VCUW053T-R20MS5
VCUW053T-R20MS5
    CYNTEC(乾坤)
    IND_5.45X5.25MM_SM
    功率电感 200nH ±20% IND_5.45X5.25MM_SM 2.80mm 5.45 x 5.25mm 3.9mΩ 20A
VCUW053T-R20MS5 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 1 OF 9 The history of revision change for the specification Document REV. Modified date CYNVC-201-033 A0 2020.1.31 CYNVC-201-033 A1 2020.7.24 CYNVC-201-033 A2 2020.11.2 CYNVC-201-033 A3 2020.12.24 CYNVC-201-033 A4 2021.1.25 CYNVC-201-033 A5 2021.5.24 Description New approval 1. Jan. -> Jul. 2. Add 2R2, 4R7, 220 spec and curve 1. Jul. -> Nov. 2. Add 3R3, 6R8 spec and curve 1. Nov. -> Dec. 2. Add R47, 1R5, 100, 150 spec 3. Add 1R5, 100 curve 1. Dec.,2020 -> Jan., 2021 2.Add R47,150 curve 1. Jan. -> May. 2. Add R68 spec and curve May., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 2 OF 9 Power Choke Coil VCUW053T MS5 type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 3.0mm Low loss realized with low DCR Capable of corresponding high frequency Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions A' L Code B B' W A1 H  T Dimensions (mm) L 5.45  0.35 W 5.25  0.20 T 2.8  0.2 A1 1.4  0.3 A’ 1.5  0.1 B 2.3  0.3 B’ 3.5  0.2 H 0 ~ + 0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 2.6 B 2.2 C 6.5 Unit : mm May., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 3 OF 9 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 1.0H  1R0 (2) Date Code Upside of Chip X XX (1) (2) XXX (3) Where PIN 2 1R0 XXX XXX (1) Year Code Ex : 2021 = 1 PIN 1 Coil clockwise around (2) Weekly Code Serial number : 01 ~ 53 (3) Taping No. Serial number : 001 ~ ZZZ May., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 4 OF 9 Specifications L0 ◇ Inductance ( H ) @ (0A) Typical VCUW053T-R10MS5 0.10 VCUW053T-R47MS5 Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum Maximum 1.8 2.1 24.0 22.0 35.0 30.0 40 0.47 6.0 7.2 13.0 11.7 12.8 11.0 40 VCUW053T-R68MS5 0.68 8.0 9.6 11.0 9.9 11.2 9.6 40 VCUW053T-1R0MS5 1.0 10.0 11.5 10.2 9.2 10.8 9.3 40 VCUW053T-1R5MS5 1.5 13.0 15.6 8.9 8.0 9.0 7.7 40 VCUW053T-2R2MS5 2.2 20.0 23.0 7.1 6.4 7.5 6.4 40 VCUW053T-3R3MS5 3.3 33.0 38.0 5.5 5.0 6.6 5.6 40 VCUW053T-4R7MS5 4.7 51.0 59.0 4.4 3.9 6.2 5.3 40 VCUW053T-6R8MS5 6.8 75.0 90.0 3.6 3.2 5.3 4.6 40 VCUW053T-100MS5 10.0 95.8 115.0 3.2 2.9 3.3 2.8 40 VCUW053T-150MS5 15.0 139.5 158.0 2.7 2.4 2.4 2.1 40 VCUW053T-220MS5 22.0 195.0 232.0 2.2 2.0 2.2 1.9 40 Part Number Rdc ( m ) ◇ Rated Voltage (V) ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to +155℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. May., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  80 0.50 60 INDUCTANCE(μH) : A5 PAGE : 5 OF 9 TEMP. RISE(℃) 40 0.04 20 15 20 25 30 35 40 45 TEMP. RISE(℃) 20 0.00 0 0 50 3 6 9 60 INDUCTANCE(μH) TEMP. RISE(℃) 40 20 0.14 0.00 INDUCTANCE(μH) 0.56 TEMP. RISE(℃) 80 0 0 2 4 6 8 10 12 14 80 0.80 60 0.60 INDUCTANCE(μH) 0.40 TEMP. RISE(℃) 20 0.20 0 0 2 4 6 40 20 0.30 INDUCTANCE(μH) 60 TEMP. RISE(℃) 80 