DF22 Series
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
7.92mm Contact Pitch High Current Connectors for
Internal Power Supplies (UL, C-UL and TÜV Listed)
Mar. 2022
DF22 Series/7.92mm Contact Pitch High Current Connectors for Internal Power Supplies (UL, C-UL and TÜV Listed)
Features
1. Rated up to 30A
Single position connector can carry current of
30A with 10 AWG conductor. Please refer to
Table # 1 for current ratings for multi- position
connectors using other conductor sizes.
2. Positive Locking Function
Completely
enclosed
locking system
Reliable interior lock protects mated connectors
from accidental disconnection.
Protection from
shorts circuits
between adjacent
contacts
2
3. Prevention of Incorrect
Connections
● R Type (Guide Key : Right Side, Color : Black)
To prevent incorrect connection when using
multiple connectors having the same Number of
contacts, 3 product types having different mating
configurations are available.
● Standard Type (Guide Key : Inside, Color : Natural)
● L Type (Guide Key : Left Side, Color : Red)
・The image on the left shows the header (the
board dipside), the image on the right shows
the socket (cable side).
・The guide key position is indicated in position
facing the mating surface of the header.
4. Molded- in contact retention
tabs
Handling of terminated contacts during the
crimping is easier and avoids entangling of wires,
since there are no protruding metal tabs.
5. Prevention of incorrect board
placement
Built- in posts assure correct connector placement
and orientation on the board.
6. Supports resin sealing
Allows potting up to 10mm.
3
7. Prevention of Short Circuits
Between Adjacent Contacts
Each contact is completely surrounded by the
housing wall electrically isolating it from adjacent
contacts.
8. Increased Retention Force of
Crimped Contacts
Can withstand usage methods that result in cable
stress.
9. Full Line of Crimp Socket
Contacts
Hirose has released DF22C- # S- 7. 92C which has
easy to push/ release latch design. and DF22B# S- 7. 92C/ DF22C- # S- 7. 92C which has improved
electrical insulation properties.
10. In- line Connections
Wire- to- wire connection is also available. Space
is saved with 2- row ( 2×2) layout for 4pos.
11. UL, C- UL, and TÜ V
Certified.
12. Glow Wire compliance
( Compliant with IEC 606952- 11)
4
Product Specifications
Rated Current
(Note 1)
Rated Voltage
No of Pos.
AWG#10
AWG#12
AWG#14
AWG#16
Operating Temperature Range
(Note 2)
-55 ~ +85℃
1
30A
25A
20A
15A
Storage Temperature Range
(Note 3)
-10 ~ +60℃
2
25A
20A
18A
15A
Operating Humidity Range
20 ~ 80%
3
25A
20A
18A
15A
Storage Humidity Range
(Note 3)
40 ~ 70%
4
22A
18A
15A
13A
5
22A
18A
15A
13A
AC/DC 1000V
Rated Current
Rated Voltage
UL
See table above
600V AC/DC
C-UL
See table above
600V AC/DC
TÜV
See table above
600V AC/DC
UL/C-UL/TÜV File No. and Recognition No.
UL : E52653
C-UL : E52653
TÜV : R9950703
Item
Specifications
Conditions
Contact Resistance
No more than 5m Ω
Measured at 1mA and no higher than 20mV
Insulation Resistance
No less than 1,000M Ω
Measured at 1000V DC
Withstand Voltage
No flashover or breakdown
2500V AC is applied for 1 minute.
Contact Insertion and
Extraction Forces
0.3N Min., 5N Max.
Measured with a steel pin of 1.6 × 0.8 ± 0.002 thickness
Durability
Contact resistance : no more than 10m Ω
30 mating cycles
Vibration Resistance
No electrical discontinuity of
1μ s or greater
Frequency 10 to 55 Hz, single amplitude 0.75 mm, at 2 h, for
3 directions.
Shock Resistance
1μ s or greater
Accelerated velocity : 490 m/s2 for 11 ms, half-sine wave in 3
directions, 3 times for each direction
Moisture-Resistance
Temperature : 40 ± 2℃ ; humidity : 90 to 95% , left as it is for
96 hours
Temperature cycles
(-55℃ : 30 minutes → 5 to 35℃ : 5 minutes → 85℃ : 30
minutes → 5 to 35℃ : 5 minutes) for 5 cycles
Solder heat Resistance
The resin parts should withstand the
temperature and resist melting.
