Technical Data 10547
Effective August 2016
HCM1A0503
Automotive grade
High current power inductors
Applications
Product features
AEC-Q200 Grade 1 qualified
High current carrying capacity
Magnetically shielded, low EMI
Frequency range up to 1 MHz
Inductance range from 0.2 μH to 10 μH
Current range from 2.3 A to 24 A
5.5 mm x 5.3 mm footprint surface mount
package in a 3.0 mm height
Alloy powder core material
Moisture Sensitivity Level (MSL): 1
Halogen free, lead free, RoHS compliant
Body electronics
• Central body control module
Vehicle access control system
Headlamps, tail lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• 77 GHz radar system
Basic and smart surround, and rear and front
view camera
Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/Car black
box system
Infotainment and cluster electronics
• Active noise cancellation (ANC)
Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
Chassis and safety electronics
• Airbag control unit
Engine and Powertrain Systems
• Powertrain control module (PCU)/Engine
Control unit (ECU)
Transmission Control Unit (TCU)
Environmental Data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020 (latest
revision) compliant
HALOGEN
Pb HF
FREE
HCM1A0503
Automotive grade high current power inductors
Product Specifications
Part Number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
K-factor5
HCM1A0503-R20-R
0.20
0.128
15.8
18
2.1
2.3
1601
HCM1A0503-R22-R
0.22
0.141
15.8
24
2.1
2.3
1004
HCM1A0503-R33-R
0.33
0.211
11.8
16
3.9
4.3
918
HCM1A0503-R35-R
0.35
0.224
11.8
15
3.9
4.3
914
HCM1A0503-R47-R
0.47
0.300
9.2
12
6.5
7.2
835
HCM1A0503-R68-R
0.68
0.435
8.0
12
8.2
9.1
713
HCM1A0503-R75-R
0.75
0.48
7.8
12
8.5
9.4
590
HCM1A0503-1R0-R
1.0
0.64
7.1
8.5
10.4
11.4
569
HCM1A0503-1R5-R
1.5
0.96
5.2
6.8
17.1
18.5
450
HCM1A0503-2R2-R
2.2
1.4
4.5
6.4
22.5
25.0
411
HCM1A0503-3R3-R
3.3
2.1
3.8
5.6
36.4
40.4
332
HCM1A0503-4R7-R
4.7
3.0
3.1
4.2
54
60.0
239
HCM1A0503-5R6-R
5.6
3.6
2.8
4.0
63
70.6
235
HCM1A0503-6R8-R
6.8
4.4
2.3
3.8
81
97.2
212
HCM1A0503-100-R
10
6.4
2.4
2.3
90
108
191
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A0503-xxx-R
HCM1A0503 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
xxxx
Dimensions (mm)
Part marking: 1AXXX=1A=Automotive grade, XXX=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros
xxxx= Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Color: Grey
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A0503
Packaging information (mm)
Drawing not to scale
xxxx
Supplied in tape and reel packaging , 2000 parts per 13” diameter reel
Core loss vs Bp-p
HCM1A0503-R20-R
1000
1 MHz
1 MHz
500 kHz
100 kHz
50 kHz
10
25 kHz
1
0.1
500 kHz
300 kHz
100
300 kHz
Core Loss (mW)
Core Loss (mW)
100
HCM1A0503-R22-R
1000
100 kHz
50 kHz
10
25 kHz
1
100
1000
Bp-p (Gauss)
10000
0.1
100
10000
1000
Bp-p (Gauss)
3
HCM1A0503
Core loss vs Bp-p
HCM1A0503-R33-R
1000
1 MHz
1 MHz
Core Loss (mW)
Core Loss (mW)
500 kHz
300 kHz
100
100 kHz
50 kHz
10
25 kHz
1
100
100
1000
300 kHz
100 kHz
50 kHz
10
0.1
10000
Bp-p (Gauss)
HCM1A0503-R47-R
1000
25 kHz
Core Loss (mW)
100 kHz
50 kHz
25 kHz
1
0.1
1 MHz
500 kHz
300 kHz
100 kHz
10
50 kHz
25 kHz
1
100
1000
0.1
10000
100
Bp-p (Gauss)
HCM1A0503-R75-R
1000
1 MHz
100
500 kHz
100 kHz
50 kHz
10
25 kHz
10000
500 kHz
300 kHz
100 kHz
10
50 kHz
25 kHz
1
1
0.1
1 MHz
100
300 kHz
1000
Bp-p (Gauss)
HCM1A0503-1R0-R
1000
Core Loss (mW)
Core Loss (mW)
10000
1000
