SDEM25201T-6R8MS
SDEM25201T-6R8MS
    CYNTEC(乾坤)
    功率电感 6.8µH ±20% 2520 1.00mm 2.50 x 2.00mm 420mΩ 1A
SDEM25201T-6R8MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : SDEM25201T-000 REVISION : A6 PAGE : 1 OF 4 Sealed Choke Coil SDEM25201T type  Features Low profile:2.5mm x 2.0mm x 1.0mm High performance (Isat) realized by metal dust core. Low loss realized with low DCR High magnetic shield construction should actualize high resolution for EMC protection. 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc.. VRM for server  Outline Dimensions W Code L Dimensions (mm) L 2.0  0.2 W 2.5  0.2 T 1.0 Max. T Note:This graph is in regard to outline dimensions spec. For outer appearance, please refer to actual product.  Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.1 B 0.8 C 2.6 Unit : mm Mar., 2017 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : SDEM25201T-000 REVISION : A6 PAGE : 2 OF 4 Specifications L0 Inductance ( H ) @ (0A) Typical SDEM25201T-R24MS 0.24 SDEM25201T-R33MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 19 23 4.60 4.30 7.00 6.30 0.33 24 29 4.50 4.20 6.50 5.85 SDEM25201T-R47MS 0.47 29 35 4.00 3.60 5.50 5.00 SDEM25201T-R68MS 0.68 39 47 3.55 3.20 4.20 3.78 SDEM25201T-1R0MS 1.0 52 62 3.30 3.00 4.00 3.60 SDEM25201T-1R5MS 1.5 84 100 2.50 2.20 3.10 2.80 SDEM25201T-2R2MS 2.2 95 115 2.15 1.97 2.60 2.30 SDEM25201T-3R3MS 3.3 180 216 1.70 1.53 1.80 1.62 SDEM25201T-4R7MS 4.7 215 258 1.60 1.45 1.70 1.55 SDEM25201T-6R8MS 6.8 350 420 1.10 1.00 1.35 1.22 SDEM25201T-100MS 10.0 574 689 0.95 0.85 1.20 1.10 SDEM25201T-150MS 15.0 925 1110 0.58 0.52 0.80 0.72 SDEM25201T-220MS 22.0 1000 1200 0.50 0.45 0.66 0.60 Part Number Rdc ( m ) *:If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:1MHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △ T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Mar., 2017 CYNTEC CO., LTD. 乾坤科技股份有限公司  PAGE : 3 OF 4 20 TEMP. RISE(℃) 0.00 0 2 3 4 5 6 DC BIAS(Amps) 7 8 9 SDEM25201T-R47MS 0.60 0.50 0.40 0.30 TEMP. RISE(℃) 0.00 3 4 5 DC BIAS(Amps) 6 7 SDEM25201T-1R0MS 1.20 1.00 0.80 0.60 TEMP. RISE(℃) 0.00 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 4.0 4.5 SDEM25201T-2R2MS 2.70 2.25 1.80 TEMP. RISE(℃) 0.00 0.4 0.8 1.2 1.6 2.0 2.4 DC BIAS(Amps) 2.8 3.2 3.6 0.6 1.2 1.8 2.4 3.0 3.6 4.2 DC BIAS(Amps) 4.8 5.4 6.0 SDEM25201T-1R5MS 100 80 1.20 60 INDUCTANCE(μH) 0.90 TEMP. RISE(℃) 40 0.60 20 0.30 0 0.00 0.0 3.50 0 0.0 40 0 80 20 0.45 60 20 4.20 40 0.90 100 TEMP. RISE(℃) 100 60 INDUCTANCE(μH) 1.35 9 INDUCTANCE(μH) 5.0 INDUCTANCE(μH) 1.0 8 0.14 1.50 TEMP. RISE(℃) 0.5 7 0.28 80 0 0.0 4 5 6 DC BIAS(Amps) 80 0.42 1.80 20 0.20 3 0.56 100 40 0.40 2 SDEM25201T-R68MS 0.0 60 INDUCTANCE(μH) 0 1 0.00 8 INDUCTANCE(μH) 2 15 0.70 TEMP. RISE(℃) 1 0.07 80 0 0 30 0.84 20 0.10 45 TEMP. RISE(℃) 0.14 100 40 0.20 0.21 0 60 INDUCTANCE(μH) 60 INDUCTANCE(μH) 0.00 10 INDUCTANCE(μH) 1 TEMP. RISE(℃) 0 0.28 TEMP. RISE (℃) INDUCTANCE(μH) 75 TEMP. RISE(℃) 40 INDUCTANCE(μH) 60 0.05 90 0.35 0.15 0.10 SDEM25201T-R33MS 0.42 80 TEMP . RISE(℃) INDUCTANCE(uH) : A6 TEMP. RISE(℃) 100 0.20 INDUCTANCE(μH) REVISION 0.4 0.8 1.2 1.6 2.0 2.4 2.8 DC BIAS(Amps) 3.2 3.6 4.0 SDEM25201T-3R3MS 100 80 2.80 60 2.10 INDUCTANCE(μH) 1.40 TEMP. RISE(℃) 40 TEMP. RISE(℃) SDEM25201T-R24MS 0.25 INDUCTANCE(μH) : SDEM25201T-000 Current Characteristic 0.30 INDUCTANCE(μH) DOCUMENT 20 0.70 0.00 0 0.0 0.3 0.6 0.9 1.2 1.5 1.8 DC BIAS(Amps) 2.1 2.4 2.7 Mar., 2017 CYNTEC CO., LTD. 乾坤科技股份有限公司 INDUCTANCE(μH) 40 TEMP. RISE(℃) 2.00 20 1.00 1.2 1.5 DC BIAS(Amps) 1.8 2.1 SDEM25201T-100MS 12.0 10.0 8.0 INDUCTANCE(μH) 2.0 TEMP. RISE(℃) 15.0 0.3 0.5 0.8 1.0 1.3 DC BIAS(Amps) 1.5 1.8 20 TEMP. RISE(℃) 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 DC BIAS(Amps) 1.8 2.0 2.2 80 SDEM25201T-150MS 70 60 12.0 9.0 50 INDUCTANCE(μH) 40 TEMP. RISE(℃) 30 6.0 20 10 0 0.0 2.0 SDEM25201T-220MS 27.0 INDUCTANCE(μH) 3.0 0 0.0 40 1.40 80 20 0.0 60 2.80 18.0 40 4.0 80 4.20 100 60 100 SDEM25201T-6R8MS 0.0 6.0 : 4 OF 4 5.60 2.4 INDUCTANCE(μH) 0.9 TEMP. RISE(℃) 0.6 PAGE 0.00 0 0.3 : A6 TEMP. RISE(℃) 3.00 0.0 INDUCTANCE(μH) 7.00 60 0.00 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 DC BIAS(Amps) 100 22.5 INDUCTANCE(μH) 80 REVISION TEMP. RISE(℃) 4.00 8.40 : SDEM25201T-000 80 18.0 60 INDUCTANCE(μH) 13.5 TEMP. RISE(℃) 40 9.0 20 4.5 TEMP. RISE(℃) INDUCTANCE(μH) 5.00 100 INDUCTANCE(uH) SDEM25201T-4R7MS TEMP. RISE(℃) 6.00 DOCUMENT 0 0.0 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 DC BIAS(Amps) 1.0 1.1 1.2 Mar., 2017
SDEM25201T-6R8MS 价格&库存
很抱歉,暂时无法提供与“SDEM25201T-6R8MS”相匹配的价格&库存,您可以联系我们找货
