MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KYB
Low impedance, 105℃
Series
KYB
・Low impedance, high ripple and long life from KYA series
・Newly innovative electrolyte is employed to minimize impedance
・Endurance with ripple current : 4,000 to 10,000 hours at 105℃
・Non solvent resistant type
・RoHS Compliant
Lower Z
KYA P169
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 100Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 80V 100V
tanδ (Max.)
0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.09 0.08
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
2
2
2
Z(-40℃)/Z(+20℃)
8
6
4
3
3
3
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃.
Rated Voltage(Vdc)
6.3 to 10Vdc
16 to 100Vdc
Time
φ5: 4,000hours φ6.3 & 8: 6,000hours φ10 to 18: 8,000hours φ5: 5,000hours φ6.3 & 8: 7,000hours φ10 to 18: 10,000hours
Capacitance change
≦±30% of the initial value
≦±25% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φd
Sleeve (PET : Brown)
F±0.5
Code : E
F±0.5
●Terminal
φD
φd
φD'
F
φD'
L'
Vent
(Exceptφ5 &φ6.3)
15min.
4min.
(φ5 to φ10)
(φ12.5 to φ18)
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
18
0.8
7.5
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
E KYB
5
6
7
8
E
9
10
11
12
13
14
M
15
16
17
18
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 6.8µF:6R8, 39µF:390, 470µF:471)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3, 50V:500)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
166
CAT. No. E1001Q
Low impedance, 105℃
KYBSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
180
390
820
1,200
1,200
1,500
1,800
2,200
2,700
3,300
3,900
4,700
6.3 6,800
6,800
8,200
8,200
10,000
10,000
12,000
12,000
15,000
15,000
18,000
18,000
22,000
120
330
560
820
1,000
1,000
1,200
1,800
2,200
2,700
2,700
3,900
10 4,700
4,700
5,600
6,800
6,800
6,800
8,200
8,200
10,000
10,000
12,000
12,000
15,000
120
270
470
680
680
820
1,000
16
1,500
1,800
2,200
2,200
3,300
3,900
3,900
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
5×11
6.3×11
8×11.5
8×15
8×20
10×12.5
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
12.5×40
16×25
18×20
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.29
0.15
0.087
0.069
0.064
0.060
0.049
0.037
0.031
0.027
0.027
0.024
0.021
0.025
0.018
0.021
0.017
0.020
0.016
0.017
0.014
0.014
0.013
0.012
0.011
0.29
0.15
0.087
0.069
0.060
0.064
0.049
0.037
0.031
0.027
0.027
0.024
0.021
0.025
0.018
0.017
0.020
0.021
0.016
0.017
0.014
0.014
0.013
0.012
0.011
0.29
0.15
0.087
0.069
0.064
0.060
0.049
0.037
0.031
0.027
0.027
0.024
0.021
0.025
1.2
0.60
0.35
0.28
0.26
0.24
0.20
0.15
0.13
0.11
0.11
0.096
0.084
0.10
0.072
0.084
0.068
0.080
0.064
0.068
0.056
0.056
0.052
0.048
0.044
1.2
0.60
0.35
0.28
0.24
0.26
0.20
0.15
0.13
0.11
0.11
0.096
0.084
0.10
0.072
0.068
0.080
0.084
0.064
0.068
0.056
0.056
0.052
0.048
0.044
1.2
0.60
0.35
0.28
0.26
0.24
0.20
0.15
0.13
0.11
0.11
0.096
0.084
0.10
340
540
840
1,050
1,050
1,210
1,400
1,650
1,910
2,230
2,230
2,530
2,860
2,610
3,140
3,000
3,640
3,140
3,610
3,530
4,080
4,220
4,220
4,280
4,700
340
540
840
1,050
1,210
1,050
1,400
1,650
1,910
2,230
2,230
2,530
2,860
2,610
3,140
3,640
3,140
3,000
3,610
3,530
4,080
4,220
4,220
4,280
4,700
340
540
840
1,050
1,050
1,210
1,400
1,650
1,910
2,230
2,230
2,530
2,860
2,610
WV
(Vdc)
Part No.
