X.FL-2LP-04K1T-A-(100)
    HRS(广濑)
X.FL-2LP-04K1T-A-(100) 数据手册
NEW Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height X.FL Series ●Connector mated condition Mated height comparison (compared to conventional company products) 0.89(0.95MAX) 1.2(1.3MAX) 0.94(1.0MAX) X.FL-LP-040 X.FL-LP-032(09) X.FL-LP(P)-068 X.FL-PR-SMT1-2 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. X.FL-R-SMT-1 X.FL-R-SMT-1 X.FL-R-SMT-1 Fig. 1 ■Features 4. High frequency transmission 1. A Low mated height of 0.94 or 1.2 mm (maximum of 1.0 or 1.3 mm) This series offers the high performance needed to meet the requirements of many different miniature devices, featuring a DC to 6 GHz capacity. X.FL-LP(P)-068 supports up to 12 GHz. When connected this series delivers a world class low mated height of 1.0 or 1.3 mm (see Figure 1). 2. Minimal mounting area required 5. Automatic board placement The receptacle requires a footprint of only 3.4 mm2, which is the same footprint as our W.FL and W. FL2 series. In addition, the same land patterns can be used. (Note: The X.FL series has no mating compatibility with the W.FL2 and W.FL series.) This product is available in embossed packaging; this allows the plug and receptacles to be automatically mounted. 6. T h e u s e o f u l t r a - f i n e c o a x i a l (fluorinated resin insulated) cables 3. Ultra lightweight The use of ultra-fine coaxial (fluorinated resin insulated) cables on these connectors offer the ability to complete connections in small, confined spaces with a smooth, easy operation. The world’s smallest and lightest class of coaxial connectors Receptacle: 3.2 mg Right angle plug: 22.0 mg (068),14.4 mg (040), and 15.7 mg (032) Plug receptacle: 5.5 mg 7. Simple connector mating / unmating Dedicated tools are available to ensure that proper mating/unmating of this connector takes place. ■Product Specifications Nominal characteristic impedance Frequency range Ratings 50ø DC~6GHz Operating temperature range -40°C to +90°C (RH 90% or less) Storage humidity range -30°C to +70°C (RH 90% or less) Specifications (for each plug type) Item X.FL-LP-040 X.FL-LP-032(09) X.FL-LP(P)-068 X.FL-PR-SMT1-2 1. Contact resistance (Center) Maximum of 20 mø (Center) Maximum of 25 mø (Center) Maximum of 25 mø (Center) Maximum of 25 mø (Outer) Maximum of 10 mø (Outer) Maximum of 25 mø (Outer) Maximum of 10 mø (Outer) Maximum of 15 mø 2. V.S.W.R. (*) 1.3 or less (DC to 3 GHz) 1.4 or less (3 to 6 GHz) 1.3 or less (DC to 3 GHz) 1.4 or less (3 to 6 GHz) 1.3 or less (DC to 3 GHz) 1.4 or less (3 to 6 GHz) 1.7 or less (6 to 12 GHz) 3. Insulation resistance Minimum of 500 MΩ , 100 V DC 4. Withstanding voltage 200 V AC, 1 minute 1.3 or less (DC to 3 GHz) 1.5 or less (3 to 6 GHz) *V.S.W.R. Measurement System (plug type) The above V.S.W.R. specification values were measured using the measurement system shown below. Network Analyzer Test Set Test Port Test Port Cable D.U.T Termination Note 1:Cable type connectors were measured with SMA conversion adapters attached to both ends of the harness product of a suitable 100 cm cable. Note 2:Board type connectors were mounted to a 50 glass epoxy board and measurements were conducted with SMA conversion adapters attached. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.1 1 X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height ■Cable Assembly (Plug) 2 ●X.FL-LP-040 (Applicable cable: outer diameter Ø0.81 or Ø0.64) 3.3 0.74 Ø0.81 or Ø0.64 Material / Finishes Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Shell Insulator Female contact Material Phosphor bronze LCP resin Phosphor bronze Finish and remarks Gold plated Black, UL94V-0 Gold plated 2 ●X.FL-LP-032 (09) (Applicable cable: outer diameterØ0.5) 0.74 3.5 Ø0.5 Material / Finishes Part Shell Insulator Female contact Material Phosphor bronze LCP resin Phosphor bronze Finish and remarks Partially gold plated Black, UL94V-0 Gold plated 2 ●X.FL-LP (P) -068 (Applicable cable: outer diameterØ1.13) 3.6 1 Ø1.13 Material / Finishes Part Shell Insulator Female contact Material Phosphor bronze LCP resin Phosphor bronze Finish and remarks Partially gold plated Black, UL94V-0 Gold plated ●Cable Guide Description Ø0.81 mm Coaxial Cable Ø0.64 mm Coaxial Cable Ø0.5 mm Coaxial Cable Ø1.13 mm Coaxial Cable 2 Cable Type 04 044 032 068 Cable Specification Dielectric Jacket Nominal Nominal attenuation Center Conductor Outer Conductor Diameter Diameter Impedance 3GHz 6GHz 7/0.05 (36 AWG) Ø0.40 Single-layer braided wire Ø0.81 50 5.6dB/m 8.3dB/m Tin plated Silver plated annealed copper wire FEP FEP Fiber or paper covered 7/0.05 (36 AWG) Ø0.44 Ø0.64 copper winding wire 50 5.85dB/m 8.59dB/m Silver plated annealed copper wire PFA PFA Tin plated Fiber or paper covered 7/0.04 (38 AWG) Ø0.32 Ø0.5 50 6.13dB/m 9.09dB/m copper winding wire Silver plated copper alloy wire PFA PFA Tin plated 7/0.08 (32 AWG) Ø0.68 Single-layer braided wire Ø1.13 50 3.7dB/m 5.3dB/m Silver plated annealed copper wire FEP Tin plated FEP X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height How to Specify Plug Cable Assembly The dimensions of a cable assembly of the X.FL series should be specified as follows: [Double-Ended Cable Assembly] [Single-Ended Cable Assembly] L(mm) L(mm) Single ended assemblies come with a blunt cut on the non-terminated end. Please contact us if special strip requirements are needed. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Product Number Structure Refer to the charts below for determining specific part number characteristics. Please select connectors listed in this catalog when placing orders and be sure to check the latest delivery specifications at the time of ordering the product. ●Used Plug: X.FL-LP-040 ◇Ø0.81 Coaxial Cable Double-Ended X.FL - 2LP - 04K「」TV - A - (L) ❶ Single-Ended ❷ ❸ ❹ ❺ ❻ X.FL - LP - 04K「」TV - A - (L) ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series name: X.FL series ❹ Cable color ❷ Assembly type LP: Single-ended, 2LP: Double-ended ❺ Cable outer conductor TV: Tin plated braided wire ❸ Cable type ❻ Total length L (mm) 04K: Ø0.81 coaxial cable 1: White, 2: Black L length in mm ◇Ø0.64 Coaxial Cable Double-Ended X.FL - 2LP - 044N「」TS - A - (L) ❶ Single-Ended ❷ ❸ ❹ ❻ X.FL - LP - 044N「」TS - A - (L) ❶ ❷ ❸ ❹ ❶ Series name: X.FL series ❺ ❻ 1: White, 2: Black ❹ Cable color TS: Tin plated fiber or paper ❺ Cable outer conductor covered copper winding wire ❷ Assembly type LP: Single-ended, 2LP: Double-ended ❸ Cable type ❺ 044N: Ø0.64 coaxial cable ❻ Total length L (mm) L length in mm Plug: X.FL-LP-032 (09) Ø0.5 coaxial cable Double-Ended X.FL - 2LP9 - 032H「」TS - A - (L) ❶ Single-Ended ❷ ❸ ❺ ❻ X.FL - LP9 - 032H「」TS - A - (L) ❶ ❷ ❸ ❶ Series name: X.FL series ❷ Assembly type LP9: Single-ended, 2LP9: Double-ended ❸ Cable type ❹ 032H: Ø0.5 coaxial cable ❹ ❺ ❻ 1: White, 2: Black ❹ Cable color TS: Tin plated fiber or paper ❺ Cable outer conductor covered copper winding wire ❻ Total length L (mm) L length in mm 3 X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height Plug: X.FL-LP (P)-068 Ø1.13 coaxial cable X.FL - 2LP P - 068W「」TV - A - (L) Double-Ended ❶ ❷ ❸ ❹ ❺ ❻ ❼ X.FL - LP P - 068W「」TV - A - (L) Single-Ended ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series name: X.FL series ❺ Cable color ❷ Assembly type LP: Single-ended, 2LP: Double-ended ❻ Cable outer conductor TV: Tin plated braided wire ❸ Connection type Batch connection type 068W: Ø1.13 coaxial cable ❹ Cable type 1: Grey, 2: Black, 3: White ❼ Total length L (mm) L length in mm ●Standard Tolerances for (L) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. L (mm) Standard Tolerances (mm) 35 ≦ L ≦ 200 ±4 200 < L ≦ 500 ±8 Note: Minimum available length (L) is 35 mm. ■Receptacles L (mm) 500 < L ≦ 1000 1000 < L Standard Tolerances (mm) ±12 ±1.5% Recommended PCB Mounting Pattern (*1) 0.56 0.3 0.5 SIG 0.65 0.3 1.7 2 1.5 1.3 1.7 2 1.3 1.3 0.18 2.6 1.4 GND SIG No conductive traces in this area GND *1) The pattern is the same as the W.FL and W.FL2 connectors. Part No. X.FL-R-SMT-1(80) HRS No CL331-0701-8-80 Packaging Reel packaging 10,000 pieces per reel φ 2 4 SIG A 2 A 4 φ330 1.5 13.5 12 5.5 1.75 ●Embossed Carrier Tape Dimensions (JIS-C-0806 compliant) ●Reel Dimensions φ13 Unreeling direction ■Plug Receptacles Recommended PCB Mounting Pattern 2.8 1.97 1.8 0.69 0.3 1.4 GND HRS No