Flow : 260℃ , 10 sec
Hand soldering : temperature of soldering iron at 300℃ for 3
seconds
Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. If you split the current over multiple lines, please factor in your
own safety margin.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary
storage such as pre-assembly and during shipping.
Materials/Finish
Product
Part
Material
Finish
Remarks
Sockets
Insulator
Polyamide
Color : Natural white (Note)
UL94V-0
Crimp Contacts
Contacts
High Conductivity Copper Alloy
Gold Plated
Insulator
Polyamide (Glass Reinforced)
Color : Natural beige (Note)
UL94V-0
Contacts
Gold Plated
Headers
Note : The Standard Colors, colors of the differing coupling forms are black for DF22R and red for DF22L.
5
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Socket, Header
DF22 B L - 2 S - 7.92 C
❶
❷ ❸
❹ ❺
❻
❼
■ Contacts
DF22 A - 1416 SCF A
❶
❽
❾
❶
Series Name
DF22
❻
Contact Pitch
7.92mm
❷
Form Type
Sockets
Blank : Standard height, standard lock
(Type I)
B
: Long type, standard lock (Type III)
C
: Long type, ergonomic lock (Type IV)
In-line Plugs
Blank : With panel stop
A
: Without panel stop
❼
Type of Housing
C
DSA
DS
No letter
❽
Applicable Cable
Blank : UL1430
A
: UL1015
❾
Applicable
Conductor
1416 : 14 to 16 AWG
1012 : 10 to 12 AWG
Packaging
SCF
SC
PCF
PC
Plating
Specifications
A : Gold Plated
❸
Guide Key Type
Blank : Inside (Color : Natural)
R
: Right side (Color : Black)
L
: Left side (Color : Red)
❹
Number of Pos.
1 to 5
❺
Connector Type
S
: Socket
DS
: Double-row socket
P
: Header
EP
: In-line plug
DEP : Double-row in-line plug
RS/P : Retainer
6
: Crimp housing
: Straight header
: Right-angle header
: Retainer
: Socket contacts / reel
: Socket contacts / bag
: In-line plug contacts / reel
: In-line plug contacts / bag
Diagram of Connector Mating Combinations
●Wire-to-Board Connection
Crimp socket (Note 2)
DF22#-#S-7.92C
Crimp contact for Socket
Retainer (Note 1)
DF22(A)-#SC(F)A
Straight pin header (Note 2)
DF22#-#RS/P-7.92
DF22#-#P-7.92DSA
DF22#-#RS/P-7.92
DF22#-#S-7.92C
Right angle pin header (Note 2)
DF22#-#P-7.92DS
●In-line or Wire-to-Wire Connection
In-line plug
Crimp contact for in-line plug
DF22#-#EP-7.92C
DF22(A)-#PC(F)A
Retainer (Note 1)
DF22B/C-#RS/P-7.92
DF22#-#EP-7.92C
DF22B/C#RS/P-7.92
Note 1 : Since this product uses thick wires, a larger load is applied to the connector when inserting/extracting or routing the wires.
Please use a retainer to reduce the load on the connector.
Crimp socket
DF22-#S-7.92C
DF22B-#S-7.92C
DF22C-#S-7.92C
Applicable Retainer
In-line plug
DF22-#RS/P-7.92
DF22-#EP-7.92C
DF22A-#EP-7.92C
DF22B/C-#RS/P-7.92
Note 2 : The key difference (L, R) product matches the mating connector of the same key (L, R).
7
Applicable Retainer
DF22B/C-#RS/P-7.92
Crimp Sockets (Standard Height Type)
[1Pos.]
No. of contacts
indicator
Cavity No.
A
1
[2 to 5Pos.]
A
B
7.7
Type Ⅰ
Standard lock
10.4
P=7.92
(11.55)
14.5
Contact No. 1
Shown with terminated and contacts installed.
14.5
Type Ⅰ
Standard lock
7.7
8
Polarity
mark
Cavity No.
8
No. of contacts
indicator
[Type I]
Height : Standard type, Standard lock
Note : The part number and HRS No. have changed to reflect the product form change of the 2 to 5 pos. types.
Standard Type (Guide Key : Inside, Color : White)
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
DF22-1S-7.92C(28)
CL0680-1012-2-28
1
8.00
DF22-2S-7.92C(28)
CL0680-1004-4-28
2
15.50
7.92
DF22-3S-7.92C(28)
CL0680-1005-7-28
3
23.42
15.84
DF22-4S-7.92C(28)
CL0680-1006-0-28
4
31.34
23.76
DF22-5S-7.92C(28)
CL0680-1007-2-28
5
39.26
31.68
Part No.