Cap
(µF)
Case size
φD×L(mm)
20℃
EKYB6R3E□□181ME11D
EKYB6R3E□□391MF11D
EKYB6R3E□□821MHB5D
EKYB6R3E□□122MH15D
EKYB6R3E□□122MJC5S
EKYB6R3E□□152MH20D
EKYB6R3E□□182MJ16S
EKYB6R3E□□222MJ20S
EKYB6R3E□□272MJ25S
EKYB6R3E□□332MJ30S
EKYB6R3E□□392MK20S
EKYB6R3E□□472MK25S
EKYB6R3E□□682MK30S
EKYB6R3E□□682ML20S
EKYB6R3E□□822MK35S
EKYB6R3E□□822MM20S
EKYB6R3E□□103MK40S
EKYB6R3E□□103ML25S
EKYB6R3E□□123MLN3S
EKYB6R3E□□123MM25S
EKYB6R3E□□153MLP1S
EKYB6R3E□□153MMN3S
EKYB6R3E□□183ML40S
EKYB6R3E□□183MMP1S
EKYB6R3E□□223MM40S
EKYB100E□□121ME11D
EKYB100E□□331MF11D
EKYB100E□□561MHB5D
EKYB100E□□821MH15D
EKYB100E□□102MH20D
EKYB100E□□102MJC5S
EKYB100E□□122MJ16S
EKYB100E□□182MJ20S
EKYB100E□□222MJ25S
EKYB100E□□272MJ30S
EKYB100E□□272MK20S
EKYB100E□□392MK25S
EKYB100E□□472MK30S
EKYB100E□□472ML20S
EKYB100E□□562MK35S
EKYB100E□□682MK40S
EKYB100E□□682ML25S
EKYB100E□□682MM20S
EKYB100E□□822MLN3S
EKYB100E□□822MM25S
EKYB100E□□103MLP1S
EKYB100E□□103MMN3S
EKYB100E□□123ML40S
EKYB100E□□123MMP1S
EKYB100E□□153MM40S
EKYB160E□□121ME11D
EKYB160E□□271MF11D
EKYB160E□□471MHB5D
EKYB160E□□681MH15D
EKYB160E□□681MJC5S
EKYB160E□□821MH20D
EKYB160E□□102MJ16S
EKYB160E□□152MJ20S
EKYB160E□□182MJ25S
EKYB160E□□222MJ30S
EKYB160E□□222MK20S
EKYB160E□□332MK25S
EKYB160E□□392MK30S
EKYB160E□□392ML20S
16
25
35
50
4,700
4,700
5,600
5,600
6,800
6,800
8,200
8,200
10,000
10,000
12,000
82
150
330
390
470
560
680
1,000
1,200
1,500
1,500
2,200
2,700
2,700
3,300
3,300
3,900
3,900
4,700
4,700
5,600
6,800
6,800
8,200
47
100
180
270
330
330
470
680
820
1,000
1,000
1,500
1,800
1,800
2,200
2,200
2,700
2,700
3,300
3,300
3,900
4,700
4,700
5,600
27
56
100
150
150
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
5×11
6.3×11
8×11.5
8×15
10×12.5
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
16×40
18×31.5
18×35.5
5×11
6.3×11
8×11.5
8×15
8×20
10×12.5
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
16×40
18×31.5
18×35.5
5×11
6.3×11
8×11.5
8×15
10×12.5
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.018
0.021
0.017
0.020
0.016
0.017
0.014
0.014
0.013
0.012
0.011
0.29
0.15
0.087
0.069
0.064
0.060
0.049
0.037
0.031
0.027
0.027
0.024
0.021
0.025
0.018
0.021
0.017
0.020
0.016
0.017
0.014
0.013
0.014
0.012