CL331-0713-7-80 0.65 0.3 1.94 2.28 Part No. X.FL-PR-SMT1-2(80) 0.8 1.35 1.5 0.33 1.3 1.94 2.24 SIG SIG A A 4 Unreeling direction 2 φ13 φ330 Ø1 .5 1.75 4 13.5 12 5.5 2 SIG No conductive traces in this area Packaging Reel packaging 10,000 pieces per reel ●Embossed Carrier Tape Dimensions (JIS-C-0806 compliant) ●Reel Dimensions 4 RoHS ○ GND RoHS ○ X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height ■Conversion Adapters ●SMA Conversion Adapter (Mating portion - X.FL side: jack - SMA side: plug) (9.98) Note: The X.FL side mating portions has a lower lock retention force than the regular product, so that the adapter cannot be used for purposes other than performance measurements. Part No. HRMP-X.FLJ 8HEX HRS No CL311-0435-1 RoHS ○ 13.74 5.6 (4.05) 6 φ6.35 Note: The X.FL side mating portions has a lower lock retention force than the regular product, so that the adapter cannot be used for purposes other than performance measurements. Part No HRMJ-X.FLP HRS No CL311-0436-4 RoHS ○ ●SMA Conversion Adapter (Mating portion - X.FL side: plug (w/o lock) - SMA side: jack) (18.12) 6 (4.05) 5.5 φ6.35 Note: This connector is used by compressing the mating portion of X.FL side onto the X.F L-R-S M T-1 portion. Part No. HRMJ-X.FLP-ST3 HRS No CL311-0450-5 RoHS ○ BTool ●Plug Mating Tool (Space-Saving Type) φ10 (100) This tool is used for mating a plug. JAPAN 8 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●SMA Conversion Adapter (Mating portion - X.FL side: plug - SMA side: jack) Part No. W.FL-LP-IN ※ HRS No CL331-0323-2 RoHS ○ *This tool can be also used for the X.FL series. ●Plug Mating and Unmating Tool Mating side Unmating side X.FL This is a combination tool that has both of the mating and unmating tool at either end. (60) Part No. X.FL-LP-IN.OUT1 HRS No CL331-0715-2 RoHS ○ 5 X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height BUsage Precautions 1. Plugs (1) Mating / un-mating 1.To un-mate a connector, use the unmating side of the plug mating and unmating tool X.FL-LP-IN.OUT1 as shown in the following figure. [How to un-mate a plug] Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Insert the tool from the direction of the cable so that it can hold the cable. Tilt the tool to pull the cable side up. Un-mating is completed. Never un-mate the plug by pulling the cable. It may cause a failure of the connector. 2. To mate a connector, use the mating side of the plug mating and unmating tool X.FL-LPIN.OUT1 or the plug mating tool W.FL-LP-IN. Align the mating axes between both of the connectors and check that the shell is properly aligned. The connector should be inserted perpendicularly as much as possible. (See the following figure) Do not attempt to insert the connector at an extreme angle. It may cause the connector to fail. X.FL Plug Connector (2) Allowable load to a cable that is mated X.FL-R-SMT-1 (Receptacle) After the connector is mated, do not apply a load to the cable in excess of the values indicated in the figure below. 2 N or less (X.FL-LP-040.X.FL-LP(P)-068) 1 N or less (X.FL-LP-032) (while wiring after mating) X.FL-R-SMT-1 When the cable is routed in such a direction that lifts the cable, it is recommended that cushioning should be placed on the plug to prevent the connector from unmating (see the example below). 1.05 ± 0.05 Cushioning (3) Precautions 6 Do not mate or unmate a connector with an excessive prying force. It may cause a failure of the connector. X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height 2. Plug Receptacles (1) Mating This product should be mated by hand. Do not apply an excessive load or over handle during the mating process. It may cause the connector to fail. [Mating procedure] 1. Before inserting the connector, bring the mating surface of the plug receptacle (X.F L-P R-S M T12) into gentle contact with that of the receptacle (X.F L-R-SMT-1) and slide them back and forth and around so that the mating axes are aligned. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Align the mating axes 2. Also make sure the PCBs the parts are mounted on are not allowed to move relative to each other. When the connector has been slightly mated with the receptacle, the connector will not move from any side-to-side or front-to-back forces applied to it. 3. Push the connector down perpendicularly until you feel it click. 