CMLB041B-R22MS
CMLB041B-R22MS
    CYNTEC(乾坤)
    SMD,4.4x4.2mm
    功率电感 220nH ±20% IND_4.4X4.2MM_SM 1.00mm 4.40 x 4.20mm 9.5mΩ 7A
CMLB041B-R22MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB041B-000 REVISION : A3 PAGE : 1 OF 3 Power Choke Coil CMLB041B type  Features High performance (Isat) realized by metal dust core. Low profile Thickness max. 1.2mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard :  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions L A' A W B B' H  Code T Dimensions(mm) L 4.4 ± 0.35 W 4.2 ± 0.25 T 1.0 ± 0.2 A 0.8 ± 0.3 A’ 1.0 ± 0.1 B 2.0 ± 0.3 B’ 2.5 ± 0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.5 B 2.2 C 5.2 Unit : mm Jun., 2016 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB041B-000 REVISION : A3 PAGE : 2 OF 3 Specifications L0 Inductance ( µH ) @ (0A) Typical CMLB041B-R47MS 0.47 CMLB041B-R68MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 17.5 19.6 6.4 5.7 7.4 6.7 0.68 31.0 36.0 5.5 5.0 7.3 6.5 CMLB041B-1R0MS 1.0 42.0 46.5 5.0 4.3 5.5 5.0 CMLB041B-1R5MS 1.5 61.0 75.0 3.6 3.4 4.6 4.0 CMLB041B-2R2MS 2.2 75.4 83.0 3.3 2.8 3.8 3.4 CMLB041B-4R7MS 4.7 171.0 193.0 2.0 1.8 2.8 2.2 CMLB041B-6R8MS 6.8 320.0 368.0 1.7 1.5 2.2 1.9 CMLB041B-8R2MS 8.2 420.0 480.0 1.5 1.3 1.9 1.6 Part Number Rdc ( mΩ) :If you require another part number please contact with us. **:Inductance Tolerance ± 20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to + 125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating * conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling Note 7. : provision all affect the part temperature. Part temperature should be verified in the end application. The rated current as listed is either the saturation current or the heating current depending on which value is lower. Jun., 2016 CYNTEC CO., LTD. 乾坤科技股份有限公司  REVISION : A3 PAGE : 3 OF 3 40 0.20 20 3 1.20 4 5 6 7 DC BIAS(Amps) 8 9 10 CMLB041B-1R0MS 1.00 ℃) 80 1.50 0.40 ℃ 20 0.00 2 3 4 DC BIAS(Amps) 5 6 CMLB041B-2R2MS 2.25 TEMP. RISE( ℃) 2 3 4 5 6 7 DC BIAS(Amps) 8 9 10 100 80 1.20 60 INDUCTANCE(µH) 0.90 TEMP. RISE ( ℃) 40 0.60 ℃ 20 0 80 5.00 60 40 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 DC BIAS(Amps) 1 CMLB041B-1R5MS 6.00 20 0.00 0 100 0.90 0.45 20 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 DC BIAS(Amps) 1.80 INDUCTANCE(µH) 40 0.00 7 ℃ INDUCTANCE(µH) 1 ℃) 0.30 0 0 TEMP. RISE( 0.00 1.80 40 0.20 INDUCTANCE(µH) 0.28 100 60 INDUCTANCE(µH) TEMP. RISE( 0.42 0 0.80 0.60 60 11 INDUCTANCE(µH) 2 TEMP. RISE( ) 1 ℃ 0.56 0.14 0 0 80 TEMP. RISE( ) ℃) 100 TEMP. RISE( ) TEMP. RISE( CMLB041B-R68MS CMLB041B-4R7MS 100 80 4.00 60 INDUCTANCE(µH) 3.00 TEMP. RISE( ℃) 40 2.00 20 1.00 0.00 0 0.0 0.4 0.8 1.2 1.6 2.0 2.4 DC BIAS(Amps) 2.8 3.2 3.6 ℃ TEMP. RISE( ) 0.30 ℃ INDUCTANCE(µH) 0.70 TEMP. RISE( ) INDUCTANCE(µH) 80 60 INDUCTANCE(µH) 0.00 INDUCTANCE(µH) 0.84 0.40 0.10 INDUCTANCE(µH) 100 TEMP. RISE( ) CMLB041B-R47MS 0.50 1.35 : CMLB041B-000 Current Characteristic 0.60 2.70 DOCUMENT 4.0 Jun., 2016
CMLB041B-R22MS 价格&库存
很抱歉,暂时无法提供与“CMLB041B-R22MS”相匹配的价格&库存,您可以联系我们找货
