VCMI104T-101MN53
VCMI104T-101MN53
    CYNTEC(乾坤)
    IND_10.85X10MM_SM
    功率电感 100µH ±20% IND_10.85X10MM_SM 3.80mm 10.85 x 10.00mm 340mΩ 2A
VCMI104T-101MN53 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 1 OF 7 The history of revision change for the specification Document  REV.  Modified date  CYNVC‐198‐055  A0  2019.8.27  CYNVC‐198‐055  A1  2020.1.15  Description  New Approval  1. Sep., 2019 ‐> Jan., 2020  2. Year Code: 2019 = 9 ‐> 2020 = 0  3. Remove frequency: (1MHz) from Features  4. Add Rated voltage (V): 75V  Jan., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 2 OF 7 Power Choke Coil VCMI104T MN53 type  AEC-Q200 Features High performance (Isat) realized by metal dust core. Low profile:Thickness max. 4.0mm Low loss realized with low DCR Capable of corresponding high frequency Compliance with RoHS and Halogen Free AEC-Q200 qualified  Application Automotive applications  Outline Dimensions L A' W B' B B1 A1 H  T Code Dimensions (mm) L 10.85  0.35 W 10.0  0.3 T 3.8  0.2 A1 2.6  0.5 A’ 2.5  0.1 B 3.0  0.3 B1 6.5  0.3 B’ 6.0  0.3 H 0 ~ + 0.15 Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown below after confirming and safety. B A C A 3.25 B 5.81 C 12.06 Unit : mm Jan., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 3 OF 7 Marking and Date Code The point on the top surface represents winding direction of choke. (1) Marking The inductor is marked with a 3-digit code Example – – 15.0H  150 Upside of Chip (2) Date Code PIN 1 X XX (1) (2) XXX (3) Where 150 PIN 2 XXX XXX (1)Year Code Coil clockwise around Ex : 2020 = 0 (2)Weekly Code Serial number : 01 ~ 53 (3)Taping No. Serial number : 001 ~ ZZZ Jan., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 4 OF 7 Specifications Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum Maximum 47.0 52.0 5.1 4.6 6.5 5.6 75 89.0 102.0 4.0 3.5 4.2 3.6 75 L0 ◇ Inductance ( H ) @ (0A) Typical VCMI104T-150MN53 15.0 VCMI104T-330MN53 33.0 Part Number Rdc ( m) ◇ Rated Voltage (V) ◇:Significant Characteristic * :If you require another part number please contact with us. **:Inductance Tolerance  20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:100KHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 20% Note 5.: Operating Temperature Range -55℃ to + 155℃ Note 6.: The part temperature (ambient + temp rise) should not exceed 155℃ under the worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8.: Cleaning Process Note (a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether system, there is a possibility that the performance decreases greatly (b) The high power ultrasonic washing may damage the choke body. (c) Please contact us if you need the cleaning via the above agents or ultrasonic washing. Current Characteristic 15.0 80 12.0 60 9.0 INDUCTANCE(μH) 6.0 TEMP. RISE(℃) 40 20 3.0 0.0 0 0 1 2 3 4 5 6 DC BIAS(Amps) 7 8 9 10 100 VCMI104T-330MN53 35.0 80 28.0 60 21.0 INDUCTANCE(μH) 14.0 TEMP. RISE(℃) 40 20 7.0 0.0 TEMP. RISE(℃) 42.0 100 VCMI104T-150MN53 INDUCTANCE(μH) INDUCTANCE(μH) 18.0 TEMP. RISE(℃)  0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 DC BIAS(Amps) Jan., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 5 OF 7 Packaging (1) Tape packaging dimensions +0.1 1.5 -0.0 t 2.0 ± 0.1 Sprocket hole 4.0 ± 0.1 1.75 ± 0.10 11.5 ± 0.1 24.0 ± 0.3 B0 A0 Carrier cavity K0 Pulling direction 16.0 ± 0.1 Dimensions Code (mm) UNITS/REEL A0 B0 K0 t 10.7  0.1 12.0  0.1 4.5  0.1 0.35  0.05 500 (2) Tape Direction The direction shall be seen from the top cover tape side. 150 XXX XXX 150 XXX XXX 150 XXX XXX Pulling direction Jan., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 6 OF 7 2.0 ± 0.5 20.0 ± 0.5 B 330.0 ± 2.0 100.0 ± 1.0 (3) Reel dimensions A 13.0 ± 1.0 mm A B 24.5  0.5 2.0  0.2 (4) Peel force of top cover tape The peel speed shall be about 300 mm/minute The peel force of top cover tape shall be between 0.1 to 1.3N Top Cover Tape 165 ~ 180° 0.1 ~ 1.3N Carrier tape Jan., 2020 Issued CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNVC-198-055 REVISION : A1 PAGE : 7 OF 7 Reflow Profile Power Choke Coil Type Tp Temperature 260℃ tp:30 Sec max. Max. Ramp Up Rate =3℃/s Max. Ramp Down Rate =6℃/s 217℃ 60~150 Sec Preheat Area 200℃ 150℃ 60~120 Sec 25℃ 25°C to Peak ( 8 minutes max.) Time (1) Reflow Soldering Method : Tp:255~260℃ Max.30 seconds ( tp ) 217℃ 60~150 seconds Pre-Heat 150 ~ 200℃ 60~120 seconds Time 25℃ to peak temperature 8 minutes max. Reflow Soldering (2) Soldering iron Method : 350 5℃ max.3 seconds Jan., 2020 Issued
VCMI104T-101MN53 价格&库存
很抱歉,暂时无法提供与“VCMI104T-101MN53”相匹配的价格&库存,您可以联系我们找货
