HCM1A1305-470-R
HCM1A1305-470-R
    EATON(伊顿)
    功率电感 47µH ±20% 1350 5.00mm 13.30 x 12.20mm
HCM1A1305-470-R 数据手册
Technical Data 10551 Effective September 2016 HCM1A1305 Automotive grade High current power inductors Applications • • • Product features Body electronics • Central body control module • Headlamps, tail lamps and interior lighting • Heating ventilation and air conditioning controllers (HVAC) • Doors, window lift and seat control Advanced driver assistance systems • Adaptive cruise control (ACC) • Automatic parking control • Collision avoidance system/ Car black box system Infotainment and cluster electronics • Audio subsystem: head unit and trunk amp • Digital instrument cluster • In-vehicle infotainment (IVI) and navigation • AEC-Q200 Grade 1 qualified • High current carrying capacity • Magnetically shielded, low EMI • Frequency range up to 1 MHz Chassis and safety electronics • Airbag control unit • Inductance range from 0.1 μH to 33 μH • Electronic stability control system (ESC) • Current range from 3.5 A to 80 A • Electric parking brake • 13.8 mm x 12.5 mm footprint surface mount package in a 5.0 mm height • Electronic Power Steering (EPS) • • Moisture Sensitivity Level (MSL): 1 Engine and Powertrain Systems • Electric pumps, motor control and auxiliaries • Alloy powder core material • • Halogen free, lead free, RoHS compliant Powertrain control module (PCU)/Engine Control unit (ECU) • Transmission Control Unit (TCU) • Environmental Data • Storage temperature range (Component): -55 °C to +155 °C • Operating temperature range: -55 °C to +155 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Product Specifications Part Number6 OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) Isat4 (A) DCR (mΩ) typical @ +20°C DCR (mΩ) maximum @ +20°C K-factor5 HCM1A1305-R10-R 0.10 0.064 43 80 0.52 0.59 818 HCM1A1305-R22-R 0.22 0.14 40 44 0.63 0.72 458 HCM1A1305-R33-R 0.33 0.21 35 44 0.80 0.92 379 HCM1A1305-R47-R 0.47 0.30 33 36 0.80 0.92 375 HCM1A1305-R56-R 0.56 0.36 28 36 1.15 1.33 265 HCM1A1305-R68-R 0.68 0.44 27 32 1.15 1.33 263 HCM1A1305-R82-R 0.82 0.52 26 26 1.4 1.61 262 HCM1A1305-1R0-R 1.0 0.64 22 30 2.1 2.42 214 HCM1A1305-1R5-R 1.5 0.96 18 22 2.75 3.16 177 HCM1A1305-1R8-R 1.8 1.15 16 20 4.0 4.6 154 HCM1A1305-2R2-R 2.2 1.41 15 18 4.6 5.29 153 HCM1A1305-3R3-R 3.3 2.11 12 16 7.7 9.2 134 HCM1A1305-4R7-R 4.7 3.01 9.3 15 11 12.7 102 HCM1A1305-5R6-R 5.6 3.58 8.8 15 12 13.8 89 HCM1A1305-6R0-R 6.0 3.84 8.1 12.5 12.5 14.5 90 HCM1A1305-6R8-R 6.8 4.35 8.3 13 13 15 74 HCM1A1305-7R8-R 7.8 4.99 7.6 15 16.8 19.4 70 HCM1A1305-8R2-R 8.2 5.25 7.3 13 17.5 20.1 67 HCM1A1305-100-R 10 6.40 6.8 13 19 21.9 65 HCM1A1305-120-R 12 7.68 5.5 9.0 21 24 81 HCM1A1305-150-R 15 9.6 5.8 11 29 33.4 49 HCM1A1305-220-R 22 14.1 3.5 6.8 45 51.8 43 HCM1A1305-330-R 33 21.1 4.0 7.0 74.5 85.5 32 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C 3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 155 °C under worst case operating conditions verified in the end application. 