Technical Data 10549
Effective June 2018
Supersedes August 2016
HCM1A0805
Automotive grade
High current power inductors
Applications
Body electronics
• Central body control module
Vehicle access control system
Headlamps, tail lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/
Car black box system
AEC-Q200 Grade 1 qualified
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
High current carrying capacity
Digital instrument cluster
Magnetically shielded, low EMI
In-vehicle infotainment (IVI) and navigation
Frequency range up to 1 MHz
Inductance range from 3.3 μH to 100 μH
Port power/USB HUB for front and
rear passengers
Current range from 1.5 A to 10 A
8.3 mm x 8.0 mm footprint surface mount
package in a 5.4 mm height
Alloy powder core material
Moisture Sensitivity Level (MSL): 1
Product features
Chassis and safety electronics
• Airbag control unit
Electronic stability control system (ESC)
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Powertrain control module (PCU)/Engine
Control unit (ECU)
Transmission Control Unit (TCU)
Environmental Data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A0805
Automotive grade high current power inductors
Effective June 2018
Product Specifications
Part Number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
K-factor5
HCM1A0805-3R3-R
3.3
2.1
8.0
8.0
9.0
10
180
HCM1A0805-4R7-R
4.7
3.0
5.7
10
17
HCM1A0805-100-R
10
6.4
2.8
8.0
50
55
48
HCM1A0805-150-R
15
9.6
2.5
6.0
64
71
48
HCM1A0805-220-R
22
14
2.0
3.8
100
110
39
HCM1A0805-470-R
47
30
1.8
3.2
145
160
31
HCM1A0805-101-R
100
64
1.5
2.7
240
265
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A0805-xxx-R
HCM1A0805 = Product code and size
xxx = inductance value in μH, R = decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
xxxx
Dimensions (mm)
Part marking: 1AXXX=automotive grade, XXX=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros.
xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Color: Grey
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A0805
Effective June 2018
Packaging information (mm)
Drawing not to scale
xxxx
Supplied in tape and reel packaging ,500 parts per 13” diameter reel
Core loss vs Bp-p
HCM1A0805-3R3-R
1000
1 MHz
500 kHz
300 kHz
500 kHz
300 kHz
100 kHz
50 kHz
25 kHz
10
1
0.1
1 MHz
1000
Core Loss (mW)
Core Loss (mW)
100
HCM1A0805-4R7-R
10000
100 kHz
100
50 kHz
25 kHz
10
1
0.1
100
1000
Bp-p (Gauss)
10000
100
1000
10000
Bp-p (Gauss)
3
HCM1A0805
Effective June 2018
Core loss vs Bp-p
HCM1A0805-100-R
10000
1 MHz
1000
Core Loss (mW)
HCM1A0805-150-R
10000
500 kHz
1 MHz
1000
300 kHz
Core Loss (mW)
100 kHz
50 kHz
100
25 kHz
10
300 kHz
100 kHz
100
1
0.1
500 kHz
50 kHz
25 kHz
10
1
100
1000
0.1
10000
Bp-p (Gauss)
1000
HCM1A0805-470-R
1000
500 kHz
300 kHz
1 MHz
1 MHz
1000
500 kHz
100 kHz
100
Core Loss (mW)
Core Loss (mW)
300 kHz
100 kHz
100
10000
Bp-p (Gauss)
HCM1A0805-220-R
10000
100
50 kHz
25 kHz
10
50 kHz
25 kHz
10
1
1
0.1
100
1000
10000
Bp-p (Gauss)
1 MHz
Core Loss (mW)
1000
500 kHz
300 kHz
100 kHz
100
50 kHz
25 kHz
10
1
4
100
1000
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
HCM1A0805-101-R
10000
0.1
10000
10000
HCM1A0805
Effective June 2018
Inductance and temperature rise vs. current
100
90
4.5
90
80
4.0
80
3.5
70
3.0
60
2.5
50
2.0
40
1.5
30
0.5
10
70
60
2.0
50
1.5
40
30
1.0
0.5
5
10
15
10
Idc (A)
100
16
90
14
80
60
6
50
40
4
30
100
90
80
12
Inductance (µH)
70
8
Temperature Rise (°C)
Inductance (µH)
10
70
10
60
8
50
40
6
30
4
2
10
4
6
8
10
12
14
4
100
90
90
80
40
80
35
70
30
60
25
50
15
30
5
10
40
8
30
4
5
6
7
8
Inductance (µH)
12
Idc (A)
60
4
12
50
70
16
3
10
100
Inductance (µH)
8
HCM1A0805-470-R
HCM1A0805-220-R
24
1
6
Idc (A)
Idc (A)
HCM1A0805-150-R
HCM1A0805-100-R
Idc (A)
12
2
3
4
5
6
0.0
Inductance (µH)
Inductance (µH)
2.5
5.0
3.0
100
HCM1A0805-4R7-R
HCM1A0805-3R3-R
3.5
Idc (A)
5
HCM1A0805
Effective June 2018
HCM1A0805-101-R
120
100
90
80
70
80
60
50
60
40
40
30
1
1.5
2
Idc (A)
6
2.5
3
3.5
4
Temperature rise (°C)
Inductance (uH)
100
HCM1A0805
Effective June 2018
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A0805-680-R”相匹配的价格&库存,您可以联系我们找货