HRS No.
No. of Pos.
A
B
CL0680-1026-7-28
1
8.00
DF22R-2S-7.92C(28)
CL0680-1027-0-28
2
15.50
7.92
DF22R-3S-7.92C(28)
CL0680-1028-2-28
3
23.42
15.84
DF22R-4S-7.92C(28)
CL0680-1029-5-28
4
31.34
23.76
DF22R-5S-7.92C(28)
CL0680-1030-4-28
5
39.26
31.68
No. of Pos.
A
B
HRS No.
100pcs per bag
Unit : mm
DF22R-1S-7.92C(28)
Part No.
Purchase Unit
Purchase Unit
100pcs per bag
Unit : mm
DF22L-1S-7.92C(28)
CL0680-1031-7-28
1
8.00
DF22L-2S-7.92C(28)
CL0680-1032-0-28
2
15.50
7.92
DF22L-3S-7.92C(28)
CL0680-1033-2-28
3
23.42
15.84
DF22L-4S-7.92C(28)
CL0680-1034-5-28
4
31.34
23.76
DF22L-5S-7.92C(28)
CL0680-1035-8-28
5
39.26
31.68
Note : Every even number position has a different locking design.
9
Purchase Unit
100pcs per bag
Crimp Sockets (Height, Long Type)
[1Pos.]
Type Ⅳ
Height : Long type,
user-friendly operation
23
(12.75)
No. of contacts
indicator
Cavity No.
A
1
[2 to 5Pos.]
A
B
Type Ⅳ
Type Ⅲ
Height : Long type, Height : Long type,
Enhanced
Standard lock
Contact No.1
ergonomic lock
(12.75)
(11.55)
14.5
7.7
10.4
P=7.92
23
14.5
7.7
8
Polarity
mark
A
Cavity No.
10
3
No. of contacts
indicator
[Type III]
Height : Long type, Standard lock
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
DF22B-2S-7.92C
CL0680-1097-5-00
2
15.50
7.92
DF22B-3S-7.92C
CL0680-1098-8-00
3
23.42
15.84
DF22B-4S-7.92C
CL0680-1099-0-00
4
31.34
23.76
DF22B-5S-7.92C
CL0680-1100-8-00
5
39.26
31.68
Purchase Unit
100pcs per bag
[Type IV]
Height : Long type, Enhanced ergonomic lock
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
DF22C-1S-7.92C
CL0680-1101-0-00
1
8.00
DF22C-2S-7.92C
CL0680-1102-3-00
2
15.50
7.92
DF22C-3S-7.92C
CL0680-1103-6-00
3
23.42
15.84
DF22C-4S-7.92C
CL0680-1104-9-00
4
31.34
23.76
Part No.
DF22CR-3S-7.92C
HRS No.
CL0680-1130-9-00
HRS No.
100pcs per bag
Unit : mm
No. of Pos.
A
B
Purchase Unit
3
23.42
15.84
100pcs per bag
Part No.
Purchase Unit
Unit : mm
No. of Pos.
A
B
DF22CL-1S-7.92C
CL0680-1133-7-00
1
8.00
DF22CL-3S-7.92C
CL0680-1135-2-00
3
23.42
15.84
11
Purchase Unit
100pcs per bag
Straight Header
[1Pos.]
4.05
1.5
3.7
3.2
10.8
Cavity No.
9.3
3.9
10.8
3.2
1
No. of contacts
indicator
[2 to 5Pos.]
A
B
9.7
12.45
No. of contacts
indicator
Cavity No.
Contact No.1
12
1.4
9
18.1
Polarity
mark
3.7
18.1
12.45
A
0.8
2.3
8.7
φ1.5
0.8
3.45
4.35
Standard Type (Guide Key : Inside, Color : Natural Beige)
Part No.
HRS No.
Unit : mm
No. of
Pos.
A
B
Bag
Packaging
Tray
Packaging
DF22-1P-7.92DSA(##)
CL0680-1013-5-##
1
DF22-2P-7.92DSA(##)
CL0680-1014-8-##
2
17.22
7.92
DF22-3P-7.92DSA(##)
CL0680-1015-0-##
3
25.14
15.84
DF22-4P-7.92DSA(##)
CL0680-1016-3-##
4
33.06
23.76
DF22-5P-7.92DSA(##)
CL0680-1017-6-##
5
40.98
31.68
Tray
Packaging
[Specification number (##)] (53) : Gold plated, bag packaging / (58) : Gold plated, tray packaging (only 1pos.)
