HCM0703-2R2-R
HCM0703-2R2-R
    EATON(伊顿)
    SMD,7.1x6.6mm
    功率电感 ±20% 8A 2.2µH 7.10 x 6.60mm 20mΩ 3.00mm IND_7.1X6.6MM_SM
HCM0703-2R2-R 数据手册
Technical Data 4085 Effective March 2016 Supersedes December 2014 HCM0703 High current power inductors Applications • Voltage Regulator Module (VRM) • Multi-phase regulators • Point-of-loadmodules • Desktop and server VRMs and EVRDs • Base station equipment • Laptop and notebook regulators • Battery power systems • Graphics cards • Data networking and storage systems Environmental Data Product features • High current carrying capacity • Low core losses • Magnetically shielded, low EMI • Frequency range up to 5 MHz • Inductance range from 0.15 μH to 33 μH • Current range from 1.8 A to 52 A • 7.4 mm x 6.8 mm footprint surface mount package in a 3.0 mm height • Iron powder core material • Storage temperature range (Component): -55 °C to +125 °C • Operating temperature range: -55 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 compliant (Latest revision) HALOGEN Pb HF FREE HCM0703 High current power inductors  Technical Data 4085 Effective March 2016 Product Specifications Part Number6 OCL1 (μH) ±20% FLL2 (μH) minimum Irms3 (A ) Isat4 (A ) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C K-factor5 HCM0703-R15-R 0.15 0.09 26 52 1.9 2.5 1044 HCM0703-R22-R 0.22 0.13 23 40 2.5 2.8 986 HCM0703-R47-R 0.47 0.28 17.5 26 4.0 4.2 580 HCM0703-R68-R 0.68 0.41 15.5 25 5.0 5.5 455 HCM0703-R82-R 0.82 0.49 13 24 6.7 8.0 439 HCM0703- 1R0-R 1.0 0.60 11 22 9.0 10 374 HCM0703- 1R5-R 1.5 0.90 9.0 18 14 15 366 HCM0703- 2R2-R 2.2 1.3 8.0 14 18 20 281 HCM0703- 3R3-R 3.3 2.0 6.0 13.5 28 30 252 HCM0703- 4R7-R 4.7 2.8 5.5 10 37 40 210 HCM0703- 6R8-R 6.8 4.1 4.5 8.0 54 60 151 HCM0703- 8R2-R 8.2 4.9 4.0 7.5 64 68 142 HCM0703- 100-R 10 6.0 3.2 7.0 71 78 132 HCM0703- 150-R 14.9±15% 10.1 2.2 5.0 113 127 105 HCM0703- 220-R 22 14.1 2.3 3.0 135 149 83 HCM0703- 330-R 33 19.8 1.8 2.2 220 242 76 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25°C. 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, @ +25 °C. 3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 4. Isat: Peak current for approximately 20% rolloff at +25 °C. 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 6. Part Number Definition: HCM0703-xxx-R HCM0703 = Product code and size -xxx= Inductance value in μH, R = decimal point, if no R is present then last character equals number of zeros. “-R” suffix = RoHS compliant Dimensions (mm) Part marking: XXX=Inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros. wly=date code, R=revision level All soldering surfaces to be coplanar within 0.10 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Color: Grey 2 www.eaton.com/electronics Technical Data 4085 HCM0703 High current power inductors Effective March 2016  Packaging information (mm) Supplied in tape and reel packaging, 1500 parts per 13” diameter reel. Temperature rise vs. total loss 50.0 Temperature Rise (°C) 40.0 30.0 20.0 10.0 0.0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 Total Loss (W) www.eaton.com/electronics 3 HCM0703 High current power inductors  Technical Data 4085 Effective March 2016 Core loss vs. Bp-p 10000 1 MHz 500 kHz 300 kHz 1000 200 kHz Core Loss (mW) 100 kHz 100 10 1 0.1 100 10000 1000 Bp-p (Gauss) Inductance characteristics 110% 100% 100% 90% 90% 80% 70% 70% 60% 50% 50% 0 10 20 www.eaton.com/electronics 30 IDC (A) 40 50 60 70 HCM0703-R22-R 80% 60% 40% 4 % of OCL % of OCL HCM0703-R15-R 110% 40% 0 10 20 30 40 IDC (A) 50 60 70 Technical Data 4085 HCM0703 High current power inductors Effective March 2016  Inductance characteristics HCM0703-R47-R 110% 90% 90% % of OCL 100% % of OCL 100% 80% 70% 80% 70% 60% 60% 50% 50% 40% 0 5 10 15 20 25 30 HCM0703-R68-R 110% 35 40 45 50 40% 0 5 10 15 IDC (A) % of OCL % of OCL 40 45 90% 80% 70% 80% 70% 60% 60% 50% 50% 40% 0 5 10 15 20 25 30 35 40 45 0 5 10 HCM0703-1R5-R 110% 100% 90% 90% % of OCL 100% 70% 50% 50% 10 15 20 IDC (A) 25 30 35 30 35 40 70% 60% 5 25 80% 60% 0 20 HCM0703-2R2-R 110% 80% 15 IDC (A) IDC (A) % of OCL 35 100% 90% 40% 30 HCM0703-1R0-R 110% 100% 40% 25 IDC (A) HCM0703-R82-R 110% 20 40% 0 5 10 15 20 25 30 IDC (A) www.eaton.com/electronics 5 HCM0703 High current power inductors  Technical Data 4085 Effective March 2016 Inductance characteristics HCM0703-4R7-R HCM0703-3R3-R 110% 110% 90% 90% % of OCL 100% % of OCL 100% 80% 70% 80% 70% 60% 60% 50% 50% 40% 0 2 4 6 8 10 12 14 16 18 40% 20 IDC (A) 0 2 4 6 HCM0703-6R8-R 90% 90% % of OCL 100% % of OCL 100% 80% 70% 50% 50% 8 IDC (A) 10 12 14 40% HCM0703-100-R 110% 0 90% % of OCL 90% % of OCL 100% 80% 70% 50% 50% 4 www.eaton.com/electronics 6 8 IDC (A) 20 4 10 12 14 6 8 10 IDC (A) 12 14 HCM0703-150-R 70% 60% 2 18 80% 60% 0 2 110% 100% 40% 6 6 16 70% 60% 4 14 80% 60% 2 12 HCM0703-8R2-R 110% 0 10 IDC (A) 110% 40% 8 40% 0 1 2 3 4 5 IDC (A) 6 7 8 9 10 Technical Data 4085 HCM0703 High current power inductors Effective March 2016  Inductance characteristics HCM0703-220-R HCM0703-330-R 100% 100% 90% 90% % of OCL 110% % of OCL 110% 80% 70% 80% 70% 60% 60% 50% 50% 40% 0 1 2 3 IDC (A) 4 5 6 40% 0 1 2 3 IDC (A) 4 5 www.eaton.com/electronics 6 7 Technical Data 4085 HCM0703 High current power inductors  Effective March 2016 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package Thickness Volume mm3
HCM0703-2R2-R 价格&库存
很抱歉,暂时无法提供与“HCM0703-2R2-R”相匹配的价格&库存,您可以联系我们找货
HCM0703-2R2-R
    • 500+2.20230
    库存:2428
    HCM0703-2R2-R
    • 1500+5.755521500+0.74380
    • 3000+5.427963000+0.70147
    • 4500+5.245344500+0.67787
    • 7500+5.024197500+0.64929
    • 10500+4.8838510500+0.63115
    • 15000+4.8595915000+0.62802
    库存:6578