2 www.eaton.com/electronics 4. Isat: Peak current for approximately 20% rolloff @ +25 °C 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 6. Part Number Definition: HCM1A1305-xxx-R HCM1A1305 = Product code and size xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 xxxx Dimensions (mm) Part marking: 1AXXX=automotive grade, XXX=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.3 millimeters unless stated otherwise DCR measured from point “a” to point “b” Color: Grey Do not route traces or vias underneath the inductor Packaging information (mm) Drawing not to scale xxxx Supplied in tape and reel packaging, 250 parts per 13” diameter reel www.eaton.com/electronics 3 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Core loss vs Bp-p HCM1A1305-R10-R 1000 1 MHz HCM1A1305-R22-R 10000 500 kHz 300 kHz Core Loss (mW) 300 kHz Core Loss (mW) 100 kHz 100 50 kHz 25 kHz 10 500 kHz 1 MHz 1000 100 kHz 100 50 kHz 25 kHz 10 1 100 1000 1 10000 Bp-p (Gauss) HCM1A1305-R33-R 10000 1 MHz 500 kHz 100 kHz 50 kHz 25 kHz 100 1000 25 kHz 1 10000 1 MHz 1000 10000 HCM1A1305-R68-R 10000 500 kHz 1 MHz 1000 Core Loss (mW) 300 kHz 100 kHz 50 kHz 100 100 Bp-p (Gauss) HCM1A1305-R56-R 1000 Core Loss (mW) 50 kHz 10 10000 25 kHz 10 4 500 kHz 100 kHz 100 Bp-p (Gauss) 1 1 MHz 300 kHz 10 1 10000 HCMA1305-R47-R 1000 300 kHz 100 1000 Bp-p (Gauss) 10000 Core Loss (mW) Core Loss (mW) 1000 100 500 kHz 300 kHz 100 kHz 50 kHz 100 25 kHz 10 100 1000 Bp-p (Gauss) www.eaton.com/electronics 10000 1 100 1000 Bp-p (Gauss) 10000 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Core loss vs Bp-p HCM1A1305-R82-R 10000 1000 1 MHz 500 kHz Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 25 kHz 100 kHz 100 10 100 1000 1 10000 1 MHz 500 kHz 1000 50 kHz 25 kHz 10 100 kHz 100 10000 Bp-p (Gauss) HCM1A1305-2R2-R 10000 1000 1 MHz 10 1000 Core Loss (mW) 100 kHz 50 kHz 25 kHz 10 1000 10000 HCM1A1305-3R3-R 10000 300 kHz 1 100 Bp-p (Gauss) 500 kHz 100 50 kHz 25 kHz 1 1000 500 kHz 300 kHz 100 kHz 100 10000 1 MHz 300 kHz 100 1000 HCM1A1305-1R8-R 10000 Core Loss (mW) Core Loss (mW) 1000 100 Bp-p (Gauss) HCM1A1305-1R5-R 10000 Core Loss (mW) 50 kHz 25 kHz Bp-p (Gauss) 1 500 kHz 300 kHz 10 1 1 MHz 1000 300 kHz 100 HCM1A1305-1R0-R 10000 1 MHz 500 kHz 300 kHz 100 kHz 100 50 kHz 25 kHz 10 100 1000 Bp-p (Gauss) 10000 1 100 1000 10000 Bp-p (Gauss) www.eaton.com/electronics 5 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Core loss vs Bp-p HCM1A1305-4R7-R 10000 1 MHz 500 kHz 100 kHz 100 50 kHz 25 kHz 100 kHz 100 