Part No.
HRS No.
Unit : mm
No. of
Pos.
A
B
Bag
Packaging
DF22R-1P-7.92DSA(##)
CL0680-1036-0-##
1
DF22R-2P-7.92DSA(##)
CL0680-1037-3-##
2
17.22
7.92
DF22R-3P-7.92DSA(##)
CL0680-1038-6-##
3
25.14
15.84
DF22R-4P-7.92DSA(##)
CL0680-1039-9-##
4
33.06
23.76
DF22R-5P-7.92DSA(##)
CL0680-1040-8-##
5
40.98
31.68
Tray
Packaging
[Specification number (##)] (53) : Gold plated, bag packaging / (57) : Gold plated, tray packaging (only 1pos.)
Part No.
HRS No.
Unit : mm
No. of
Pos.
A
B
Bag
Packaging
DF22L-1P-7.92DSA(##)
CL0680-1041-0-##
1
DF22L-2P-7.92DSA(##)
CL0680-1042-3-##
2
17.22
7.92
DF22L-3P-7.92DSA(##)
CL0680-1043-6-##
3
25.14
15.84
DF22L-4P-7.92DSA(##)
CL0680-1044-9-##
4
33.06
23.76
DF22L-5P-7.92DSA(##)
CL0680-1045-1-##
5
40.98
31.68
Note 1 : Bag packaging (100pcs per bag). Order by number of packs.
Note 2 : Tray packaging (150pcs per tray). Order by number of 150.
Note 3 : Every even number position has a different locking design.
■ Recommended PCB Layout (Board thickness : 1.6±0.1)
[1Pos.]
11.1±0.1
3.2±0.05
1+0.1
2-R0.5
3.4±0.1
8.5 +0.1
--0.2
2.5 +0.1
[2 to 5Pos.]
7
+0
0 .1
3.45±0.05
.1
+00
6
1.
φ
P=7.92±0.05
B±0.05
4.35±0.05
-φ
1.
13
Right Angle Header
A
B
C
0.8
5
A
Cavity No.
No. of contacts
indicator
5
1.2
14
A
3.7
3.5
15.2
1.6
9
17.6
24
Contact No.1
φ1.5
9.45
12.2
P=7.92
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
C
DF22-2P-7.92DS(##)
CL0680-1008-5-##
2
19.80
15.00
7.92
DF22-3P-7.92DS(##)
CL0680-1009-8-##
3
27.72
22.92
15.84
DF22-4P-7.92DS(##)
CL0680-1010-7-##
4
35.64
30.84
23.76
DF22-5P-7.92DS(##)
CL0680-1011-0-##
5
43.56
38.76
31.68
HRS No.
A
B
C
DF22R-2P-7.92DS(##)
CL0680-1018-9-##
2
19.80
15.00
7.92
DF22R-3P-7.92DS(##)
CL0680-1019-1-##
3
27.72
22.92
15.84
DF22R-4P-7.92DS(##)
CL0680-1020-0-##
4
35.64
30.84
23.76
DF22R-5P-7.92DS(##)
CL0680-1021-3-##
5
43.56
38.76
31.68
Part No.
HRS No.
A
B
C
CL0680-1022-6-##
2
19.80
15.00
7.92
DF22L-3P-7.92DS(##)
CL0680-1023-9-##
3
27.72
22.92
15.84
DF22L-4P-7.92DS(##)
CL0680-1024-1-##
4
35.64
30.84
23.76
DF22L-5P-7.92DS(##)
CL0680-1025-4-##
5
43.56
38.76
31.68
[Specification number (##)] (53) : Gold Plated
B±0.05
C±0.05
6
P=7.92±0.05
+0
0 .1
.1
+0 0
5
1.
-φ
15
Purchase Unit
100pcs per bag
Unit : mm
No. of Pos.
DF22L-2P-7.92DS(##)
2-φ
1.
100pcs per bag
Unit : mm
No. of Pos.
15.2±0.05
Part No.
Purchase Unit
Purchase Unit
100pcs per bag
In-line Plug
[1Pos.]
12.72
9.3
No. of contacts
indicator
Cavity No.
A
1
[2, 3Pos.]
A
Contact No.1
9.97
12.72
B
No. of contacts
indicator
Cavity No.
10.5
34.95
34.95
3
3
16
A
2
1
Polarity
mark
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
DF22A-1EP-7.92C
CL0680-1053-0-00
1
9.30
DF22A-2EP-7.92C
CL0680-1054-2-00
2
18.00
7.92
DF22A-3EP-7.92C
CL0680-1055-5-00
3
26.00
15.84
Part No.
