VCHA105D-R22MS6
VCHA105D-R22MS6
    CYNTEC(乾坤)
    IND_10.85X10MM_SM
    功率电感 220nH ±20% IND_10.85X10MM_SM 5.20mm 10.85 x 10.00mm 0.8mΩ 37A
VCHA105D-R22MS6 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 1 OF 9 The history of revision change for the specification Document  REV.  Modified date  CYNVC‐175‐018  A0  2017.5.31  CYNVC‐175‐018  A1  2017.6.19  CYNVC‐175‐018  A2  2017.11.13  CYNVC‐175‐018  A3  2018.3.13  CYNVC‐175‐018  A4  2018.6.15  CYNVC‐175‐018  A5  2018.11.13  CYNVC‐175‐018  A6  2019.9.16  CYNVC‐175‐018  A7  2020.1.21  CYNVC‐175‐018  A8  2020.6.15  CYNVC‐175‐018  A9  2020.9.9  CYNVC‐175‐018  B0  2020.12.1  Description  New Approval  1. May ‐> Jun.  2. Remove spec of 101  3. Remove curve of 101  4. Add spec of 120  1. Add curve of 120  2. Jun. ‐> Nov.  1. Add “AEC‐Q200” logo on page 2  2. Nov., 2017 ‐> Mar., 2018  3. Year code 2017 = 7 ‐> 2018 = 8  1. Mar. ‐> Jun.  2. Add spec of R22  3. Add curve of R22  1. Jun. ‐> Nov.  2. Remove spec & curve of R22, 120  1. Nov., 2018 ‐> Sep., 2019  2. Add spec & curve of 101  1. Sep., 2019 ‐> Jan., 2020  2. Year code 2019 = 9 ‐> 2020 = 0  1. Jan. ‐> Jun.  2. Add spec and curve of R68  3. Add rated voltage  1. Jun. ‐> Sep.  2. Update Land Pattern A: 4.95 ‐> 5.0 ; B: 5.4 ‐> 4.9 ; C: 13.6 ‐> 12.88  1. Sep. ‐>Dec.  2. Add spec and curve of 1R5  Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 2 OF 9 Power Choke Coil VCHA105D MS6 type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 5.4mm Low loss realized with low DCR Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions L A' Code W B' B A1 H  T B1 Dimensions (mm) L 10.85  0.35 W 10.0  0.3 T 5.2  0.2 A1 2.2  0.5 A’ 2.5  0.1 B 4.5  0.3 B1 6.5  0.3 B’ 6.0  0.3 H 0 ~ + 0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 5.00 B 4.90 C 12.88 Unit : mm Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 3 OF 9 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 1.0H  1R0 Upside of Chip (2) Date Code PIN 1 X XX (1) (2) XXX (3) Where 1R0 PIN 2 XXX XXX (1) Year Code Coil clockwise around Ex : 2020 = 0 (2) Weekly Code Serial number : 01 ~ 53 (3) Taping No. Serial number : 001 ~ ZZZ Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 4 OF 9 Specifications Part Number L0 ◇ Inductance ( H ) @ (0A) Rdc ( m ) ◇ Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Rated Voltage (V) Typical Maximum Typical Maximum Typical Maximum Maximum VCHA105D-R68MS6 0.68 1.85 2.22 32.0 28.8 46.0 Note 5 39.4 Note 5 80 VCHA105D-1R0MS6 1.0 2.30 2.76 30.0 27.0 37.0 31.7 80 VCHA105D-1R5MS6 1.5 3.50 4.20 24.8 22.3 26.8 23.0 80 VCHA105D-2R2MS6 2.2 4.1 4.9 23.0 20.7 25.0 21.4 80 VCHA105D-3R3MS6 3.3 6.2 7.4 18.7 16.8 19.0 16.3 80 VCHA105D-4R7MS6 4.7 8.3 10.0 14.5 13.0 15.7 13.5 80 VCHA105D-6R8MS6 6.8 12.0 14.0 12.0 10.8 13.3 11.4 80 VCHA105D-100MS6 10.0 21.0 24.2 8.7 7.8 12.7 10.9 80 VCHA105D-150MS6 15.0 27.2 31.3 7.6 6.8 9.2 7.9 80 VCHA105D-220MS6 22.0 43.5 50.0 6.0 5.4 8.8 7.5 80 VCHA105D-330MS6 33.0 65.5 75.3 4.8 4.3 7.6 6.5 80 VCHA105D-470MS6 47.0 89.0 103.0 4.1 3.6 4.9 4.2 80 VCHA105D-680MS6 68.0 132.0 152.0 3.3 3.0 4.2 3.6 80 VCHA105D-101MS6 100.0 203.0 234.0 2.8 2.5 3.5 3.0 55 ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30% Note 5.: Isat : DC current (A) that will cause L0 to drop approximately 35% Note 6.: Operating Temperature Range -55℃ to +165℃ Note 7.: The part temperature (ambient + temp rise) should not exceed 165℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 8.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 9.