SB230
SB230
    SMCDIODESOLUTIONS(桑德斯)
    DO-15(DO-204AC)
    肖特基二极管 VRRM=30V IF=2A VF=0.5V DO15
SB230 数据手册
SB220 THRU SB260 Technical Data Data Sheet N0870, Rev. B SB220 THRU SB260 SCHOTTKY RECTIFIER Features           DO-15 Circuit Diagram Schottky Barrier Chip Guard Ring Die Construction for Transient Protection High Current Capability Low Power Loss, High Efficiency High Surge Current Capability For Use in Low Voltage, High Frequency Inverters, Free Wheeling, and Polarity Protection Applications Green Products in Compliance with the RoHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data       Case: JEDEC DO-15 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.014 ounce, 0.40 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristics Symbol Maximum repetitive peak reverse voltage Maximum DC blocking voltage Maximum RMS voltage Maximum average forward rectified current 0.375"( 9.5mm ) lead length at TL=100℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load ( JEDEC Method) Maximum instantaneous forward voltage at 2.0A VRRM VDC VRMS SB230 SB240 SB250 SB260 Units 20 30 40 50 60 V 14 21 28 35 42 V I(AV) 2.0 A IFSM 50 A VF Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ IR Typical junction capacitance ( Note 1) CJ Typical thermal resistance junction to lead Typical thermal resistance junction to ambient( Note 2) Operating junction and storage temperature range SB220 0.5 0.70 5.0 10 170 V mA 140 pF RθJL 15 ℃/W RθJA 50.0 ℃/W TJ,TSTG -65 to +150 ℃ Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm) lead length, P.C.B mounted.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SB220 THRU SB260 Technical Data Data Sheet N0870, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SB220 THRU SB260 Technical Data Data Sheet N0870, Rev. B Mechanical Dimensions DO-15 SYMBOL SB220 THRU SB260 Max. Min. Max. A 25.4 - 1.000 - B 5.5 7.62 0.217 0.300 C 0.6 0.9 0.024 0.034 D 2.6 3.6 0.104 0.140 Marking Diagram Package Shipping DO-15(Pb-Free) 3000pcs / tape Where XXXXX is YYWWL SB240 Device Inches Min. SB 2 40 SSG YY WW L SSG XXXXX Ordering Information Millimeters For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Device Type = Forward Current (2A) = Reverse Voltage (40V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification DO-15 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SB220 THRU SB260 Technical Data Data Sheet N0870, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SB230 价格&库存
很抱歉,暂时无法提供与“SB230”相匹配的价格&库存,您可以联系我们找货