HRS No.
Purchase Unit
100pcs per bag
Unit : mm
No. of Pos.
A
B
Purchase Unit
DF22AR-2EP-7.92C
CL0680-1069-0-00
2
18.00
7.92
DF22AR-3EP-7.92C
CL0680-1070-9-00
3
26.00
15.84
No. of Pos.
A
B
Purchase Unit
2
18.00
7.92
100pcs per bag
Part No.
DF22AL-2EP-7.92C
HRS No.
CL0680-1074-0-00
17
100pcs per bag
Unit : mm
In-line Plug (Panel Lock Type)
[1Pos.]
8.12
12.72
9.3
No. of contacts
indicator
Cavity No.
34.95
20.7
A 1
16.3
[2, 3Pos.]
3
A
3
Contact No.1
9.97
12.72
B
No. of contacts
indicator
10.5
Cavity No.
34.95
A
3
20.7
Polarity
mark
3
2
C
18
1
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
C
DF22-1EP-7.92C
CL0680-1048-0-00
1
9.30
16.30
DF22-2EP-7.92C
CL0680-1049-2-00
2
17.22
7.92
24.22
DF22-3EP-7.92C
CL0680-1050-1-00
3
25.14
15.84
32.14
Purchase Unit
100pcs per bag
HRS No.
No. of Pos.
A
B
C
DF22R-2EP-7.92C
CL0680-1059-6-00
2
17.22
7.92
24.22
DF22R-3EP-7.92C
CL0680-1060-5-00
3
25.14
15.84
32.14
Purchase Unit
100pcs per bag
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
C
DF22L-1EP-7.92C
CL0680-1063-3-00
1
9.30
16.30
DF22L-2EP-7.92C
CL0680-1064-6-00
2
17.22
7.92
24.22
Purchase Unit
100pcs per bag
■ Panel Cutout
[2, 3Pos.]
[1Pos.]
(C-0.5-X) +0.1
11±0.2
10.27 +0.1
3.5±0.1
4.16 +0.1
(A+0.4) +0.1
3.5±0.1
4.835 +0.1
(15.8-X) +0.1
Part No.
Unit : mm
Unit : mm
Panel thickness
X
2.0
0.48
1.6
0.96
1.2
1.44
0.8
1.92
Note : Do not use a rounded surface at the panel tab portion.
19
In-line Double-row Socket
20.14
17.44
15.5
7.92
23
14.5
Standard lock
(21.29)
Polarity
mark
Contact No.1
1
3
2
4
A
Cavity No.
No. of contacts
indicator
Part No.
DF22B-4DS-7.92C
HRS No.
Unit : mm
No. of Pos.
Lock type
Purchase Unit
4
Standard lock
100pcs per bag
CL0680-1142-8-00
Part No.
HRS No.
DF22BR-4DS-7.92C
CL0680-1156-2-00
Unit : mm
No. of Pos.
Lock type
Purchase Unit
4
Standard lock
100pcs per bag
Part No.
HRS No.
DF22BL-4DS-7.92C
CL0680-1161-2-00
Unit : mm
No. of Pos.
Lock type
Purchase Unit
4
Standard lock
100pcs per bag
In-line Double-row Plug
Panel lock type
17.22
7.92
Without panel lock function
3
17.22
7.92
21.79
19.04
21.79
19.04
3
10.5
24.22
4
A
No. of contacts
indicator
Cavity No.
34.95
20.7
34.95
20.7
No. of contacts
indicator
10.5
Polarity
mark
Part No.
HRS No.
4
A
Connector type
CL0680-1051-4-00
4
Panel lock type
DF22A-4DEP-7.92C
CL0680-1056-8-00
4
Purchase Unit
100pcs per bag
HRS No.
DF22R-4DEP-7.92C
CL0680-1170-3-00
Unit : mm
No. of Pos.
Connector type
Purchase Unit
4
Panel lock type
100pcs per bag
Part No.
HRS No.
Polarity
mark
Unit : mm
No. of Pos.
DF22-4DEP-7.92C
Part No.
Contact No.1
Cavity No.
Unit : mm
No. of Pos.