4. If the mating axes are not aligned, it will fail to make a complete connection. When there has been a failure to make a connection due to misaligned mating axes, Please check that the female terminal contacts on the plug receptacle have not been damaged Mold surface Female terminal (2) Unmating When unmating a connector, it is desirable to pull the connector in the direction perpendicular to the surface on which the connector is mounted. However, unmating the FPC in a perpendicular direction can be difficult when an FPC is detached from a thin printed circuit board. When you find it difficult to unmate the connector, detach it to an oblique direction as shown in the left figure below. Avoid detaching the connector in a way as shown in the right figure. SIG Terminal SIG Terminal (3) Precautions GND Terminal GND Terminal GND Terminal Do not mate or unmate a connector with an excessive prying force. It may cause a failure of the connector. 7 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. X.FL Series●Low-Profile, Ultraminiature Lightweight SMT Coaxial Connectors - 0.94 or 1.2 mm Mated Height (4) Notes for mounting Avoid mounting multiple connectors of this type on the same circuit board. (If it is unavoidable to mount multiple connectors, take necessary measures for use, such as separating the circuit board between the connectors.) When the connector is mounted on an FPC, insufficient stiffness may lead to land pattern separation or solder separation. It is recommended that the FPC should be lined with a stiffening film. (5) Precautions 1. Do not mate or unmate a connector with an excessive prying force. It may cause a failure of the connector. 2. The connector may become disconnected if it is dropped, or extreme stress is applied to the FPC. To prevent this from happening, fix the connector in place by holding it with an added portion of the case or some type of cushioning material. 3. Reflow conditions of receptacles and plug receptacles Soldering profile for lead free solder (reference) (1) Recommended reflow temperature profile [reference] 10 seconds or less Temperature (ç) 250ç or lower 260 240 220 200 180 160 140 120 100 80 0 230℃ 220℃ 180℃ 130℃ Time (second) 120 seconds or less Preheat time 50 seconds or less 60 seconds or less Soldering time 1. The temperatures indicated are the surface temperatures on the printed circuit board at the points of contact with the terminals. 2. Reflow soldering should be performed at a peak temperature of 250°C or less at the surface of the printed circuit board. 3. The temperature profile varies depending on conditions such as the size of the printed circuit board, the solder paste type, and solder thickness. (2) Recommended metal mask thickness (3) Reflow cycles 0.1mm~0.12mm 2 times 4. Operating Environment and Storage Conditions (1) Operating environment This product was designed under the assumption that it would be used in a normal operating environment. Use of this connector under adverse environmental conditions may lead to discoloration or other kinds of degradation. Use of the connector in regions having exposure to excessive amounts of fine particles and dust, high densities of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive gasses (e.g., exhaust gas from automobiles or factories), is not advised Environments having a large difference in temperature, such as a place near a heater. (2) Storage conditions Store the product in Hirose Electric's packaging or similar packaging conditions. Temperature: -10 to +40°C, humidity: 85% or less (recommended storage conditions) Use the product within six months from delivery. Products for which the storage period has expired must be tested for solderability before the use. ® 8 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 1/2014. Contents are subject to change without notice for the purpose of improvements.
X.FL-2LP-04K1T-A-(100) 价格&库存
很抱歉,暂时无法提供与“X.FL-2LP-04K1T-A-(100)”相匹配的价格&库存,您可以联系我们找货