0.29
0.15
0.087
0.069
0.060
0.064
0.049
0.037
0.031
0.027
0.027
0.024
0.021
0.025
0.018
0.021
0.017
0.020
0.016
0.017
0.014
0.013
0.014
0.012
0.48
0.20
0.12
0.093
0.10
0.072
0.084
0.068
0.080
0.064
0.068
0.056
0.056
0.052
0.048
0.044
1.2
0.60
0.35
0.28
0.26
0.24
0.20
0.15
0.13
0.11
0.11
0.096
0.084
0.10
0.072
0.084
0.068
0.080
0.064
0.068
0.056
0.052
0.056
0.048
1.2
0.60
0.35
0.28
0.24
0.26
0.20
0.15
0.13
0.11
0.11
0.096
0.084
0.10
0.072
0.084
0.068
0.080
0.064
0.068
0.056
0.052
0.056
0.048
2.0
0.80
0.48
0.38
0.40
3,140
3,000
3,640
3,140
3,610
3,530
4,080
4,220
4,220
4,280
4,700
340
540
840
1,050
1,050
1,210
1,400
1,650
1,910
2,230
2,230
2,530
2,860
2,610
3,140
3,000
3,640
3,140
3,610
3,530
4,080
4,220
4,220
4,280
340
540
840
1,050
1,210
1,050
1,400
1,650
1,910
2,230
2,230
2,530
2,860
2,610
3,140
3,000
3,640
3,140
3,610
3,530
4,080
4,220
4,220
4,280
238
385
620
810
810
Part No.
EKYB160E□□472MK35S
EKYB160E□□472MM20S
EKYB160E□□562MK40S
EKYB160E□□562ML25S
EKYB160E□□682MLN3S
EKYB160E□□682MM25S
EKYB160E□□822MLP1S
EKYB160E□□822MMN3S
EKYB160E□□103ML40S
EKYB160E□□103MMP1S
EKYB160E□□123MM40S
EKYB250E□□820ME11D
EKYB250E□□151MF11D
EKYB250E□□331MHB5D
EKYB250E□□391MH15D
EKYB250E□□471MJC5S
EKYB250E□□561MH20D
EKYB250E□□681MJ16S
EKYB250E□□102MJ20S
EKYB250E□□122MJ25S
EKYB250E□□152MJ30S
EKYB250E□□152MK20S
EKYB250E□□222MK25S
EKYB250E□□272MK30S
EKYB250E□□272ML20S
EKYB250E□□332MK35S
EKYB250E□□332MM20S
EKYB250E□□392MK40S
EKYB250E□□392ML25S
EKYB250E□□472MLN3S
EKYB250E□□472MM25S
EKYB250E□□562MLP1S
EKYB250E□□682ML40S
EKYB250E□□682MMN3S
EKYB250E□□822MMP1S
EKYB350E□□470ME11D
EKYB350E□□101MF11D
EKYB350E□□181MHB5D
EKYB350E□□271MH15D
EKYB350E□□331MH20D
EKYB350E□□331MJC5S
EKYB350E□□471MJ16S
EKYB350E□□681MJ20S
EKYB350E□□821MJ25S
EKYB350E□□102MJ30S
EKYB350E□□102MK20S
EKYB350E□□152MK25S
EKYB350E□□182MK30S
EKYB350E□□182ML20S
EKYB350E□□222MK35S
EKYB350E□□222MM20S
EKYB350E□□272MK40S
EKYB350E□□272ML25S
EKYB350E□□332MLN3S
EKYB350E□□332MM25S
EKYB350E□□392MLP1S
EKYB350E□□472ML40S
EKYB350E□□472MMN3S
EKYB350E□□562MMP1S
EKYB500E□□270ME11D
EKYB500E□□560MF11D
EKYB500E□□101MHB5D
EKYB500E□□151MH15D
EKYB500E□□151MJC5S
□□ : Enter the appropriate lead forming or taping code.