Connector type
DF22L-4DEP-7.92C
CL0680-1175-7-00
4
Panel lock type
DF22AL-4DEP-7.92C
CL0680-1189-1-00
4
Purchase Unit
100pcs per bag
■ Recommended Panel Cutout (Panel mount type)
(23.72-X) +0.1
6.3±0.1
11±0.2
22.09 +0.1
Contact No.1
17.62 +0.1
Unit : mm
Panel thickness
X
2.0
0.48
1.6
0.96
1.2
1.44
0.8
1.92
21
Retainer
A
B
7.92
Cavity No.
A5
4
3
2
1
No. of contacts
indicator
7.92
A
B
11.6
2
[For Long type, standard lock (Type III)
Long type, enhanced ergonomic lock (Type IV)]
3.2
3.2
8.6
2
[For Standard height, standard lock (Type I)]
Cavity No.
A5
22
4
3
2
1
No. of contacts
indicator
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
Purchase Unit
DF22-1RS/P-7.92
CL0680-1213-4-00
1
7.04
DF22-2RS/P-7.92
CL0680-1209-7-00
2
15.50
7.92
DF22-3RS/P-7.92
CL0680-1210-6-00
3
23.42
15.84
DF22-4RS/P-7.92
CL0680-1211-9-00
4
31.34
23.76
DF22-5RS/P-7.92
CL0680-1212-1-00
5
39.26
31.68
Applicable Socket
DF22-#S-7.92C(28) For Standard height, standard lock(Type I)
#indicates number of contacts.
100pcs per bag
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF22B/C-1RS/P-7.92
CL0680-1214-0-00
1
7.04
DF22B/C-2RS/P-7.92
CL0680-1200-2-00
2
15.50
7.92
DF22B/C-3RS/P-7.92
CL0680-1201-5-00
3
23.42
15.84
DF22B/C-4RS/P-7.92
CL0680-1202-8-00
4
31.34
23.76
DF22B/C-5RS/P-7.92
CL0680-1203-0-00
5
39.26
31.68
Applicable Socket
DF22B-#S-7.92C For Long type, standard lock (Type III)
DF22C-#S-7.92C Long type, enhanced ergonomic lock (Type IV)
DF22-#EP-7.92C
DF22A-#EP-7.92C
Note : When connecting retainer into the plug housing, please note the cavity numbers will line up numerically,
but the retainer cavity numbers will be upside down compared to the plug cavity numbers.
23
Purchase Unit
100pcs per bag
Crimp Contact for Socket
[For 14 to 16 AWG]
[For 10 to 12 AWG]
4.7
4.7
t=0.3
● Strip length : 3.5 to 4.5mm
φ2
P=15.5
1.6 1.3 2.9 1.4
4 0.8
1.6 1.5 2.7 1.4
20.8
17
3 0.8
φ
1.
5
21.8
17
2.8
3.8
2.8
3.8
P=16.5
t=0.4
● Strip length 3.5 to 4.5mm
Reel Contact, Applicable Tool : Applicator
Applicable cable
Part No.
HRS No.
DF22-1416SCFA
CL0680-1085-6-00
1430
DF22A-1416SCFA
CL0680-1087-1-00
1015
DF22A-1012SCFA
CL0680-1106-4-00
UL style AWG Wire Construction Sectional area Jacket diameter
1015
14
41/0.26mm
2.18mm2
16
26/0.254mm
1.32mm2
14
41/0.26mm
2.18mm2
16
26/0.254mm
1.32mm2
10
104/0.26mm
5.52mm2
12
65/0.26mm
3.45mm2
Finish
2500pcs
per reel
2.4 to 3.0mm
3.0 to 3.8mm
Purchase
Unit
Gold Plated
2000pcs
per reel
3.6 to 4.9mm
Note 1 : The conductor of applicable wire is tin plated annealed copper.
Note 2 : When using other than the applicable wire, contact your nearest Hirose representative.
Bulk Contact, Applicable Tool : Manual Crimping Tool
Part No.
HRS No.
Applicable cable
DF22-1416SCA
CL0680-1190-0-00
1430
DF22A-1416SCA
CL0680-1191-0-00
1015
DF22A-1012SCA
CL0680-1107-7-00
1015
16
26/0.254mm
1.32mm2
2.6mm
14
41/0.26mm
2.18mm2
3.7mm
16
26/0.254mm
1.32mm2
3.2mm
10
104/0.26mm
5.52mm2
4.69mm
12
65/0.26mm
3.45mm2
4.04mm
24
Finish
Purchase
Unit
Gold Plated
100pcs
per bag
Crimp Contact for In-line Plug
4.7
2.8
1.6
25.2
0.8
1.6 1.5 2.7 1.4
1416
φ1
.5
3 0.8
29
3.8
P=15.5
t=0.3
Part No.