50 kHz 25 kHz 10 100 1000 1 10000 Bp-p (Gauss) 100 HCM1A1305-6R0-R 1 MHz 100 kHz 100 50 kHz 25 kHz 10 100 kHz 50 kHz 25 kHz 10 100 1000 1 10000 100 1 MHz 500 kHz 1 MHz 1000 Core Loss (mW) 300 kHz 100 kHz 100 10000 HCM1A1305-8R2-R 10000 1000 1000 Bp-p (Gauss) HCM1A1305-7R8-R 10000 Core Loss (mW) 500 kHz 300 kHz 100 Bp-p (Gauss) 50 kHz 25 kHz 10 1 1 MHz 1000 Core Loss (mW) Core Loss (mW) 500 kHz 300 kHz 1 10000 HCM1A1305-6R8-R 10000 1000 1000 Bp-p (Gauss) 10000 500 kHz 300 kHz 100 kHz 100 50 kHz 25 kHz 10 100 1000 Bp-p (Gauss) 6 500 kHz 300 kHz 10 1 1 MHz 1000 300 kHz Core Loss (mW) 1000 Core Loss (mW) HCM1A1305-5R6-R 10000 www.eaton.com/electronics 10000 1 100 1000 Bp-p (Gauss) 10000 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Core loss vs Bp-p HCM1A1305-100-R 10000 1 MHz 1000 500 kHz 1000 Core Loss (mW) Core Loss (mW) 300 kHz 100 kHz 100 50 kHz 25 kHz 1 MHz 100 kHz 100 50 kHz 25 kHz 10 100 1000 1 10000 100 Bp-p (Gauss) 1 MHz 100 kHz 50 kHz 25 kHz 10 1 1 MHz 1000 Core Loss (mW) Core Loss (mW) 500 kHz 300 kHz 100 10000 HCM1A1305-220-R 10000 1000 1000 Bp-p (Gauss) HCM1A1305-150-R 10000 500 kHz 300 kHz 100 kHz 100 50 kHz 25 kHz 10 100 1000 10000 Bp-p (Gauss) 1 100 1000 10000 Bp-p (Gauss) HCM1A1305-330-R 10000 1 MHz 1000 Core Loss (mW) 500 kHz 300 kHz 10 1 HCM1A1305-120-R 10000 500 kHz 300 kHz 100 kHz 100 50 kHz 25 kHz 10 1 100 1000 10000 Bp-p (Gauss) www.eaton.com/electronics 7 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Inductance and temperature rise vs. current HCM1A1305-R22-R 100 0.30 100 90 90 0.25 70 0.08 60 0.06 50 40 0.04 30 Inductance (μH) 80 Temperature Rise (°C) 20 0.02 80 70 0.20 60 0.15 50 40 0.10 30 20 0.05 10 0 10 20 30 40 50 60 70 80 90 100 10 0 0.00 0 10 20 30 40 100 90 0.40 90 80 0.35 60 0.20 50 40 0.15 30 0.10 Inductance (μH) 0.25 0.05 40 50 60 70 70 0.30 60 0.25 50 0.20 40 0.15 30 20 0.05 10 30 80 0.10 20 20 0.00 0 10 0 10 20 30 HCM1A1305-R56-R 0.60 100 60 50 40 0.20 30 10 0 5 10 15 20 25 Idc (A) 8 90 80 70 60 0.40 50 0.30 40 30 0.20 20 0.10 www.eaton.com/electronics 30 35 40 45 50 0 100 0.50 Inductance (μH) 70 0.30 60 0.60 Temperature Rise (°C) Inductance (μH) 80 0.40 50 HCM1A1305-R68-R 0.70 90 0.50 40 Idc (A) Idc (A) 0.00 0 0.45 70 10 80 100 Temperature Rise (°C) Inductance (μH) 0.30 0 70 HCM1A1305-R47-R HCM1A1305-R33-R 0.35 0.00 60 Idc (A) Idc (A) 0.40 50 Temperature Rise (°C) 0.00 0 20 0.10 0.00 10 0 5 10 15 20 25 Idc (A) 30 35 40 45 50 0 Temperature Rise (°C) Inductance (μH) 0.10 Temperature Rise (°C) HCM1A1305-R10-R 0.12 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Inductance and temperature rise vs. current 100 0.60 60 0.50 50 0.40 40 0.30 30 0.20 Inductance (μH) 70 Temperature Rise (°C) 70 0.8 60 0.6 50 40 0.4 20 0.10 80 30 20 0.2 10 10 5 10 15 20 25 30 