VCMT053T-R33MN52M
VCMT053T-R33MN52M
    CYNTEC(乾坤)
    SMD,5.45x5.25mm
    功率电感 330nH ±20% IND_5.45X5.25MM_SM 2.80mm 5.45 x 5.25mm 5mΩ 9.6A
VCMT053T-R33MN52M 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 1 OF 9 The history of revision change for the specification Document  REV.  Modified date  Description  CYNVC‐19Y‐032  A0  2019.11.12  CYNVC‐19Y‐032  A1  2020.1.15  CYNVC‐19Y‐032  A2  2020.2.14  CYNVC‐19Y‐032  A3  2020.4.7  CYNVC‐19Y‐032  A4  2020.4.10  CYNVC‐19Y‐032  A5  2021.6.10  New approval  1. Nov., 2019 ‐> Jan., 2020  2. Year code 2019 = 9 ‐> 2020 = 0  3. Remove frequency: (1MHz) from Features  1. Jan., ‐> Feb.,  2. Add 1R0, 1R5, 2R2 spec and curve.  1. Feb., ‐> Apr.,  2. Add R47 spec and curve.  1. Add “AEC‐Q200” logo  2. Add notice ”AEC‐Q200 qualified” in Features  3. Remove Notice ”Preliminary specification”  1. Apr., 2020 ‐> Jun., 2021  2. Year code 2020 = 0 ‐> 2021 = 1  3.Update carrier size    Width: 16.0 ‐> 12.0 ; F: 7.5 ‐> 5.5 (From sprocket hole to carrier hole)  4. Update Reel size  A: 16.0 ± 0.5 ‐> 12.5 ± 0.5  Jun., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 2 OF 9 Power Choke Coil VCMT053T MN52M type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 3.0mm Low loss realized with low DCR Capable of corresponding high frequency Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions A' L B B' W A1 H  T Code Dimensions (mm) L 5.45  0.35 W 5.25  0.20 T 2.8  0.2 A1 1.02  0.30 A’ 1.5  0.1 B 2.540  0.254 B’ 3.5  0.2 H 0 ~ + 0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.79 B 2.946 C 6.756 Unit : mm Jun., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 3 OF 9 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 4.7H  4R7 Upside of Chip (2) Date Code PIN 2 X XX (1) (2) XXX (3) 4R7 XXX XXX PIN 1 Where (1) Year Code Coil clockwise around Ex : 2021 = 1 (2) Weekly Code Serial number : 01 ~ 53 (3) Taping No. Serial number : 001 ~ ZZZ Jun., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 4 OF 9 Specifications L0 ◇ Inductance ( H ) @ (0A) Typical VCMT053T-R33MN52M 0.33 VCMT053T-R47MN52M Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum Maximum 4.5 5.0 16.7 15.0 11.2 9.6 50 0.47 6.9 7.9 12.4 11.2 14.0 12.0 50 VCMT053T-R68MN52M 0.68 8.6 9.74 11.3 10.2 11.7 10.0 50 VCMT053T-1R0MN52M 1.0 10.0 11.5 10.8 9.7 8.0 6.5 50 VCMT053T-1R5MN52M 1.5 15.4 17.7 8.2 7.4 7.1 5.9 50 VCMT053T-2R2MN52M 2.2 20.0 23.0 7.1 6.4 6.3 5.1 50 VCMT053T-3R3MN52M 3.3 33.0 38.0 5.5 5.0 5.5 4.7 50 VCMT053T-4R7MN52M 4.7 51.0 59.0 4.4 3.9 4.5 3.9 50 VCMT053T-6R8MN52M 6.8 80.0 92.0 3.5 3.1 3.5 3.0 50 VCMT053T-100MN52M 10.0 112.6 129.5 2.8 2.5 2.35 2.0 50 VCMT053T-150MN52M 15.0 170.0 196.0 2.4 2.2 2.2 1.9 50 Part Number Rdc ( m ) ◇ Rated voltage (V) ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 20% Note 5.: Operating Temperature Range -55℃ to +155℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Jun., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 REVISION : A5 PAGE : 5 OF 9 20 0.07 6 8 VCMT053T-R68MN52M 0.84 0.70 0.56 TEMP. RISE(℃) 100 1.20 80 1.00 0.00 18 21 