 7.2  0.3 T 5.2  0.2 A1 2.0  0.3 A’ 2.1  0.3 B 3.0  0.3 B1 5.4  0.3 B’ 3.6  0.3 H 0 ~ + 0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 3.50 B 2.55 C 9.26 Unit : mm Sep., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 3 OF 9 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 4.7H  4R7 Upside of Chip (2) Date Code PIN 2 X XX (1) (2) XXX (3) 4R7 XXX XXX PIN 1 Where (1) Year Code Coil clockwise around Ex : 2020 = 0 (2) Weekly Code Serial number : 01 ~ 53 (3) Taping No. Serial number : 001 ~ ZZZ Sep., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 4 OF 9 Specifications Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum Maximum 6.1 7.3 11.4 10.3 16.3 14.0 80 2.2 9.5 11.4 9.7 8.7 14.8 12.7 80 VCHA075D-3R3MS6 3.3 14.0 15.4 8.0 7.2 13.5 11.6 80 VCHA075D-4R7MS6 4.7 19.0 20.9 7.0 6.3 13.1 11.2 80 VCHA075D-5R6MS6 5.6 21.5 24.0 6.5 5.9 10.6 9.1 80 VCHA075D-6R8MS6 6.8 24.2 26.6 6.1 5.5 10.2 8.7 80 VCHA075D-8R2MS6 8.2 29.0 31.9 5.6 5.0 9.0 7.7 80 VCHA075D-100MS6 10.0 34.5 38.0 5.2 4.7 8.0 6.9 80 VCHA075D-150MS6 15.0 60.0 66.0 3.8 3.4 6.9 5.9 80 VCHA075D-220MS6 22.0 85.0 93.5 3.3 3.0 6.3 5.4 80 VCHA075D-330MS6 33.0 116.0 127.6 3.2 2.8 4.9 4.2 80 VCHA075D-470MS6 47.0 156.0 171.6 2.4 2.2 4.1 3.5 80 VCHA075D-560MS6 56.0 182.0 209.3 2.2 2.0 3.3 2.8 80 VCHA075D-680MS6 68.0 222.0 255.0 2.0 1.8 2.8 2.4 80 L0 ◇ Inductance ( H ) @ (0A) Typical VCHA075D-1R5MS6 1.5 VCHA075D-2R2MS6 Part Number Rdc ( m ) ◇ Rated Voltage (V) ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +165℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 165℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Sep., 2020 Issued 1.20 TEMP. RISE(℃) 2.00 40 0.60 20 0.30 6 8 10 12 14 DC BIAS(Amps) 16 18 20 60 TEMP. RISE(℃) 40 0.00 12 14 4.80 2.40 TEMP. RISE(℃) 0.00 4 INDUCTANCE(μH) 9.60 5 6 7 8 9 DC BIAS(Amps) 10 11 12 8.00 6.40 3.20 TEMP. RISE(℃) 3 4 5 6 7 DC BIAS(Amps) 16 18 20 100 60 40 20 0 1 2 3 4 5 6 7 8 9 10 11 12 13 8 9 10 11 VCHA075D-6R8MS6 100 80 60 4.20 INDUCTANCE(μH) 2.80 TEMP. RISE(℃) 40 20 1.40 0.00 12.0 80 10.0 0 0.00 2 14 5.60 100 20 1 12 INDUCTANCE(μH) 0 0 40 1.60 0 10 TEMP. RISE(℃) 7.00 60 INDUCTANCE(μH) 8 2.00 13 VCHA075D-8R2MS6 4.80 6 80 3.00 80 INDUCTANCE(μH) 3 4 VCHA075D-4R7MS6 0 0 2 0 2 0.00 20 1 20 4.00 8.40 40 1.20 0 40 5.00 100 60 INDUCTANCE(μH) TEMP. RISE(℃) DC BIAS(Amps) 6.00 3.60 0.80 16 VCHA075D-5R6MS6 7.20 INDUCTANCE(μH) 8 10 DC BIAS(Amps) INDUCTANCE(μH) 6 TEMP. RISE(℃) 4 INDUCTANCE(μH) 1.00 0 2 60 1.20 6.00 20 0.70 0 80 0 100 2.80 1.40 100 0.00 80 INDUCTANCE(μH) VCHA075D-2R2MS6 DC BIAS(Amps) 3.50 2.10 : 5 OF 9 1.60 22 VCHA075D-3R3MS6 4.20 PAGE TEMP. RISE(℃) 4 INDUCTANCE(μH) 2 