Bp-p (Gauss)
HCM1A0503-R68-R
100
300 kHz
10
100
1000
1 MHz 500 kHz
100
4
500 kHz
1
0.1
Core Loss (mW)
HCM1A0503-R35-R
1000
0.1
100
1000
Bp-p (Gauss)
10000
100
1000
Bp-p (Gauss)
10000
HCM1A0503
Core loss vs Bp-p
HCM1A0503-1R5-R
1000
1 MHz
500 kHz
100 kHz
10
50 kHz
25 kHz
100
100 kHz
50 kHz
25 kHz
1000
0.1
10000
Bp-p (Gauss)
100
HCM1A0503-3R3-R
1 MHz
500 kHz
Core Loss (mW)
100 kHz
10
1 MHz
100
300 kHz
50 kHz
25 kHz
1
10000
1000
Bp-p (Gauss)
HCM1A0503-4R7-R
1000
100
Core Loss (mW)
300 kHz
1
1000
500 kHz
300 kHz
100 kHz
10
50 kHz
25 kHz
1
100
1000
1 MHz
100
500 kHz
Core Loss (mW)
50 kHz
25 kHz
1
0.1
100
1000
Bp-p (Gauss)
10000
1000
10000
Bp-p (Gauss)
1 MHz
100
100 kHz
100
HCM1A0503-6R8-R
1000
300 kHz
10
0.1
10000
Bp-p (Gauss)
HCM1A0503-5R6-R
1000
Core Loss (mW)
500 kHz
10
1
0.1
1 MHz
100
300 kHz
Core Loss (mW)
Core Loss (mW)
100
0.1
HCM1A0503-2R2-R
1000
500 kHz
300 kHz
100 kHz
10
50 kHz
25 kHz
1
0.1
100
1000
10000
Bp-p (Gauss)
5
HCM1A0503
Core loss vs Bp-p
Inductance and temperature rise vs. current
Core Loss (mW)
90
500 kHz
0.16
80
300 kHz
0.14
70
0.12
60
0.10
50
0.08
40
0.06
30
0.04
10
100 kHz
50 kHz
10
25 kHz
1
0.00
0.1
100
100
0.18
Inductance (µH)
1 MHz
100
HCM1A0503-R20-R
0.20
1000
10
15
10000
Bp-p (Gauss)
Idc (A)
25
30
35
40
Temperature Rise (°C)
HCM1A0503-100-R
1000
80
0.14
70
0.12
60
0.10
50
0.08
40
0.06
30
0.04
10
0.00
10
15
25
30
Idc (A)
35
40
45
50
100
90
0.30
80
0.25
70
60
0.20
50
0.15
40
30
0.10
0.00
10
10
15
Idc (A)
30
90
0.16
Inductance (µH)
0.18
100
Inductance (µH)
6
HCM1A0503-R33-R
HCM1A0503-R22-R
0.20
HCM1A0503
0.50
90
0.45
90
80
0.40
80
0.35
70
0.30
60
0.25
50
0.20
40
0.15
40
0.15
30
0.05
10
30
0.10
0.05
0.00
10
15
30
10
Idc (A)
HCM1A0503-R68-R
0.70
100
0.60
50
0.30
40
30
0.20
0.10
0.00
10
25
0.10
100
80
0.70
70
0.60
60
0.50
50
0.40
40
0.30
30
0.20
0.10
10
0.2
0.00
10
15
40
30
10
15
Idc (A)
HCM1A0503-1R5-R
1.8
0.80
Idc (A)
60
0.30
90
5
70
0.40
0.90
0.50
10
90
80
1.4
70
1.2
60
1.0
50
0.8
40
0.6
0.0
1.6
Inductance (µH)
Inductance (µH)
HCM1A0503-1R0-R
1.00
7
Idc (A)
15
90
0.20
0.60
Inductance (µH)
0.40
60
Inductance (µH)
70
25
0.70
80
0.50
Idc (A)
HCM1A0503-R75-R
0.80
90
15
50
100
30
4
6
8
Idc (A)
10
12
14
60
0.20
Inductance (µH)
Inductance (µH)
70
0.30
0.25
HCM1A0503-R47-R
100
HCM1A0503-R35-R
0.35
HCM1A0503
90
80
60
1.2
50
40
0.8
30
10
12
14
100
4.5
90
4.0
80
3.5
70
3.0
60
2.5
50
2.0
40
1.5
30
1.0
10
0.0
2
3
4
Idc (A)
5
6
HCM1A0503-6R8-R
7
6
Inductance (µH)
5
1
1.5
2
2.5
Idc (A)
3
3.5
4
4.5
5
4
6
8
Idc (A)
10
12
HCM1A0503-5R6-R
90
5
80
70
4
60
3
50
40
2
30
10
2
3
4
Idc (A)
5
6
7
8
HCM1A0503-100-R
90
8
80
7
70
6
60
5
50
4
40
30
80
40
1
50
2
30
1.0
10
60
3
40
100
70
4
50
1.5
6
Inductance (µH)
Idc (A)
8
HCM1A0503-4R7-R
5.0
Inductance (µH)
6
Inductance (µH)
4
60
2.0
0.0
2
0.5
10
0.0
80
1.6
90
2.5
Inductance (µH)
70
100
3.0
Inductance (µH)
2.0
HCM1A0503-3R3-R
3.5
100
100
3
30
1
10
1
1.5
2
Idc (A)
2.5
3
3.5
4
HCM1A0503-2R2-R
2.4
8
HCM1A0503
Effective July 2016
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A0503-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+5.617902000+0.67163
- 4000+5.195554000+0.62113
- 6000+4.983306000+0.59576
- 国内价格 香港价格
- 1+12.973451+1.55099
- 10+10.1109610+1.20877
- 25+9.1404025+1.09274
- 50+8.4670350+1.01224
- 100+7.84347100+0.93769
- 250+7.08674250+0.84723
- 500+6.56082500+0.78435
- 1000+6.072161000+0.72593
- 国内价格
- 25+1.25429
- 100+1.23388
- 250+1.21435
- 500+1.19393
- 1000+1.17440