167
CAT. No. E1001Q
Low impedance, 105℃
KYBSeries
◆STANDARD RATINGS
WV
(Vdc)
Cap
(µF)
Case size
φD×L(mm)
20℃
50
63
80
180
220
270
390
470
470
680
820
820
1,000
1,000
1,200
1,200
1,500
1,500
1,800
2,200
2,200
2,700
18
33
56
82
120
120
180
220
330
390
390
560
680
680
820
820
1,000
1,000
1,200
1,200
1,500
1,500
1,800
1,800
2,200
12
22
39
8×20
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
16×40
18×31.5
18×35.5
5×11
6.3×11
8×11.5
8×15
8×20
10×12.5
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
18×31.5
16×40
18×35.5
18×40
5×11
6.3×11
8×11.5
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.075
0.069
0.055
0.043
0.038
0.034
0.030
0.025
0.028
0.021
0.025
0.019
0.024
0.019
0.021
0.016
0.014
0.014
0.013
0.50
0.25
0.16
0.12
0.085
0.11
0.073
0.055
0.045
0.040
0.036
0.030
0.026
0.028
0.022
0.028
0.020
0.025
0.020
0.022
0.018
0.018
0.016
0.017
0.016
0.80
0.43
0.18
0.30
0.28
0.22
0.18
0.16
0.14
0.12
0.10
0.12
0.084
0.10
0.076
0.096
0.076
0.084
0.064
0.056
0.056
0.052
2.0
1.0
0.64
0.48
0.34
0.44
0.30
0.22
0.18
0.16
0.15
0.12
0.11
0.12
0.088
0.12
0.080
0.10
0.080
0.088
0.072
0.072
0.064
0.068
0.064
3.2
1.8
0.72
980
1,100
1,300
1,600
1,820
1,820
2,100
2,450
2,350
2,800
2,600
3,100
2,750
3,150
2,890
3,550
3,900
3,800
4,100
220
350
530
700
880
725
1,050
1,300
1,550
1,780
1,780
2,100
2,415
2,250
2,700
2,500
3,000
2,730
3,000
2,800
3,200
3,300
3,590
3,570
3,670
163
267
462
WV
(Vdc)
Part No.
Cap
(µF)
Case size
φD×L(mm)
20℃
EKYB500E□□181MH20D
EKYB500E□□221MJ16S
EKYB500E□□271MJ20S
EKYB500E□□391MJ25S
EKYB500E□□471MJ30S
EKYB500E□□471MK20S
EKYB500E□□681MK25S
EKYB500E□□821MK30S
EKYB500E□□821ML20S
EKYB500E□□102MK35S
EKYB500E□□102MM20S
EKYB500E□□122MK40S
EKYB500E□□122ML25S
EKYB500E□□152MLN3S
EKYB500E□□152MM25S
EKYB500E□□182MLP1S
EKYB500E□□222ML40S
EKYB500E□□222MMN3S
EKYB500E□□272MMP1S
EKYB630E□□180ME11D
EKYB630E□□330MF11D
EKYB630E□□560MHB5D
EKYB630E□□820MH15D
EKYB630E□□121MH20D
EKYB630E□□121MJC5S
EKYB630E□□181MJ16S
EKYB630E□□221MJ20S
EKYB630E□□331MJ25S
EKYB630E□□391MJ30S
EKYB630E□□391MK20S
EKYB630E□□561MK25S
EKYB630E□□681MK30S
EKYB630E□□681ML20S
EKYB630E□□821MK35S
EKYB630E□□821MM20S
EKYB630E□□102MK40S
EKYB630E□□102ML25S
EKYB630E□□122MLN3S
EKYB630E□□122MM25S
EKYB630E□□152MLP1S
EKYB630E□□152MMN3S
EKYB630E□□182ML40S
EKYB630E□□182MMP1S
EKYB630E□□222MM40S
EKYB800E□□120ME11D
EKYB800E□□220MF11D
EKYB800E□□390MHB5D
56
82
82
120
180
220
270
270
390
470