TEMP. RISE(℃) 0 : A6 0.40 0 0.00 INDUCTANCE(μH) 80 60 INDUCTANCE(μH) 0.90 2.40 REVISION TEMP. RISE(℃) 1.50 100 : CYNVC-175-017 TEMP. RISE(℃) VCHA075D-1R5MS6 DOCUMENT 2 4 6 8 DC BIAS(Amps) 10 12 VCHA075D-100MS6 100 80 8.0 60 INDUCTANCE(μH) 6.0 TEMP. RISE(℃) 40 4.0 TEMP. RISE(℃) 1.80 INDUCTANCE(μH) Current Characteristic TEMP. RISE(℃)  TEMP. RISE(℃) INDUCTANCE(μH) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 2.0 0.0 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 10 Sep., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 20 3.0 0 1 2 3 6 7 TEMP. RISE(℃) 60 21.0 INDUCTANCE(μH) 14.0 TEMP. RISE(℃) 40 20 7.0 0.0 2 72.0 3 4 DC BIAS(Amps) 5 60.0 48.0 INDUCTANCE(μH) 24.0 TEMP. RISE(℃) 0.0 0.5 1.0 1.5 2.0 2.5 3.0 DC BIAS(Amps) 3.5 4.0 4.5 2 3 4 5 DC BIAS(Amps) 6 7 8 VCHA075D-470MS6 100 80 60 27.0 INDUCTANCE(μH) 18.0 TEMP. RISE(℃) 40 20 0.0 0 0.0 70.0 0 0.0 0 1 36.0 80 20 12.0 20 45.0 84.0 40 40 4.5 100 60 36.0 TEMP. RISE(℃) 9.0 6 VCHA075D-560MS6 60 INDUCTANCE(μH) 13.5 9.0 INDUCTANCE(μH) 1 80 54.0 0 0 100 VCHA075D-220MS6 0 80 28.0 : 6 OF 9 0.0 100 35.0 PAGE 18.0 8 VCHA075D-330MS6 42.0 INDUCTANCE(μH) 4 5 DC BIAS(Amps) INDUCTANCE(μH) 0 : A6 TEMP. RISE(℃) 40 REVISION TEMP. RISE(℃) TEMP. RISE(℃) 6.0 0.0 INDUCTANCE(μH) 22.5 60 INDUCTANCE(μH) 9.0 80 : CYNVC-175-017 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 4.0 4.5 5.0 100 VCHA075D-680MS6 80 56.0 60 42.0 INDUCTANCE(μH) 28.0 TEMP. RISE(℃) 40 TEMP. RISE(℃) 12.0 27.0 INDUCTANCE(μH) 15.0 100 TEMP. RISE(℃) VCHA075D-150MS6 TEMP. RISE(℃) INDUCTANCE(μH) 18.0 DOCUMENT 20 14.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 DC BIAS(Amps) 3.0 3.5 4.0 Sep., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 7 OF 9 Packaging (1) Tape packaging dimensions 4.0 ± 0.1 t 2.0 ± 0.1 +0.1 1.5 -0.0 Sprocket hole 1.75 ± 0.10 7.5 ± 0.1 16.0 ± 0.3 B0 A0 K0 Carrier cavity Pulling direction 12.0 ± 0.1 Dimensions Code (mm) UNITS/REEL A0 B0 K0 t 7.7  0.1 8.2  0.1 6.0  0.1 0.50  0.05 500 (2) Tape Direction The direction shall be seen from the top cover tape side. XXX XXX 4R7 XXX XXX 4R7 Pulling direction Sep., 2020 Issued XXX XXX 4R7 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 8 OF 9 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (3) Reel dimensions A 13.0 ± 1.0 mm A B 16.0  0.5 2.0  0.2 (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 1.3N. Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape Sep., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-017 REVISION : A6 PAGE : 9 OF 9 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds. Sep., 2020 Issued
VCHA075D-5R6MS6 价格&库存
很抱歉,暂时无法提供与“VCHA075D-5R6MS6”相匹配的价格&库存,您可以联系我们找货