TEMP. RISE(℃) 1 2 3 4 5 6 7 8 9 10 60 INDUCTANCE(μH) 1.20 20 0.70 0.00 0 3 4 5 DC BIAS(Amps) 40 TEMP. RISE(℃) 0.80 20 0 1 2 3 4 5 6 7 8 9 10 6 7 8 VCUW053T-4R7MS5 6.00 INDUCTANCE(μH) 40 TEMP. RISE(℃) TEMP. RISE(℃) 60 INDUCTANCE(μH) 2 100 80 0 80 1 18 0.00 100 2.80 0 16 DC BIAS(Amps) 3.50 1.40 14 1.60 11 VCUW053T-3R3MS5 2.10 12 2.00 DC BIAS(Amps) 4.20 10 0.40 0 0.00 0 8 VCUW053T-2R2MS5 2.40 100 1.20 0.60 40 DC BIAS(Amps) VCUW053T-1R5MS5 INDUCTANCE(μH) 100 0.00 16 1.50 0.90 18 1.00 DC BIAS(Amps) 1.80 15 VCUW053T-1R0MS5 1.20 100 0.70 0.28 12 DC BIAS(Amps) VCUW053T-R68MS5 0.42 40 0.20 DC BIAS(Amps) 0.84 60 INDUCTANCE(μH) 0.30 TEMP. RISE(℃) 10 80 0.40 TEMP. RISE(℃) 5 100 0.10 0 0 VCUW053T-R47MS5 100 5.00 80 4.00 60 INDUCTANCE(μH) 3.00 40 TEMP. RISE(℃) 2.00 TEMP. RISE(℃) 0.06 0.00 INDUCTANCE(μH) REVISION TEMP. RISE(℃) 0.08 0.60 INDUCTANCE(μH) 0.10 100 TEMP. RISE(℃) INDUCTANCE(μH) VCUW053T-R10MS5 0.02 INDUCTANCE(μH) : CYNVC-201-033 Current Characteristic 0.12 INDUCTANCE(μH) DOCUMENT 20 1.00 0.00 0 0 1 2 3 4 DC BIAS(Amps) 5 6 7 May., 2021 Issued VCUW053T-6R8MS5 80 5.60 60 INDUCTANCE(μH) 40 TEMP. RISE(℃) 2.80 1.40 0.00 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 TEMP. RISE(℃) TEMP. RISE(℃) 20 0 0.0 100 27.00 80 22.50 40 6.0 20 3.0 0.0 0 1.5 2.0 DC BIAS(Amps) 40 4.0 0.0 60 INDUCTANCE(μH) 1.0 60 INDUCTANCE(μH) 6.0 0 2.5 3.0 3.5 INDUCTANCE(μH) 12.0 0.5 100 8.0 2.0 TEMP. RISE(℃) INDUCTANCE(μH) 15.0 0.0 : 6 OF 9 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 DC BIAS(Amps) VCUW053T-150MS5 9.0 PAGE 80 DC BIAS(Amps) 18.0 : A5 10.0 20 5.5 REVISION VCUW053T-220MS5 100 80 18.00 60 13.50 40 9.00 INDUCTANCE(μH) 4.50 TEMP. RISE(℃) 4.20 INDUCTANCE(μH) 7.00 : CYNVC-201-033 VCUW053T-100MS5 12.0 100 TEMP. RISE(℃) INDUCTANCE(μH) 8.40 DOCUMENT TEMP. RISE(℃) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 TEMP. RISE(℃) 0 0.00 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 DC BIAS(Amps) May., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 7 OF 9 Packaging (1) Tape packaging dimensions t 4.0 ± 0.1 +0.1 1.5 -0.0 2.0 ± 0.1 Sprocket hole 1.75 ± 0.10 7.5 ± 0.1 16.0 ± 0.3 B0 K0 Carrier cavity A0 8.0 ± 0.1 Pulling direction Dimensions Code (mm) UNITS/REEL A0 B0 K0 t 5.75  0.10 6.05  0.10 3.6  0.1 0.35  0.05 2,000 (2) Tape Direction The direction shall be seen from the top cover tape side. XXX XXX 1R0 XXX XXX 1R0 Pulling direction May., 2021 Issued XXX XXX 1R0 XXX XXX 1R0 CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 8 OF 9 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (3) Reel dimensions A 13.0 ± 1.0 mm A B 16.0  0.5 2.0  0.2 (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 1.3N. Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape May., 2021 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-201-033 REVISION : A5 PAGE : 9 OF 9 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds May., 2021 Issued
VCUW053T-R20MS5 价格&库存
很抱歉,暂时无法提供与“VCUW053T-R20MS5”相匹配的价格&库存,您可以联系我们找货