470
80
560
560
680
680
820
820
1,000
1,200
1,200
1,500
6.8
15
27
39
56
56
82
100
120
150
180
220
100 270
270
330
390
390
470
470
560
560
680
680
820
1,000
8×15
8×20
10×12.5
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
12.5×35
18×20
12.5×40
16×25
16×31.5
18×25
16×35.5
16×40
18×31.5
18×35.5
5×11
6.3×11
8×11.5
8×15
8×20
10×12.5
10×16
10×20
10×25
10×30
12.5×20
12.5×25
12.5×30
16×20
16×25
12.5×35
18×20
12.5×40
16×31.5
16×35.5
18×25
16×40
18×31.5
18×35.5
18×40
Rated
ripple
current
(mArms/
-10℃ 105℃,
100kHz)
Impedance
(Ω max./100kHz)
0.14
0.11
0.14
0.10
0.075
0.060
0.053
0.048
0.039
0.033
0.036
0.026
0.032
0.024
0.028
0.022
0.027
0.020
0.018
0.020
0.018
0.80
0.43
0.18
0.14
0.11
0.14
0.10
0.075
0.060
0.053
0.048
0.039
0.033
0.036
0.028
0.026
0.032
0.024
0.022
0.020
0.027
0.018
0.020
0.018
0.017
0.56
0.44
0.56
0.40
0.30
0.24
0.22
0.20
0.16
0.14
0.15
0.11
0.13
0.096
0.12
0.088
0.11
0.080
0.072
0.080
0.072
3.2
1.8
0.72
0.56
0.44
0.56
0.40
0.30
0.24
0.22
0.20
0.16
0.14
0.15
0.12
0.11
0.13
0.096
0.088
0.080
0.11
0.072
0.080
0.072
0.068
585
735
624
780
1,040
1,170
1,350
1,430
1,620
1,950
1,750
2,250
2,100
2,450
2,250
2,400
2,270
2,600
2,900
2,550
3,050
163
267
462
585
735
624
780
1,040
1,170
1,350
1,430
1,620
1,950
1,750
2,250
2,250
2,100
2,450
2,400
2,600
2,270
2,900
2,550
3,050
3,510
Part No.
EKYB800E□□560MH15D
EKYB800E□□820MH20D
EKYB800E□□820MJC5S
EKYB800E□□121MJ16S
EKYB800E□□181MJ20S
EKYB800E□□221MJ25S
EKYB800E□□271MJ30S
EKYB800E□□271MK20S
EKYB800E□□391MK25S
EKYB800E□□471MK30S
EKYB800E□□471ML20S
EKYB800E□□561MK35S
EKYB800E□□561MM20S
EKYB800E□□681MK40S
EKYB800E□□681ML25S
EKYB800E□□821MLN3S
EKYB800E□□821MM25S
EKYB800E□□102MLP1S
EKYB800E□□122ML40S
EKYB800E□□122MMN3S
EKYB800E□□152MMP1S
EKYB101E□□6R8ME11D
EKYB101E□□150MF11D
EKYB101E□□270MHB5D
EKYB101E□□390MH15D
EKYB101E□□560MH20D
EKYB101E□□560MJC5S
EKYB101E□□820MJ16S
EKYB101E□□101MJ20S
EKYB101E□□121MJ25S
EKYB101E□□151MJ30S
EKYB101E□□181MK20S
EKYB101E□□221MK25S
EKYB101E□□271MK30S
EKYB101E□□271ML20S
EKYB101E□□331ML25S
EKYB101E□□391MK35S
EKYB101E□□391MM20S
EKYB101E□□471MK40S
EKYB101E□□471MLN3S
EKYB101E□□561MLP1S
EKYB101E□□561MM25S
EKYB101E□□681ML40S
EKYB101E□□681MMN3S
EKYB101E□□821MMP1S
EKYB101E□□102MM40S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(µF)
6.8
220
680
2,200
4,700
to
to
to
to
to
180
560
1,800
3,900
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
168
CAT. No. E1001Q
