CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: SDEM20161T-000
REVISION
: A4
PAGE
: 1 OF 4
Sealed Choke Coil SDEM20161T type
Features
Low profile:2.0mm x 1.6mm x 1.0mm
High performance (Isat) realized by metal dust core.
Low loss realized with low DCR
High magnetic shield construction should actualize high resolution for EMC.
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc..
VRM for server
Outline Dimensions
W
Code
L
Dimensions (mm)
L
1.6 0.1
W
2.0 0.1
T
1.0 Max.
T
Note :This graph is in regard to outline dimensions spec. For outer appearance, please refer to actual product.
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
1.6
B
0.7
C
2.0
Unit : mm
Jan., 2018
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: SDEM20161T-000
REVISION
: A4
PAGE
: 2 OF 4
Specifications
L0
Inductance
( H )
@ (0A)
Typical
Maximum
SDEM20161T-R24MS
0.24
5.0
4.50
6.1
5.50
SDEM20161T-R33MS
0.33
27
32
4.0
3.60
4.6
4.10
SDEM20161T-R47MS
0.47
34
41
3.5
3.00
4.4
3.90
SDEM20161T-R68MS
0.68
46
55
3.2
2.80
3.7
3.30
SDEM20161T-1R0MS
1.0
60
72
2.7
2.40
3.15
2.70
SDEM20161T-1R5MS
1.5
100
120
2.4
2.16
2.7
2.43
SDEM20161T-2R2MS
2.2
134
159
1.8
1.60
1.9
1.70
SDEM20161T-3R3MS
3.3
255
306
1.2
1.08
1.5
1.35
SDEM20161T-4R7MS
4.7
355
426
1.1
1.00
1.4
1.26
SDEM20161T-6R8MS
6.8
532
639
0.8
0.72
1.15
1.05
SDEM20161T-100MS
10.0
840
1010
0.7
0.63
0.8
0.72
Part Number
Rdc ( m )
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Typical
Typical
Maximum
Maximum
*:If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:1MHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △ T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to +125℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is
lower.
Jan., 2018
CYNTEC CO., LTD.
乾坤科技股份有限公司
INDUCTANCE(μH)
40
TEMP. RISE(℃)
0.10
3
4
5
DC BIAS(Amps)
6
7
0.50
0.40
INDUCTANCE(μH)
0.20
TEMP. RISE(℃)
3
4
DC BIAS(Amps)
5
0.80
TEMP. RISE(℃)
0.00
1.2
1.6
2.0
2.4
2.8
3.2
3.6
TEMP.RISE(℃)
0.8
0.00
1.2
1.6
2.0
DC BIAS(Amps)
1.6
2.0
2.4
2.8
3.2
3.6
4.0
4.4
100
SDEM20161T-1R5MS
80
60
40
0.60
INDUCTANCE(μH)
0.30
TEMP. RISE(℃)
0.00
3.50
2.4
2.8
3.2
INDUCTANCE(μH)
80
1.2
0.90
4.20
40
1.20
100
40
0.45
0.0
100
60
TEMP. RISE(℃)
8.0
0.14
1.50
TEMP. RISE(℃)
INDUCTANCE(μH)
1.80
0.90
7.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
DC BIAS(Amps)
2.25
INDUCTANCE(μH)
6.0
60
0.28
80
4.0
SDEM20161T-2R2MS
1.35
5.0
80
DC BIAS(Amps)
2.70
4.0
INDUCTANCE(μH)
1.80
3.0
0.42
100
2.0
SDEM20161T-R68MS
0.0
40
0.20
0.0
1.0
0.00
60
0.40
10
DC BIAS(Amps)
1.00
INDUCTANCE(μH)
TEMP. RISE(℃)
0.56
6
SDEM20161T-1R0MS
0.60
INDUCTANCE(μH)
INDUCTANCE(μH)
1.20
0.07
80
2
30
0.14
0.84
40
100
40
0.10
0.21
0.0
60
0.30
60
DC BIAS(Amps)
SDEM20161T-R47MS
0.60
70
0.28
8
INDUCTANCE(μH)
2
TEMP. RISE(℃)
1
80
SDEM20161T-R33MS
0.00
: 3 OF 4
TEMP. RISE(℃)
60
0.15
0.00
INDUCTANCE(μH)
TEMP. RISE(℃)
0.20
PAGE
0.35
80
TEMP. RISE(℃)
INDUCTANCE(μH)
0.25
INDUCTANCE(μH)
0.42
100
: A4
TEMP. RISE(℃)
SDEM20161T-R24MS
REVISION
TEMP. RISE(℃)
0.30
: SDEM20161T-000
SDEM20161T-3R3MS
100
80
2.80
60
2.10
40
1.40
INDUCTANCE(μH)
0.70
TEMP. RISE(℃)
0.00
0.4
0.6 0.8 1.0
1.2 1.4 1.6 1.8
DC BIAS(Amps)
2.0
2.2 2.4
Jan., 2018
TEMP. RISE(℃)
Current Characteristic
INDUCTANCE(μH)
DOCUMENT
CYNTEC CO., LTD.
乾坤科技股份有限公司
60
3.0
40
2.0
INDUCTANCE(μH)
1.0
0.0
0.2
0.4
0.6
0.8 1.0 1.2 1.4
DC BIAS(Amps)
1.6
1.8
2.0
100
7.00
80
5.60
60
4.20
40
TEMP. RISE(℃)
0.2
0.4
0.6
0.8
1.0
1.2
DC BIAS(Amps)
1.4
1.6
1.8
100
10.0
INDUCTANCE(μH)
: 4 OF 4
INDUCTANCE(μH)
2.2
SDEM20161T-100MS
12.0
PAGE
2.80
TEMP. RISE(℃)
0.0
INDUCTANCE(μH)
4.0
TEMP. RISE(℃)
80
: A4
80
8.0
60
6.0
40
4.0
INDUCTANCE(μH)
2.0
TEMP. RISE(℃)
INDUCTANCE(μH)
5.0
REVISION
SDEM20161T-6R8MS
8.40
100
: SDEM20161T-000
TEMP. RISE(℃)
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
DC BIAS(Amps)
Jan., 2018
TEMP..RISE(℃)
SDEM20161T-4R7MS
6.0
DOCUMENT
很抱歉,暂时无法提供与“SDEM20161T-R47MS”相匹配的价格&库存,您可以联系我们找货
