WCM1513FASV-301-LM
WCM1513FASV-301-LM
    TAI-TECH(台庆)
    FILTER_15X13MM_SM
    共模滤波器 300Ω@100MHz DCR=3.5mΩ 125V 14A
WCM1513FASV-301-LM 数据手册
TAI-TECH P2 Wire Wound Power Common Mode Filter WCM1513FASV-SERIES-LM 1. Features 1. High reliability -Reliability tests comply with AEC-Q200 Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension C Halogen-free Series A(mm) WCM1513 15.0±0.5 B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) 13.0±0.4 6.0 max. 9.3 Typ. 2.7±0.5 3.6±0.5 2.8±0.5 Unit:mm 3. Part Numbering WCM 1513 A B F A S V C D E F - 551 - LM G H A: Series B: Dimension C: Material Ferrite Core D: Process Asembled E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 551=550Ω H: Laser Marking 4. Specification TAI-TECH Part Number Impedance (Ω) DC Resistance Test (mΩ) max. Frequency (MHz) (1 line) Rated Current (A) max. Rated Volt. (Vdc) max. Insulation Resistance (MΩ) min. min. typ. WCM1513FASV-301-LM 200 300 100 3.5 14 125 10 WCM1513FASV-551-LM 450 550 100 4 10 125 10 WCM1513FASV-701-LM 500 700 100 5 10 125 10 Note: Measurement board data Material : FR4 Board dimensions : 100 X 50 X 1.6t mm Pattern dimensions: 45 X 30 mm (Double side board) Pattern thickness : 50 μm www.tai-tech.com.tw Downloaded From Oneyac.com TAI-TECH WCM1513FASV-301-LM 10000 WCM1513FASV-551-LM 10000 1000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P3 Normal Mode 100 Common Mode 10 Normal Mode 100 Common Mode 10 1 1 1 10 100 1000 1 FREQUENCY(MHz) 100 FREQUENCY(MHz) WCM1513FASV-701-LM 10000 IMPEDANCE(Ohm) 10 1000 Normal Mode 100 Common Mode 10 1 1 10 100 1000 FREQUENCY(MHz) 5. Schematic Diagram Impedance DC Resistance www.tai-tech.com.tw Downloaded From Oneyac.com Insulation Resistance 1000 单击下面可查看定价,库存,交付和生命周期等信息 >>TAI-TECH(台庆) Downloaded From Oneyac.com
WCM1513FASV-301-LM 价格&库存
很抱歉,暂时无法提供与“WCM1513FASV-301-LM”相匹配的价格&库存,您可以联系我们找货