HRS No.
DF22-1416PCFA
CL0680-2002-4-00
DF22A-1416PCFA
CL0680-1194-0-00
Applicable cable
1430
1015
14
41/0.26mm
2.18mm2
16
26/0.254mm
1.32mm2
14
41/0.26mm
2.18mm2
16
26/0.254mm
1.32mm2
Finish
Purchase
Unit
2500pcs
per reel
2.4 to 3.0mm
Gold Plated
2000pcs
per reel
3.0 to 3.8mm
Part No.
DF22-1416PCA
DF22A-1416PCA
HRS No.
CL0680-1192-0-00
CL0680-1193-0-00
Applicable cable
1430
1015
16
26/0.254mm
1.32mm2
2.6mm
14
26/0.254mm
2.18mm
2
3.7mm
16
26/0.254mm
1.32mm2
3.2mm
25
Finish
Purchase
Unit
Gold Plated
100pcs
per bag
Mated Dimensions
● Socket
to Straight Header Connection
1 Pos.
(12.45) DF22-/1RS/P-7.92
(13.5)
(23.7)
(25.7)
DF22#-1P-7.92DSA(##)
2 to 5 Pos.
(12.45)
DF22- # RS/P-7.92
(13.5)
DF22#- # P-7.92DSA(##)
(28.7)
(26.7)
DF22#- # S-7.92C(28)
DF22B/C- # RS/P-7.92
DF22B#- # S-7.92C
DF22C#- # S-7.92C
(23.7)
(25.7)
Socket to Right Angle Header Connection
(31.6)
(29.6)
DF22#-#S-7.92C(28)
(12.25)
DF22#-#P-7.92DS(##)
(34.6)
(32.6)
(13.3)
DF22#-#P-7.92DS(##)
DF22-#RS/P-7.92
DF22B#-#S-7.92C
DF22C#-#S-7.92C
DF22B/C-*RS/P-7.92
DF22B/C-#RS/P-7.92
Socket to In-line Plug (Panel lock type) Connection
(13.0)
DF22#- # EP-7.92C
(44.55)
(40.55)
DF22- # RS/P-7.92C
DF22#- # EP-7.92C
(47.55)
(43.55)
DF22B#-# S-7.92C
DF22C#-# S-7.92C
(14.2)
DF22#-1P-7.92DSA(**)
DF22B/C-1RS/P-7.92
(26.7)
(28.7)
DF22B#-1S-7.92C
DF22C#-1S-7.92C
DF22#-1S-7.92C(28)
26
Socket to In-line Plug Connection
DF22A#-#EP-7.92C
(44.55)
(40.55)
DF22#-#S- 7.92C(28)
(13.0)
DF22-RS/P-7.92
DF22B/C-#RS/P -7.92
DF22B#-#S-7.92C
DF22C#-#S-7.92C
(14.2)
DF22A#-#EP-7.92C
(47.55)
(43.55)
DF22B/C-#RS/P -7.92
In-line Double-row socket to In-line Double-row Plug
DF22B#-4DS-7.92C
(22.1)
(43.55)
DF22#-4DEP-7.92C
DF22C#-4DS-7.92C
(23.3)
(43.55)
DF22#-4DEP-7.92C
In-line Double-row socket to In-line Double-row Plug Connection
DF22B#-4DS-7.92C
(22.1)
(43.55)
DF22A#-4DEP-7.92C
(43.55)
DF22C#-4DS-7.92C
(23.3)
DF22B/C-#RS/P -7.92
DF22A#-4DEP-7.92C
27
Tools
Type
Hirose Press Unit
Applicators Used in Hirose Press
Unit
Applicators Used in Press Units
of Other Japanese Companies
(Note 2)
Applicator Manufactured
by Japan Automatic Machine (Note
3)
Crimping Tools
Note
Note
Note
Note
Note
Note
Note
Part No.
HRS N o.
