CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 1 OF 7
The history of revision change for the specification
Document
REV.
Modified date Description
CYNVC‐201‐007
A0
2020.1.8
New approval
CYNVC‐201‐007
A1
2020.1.31
1. Remove frequency: (2MHz) from Features
Jan., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 2 OF 7
Power Choke Coil VCUW075D MS6 type
AEC-Q200
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 5.4mm
Low loss realized with low DCR
Capable of corresponding high frequency
Compliance with RoHS and Halogen Free
AEC-Q200 qualified
Application
Automotive applications
Outline Dimensions
A'
L
B B'
W
A1
H
T
Code
Dimensions (mm)
L
7.70 0.35
W
7.2 0.3
T
5.2 0.2
A1
2.0 0.3
A’
2.1 0.3
B
3.0 0.3
B’
3.6 0.3
H
0 ~ + 0.15
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
3.5
B
2.6
C
8.6
Unit : mm
Jan., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 3 OF 7
Marking and Date Code
The point on the top surface represents winding direction of choke.
(1) Marking
The inductor is marked with a 3-digit code
Example – – 100.0H 101
Upside of Chip
PIN 2
(2) Date Code
X
XX
(1)
(2)
XXX
(3)
Where
(1) Year Code
Ex : 2020 = 0
(2) Weekly Code
Serial number : 01 ~ 53
101
XXX
XXX
PIN 1
Coil clockwise around
(3) Taping No.
Serial number : 001 ~ ZZZ
Jan., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 4 OF 7
Specifications
Part Number
Heat Rating Current
DC Amps. Idc ( A )
L0 ◇
Inductance
( H )
@ (0A)
Typical
Maximum
Typical
100.0
313.0
348.0
2.0
VCUW075D-101MS6
Rdc ( m) ◇
Saturation Current Rated voltage
DC Amps. Isat ( A )
(V)
Maximum Typical
1.8
Maximum
Maximum
2.2
55
2.6
◇:Significant Characteristic
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to + 165℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 165℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Note 8.: Cleaning Process Note
(a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether
system, there is a possibility that the performance decreases greatly
(b) The high power ultrasonic washing may damage the choke body.
(c) Please contact us if you need the cleaning via the above agents or ultrasonic washing.
Current Characteristic
VCUW075D-101MS6
120
100
100
80
80
60
60
INDUCTANCE(μH)
40
TEMP. RISE(℃)
40
TEMP. RISE(℃)
INDUCTANCE(μH)
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
2.2
2.4
2.6
2.8
3.0
DC BIAS(Amps)
Jan., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 5 OF 7
Packaging
(1) Tape packaging dimensions
4.0 ± 0.1
t
2.0 ± 0.1
+0.1
1.5 -0.0
Sprocket hole 1.75 ± 0.10
7.5 ± 0.1
16.0 ± 0.3
B0
A0
K0
Carrier cavity
Pulling direction
12.0 ± 0.1
Dimensions Code (mm)
UNITS/REEL
A0
B0
K0
t
7.7 0.1
8.2 0.1
6.0 0.1
0.50 0.05
500
(2) Tape Direction
The direction shall be seen from the top cover tape side.
XXX
XXX
101
XXX
XXX
101
Pulling direction
Jan., 2020 Issued
XXX
XXX
101
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 6 OF 7
2.0 ± 0.5
20.0 ± 0.5
B
330.0 ± 2.0
100.0 ± 1.0
(3) Reel dimensions
A
13.0 ± 1.0
mm
A
B
16.0 0.5
2.0 0.2
(4) Peel force of top cover tape
The peel speed shall be about 300 mm/minute
The peel force of top cover tape shall be between 0.1 to 1.3N
Top Cover Tape
165 ~ 180°
0.1 ~ 1.3N
Carrier tape
Jan., 2020 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-201-007
REVISION
: A1
PAGE
: 7 OF 7
Reflow Profile
Power Choke Coil Type
Tp
Temperature
260℃
tp:30 Sec max.
Max. Ramp Up Rate =3℃/s
Max. Ramp Down Rate =6℃/s
217℃
60~150 Sec
Preheat Area
200℃
150℃
60~120 Sec
25℃
25°C to Peak ( 8 minutes max.)
Time
(1) Reflow Soldering Method :
Reflow Soldering
Tp:255~260℃
Max.30 seconds ( tp )
217℃
60~150 seconds
Pre-Heat
150 ~ 200℃
60~120 seconds
Time 25℃ to peak temperature
8 minutes max.
(2) Soldering iron Method : 350 5℃ max.3 seconds
Jan., 2020 Issued
很抱歉,暂时无法提供与“VCUW075D-3R3MS6”相匹配的价格&库存,您可以联系我们找货