VCMT053T-1R5MN52M 1.80 1.50 1.20 INDUCTANCE(μH) 0.60 TEMP. RISE(℃) 0.00 2 3 4 5 6 7 8 9 DC BIAS(Amps) 10 11 12 3.50 2.80 INDUCTANCE(μH) 1.40 TEMP. RISE(℃) 0.00 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 0 2 4 6 8 10 12 DC BIAS(Amps) 14 16 18 VCMT053T-2R2MN52M 100 80 60 INDUCTANCE(μH) 0.80 TEMP. RISE(℃) 40 20 0.00 80 5.00 0 0 20 1.20 6.00 20 0.70 40 1.60 100 40 100 0.20 0 0 60 2.10 25 0.40 13 VCMT053T-3R3MN52M 4.20 TEMP. RISE(℃) 2.00 INDUCTANCE(μH) 1 23 60 0.40 80 0 0 20 80 INDUCTANCE(μH) 2.40 20 0.30 10 13 15 18 DC BIAS(Amps) 0.60 100 40 8 VCMT053T-1R0MN52M 0 60 0.90 5 0.80 24 INDUCTANCE(μH) 9 12 15 DC BIAS(Amps) 3 0.00 0 6 20 0 0 20 0.14 3 TEMP. RISE(℃) 0.00 40 0.28 0 0.10 0 60 INDUCTANCE(μH) 0.42 INDUCTANCE(μH) 10 12 14 16 18 20 22 24 26 DC BIAS(Amps) INDUCTANCE(μH) 4 TEMP. RISE(℃) 2 40 0.20 TEMP. RISE(℃) 40 60 0.30 TEMP. RISE(℃) TEMP. RISE(℃) 80 0.40 TEMP. RISE(℃) 0.14 100 VCMT053T-R47MN52M 1 2 3 4 5 6 7 8 DC BIAS(Amps) 9 10 11 12 100 VCMT053T-4R7MN52M 80 4.00 60 3.00 INDUCTANCE(μH) 2.00 TEMP. RISE(℃) 40 TEMP. RISE(℃) INDUCTANCE(μH) 0 INDUCTANCE(μH) 0.50 60 0.21 0.00 INDUCTANCE(μH) 80 INDUCTANCE(μH) 0.28 0.60 TEMP. RISE(℃) INDUCTANCE(μH) 0.35 100 TEMP. RISE(℃) VCMT053T-R33MN52M 0.42 INDUCTANCE(μH) : CYNVC-19Y-032 Current Characteristic TEMP. RISE(℃)  DOCUMENT 20 1.00 0.00 0 0 1 2 3 4 5 DC BIAS(Amps) 6 7 8 Jun., 2021 Issued VCMT053T-6R8MN52M 80 5.60 60 4.20 INDUCTANCE(μH) 2.80 TEMP. RISE(℃) 40 20 1.40 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 60 TEMP. RISE(℃) 100 80 8.0 60 6.0 INDUCTANCE(μH) 4.0 TEMP. RISE(℃) 40 20 2.0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 40 TEMP. RISE(℃) INDUCTANCE(μH) 80 12.0 6.0 : 6 OF 9 100 15.0 INDUCTANCE(μH) PAGE DC BIAS(Amps) VCMT053T-150MN52M 9.0 : A5 10.0 0.0 5.5 DC BIAS(Amps) 18.0 REVISION 0.0 0 0.00 INDUCTANCE(μH) 7.00 : CYNVC-19Y-032 VCMT053T-100MN52M 12.0 100 TEMP. RISE(℃) INDUCTANCE(μH) 8.40 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 3.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 DC BIAS(Amps) Jun., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 7 OF 9 Packaging (1) Tape packaging dimensions t 2.0 ± 0.1 4.0 ± 0.1 Sprocket hole 1.75 ± 0.10 +0.1 1.5 -0.0 5.5 ± 0.1 12.0 ± 0.3 B0 K0 Carrier cavity A0 8.0 ± 0.1 Pulling direction Dimensions Code (mm) UNITS/REEL A0 B0 K0 t 5.75  0.10 6.05  0.10 3.6  0.1 0.35  0.05 2,000 (2) Tape Direction The direction shall be seen from the top cover tape side. XXX XXX 4R7 XXX XXX 4R7 Pulling direction Jun., 2021 Issued XXX XXX 4R7 XXX XXX 4R7 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 8 OF 9 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (1) Reel dimensions A 13.0 ± 1.0 mm A B 12.5  0.5 2.0  0.2 (2) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 1.3N. Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape Jun., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-19Y-032 REVISION : A5 PAGE : 9 OF 9 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds Jun., 2021 Issued
VCMT053T-R33MN52M 价格&库存
很抱歉,暂时无法提供与“VCMT053T-R33MN52M”相匹配的价格&库存,您可以联系我们找货
