CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 1 OF 9
The history of revision change for the specification
Document
REV.
Modified date
CYNVC‐175‐018
A0
2017.5.31
CYNVC‐175‐018
A1
2017.6.19
CYNVC‐175‐018
A2
2017.11.13
CYNVC‐175‐018
A3
2018.3.13
CYNVC‐175‐018
A4
2018.6.15
CYNVC‐175‐018
A5
2018.11.13
CYNVC‐175‐018
A6
2019.9.16
CYNVC‐175‐018
A7
2020.1.21
CYNVC‐175‐018
A8
2020.6.15
CYNVC‐175‐018
A9
2020.9.9
CYNVC‐175‐018
B0
2020.12.1
Description
New Approval
1. May ‐> Jun.
2. Remove spec of 101
3. Remove curve of 101
4. Add spec of 120
1. Add curve of 120
2. Jun. ‐> Nov.
1. Add “AEC‐Q200” logo on page 2
2. Nov., 2017 ‐> Mar., 2018
3. Year code 2017 = 7 ‐> 2018 = 8
1. Mar. ‐> Jun.
2. Add spec of R22
3. Add curve of R22
1. Jun. ‐> Nov.
2. Remove spec & curve of R22, 120
1. Nov., 2018 ‐> Sep., 2019
2. Add spec & curve of 101
1. Sep., 2019 ‐> Jan., 2020
2. Year code 2019 = 9 ‐> 2020 = 0
1. Jan. ‐> Jun.
2. Add spec and curve of R68
3. Add rated voltage
1. Jun. ‐> Sep.
2. Update Land Pattern A: 4.95 ‐> 5.0 ; B: 5.4 ‐> 4.9 ; C: 13.6 ‐> 12.88
1. Sep. ‐>Dec.
2. Add spec and curve of 1R5
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 2 OF 9
Power Choke Coil VCHA105D MS6 type
AEC-Q200
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 5.4mm
Low loss realized with low DCR
Compliance with RoHS and Halogen Free
AEC-Q200 qualified
Application
Automotive applications
Outline Dimensions
L
A'
Code
W
B'
B
A1
H
T
B1
Dimensions (mm)
L
10.85 0.35
W
10.0 0.3
T
5.2 0.2
A1
2.2 0.5
A’
2.5 0.1
B
4.5 0.3
B1
6.5 0.3
B’
6.0 0.3
H
0 ~ + 0.15
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
5.00
B
4.90
C
12.88
Unit : mm
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 3 OF 9
Marking and Date Code
The point on the top surface represents winding direction of choke.
(1) Marking
The inductor is marked with a 3-digit code
Example – – 1.0H 1R0
Upside of Chip
(2) Date Code
PIN 1
X
XX
(1)
(2)
XXX
(3)
Where
1R0
PIN 2
XXX
XXX
(1) Year Code
Coil clockwise around
Ex : 2020 = 0
(2) Weekly Code
Serial number : 01 ~ 53
(3) Taping No.
Serial number : 001 ~ ZZZ
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 4 OF 9
Specifications
Part Number
L0 ◇
Inductance
( H )
@ (0A)
Rdc ( m ) ◇
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Rated Voltage
(V)
Typical
Maximum
Typical
Maximum
Typical
Maximum
Maximum
VCHA105D-R68MS6
0.68
1.85
2.22
32.0
28.8
46.0 Note 5
39.4 Note 5
80
VCHA105D-1R0MS6
1.0
2.30
2.76
30.0
27.0
37.0
31.7
80
VCHA105D-1R5MS6
1.5
3.50
4.20
24.8
22.3
26.8
23.0
80
VCHA105D-2R2MS6
2.2
4.1
4.9
23.0
20.7
25.0
21.4
80
VCHA105D-3R3MS6
3.3
6.2
7.4
18.7
16.8
19.0
16.3
80
VCHA105D-4R7MS6
4.7
8.3
10.0
14.5
13.0
15.7
13.5
80
VCHA105D-6R8MS6
6.8
12.0
14.0
12.0
10.8
13.3
11.4
80
VCHA105D-100MS6
10.0
21.0
24.2
8.7
7.8
12.7
10.9
80
VCHA105D-150MS6
15.0
27.2
31.3
7.6
6.8
9.2
7.9
80
VCHA105D-220MS6
22.0
43.5
50.0
6.0
5.4
8.8
7.5
80
VCHA105D-330MS6
33.0
65.5
75.3
4.8
4.3
7.6
6.5
80
VCHA105D-470MS6
47.0
89.0
103.0
4.1
3.6
4.9
4.2
80
VCHA105D-680MS6
68.0
132.0
152.0
3.3
3.0
4.2
3.6
80
VCHA105D-101MS6
100.0
203.0
234.0
2.8
2.5
3.5
3.0
55
◇:Significant Characteristic
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Isat : DC current (A) that will cause L0 to drop approximately 35%
Note 6.: Operating Temperature Range -55℃ to +165℃
Note 7.: The part temperature (ambient + temp rise) should not exceed 165℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other
cooling provision all affect the part temperature. Part temperature should be verified in the end
application.
