Technical Data 4371
Effective September 2017
Supersedes June 2014
HCM1305
High current power inductors
Applications
Product features
High current carrying capacity
Low core losses
Magnetically shielded, low EMI
Frequency range up to 5 MHz
Inductance range from 0.10 µH to 33 µH
Current range from 5.2 A to 118 A
13.8 mm x 12.5 mm footprint surface mount
package in a 5.0 mm height
Iron powder core material
Voltage Regulator Module (VRM)
Multi-phase regulators
Point-of-load modules
Desktop and server VRMs and EVRDs
Base station equipment
Notebook and laptop regulators
Battery power systems
Graphics cards
Data networking and storage systems
Environmental data
Storage temperature range (component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4371
Product specifications
DCR (m1)
@ +20 °C
maximum
K-factor5
0.52
0.59
848
110
0.63
0.72
843
80
0.80
0.92
506
38
65
0.80
0.92
506
0.36
36
55
1.15
1.33
500
0.44
34
54
1.15
1.33
500
0.82
0.52
31
53
1.40
1.61
358
1.00
0.64
29
50
2.10
2.42
275
HCM1305-1R5-R
1.50
0.96
23
48
2.75
3.16
225
HCM1305-1R8-R
1.80
1.15
21
40
4.00
4.60
216
HCM1305-2R2-R
2.20
1.41
4.60
5.29
191
HCM1305-3R3-R
3.30
2.11
15
32
7.70
9.20
170
HCM1305-4R7-R
4.70
3.01
12
27
11.0
12.7
161
HCM1305-5R6-R
5.60
3.58
11.5
22
12.0
13.8
142
HCM1305-6R8-R
6.80
4.35
11
21
13.0
15.0
129
HCM1305-7R8-R
7.80
4.99
10
18.5
16.8
19.4
117
HCM1305-8R2-R
8.20
5.25
9.5
18
17.5
20.1
117
HCM1305-100-R
10.0
6.40
9.0
16
19.0
21.9
90
HCM1305-150-R
15.0
9.60
7.7
13
29.0
33.4
74
HCM1305-220-R
22.0
14.1
6.2
10
45.0
51.8
63
HCM1305-330-R
33.0
21.1
5.2
8
74.5
85.5
48
OCL1
(µH) ± 20%
FLL2 Min.
(µH)
HCM1305-R10-R
0.10
HCM1305-R22-R
HCM1305-R33-R
Irms3
(A)
Isat4
(A)
0.064
55
118
0.22
0.14
51
0.33
0.21
42
HCM1305-R47-R
0.47
0.30
HCM1305-R56-R
0.56
HCM1305-R68-R
0.68
HCM1305-R82-R
HCM1305-1R0-R
Part Number6
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc,
+25 °C.
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, @ +25 °
C.
3. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
2
www.eaton.com/electronics
DCR (m1)
@ +20 °C ±
nominal
4. Isat: Peak current for approximately 20% rolloff at +25 °C.
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * 6I.
Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in µH), 6I (Peak to peak
ripple current in amps).
6. Part Number Definition: HCM1305-yyy-R
- HCM1305 = Product code and size
yyy= Inductance value in µH, R = decimal point,
if no R is present then third character = number of zeros.
“-R” suffix = RoHS compliant
HCM1305
Technical Data 4371
Dimensions- mm
Top View
13.3±0.5
Side View
5.0 max.
Bottom View
Recommended Pad Layout
Schematic
2.54±0.3
3.3
12.2±0.3
xxx
wlyy R
4.0±0.5
7.7 typ.
14.3
4.9
8.5 typ.
Part Marking: xxx = Inductance value in µH, R = decimal point, if no R is present, third character = number of zeros, wlyy = (Date Code), R = (Revision Level)
All soldering surfaces to be coplanar within 0.10 millimeters.
Tolerances are ±0.3 millimeters unless stated otherwise.
Color: Grey.
Do not route traces or vias underneath the inductor
Packaging information - mm
Supplied in tape and reel packaging, 400 parts per 13” diameter reel.
3
HCM1305
Technical Data 4371
Temperature rise vs. total loss
50.0
Temperature Rise (˚C)
40.0
30.0
20.0
10.0
0.0
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
Total Loss (W)
Core loss vs. Bp-p
10000
1MHz
500KHz
300KHz
200KHz
100KHz
Core Loss (mW)
1000
100
10
1
100
1000
Bp-p (Gauss)
4
10000
HCM1305
Technical Data 4371
Inductance characteristics
HCM1305-R47-R
100%
100%
90%
90%
% of OCL
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
60
80
100
120
80
100
120
HCM1305-R68-R
HCM1305-R56-R
110%
100%
100%
90%
90%
% of OCL
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
60
80
100
10
Idc (A)
40
50
60
70
80
Idc (A)
HCM1305-R82-R
HCM1305-1R0-R
110%
100%
100%
90%
90%
% of OCL
110%
% of OCL
60
Idc (A)
Idc (A)
% of OCL
% of OCL
HCM1305-R33-R
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
40
50
60
70
80
10
40
50
60
70
Idc (A)
Idc (A)
5
HCM1305
Technical Data 4371
HCM1305-1R8-R
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCM1305-1R5-R
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
30
35
40
45
50
55
5
10
15
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
40
45
50
55
60
HCM1305-3R3-R
HCM1305-2R2-R
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
30
35
40
45
5
10
15
Idc (A)
25
30
35
40
45
50
Idc (A)
HCM1305-5R6-R
HCM1305-4R7-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
35
Idc (A)
Idc (A)
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
Idc (A)
6
30
30
35
10
15
Idc (A)
30
HCM1305
Technical Data 4371
HCM1305-7R8-R
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCM1305-6R8-R
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
2
4
6
8
10
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
14
16
18
24
26
HCM1305-100-R
HCM1305-8R2-R
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
4
6
8
10
12
14
16
18
24
26
4
6
8
10 12 14 16 18 20 22
Idc (A)
24 26
Idc (A)
HCM1305-220-R
HCM1305-150-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
12
Idc (A)
Idc (A)
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
4
6
8
10
Idc (A)
12
14
16
18
4
6
8
10
12
14
16
18
22
Idc (A)
7
HCM1305
Technical Data 4371
HCM1305-330-R
110%
100%
% of OCL
90%
80%
70%
60%
50%
40%
4
6
8
Idc (A)
8
10
12
14
16
18
HCM1305
Technical Data 4371
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4371 BU-SB14459
September 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“HCM1305-2R2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 400+23.92810
- 15200+18.20905
- 国内价格 香港价格
- 1+14.216371+1.84044
- 10+11.7031410+1.51508
- 100+9.62056100+1.24547
- 国内价格 香港价格
- 400+8.63508400+1.11789
- 800+8.14289800+1.05417
- 1200+7.868341200+1.01863
- 2000+7.535822000+0.97558
- 2800+7.324762800+0.94826
- 4000+7.107704000+0.92016
