CMLE042T-R22MS
CMLE042T-R22MS
    CYNTEC(乾坤)
    SMD,4.4x4.2mm
    功率电感 220nH ±20% IND_4.4X4.2MM_SM 1.80mm 4.40 x 4.20mm 6mΩ 9.5A
CMLE042T-R22MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLE042T-000 REVISION : A2 PAGE : 1 OF 4 Power Choke Coil CMLE042T type  Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 2.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions A' L A Code B W B' H  T Dimensions (mm) L 4.40  0.35 W 4.20  0.25 T 1.8  0.2 A 0.8  0.3 A’ 1.0  0.1 B 2.0  0.3 B’ 2.5  0.2 H 0 ~ +0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.5 B 2.2 C 5.2 Unit : mm Dec., 2021 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLE042T-000 REVISION : A2 PAGE : 2 OF 4 Specifications L0 Inductance ( H ) @ (0A) Typical CMLE042T-R36MS 0.36 CMLE042T-R47MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 8.0 9.2 12.80 11.50 11.00 9.50 0.47 8.4 9.5 11.50 10.00 9.50 8.50 CMLE042T-R68MS 0.68 11.7 13.5 8.70 7.80 9.00 7.70 CMLE042T-1R0MS 1.0 17.0 20.0 7.50 6.50 8.70 7.60 CMLE042T-1R5MS 1.5 30.0 36.0 5.80 5.20 7.00 6.00 CMLE042T-2R2MS 2.2 36.0 42.0 5.50 4.80 6.50 5.70 CMLE042T-3R3MS 3.3 55.0 64.0 3.70 3.30 5.00 4.30 CMLE042T-4R7MS 4.7 74.0 89.0 3.50 3.10 4.60 3.80 CMLE042T-6R8MS 6.8 128.0 148.0 2.60 2.35 3.30 2.70 Part Number Rdc ( m ) * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition : 100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Dec., 2021 CYNTEC CO., LTD. 乾坤科技股份有限公司 0.32 100 0.60 80 0.50 60 0.16 TEMP. RISE(℃) 40 20 0.08 0 2 4 6 8 10 12 14 16 0.84 80 0.40 60 0.30 INDUCTANCE(μH) 0.20 20 0.10 0 0.00 0 2 4 6 8 100 40 20 0.14 0.00 10 12 60 INDUCTANCE(μH) 0.40 TEMP. RISE(℃) 20 0 2.70 80 2.25 40 20 0.30 0.00 INDUCTANCE(μH) 100 60 TEMP. RISE(℃) 1 2 3 4 5 2 3 4 5 6 7 8 9 10 11 60 1.35 INDUCTANCE(μH) 0.90 TEMP. RISE(℃) 6.00 80 5.00 40 20 0 0.00 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 DC BIAS(Amps) 40 20 0.45 100 60 0.70 100 0 1 2 3 4 5 6 7 8 DC BIAS(Amps) INDUCTANCE(μH) 2.80 TEMP. RISE(℃) 9 80 0 TEMP. RISE(℃) 3.50 1.40 8 1.80 10 CMLE042T-3R3MS INDUCTANCE(μH) 7 CMLE042T-2R2MS DC BIAS(Amps) 2.10 6 0.00 0 1 40 0.20 0 TEMP. RISE(℃) 1.20 0.60 100 DC BIAS(Amps) 1.50 INDUCTANCE(μH) 20 80 0.60 14 CMLE042T-1R5MS 0.90 18 0.80 DC BIAS(Amps) 1.80 16 0.00 0 8 INDUCTANCE(μH) TEMP. RISE(℃) 0.28 6 14 1.00 TEMP. RISE(℃) INDUCTANCE(μH) 60 INDUCTANCE(μH) 4 12 CMLE042T-1R0MS 1.20 80 0.56 2 10 DC BIAS(Amps) 0.70 0 40 TEMP. RISE(℃) 18 CMLE042T-R68MS 0.42 100 CMLE042T-R47MS DC BIAS(Amps) INDUCTANCE(μH) : 3 OF 4 TEMP. RISE(℃) INDUCTANCE(μH) 0.00 INDUCTANCE(μH) PAGE TEMP. RISE(℃) 0.24 4.20 : A2 100 CMLE042T-4R7MS 80 4.00 60 3.00 INDUCTANCE(μH) 2.00 TEMP. RISE(℃) 40 TEMP. RISE(℃) INDUCTANCE(μH) 0.40 0 REVISION TEMP. RISE(℃) CMLE042T-R36MS INDUCTANCE(μH) 0.48 0 : CMLE042T-000 Current Characteristic TEMP. RISE(℃)  DOCUMENT 20 1.00 0 0.00 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 4.0 4.5 5.0 5.5 Dec., 2021 CYNTEC CO., LTD. 乾坤科技股份有限公司 8.40 : CMLE042T-000 REVISION : A2 PAGE : 4 OF 4 100 CMLE042T-6R8MS 7.00 80 5.60 60 4.20 INDUCTANCE(μH) 2.80 TEMP. RISE(℃) 40 TEMP. RISE(℃) INDUCTANCE(μH) DOCUMENT 20 1.40 0.00 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 DC BIAS(Amps) 3.5 4.0 4.5 Dec., 2021
CMLE042T-R22MS 价格&库存
很抱歉,暂时无法提供与“CMLE042T-R22MS”相匹配的价格&库存,您可以联系我们找货
