RJM74M0204W6T47R0
RJM74M0204W6T47R0
    THUNDER(盛雷城)
    MELF0204
    金属膜电阻 0204 47Ω ±0.05% 400mW
RJM74M0204W6T47R0 数据手册
RJM SERIES HIGH PRECISION SMT TYPE RESISTORS MELF TYPE METAL FILM RESISTORS, COATED TYPE Feature · Advanced thin film technology · Excellent overall stability: Class 0.05% · Extremely low TCR: up to ±5ppm/K · Exceptionally low noise and voltage coefficient • Compliant to RoHS directive 2011/65/EU • Compliant to REACH (EC No. 1907/2006)) (last updated: 27/06/2018) Description Production is strictly controlled and follows extensive set of instructions established in production procedure for reproducibility. A homogeneous film of metal alloy is deposited on the surface of high-grade ceramic cores (85%~96% AL2O3) and conditioned to achieve the desired stability and the temperature coefficients. A professional laser or an extreme thin emery wheel is pressed on the metalized rods to not only achieve the target value but also prefect electronics performance by smoothly cutting a helical groove in the resistance layer on the ceramic rods without damaging the ceramics. The resistance layers are covered by a protective coating and hard Bakelite designed for electrical, mechanical, and climatic protection. The resistors are tested in accordance with MIL-R-10509F which refers to MIL- STD-202 or IEC60115. The established reliability in accordance with CECC 40401-803 Version E is available upon request. www.thunder-resistor.com sales@thunder-resistor.com 1 1. PRODUCT: METAL FILM MELF TYPE PRECISION RESISTORS 2. PART NUMBER: Part number of the melf type precision metal film resistor is identified by the series name, power rating, metric size code, resistance tolerance, temperature coefficient, packing type and resistance value. For example: RJM Series Name 73P Power rating 0204 Size code B Tolerance 6 TCR T Packing Style 5051 Resistance Value (1) Series name: RJM series (2) Power rating listed in the Electric characteristics M= Tiny size; P= power mode; S= Small size; “ “= normal size (3) Metric size: DIN: 0102, DIN: 0204, DIN: 0207, DIN: 0411, DIN: 0617 (4) Tolerance: W=±0.05%; B=±0.1%; C=±0.25%; D=±0.5%; F=±1%; G=±2% (5) T.C.R.: 7≤ ±5ppm/℃; 6≤ ±10ppm/℃; 5≤ ±15ppm/℃; 3=±25ppm/℃; 2≤ ±50ppm/℃; 1≤±100ppm/℃; 0≤±200ppm/℃ (6) Packaging Type: B=BULK/BOX T=REEL/BOX (7) Resistance Value: 100K(1003); 22K5(2252); 2K15(2151);120R(1200); 10R(10R0); 1.8R(1R80); 0.99R(R990)……… (9) RJM73P020400TR000 and RJM74P020700TR000 are jumpers with resistance lower than 15mΩ 3. Structure of the resistors: www.thunder-resistor.com sales@thunder-resistor.com 2 4. COLOR BAND-CODE: Four color bands codes for size 0102 and 0204. Five color bands for size 0207, 0411, 0516 www.thunder-resistor.com sales@thunder-resistor.com 3 5. * ELECTRICAL CHARACTERISTICS Unless otherwise specified, all values are tested at the following condition Temperature: 21℃ to 25℃; Relative humidity: 45% to 70%; The parts must be well soldering with good soldering pads. Power Rating X Resistance Value * Rated Continuous Working Voltage (RCWV)= * Resistance value out of range is available on request. * The post high temperature treatment after final tin plating is strictly controlled by our production procedure to minimize the tin whisker phenomenon * The resistances of all jumpers are lower than 15mΩ www.thunder-resistor.com sales@thunder-resistor.com 4 6. Derating curves The power dissipation on the resistor generates a temperature rise against the local ambient, depending on the heat flow support of the printed-circuit board (thermal resistance). The rated dissipation applies only if the permitted film temperature is not exceeded. These resistors do not feature a limited lifetime when operated within the permissible limits. However, resistance value drift increasing over operating time may result in exceeding a limit acceptable to the specific application, thereby establishing a functional lifetime. For MELF resistors working at an ambiance temperature of 70 ℃ or above, the power rating shall be derated in accordance with the above curves. 