Applicable Wire (Note
Applicable Contact (Note 6)
7)
CM-105C
CL0901-0001-000
DF22/DF22A-1416SCFA/
PCFA
AP105-DF22-1416
CL0901-4576-700
UL1430
DF22-1416SCFA/PCFA
AP105DF22A-1416
CL0901-4578-200
UL1015
DF22A-1416SCFA/PCFA
AP109ADF22-1416
CL0901-4579-500
UL1430
DF22-1416SCFA/PCFA
AP109ADF22A-1416
CL0901-4580-400
UL1015
DF22A-1416SCFA/PCFA
AP109ADF22A-1012
CL0901-4582-000
UL1015
DF22A-1012SCFA (Note 1)
CHS893800H-UP
UL1430
DF22-1416SCFA/PCFA
CHS893900H-UP
UL1015
DF22A-1416SCFA/PCFA
QHS895800H-UP
UL1015
HT104/DF22-1416
CL0550-0285-000
16 AWG : UL1430
DF22-1416SCA/PCA
HT104/
CL0550-0286-2-
16, 14 AWG :
DF22A-1416
00
UL1015
HT103/
DF22A-1012
CL0550-0288-800
10, 12 AWG :
UL1015
1 : When crimping DF22A-1012SCFA use a press of at least 3.5 tons.
2 : Applicators compatible with other Japanese companies (AP109A Applicator) cannot be used
with the Hirose Press Unit CM-105C.
An attachment is required when using the applicator. Please contact the press unit manufacturer
for inquiries on attachments.
3 : Please contact Japan Automatic Machine (J.A.M.) via their homepage regarding inquiries on the
applicator or crimping defects. (URL: http://www.jam-net.co.jp)
4 : Problems caused by tools other than those specified are not covered by the warranty.
5 : Crimping should be carried out based on the "Crimping Quality Standards" and "Crimping
Conditions Table."
6 : Applicable contacts are limited to those listed in the table.
7 : Applicable cables are limited to those listed in the table.
28
DF22A-1416SCA/PCA
DF22A-1012SCA
Contact Extraction
● Contact extraction tool
Flat- bladed screwdriver, 1. 4mm blade width
● Intended crimp Contacts
DF22- 1416SC( F) A, DF22A- 1416SC( F) A, DF22A- 1012SC( F) A, DF22- 1416PC( F) A, DF22A- 1416PC( F) A
● Work Method
1. Refer to the drawing No. 1. Insert correct size screwdriver in the housing against the molded- in lance.
Push down the lance as shown.
2. Assure that the lance is deflected to release the contact and pull out wire with the crimped contact.
( Housing Cross- Sectional Diagram)
(1)
(2)
Flat-bladed screwdriver
Molded-in lance
Note : Please do not reuse the reparred housing. Replace it to new one.
Caution
There are parts on the crimp contact that can cause injuries, please use caution when unmating the contacts.
29
Precautions
1. If this product is used outside the specifications, evaluate it in the final set to confirm that
there are no problems in use.
2. No outdoor use.
3. Notification for harness assembly
1) When inserting the crimping terminal to the crimping socket, please do not tilt the crimping terminal or twist the cable.
Insertion at tilted angles or twisting the cable may cause deformation of the crimping terminal or crimping socket.
2) After inserting the crimping terminal to the crimping socket, please make sure that the lance has been hooked with
pulling the cable lightly. When checking the hook, please avoid bending the cable for preventing terminal drop- off.
Load
Load
3) Bundle cables/ Cabtyre Cables
Recommend bundle and strip position of cables are 100mm or more.
Bundling close to the connectors may cause terminal drop- off, breaking cables and unstable connection.
More than 100mm
4. Notification for Insertion Extraction
Caution
1) Please insert/ extract the crimping socket straight to the mating connector. Insertion/ extraction at tilted angles applies
load concentration to the connector end and may cause deformation ( at connection area, socket and header case,
etc) . There is firing risk using this kind of deformed connector.
Insertion
Extraction
2) When it is hard to extract, please lightly insert the connector beforehand and then pull it with releasing the lock.
Forced extraction has a risk of connector breakage.
30
5. Notification of wiring
Caution
1) When using a thick cable, short cable length and bending close to the connector end, these load concentration may
cause deformation. Please note that there is firing risk using deformed connector. When installing, please refrain from
stress concentration such as cable bending close to the connector end or cable twisting.
Stress concentration;
Cable bending close
to connector
Current Ratings
The current rating listed in the catalog indicates the allowable current per contact. However, in applications
requiring current transmission through all the contacts, about one- third of the listed rating should be applied.
When the current rating for the connector is 3A, and the allowable current of the conductor being used is 1A,
then rating of 1A will be used for the entire assembly.
The connectors should not be mating / unmating when the electrical current is being applied.
Hot swap should not be performed.
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
Please consult with your Hirose sales representative if you are planning to use the product for any of the following
applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. )
Hirose will consider the validity of the warranty depending on the conditions.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 3/ 2022. Contents are subject to change without notice for the purpose of improvements.
31