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Dec., 2020 Issued 1.00 60 0.42 INDUCTANCE(μH) 0.28 TEMP. RISE(℃) 40 20 0.14 5 10 15 20 1.80 25 30 35 40 DC BIAS(Amps) 45 50 55 1.50 80 1.20 60 INDUCTANCE(μH) 0.90 TEMP. RISE(℃) 40 0.60 0.00 80 0 TEMP. RISE(℃) 20 0 5 10 15 20 25 DC BIAS(Amps) 1.40 TEMP. RISE(℃) TEMP. RISE(℃) 0.00 20 0 3 6 9 12 15 18 21 DC BIAS(Amps) 6 9 18 21 7.00 5.60 TEMP. RISE(℃) 0.00 2 4 6 8 10 12 DC BIAS(Amps) 14 16 18 2.00 TEMP. RISE(℃) 20 40 20 0.00 80 10.0 0 0 60 INDUCTANCE(μH) 12.0 20 1.40 100 80 3.00 100 40 2.80 30 VCHA105D-4R7MS6 0 0 60 INDUCTANCE(μH) 4.20 27 4.00 24 VCHA105D-6R8MS6 8.40 INDUCTANCE(μH) 12 15 DC BIAS(Amps) INDUCTANCE(μH) 3 24 1.00 0 0 40 0.45 5.00 20 0.70 60 INDUCTANCE(μH) 0.90 80 40 100 80 1.35 6.00 INDUCTANCE(μH) INDUCTANCE(μH) 40 1.80 100 60 2.10 35 VCHA105D-2R2MS6 0 TEMP. RISE(℃) 2.80 30 0.00 TEMP. RISE(℃) INDUCTANCE(μH) 3.50 40 0.40 DC BIAS(Amps) VCHA105D-3R3MS6 60 INDUCTANCE(μH) 0.60 2.25 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 4.20 100 0.80 2.70 20 0.30 VCHA105D-1R0MS6 0 100 VCHA105D-1R5MS6 : 5 OF 9 0.00 60 INDUCTANCE(μH) 0 PAGE 0.20 0 0.00 INDUCTANCE(μH) 80 : B0 TEMP. RISE(℃) 0.56 1.20 REVISION TEMP. RISE(℃) 0.70 100 : CYNVC-175-018 TEMP. RISE(℃) VCHA105D-R68MS6 DOCUMENT 2 4 6 8 10 12 14 DC BIAS(Amps) 16 18 20 22 VCHA105D-100MS6 100 80 8.0 60 6.0 INDUCTANCE(μH) 4.0 TEMP. RISE(℃) 40 TEMP. RISE(℃) 0.84 INDUCTANCE(μH) Current Characteristic TEMP. RISE(℃)  TEMP. RISE(℃) INDUCTANCE(μH) CYNTEC CO., LTD. 乾坤科技股份有限公司 20 2.0 0.0 0 0 2 4 6 8 10 DC BIAS(Amps) 12 14 16 Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 40 20 3.0 3 4 42.0 5 14.0 TEMP. RISE(℃) 20 1 2 3 4 5 6 DC BIAS(Amps) 7 8 80 56.0 60 INDUCTANCE(μH) 28.0 TEMP. RISE(℃) 40 20 14.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 DC BIAS(Amps) 5 6 7 8 DC BIAS(Amps) 9 10 11 12 VCHA105D-470MS6 100 80 60 INDUCTANCE(μH) 27.0 TEMP. RISE(℃) 40 18.0 20 9.0 0 0 1 2 120.0 100 70.0 42.0 4 3 4 5 6 7 DC BIAS(Amps) VCHA105D-680MS6 84.0 3 36.0 9 4.0 4.5 5.0 5.5 INDUCTANCE(μH) 0 2 0.0 0 0.0 0 1 45.0 40 7.0 40 20 54.0 TEMP. RISE(℃) INDUCTANCE(μH) TEMP. RISE(℃) 0 60 21.0 60 INDUCTANCE(μH) 0.0 80 28.0 80 4.0 100 35.0 100 8.0 6 7 8 9 10 11 12 13 14 DC BIAS(Amps) VCHA105D-330MS6 : 6 OF 9 VCHA105D-220MS6 12.0 INDUCTANCE(μH) 2 PAGE 16.0 0 1 : B0 TEMP. RISE(℃) TEMP. RISE(℃) REVISION TEMP. RISE(℃) 6.0 : CYNVC-175-018 100 VCHA105D-101MS6 100.0 80 80.0 60 INDUCTANCE(μH) 60.0 TEMP. RISE(℃) 40 40.0 TEMP. RISE(℃) INDUCTANCE(μH) 0 INDUCTANCE(μH) 20.0 60 9.0 0.0 INDUCTANCE(μH) 80 INDUCTANCE(μH) 12.0 24.0 TEMP. RISE(℃) INDUCTANCE(μH) 15.0 100 TEMP. RISE(℃) VCHA105D-150MS6 18.0 DOCUMENT 20 20.0 0.0 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 DC BIAS(Amps) Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 7 OF 9 Packaging (1) Tape packaging dimensions 4.0 ± 0.1 t 2.0 ± 0.1 +0.1 1.5 -0.0 1.75 ± 0.10 Sprocket hole 11.5 ± 0.1 24.0 ± 0.3 B0 A0 Carrier cavity K0 16.0 ± 0.1 Pulling direction Dimensions Code (mm) A0 B0 K0 t 10.7  0.1 12.0  0.1 6.0  0.1 0.50  0.05 UNITS/REEL 500 (2) Tape Direction The direction shall be seen from the top cover tape side. 1R0 XXX XXX 1R0 XXX XXX 1R0 XXX XXX Pulling direction Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 8 OF 9 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (3) Reel dimensions A 13.0 ± 1.0 mm A B 24.5  0.5 2.0  0.2 (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute. The peel force of top cover tape shall be between 0.1 to 1.3N. Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape Dec., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-175-018 REVISION : B0 PAGE : 9 OF 9 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Reflow Soldering Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. (2) Soldering iron Method : 350  5℃ max.3 seconds Dec., 2020 Issued
VCHA105D-R22MS6 价格&库存
很抱歉,暂时无法提供与“VCHA105D-R22MS6”相匹配的价格&库存,您可以联系我们找货
