CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 1 OF 8
The history of revision change for the specification
Document No
REV.
Modified date Description
CYNVC‐176‐010
A0
2017.6.16
CYNVC‐176‐010
A1
2020.9.21
CYNVC‐176‐010
A2
2021.7.23
New Approval
1. Jun., 2017 ‐> Sep., 2020
2. Add 2R2 spec and curve
3. Remove 100, 220 spec and curve
1. Sep.,2020 ‐> Jul.,2021
2. Date Code: 2020 = 0 ‐> 2021 = 1
3. Add Rated voltage (V): 75V
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 2 OF 8
Power Choke Coil VCMV177T MN2 type
AEC-Q200
Features
High performance (Isat) realized by metal dust core.
Low profile:Thickness max. 7.0mm
Low loss realized with low DCR
Capable of corresponding high frequency
Compliance with RoHS and Halogen Free
AEC-Q200 qualified
Application
Automotive applications
Outline Dimensions
A'
L
B B'
W
A1
H
Code
Dimensions (mm)
L
17.15 0.35
W
16.95 0.20
T
6.8 0.2
A1
3.0 0.5
A’
3.5 0.1
B
12.0 0.3
B’
13.0 0.5
H
0 ~ + 0.3
T
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
12.8
B
11.2
C
18.2
Unit : mm
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 3 OF 8
Marking and Date Code
The point on the top surface represents winding direction of choke.
Marking
The inductor is marked with a 3-digit code
Example – – 2.2H 2R2
Upside of Chip
Date Code
X
XX
(1)
(2)
XXX
(3)
Where
(1) Year Code
PIN 1
2R2
PIN 2
XXX
XXX
Coil clockwise around
Ex : 2021 = 1
(2) Weekly Code
Serial number : 01 ~ 53
(3) Taping No.
Serial number : 001 ~ ZZZ
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 4 OF 8
Specifications
L0 ◇
Inductance
( H )
@ (0A)
Typical
VCMV177T-2R2MN2
2.2
VCMV177T-150MN2
VCMV177T-330MN2
Part Number
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
Maximum
2.20
2.64
33.0
29.7
44.1
37.8
75
15.0
15.0
18.0
13.0
11.7
20.3
17.4
75
33.0
31.0
37.2
8.9
8.0
12.7
10.8
75
Rdc ( m ) ◇
Rated Voltage
(V)
◇:Significant Characteristic
* :If you require another part number please contact with us.
**:Inductance Tolerance 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:100KHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate ΔT of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 20%
Note 5.: Operating Temperature Range -55℃ to + 125℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.: The rated current as listed is either the saturation current or the heating current depending on which value
is lower.
Note 8.: Cleaning Process Note
(a) If this power choke is dipped in the cleaning agent, such as toluene, xylene, ketone, and ether
system, there is a possibility that the performance decreases greatly
(b) The high power ultrasonic washing may damage the choke body.
(c) Please contact us if you need the cleaning via the above agents or ultrasonic washing.
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
REVISION
: A2
PAGE
: 5 OF 8
1.80
80
15.0
60
INDUCTANCE(μH)
1.35
18.0
TEMP. RISE(℃)
40
0.90
0.00
5
10
15
30
35
40
45
50
60
INDUCTANCE(μH)
9.0
TEMP. RISE(℃)
40
6.0
4
6
8
10
12
14
16
18
DC BIAS(Amps)
VCMV177T-330MN2
80
28.0
60
INDUCTANCE(μH)
TEMP. RISE(℃)
40
14.0
TEMP. RISE(℃)
100
35.0
21.0
80
12.0
0.0
55
DC BIAS(Amps)
42.0
100
3.0
VCMV177T-150MN2
TEMP. RISE(℃)
INDUCTANCE (μH)
2.25
100
INDUCTANCE(μH)
VCMV177T-2R2MN2
2.70
INDUCTANCE(μH)
: CYNVC-176-010
Current Characteristic
TEMP. RISE (℃)
DOCUMENT
2
3
4
5
6
7
8
9
10
11
12
13
DC BIAS(Amps)
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 6 OF 8
Packaging
(1) Tape packaging dimensions
t
+0.1
1.5 -0.0
4.0 ± 0.1
2.0 ± 0.1
1.75 ± 0.10
Sprocket hold
11.5 ± 0.1
24.0 ± 0.3
B0
K0
A0
Carrier cavity
24.0 ± 0.1
Pulling direction
Dimensions Code (mm)
UNITS/REEL
A0
B0
K0
t
17.45 0.10
17.8 0.1
7.3 0.1
0.50 0.05
200
(2) Tape Direction
The direction shall be seen from the top cover tape side.
2R2
XXX
XXX
2R2
XXX
XXX
2R2
XXX
XXX
Pulling direction
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 7 OF 8
2.0 ± 0.5
20.0 ± 0.5
B
330.0 ± 2.0
100.0 ± 1.0
(3) Reel dimensions
A
13.0 ± 1.0
mm
A
B
24.5 0.5
2.0 0.2
(4) Peel force of top cover tape
The peel speed shall be about 300 mm/minute.
The peel force of top cover tape shall be between 0.1 to 1.3N.
Top Cover Tape
165 ~ 180°
0.1 ~ 1.3N
Carrier tape
Jul., 2021 Issued
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNVC-176-010
REVISION
: A2
PAGE
: 8 OF 8
Reflow Profile
Power Choke Coil Type
Tp
Temperature
260℃
tp:30 Sec max.
Max. Ramp Up Rate =3℃/s
Max. Ramp Down Rate =6℃/s
217℃
60~150 Sec
Preheat Area
200℃
150℃
60~120 Sec
25℃
25°C to Peak ( 8 minutes max.)
Time
(1) Reflow Soldering Method :
Reflow Soldering
Tp:255~260℃
Max.30 seconds ( tp )
217℃
60~150 seconds
Pre-Heat
150 ~ 200℃
60~120 seconds
Time 25℃ to peak temperature
8 minutes max.
(2) Soldering iron Method : 350 5℃ max.3 seconds
Jul., 2021 Issued
很抱歉,暂时无法提供与“VCMV177T-680MN2”相匹配的价格&库存,您可以联系我们找货