Note 8.: The rated current as listed is either the saturation current or the heating current depending on which
value is lower.
Note 9.: Cleaning Process Note
(a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether
system, there is a possibility that the performance decreases greatly
(b) The high power ultrasonic washing may damage the choke body.
(c) Please contact us if you need the cleaning via the above agents or ultrasonic washing.
Dec., 2020 Issued
1.00
60
0.42
INDUCTANCE(μH)
0.28
TEMP. RISE(℃)
40
5
10
15
25 30 35 40
DC BIAS(Amps)
45
50
55
1.50
80
1.20
60
INDUCTANCE(μH)
0.90
TEMP. RISE(℃)
40
0.60
0.00
80
TEMP. RISE(℃)
10
15
DC BIAS(Amps)
1.40
TEMP. RISE(℃)
TEMP. RISE(℃)
0.00
6
9
12
15
18
21
DC BIAS(Amps)
6
9
18
21
7.00
5.60
TEMP. RISE(℃)
0.00
2
4
6
8
10
12
DC BIAS(Amps)
14
16
18
2.00
TEMP. RISE(℃)
80
10.0
INDUCTANCE(μH)
12.0
100
80
3.00
100
40
2.80
30
VCHA105D-4R7MS6
INDUCTANCE(μH)
4.20
27
4.00
24
VCHA105D-6R8MS6
8.40
INDUCTANCE(μH)
12
15
DC BIAS(Amps)
INDUCTANCE(μH)
3
24
1.00
0.45
5.00
60
INDUCTANCE(μH)
0.90
80
40
100
80
1.35
6.00
INDUCTANCE(μH)
INDUCTANCE(μH)
40
1.80
100
60
2.10
35
VCHA105D-2R2MS6
TEMP. RISE(℃)
2.80
30
0.00
TEMP. RISE(℃)
INDUCTANCE(μH)
3.50
40
0.40
DC BIAS(Amps)
VCHA105D-3R3MS6
60
INDUCTANCE(μH)
0.60
2.25
0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36
4.20
100
0.80
2.70
VCHA105D-1R0MS6
VCHA105D-1R5MS6
: 5 OF 9
0.00
60
INDUCTANCE(μH)
PAGE
0.20
INDUCTANCE(μH)
80
: B0
TEMP. RISE(℃)
0.56
1.20
REVISION
TEMP. RISE(℃)
0.70
100
: CYNVC-175-018
TEMP. RISE(℃)
VCHA105D-R68MS6
DOCUMENT
2
4
6
8
10 12 14
DC BIAS(Amps)
16
18
VCHA105D-100MS6
100
80
8.0
60
6.0
INDUCTANCE(μH)
4.0
TEMP. RISE(℃)
40
TEMP. RISE(℃)
0.84
INDUCTANCE(μH)
Current Characteristic
TEMP. RISE(℃)
TEMP. RISE(℃)
INDUCTANCE(μH)
CYNTEC CO., LTD.