7. Pulse load capability www.thunder-resistor.com sales@thunder-resistor.com 5 8. ENVIRONMENTAL CHARACTERISTICS (1) Temperature Coefficient Test IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C (or 100°C upon request) above room temperature. Then measure the resistance. The Temperature Coefficient is calculated by the following equation and its value should be within the range requested. R = Resistance value under the testing R0= Resistance value at the room temperature t = the 2nd testing temperature t0 = Room temperature (2) Short Time Overload Test IEC60115-1 4.13: At 2.5 times rated voltage or 2 times the maximum working voltage whichever is lower for 5 seconds, the resistor should be free from defects. The change of the resistance value of normal size resistors should be within ±(0.1%+0.05Ω) and within ±(0.2%+0.05Ω) for tiny size resistors as compared with the value before the test. (3) Solderability IEC 60115-1, 4.17: 255±5°C for 3±0.5 Seconds, there are at least 90% solder coverage on the termination. (4) Resistance to soldering heat: IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, immersed only the cap into tin bath. The change of the resistance value should be within ±(0.15%+0.1Ω) as compared with the value before the test. (5) Rapid change of temperature (Thermal shock) IEC 60115-1, 4.19: 30 min at LCT; 30 min at UCT; LCT = -55°C; UCT = 125°C. 5 cycle from LCT to room temperature. and to UCT and to room temperature. The change of the resistance value shall be within ±(0.25%+0.05Ω) for the resistors of tight tolerance and normal size; should be within ±(1%+0. 05Ω) for resistors of normal tolerance and tiny size as compared with the value before the load.as compared with the value before the load. www.thunder-resistor.com sales@thunder-resistor.com 6 (6) Damp Heat Steady State IEC 60115-1, 4.24: 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV or the maximum working voltage whichever is lower. The change of the resistance value should be within ±(0.25%+0. 05Ω) for resistors with tight tolerance and normal size and should be within ±(1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (7) Load Life Test IEC 60115-1, 4.25: 70±2°C at RCWV or the maximum working voltage whichever is lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged not much effected mutually by the temperature of others and the excessive ventilation shall not be performed. The change of the resistance value should be within ±(0.25%+0.05Ω) for resistors with tight tolerance and normal size and should be within ± (1%+0.05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (8) Endurance at upper category temperature IEC60115-1, 4.25.3: put resistors in over with temperature at 125 °C for 1000h. The change of the resistance value should be within ±(0.25%+0. 05Ω) for resistors with tight tolerance and within ±(1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (9) Accidental Overload Test IEC 60115-1, 4.26: 4 times RCWV or 2 times the maximum working voltage whichever is lower for 1 Minute. No evidence of flaming or arcing. (10) Component solvent resistance IEC 60115-1, 4.29: Isopropyl alcohol; 50 °C; method 2. No visible damage. (11) Solvent resistance of marking IEC 60115-1, 4.30: Isopropyl alcohol; 50 °C; method 1, toothbrush. Marking legible; no visible damage www.thunder-resistor.com sales@thunder-resistor.com 7 (12) Resistance to Solvent IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. Marking legible; no visible deterioration occurred. (13) Damp heat, steady state, accelerated IEC 60115-1, 4.37: (85 ± 2)°C, (85 ± 5)% RH; U = 0.3 x RCWV or U = 0.3 x Umax or 100V whichever is lower for 120 hours. The change of the resistance value should be within ±(0.25%+0. 05Ω) for resistors with tight tolerance and within ±(1%+0. 05Ω) for resistors with normal tolerance and tiny size as compared with the value before the load. (14) Electrostatic discharge (Human Body Model) IEC 60115-1, 4.38: IEC 61340-3-1 (1); 3 pos. + 3 neg. discharges. RJM72P0102: 1.5kV; RJM73P0204: 2kV; RJM74P0207: 3kV; RJM16M0207: 3 kV; RJM17M0411: 4kV; RJM18M0617: 6kV The change of the resistance value should be within ±(0.50%+0. 05Ω) as compared with the value before the load. Disclaimer All products, product specifications and data are subject to change without notice to improve reliability, function, design or otherwise. Thunder Precision Resistors makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product to the maximum extent permitted by applicable law. www.thunder-resistor.com sales@thunder-resistor.com 8
RJM74M0204W6T47R0 价格&库存
很抱歉,暂时无法提供与“RJM74M0204W6T47R0”相匹配的价格&库存,您可以联系我们找货