35 40 45 50 0.0 0 0 5 10 15 20 HCM1A1305-1R5-R 80 1.4 70 1.2 60 1.0 50 0.8 40 0.6 30 20 0.4 20 10 0.2 10 0 0.0 0.8 50 40 0.6 30 0.4 0.2 20 25 30 35 40 Inductance (μH) 60 Temperature Rise (°C) Inductance (μH) 1.0 0 5 10 15 20 25 30 35 HCM1A1305-3R3-R HCM1A1305-2R2-R 100 3.5 90 70 60 1.6 50 1.2 40 30 0.8 90 80 2.5 Inductance (μH) 80 2.0 100 3.0 Temperature Rise (°C) 2.4 70 60 2.0 50 1.5 40 30 1.0 20 0.4 0.0 10 0 5 10 15 20 Idc (A) 25 0 Idc (A) Idc (A) Inductance (μH) 100 1.6 70 2.8 0 45 90 80 1.2 15 40 1.8 90 1.4 10 35 HCM1A1305-1R8-R 2.0 100 1.6 5 30 Idc (A) Idc (A) 0 25 Temperature Rise (°C) 0 30 35 0 Temperature Rise (°C) Inductance (μH) 90 1.0 80 0.70 0.0 100 90 0.80 0.00 HCM1A1305-1R0-R 1.2 Temperature Rise (°C) HCM1A1305-R82-R 0.90 20 0.5 0.0 10 0 5 10 15 20 25 30 0 Idc (A) www.eaton.com/electronics 9 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Inductance and temperature rise vs. current HCM1A1305-5R6-R HCM1A1305-4R7-R 6 100 100 90 90 3 60 50 2 40 30 1 80 70 4 60 3 50 40 2 20 30 20 1 10 0 5 10 15 20 25 30 0 0 0 5 10 15 0 HCM1A1305-6R8-R HCM1A1305-6R0-R 100 7 100 90 6 60 4 50 3 40 30 2 5 Inductance (μH) 70 80 Temperature Rise (°C) 5 90 6 80 Inductance (μH) 25 Idc (A) Idc (A) 7 20 70 60 4 50 3 40 30 2 20 1 0 20 1 10 0 2 4 6 8 10 12 14 16 18 0 0 Idc (A) 100 4 6 8 10 12 14 16 18 HCM1A1305-8R2-R 100 5 60 4 50 40 3 30 2 20 1 8 Inductance (μH) 70 80 70 6 60 50 4 40 30 2 20 10 0 2 4 6 8 10 Idc (A) www.eaton.com/electronics 0 90 Temperature Rise (°C) 6 Inductance (μH) 2 10 80 10 0 90 7 0 10 Idc (A) HCM1A1305-7R8-R 8 Temperature Rise (°C) 0 10 12 14 16 18 0 10 0 0 2 4 6 8 Idc (A) 10 12 14 16 0 Temperature Rise (°C) Inductance (μH) 70 Inductance (μH) 80 Temperature Rise (°C) 4 5 Temperature Rise (°C) 5 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Inductance and temperature rise vs. current HCM1A1305-120-R 14 100 90 80 60 6 50 40 4 30 Inductance (μH) 70 8 10 70 60 8 50 6 40 30 4 20 20 2 2 10 0 2 4 6 8 10 12 14 16 0 0 10 0 2 4 6 HCM1A1305-150-R 0 100 90 90 20 60 8 50 40 6 30 4 20 2 Inductance (μH) 70 10 Temperature Rise (°C) 80 12 Inductance (μH) 12 HCM1A1305-220-R 24 100 14 0 10 Idc (A) Idc (A) 16 8 80 70 16 60 12 50 40 8 30 20 4 10 10 0 2 4 6 8 10 12 14 0 0 0 1 2 3 4 5 6 7 8 9 0 Idc (A) Idc (A) HCM1A1305-330-R 35 Temperature Rise (°C) 0 90 12 80 Temperature Rise (°C) Inductance (μH) 10 100 Temperature Rise (°C) HCM1A1305-100-R 12 100 90 30 70 60 20 50 15 40 30 10 Temperature Rise (°C) Inductance (μH) 80 25 20 5 0 10 0 1 2 3 4 5 6 7 8 9 0 Idc (A) www.eaton.com/electronics 11 HCM1A1305 Automotive grade high current power inductors Technical Data 10551 Effective September 2016 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
HCM1A1305-470-R 价格&库存
很抱歉,暂时无法提供与“HCM1A1305-470-R”相匹配的价格&库存,您可以联系我们找货
