CMLB065T-470MS
CMLB065T-470MS
    CYNTEC(乾坤)
    IND_7.05X6.6MM_SM
    功率电感 47µH ±20% IND_7.05X6.6MM_SM 4.80mm 7.05 x 6.60mm 198mΩ 2A
CMLB065T-470MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CMLB065T-000 REVISION : A2 PAGE : 1 OF 4 Power Choke Coil CMLB065T type  Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 5.0mm Low loss realized with low DCR Capable of corresponding high frequency (1MHz) 100% lead (Pb) free meet RoHS standard  Application DC/DC converter for CPU in Notebook PC Thin type on-board power supply module for exchanger VRM for server  Outline Dimensions A' L A B W B' H  Code Dimensions (mm) L 7.05  0.35 W 6.6  0.2 T 4.8  0.2 A 1.6  0.3 A’ 2.0  0.1 B 3.0  0.3 B’ 3.6  0.2 H 0 ~ +0.15 T Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 3.5 B 3.7 C 8.4 Unit : mm Dec., 2021 CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CMLB065T-000 REVISION : A2 PAGE : 2 OF 4 Specifications L0 Inductance ( H ) @ (0A) Typical CMLB065T-R36MS 0.36 CMLB065T-R47MS Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 2.67 3.10 21.5 19.0 28.0 24.0 0.47 3.21 3.70 20.2 18.0 24.0 20.0 CMLB065T-R56MS 0.56 3.40 3.90 20.0 17.0 20.0 18.0 CMLB065T-R68MS 0.68 3.80 4.20 18.2 16.0 17.0 15.0 CMLB065T-1R0MS 1.0 5.50 6.40 13.2 12.5 16.8 14.5 Part Number Rdc ( m ) CMLB065T-1R5MS 1.5 6.00 7.50 12.3 11.2 12.7 11.0 CMLB065T-2R2MS 2.2 10.20 11.80 11.0 9.9 12.1 10.0 CMLB065T-3R3MS 3.3 16.50 18.50 9.0 8.5 9.0 8.1 CMLB065T-4R7MS 4.7 21.00 24.00 6.7 6.0 8.0 7.0 CMLB065T-5R6MS 5.6 30.00 36.00 6.0 5.4 7.7 6.7 CMLB065T-6R8MS 6.8 36.00 40.00 5.5 5.0 7.3 6.5 CMLB065T-100MS 10.0 47.10 54.00 4.7 4.3 5.3 4.7 *: If you require another part number please contact with us. **: Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +125℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Dec., 2021 CYNTEC CO., LTD. 乾坤科技股份有限公司  : CMLB065T-000 REVISION : A2 PAGE : 3 OF 4 Current Characteristic 0.28 0.54 80 0.45 60 TEMP. RISE(℃) 40 20 0.07 0 0.00 0 3 6 9 12 15 18 21 24 27 20 0.09 0 0.00 30 0 3 6 9 12 DC BIAS(Amps) INDUCTANCE(μH) 0.50 0.40 100 0.84 80 0.70 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 0.20 20 0.10 INDUCTANCE(μH) CMLB065T-R56MS 0.30 0 0.00 0 3 6 9 12 15 18 21 24 27 INDUCTANCE(μH) 0.28 TEMP. RISE(℃) 0.00 INDUCTANCE(μH) TEMP. RISE(℃) 1.50 8 10 12 14 DC BIAS(Amps) 16 18 20 0 3 6 9 12 2.00 1.60 INDUCTANCE(μH) 0.80 TEMP. RISE (℃) 0.00 27 30 12 15 100 60 40 TEMP. RISE(℃) 20 0.30 0.00 80 3.50 0 6 9 DC BIAS(Amps) 24 INDUCTANCE(μH) 0.60 4.20 20 3 21 80 0.90 100 40 0.40 0 18 CMLB065T-1R5MS 0 0 60 1.20 15 1.20 20 INDUCTANCE(μH) 6 CMLB065T-2R2MS 2.40 INDUCTANCE(μH) 80 0 4 40 0.14 1.80 20 2 100 60 0.42 100 40 0.20 0 30 80 0 60 TEMP. RISE(℃) 27 0.00 TEMP. RISE(℃) INDUCTANCE(μH) 0.80 0.40 24 DC BIAS(Amps) 1.00 INDUCTANCE(μH) 21 0.56 30 CMLB065T-1R0MS 0.60 18 CMLB065T-68MS DC BIAS(Amps) 1.20 15 DC BIAS(Amps) TEMP. RISE(℃) 0.60 40 TEMP. RISE(℃) 0.18 TEMP. RISE(℃) 0.14 60 INDUCTANCE(μH) 0.27 TEMP. RISE(℃) INDUCTANCE(μH) 80 0.36 2 4 6 8 10 12 14 DC BIAS(Amps) 16 18 20 CMLB065T-3R3MS 100 80 2.80 60 2.10 INDUCTANCE(μH) 1.40 TEMP. RISE(℃) 40 TEMP. RISE(℃) 0.21 100 CMLB065T-R47MS TEMP. RISE(℃) 0.35 100 INDUCTANCE(μH) CMLB065T-R36MS TEMP. RISE(℃) 0.42 INDUCTANCE(μH) DOCUMENT 20 0.70 0.00 0 0.0 1.5 3.0 4.5 6.0 7.5 9.0 DC BIAS(Amps) 10.5 12.0 13.5 Dec., 2021 CYNTEC CO., LTD. 乾坤科技股份有限公司 80 6.00 60 INDUCTANCE(μH) 3.00 40 TEMP. RISE(℃) 2.00 20 1.00 0 0.00 0 1 2 3 4 5 6 7 8 9 10 80 60 INDUCTANCE(μH) 3.60 20 1.20 12.0 80 10.0 20 0.00 0 1 2 3 4 5 DC BIAS(Amps) 6 7 8 INDUCTANCE(μH) 100 40 1.40 0 40 TEMP. RISE(℃) 2.40 0 0 60 TEMP. RISE(℃) 100 0.00 TEMP. RISE(℃) INDUCTANCE(μH) 5.60 2.80 : 4 OF 4 1 2 3 4 5 6 7 8 9 10 11 DC BIAS(Amps) 7.00 INDUCTANCE(μH) PAGE 4.80 11 CMLB065T-6R8MS 4.20 : A2 CMLB065T-5R6MS DC BIAS(Amps) 8.40 REVISION TEMP. RISE(℃) 4.00 7.20 : CMLB065T-000 100 CMLB065T-100MS 80 8.0 60 INDUCTANCE(μH) 6.0 TEMP. RISE (℃) 40 4.0 TEMP. RISE(℃) INDUCTANCE(μH) 5.00 100 INDUCTANCE(μH) CMLB065T-4R7MS TEMP. RISE(℃) 6.00 DOCUMENT 20 2.0 0.0 0 0 1 2 3 4 5 DC BIAS(Amps) 6 7 8 9 Dec., 2021
CMLB065T-470MS 价格&库存
很抱歉,暂时无法提供与“CMLB065T-470MS”相匹配的价格&库存,您可以联系我们找货
