TROMPETER SPECIFICATION SHEET
CABLE, RADIO FREQUENCY, TWIN CONDUCTOR, BALANCED LINE
TWCH-78-2
(*) – CINCH
MARK: TROMPETER ELECTRONICS TWINAX, TWCH-78-2 (*) CONNECTIVITY
SOLUTIONS
ASSIGNED
VENDOR NUMBER
REQUIREMENTS:
1. IMPEDENCE (OF PAIR) -------------------------------- 78 3 OHMS
2. OPERATING VOLTAGE -------------------------------- 1 KVRMS MAX/2 KVDC
3. BEND RADIUS -------------------------------------------- 1.25 INCH MIN
4. CAPACITANCE ------------------------------------------- COND TO COND -------------------COND TO SHIELD ----------------COND TO SHIELD TO COND---TWO COND TO SHIELD ---------5. CONDUCTOR LOOP RESISTANCE ---------------- 19.0 OHMS/M FT MAX
6. VELOCITY OF PROPAGATION ---------------------- 66% NOM
7. ATTENTUATION: FREQUENCY
dB/100 FT NOM
FREQUENCY
21.2 PF/FT
36.0 PF/FT
38.0 PF/FT
62.0 PF/FT
dB/100 FT NOM
APPR C.MONAHAN
DATE 10/19/2016
1 MHz
0.70
40 MHz
4.50
3 MHz
1.10
50 MHz
5.10
4 MHz
1.40
100 MHz
7.50
5 MHz
1.55
200 MHz
10.50
7 MHz
1.80
500 MHz
16.00
10 MHz
2.20
700 MHz
18.60
20 MHz
3.10
1000 MHz
22.50
30 MHz
3.90
8. HEAT AGING ATTENUATION TEST: SUBJECT A 180 FOOT SAMPLE TO 80C IN AIR CIRCULATING OVEN
FOR 72 HRS. REMOVE CABLE FROM THE OVEN AND LET STABILIZE TO ROOM TEMP (4 HRS MIN). THE
ATTENTUATION AT 7 MHz SHALL NOT INCREASE MORE THAN .48 dB/100 FT FROM ITS UNAGED VALUE
9. WEIGHT ---------------------------------------------------- .0386 LB/ FT
10. INSULATION RESISTANCE (MIN) ------------------ 20 MEGOHMS/1000 FT
11. OPERATING TEMPERATURE RANGE ------------ -30 C TO +80 C
DESCRIPTION
CONSTRUCTIONAL DETAILS
INNER CONDUCTORS
TWO CONDUCTORS, EACH 7 STRANDS OF AWG
SIZE 28 TINNED COPPER WIRE. NOM DIA .037
(AWG 20)
DIELECTRICS
TWO EACH POLYETHYLENE, ONE BLUE, ONE
NATURAL. NOM DIA .076
DWN DKC
TWO EACH POLYETHYLENE. NOM DIA .052
FILLERS
SHIELD
JACKET
DWN
DKC
12-11-97
CHK
C. M
10-19-97
ENG
C.M
10-19-97
APPR
C.M
10-19-97
MATERIAL
__________
SCALE
REV D
CABLE CORE
EO 56534
.154 NOM O.D., .160 MAX DIELECTRICS AND
FILLERS TO HAVE A 2.92 .25 RIGHT-HAND OR
LEFT-HAND LAY, 4 TWISTS PER FOOT. A NYLON
THREAD WRAP SHALL BE APPLIED WITH
SUFFICIENT COVERAGE TO MAINTAIN THE
POSITION OF THE COMPONENTS
SINGLE BRAID, (128 STRANDS 16X8) AWG SIZE 36
TINNED COPPER WIRE. 9.8 PICKS/IN, 32 BRAID
ANGLE, 4.2 OHM/M FT D.C. RESISTANCE. SHIELD
COVERAGE 93% NOM, MAX O.D. .195
BLUE (PER EIA-359-A, MUNSELL COLOR CHART,
SYMBOL CENTROID) FLAME RETARDANT HALOGEN
FREE POLYOLEFIN .242 .005 O.D.
CODE IDENT
DRAWING NO.
REV
14949
TWCH-78-2
D
DATE
1-2-97
SHEET
很抱歉,暂时无法提供与“TWCH-78-2”相匹配的价格&库存,您可以联系我们找货