乾坤科技股份有限公司
0.0
4
6
8
10
DC BIAS(Amps)
12
14
16
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
40
3
4
42.0
5
14.0
TEMP. RISE(℃)
2
3
4
5
6
DC BIAS(Amps)
7
8
80
56.0
60
INDUCTANCE(μH)
28.0
TEMP. RISE(℃)
40
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
DC BIAS(Amps)
5
6
7
8
DC BIAS(Amps)
9
10
11
12
VCHA105D-470MS6
100
80
60
INDUCTANCE(μH)
27.0
TEMP. RISE(℃)
40
18.0
2
120.0
100
70.0
42.0
4
3
4
5
6
7
DC BIAS(Amps)
VCHA105D-680MS6
84.0
3
36.0
9
4.0
4.5
5.0
5.5
INDUCTANCE(μH)
0.0
45.0
40
7.0
40
TEMP. RISE(℃)
INDUCTANCE(μH)
TEMP. RISE(℃)
21.0
60
INDUCTANCE(μH)
0.0
80
28.0
80
4.0
100
35.0
100
8.0
6 7 8 9 10 11 12 13 14
DC BIAS(Amps)
VCHA105D-330MS6
: 6 OF 9
VCHA105D-220MS6
12.0
INDUCTANCE(μH)
2
PAGE
16.0
: B0
TEMP. RISE(℃)
TEMP. RISE(℃)
REVISION
TEMP. RISE(℃)
6.0
: CYNVC-175-018
100
VCHA105D-101MS6
100.0
80
80.0
60
INDUCTANCE(μH)
60.0
TEMP. RISE(℃)
40
40.0
TEMP. RISE(℃)
INDUCTANCE(μH)
INDUCTANCE(μH)
20.0
60
9.0
0.0
INDUCTANCE(μH)
80
INDUCTANCE(μH)
12.0
24.0
TEMP. RISE(℃)
INDUCTANCE(μH)
15.0
100
TEMP. RISE(℃)
VCHA105D-150MS6
18.0
DOCUMENT
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
DC BIAS(Amps)
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 7 OF 9
Packaging
(1) Tape packaging dimensions
4.0 ± 0.1
t
2.0 ± 0.1
+0.1
1.5 -0.0
1.75 ± 0.10
Sprocket hole
11.5 ± 0.1
24.0 ± 0.3
B0
A0
Carrier cavity
K0
16.0 ± 0.1
Pulling direction
Dimensions Code (mm)
A0
B0
K0
t
10.7 0.1
12.0 0.1
6.0 0.1
0.50 0.05
UNITS/REEL
500
(2) Tape Direction
The direction shall be seen from the top cover tape side.
1R0
XXX
XXX
1R0
XXX
XXX
1R0
XXX
XXX
Pulling direction
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 8 OF 9
2.0 ± 0.5
20.0 ± 0.5
B
330.0 ± 2.0
100.0 ± 1.0
(3) Reel dimensions
A
13.0 ± 1.0
mm
A
B
24.5 0.5
2.0 0.2
(4) Peel force of top cover tape
The peel speed shall be about 300 mm/minute.
The peel force of top cover tape shall be between 0.1 to 1.3N.
Top Cover Tape
165 ~ 180°
0.1 ~ 1.3N
Carrier tape
Dec., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-175-018
REVISION
: B0
PAGE
: 9 OF 9
Reflow Profile
Power Choke Coil Type
Tp
Temperature
260℃
tp:30 Sec max.
Max. Ramp Up Rate =3℃/s
Max. Ramp Down Rate =6℃/s
217℃
60~150 Sec
Preheat Area
200℃
150℃
60~120 Sec
25℃
25°C to Peak ( 8 minutes max.)
Time
(1) Reflow Soldering Method :
Reflow Soldering
Tp:255~260℃
Max.30 seconds ( tp )
217℃
60~150 seconds
Pre-Heat
150 ~ 200℃
60~120 seconds
Time 25℃ to peak temperature
8 minutes max.
(2) Soldering iron Method : 350 5℃ max.3 seconds
Dec., 2020 Issued
很抱歉,暂时无法提供与“VCHA105D-6R8MS6”相匹配的价格&库存,您可以联系我们找货
