Micro-USB connectors meeting USB 2.0 Standard
Note : Contact us to ascertain whether a TID number has
been acquired for an individual product.
Fig.1
■Overview
Extremely small highly reliable connectors complying with
physical, electrical and environmental requirements of
Micro-USB standard (USB 2.0).
Receptacles and plugs are available in a wide variety of
mounting and termination styles, allowing their use in
various applications.
Reverse
(Top mount)
Drop-in
(Mid-mount)
Standard
(Bottom mount)
■Features
1. Size reduction
Compared with the standard Mini-USB connectors, the
size of ZX connectors is reduced by approximately 60%
while still allowing a high-speed data transfer of 480 Mbps,
specified in USB 2.0.
2. Receptacle styles
Two interface configurations: Micro-B and Micro-AB in
standard, mid-mount and reverse mounting styles.
SMT and through-hole (shell) PC board terminations.
Fig.2
3. Plug styles
Corresponding to the receptacle styles, two interface
configurations: Micro-A and Micro-B, with direct wire or
PCB wire soldering.
Several plug styles can be used for data transmission,
earphone or charging applications.
USB 2.0 Hi-Speed (480 Mbps)
Eye diagram measurement results :
Measured with 2.4 m long USB 2.0 cable
4. Smooth mating and unmating
A smooth mating and unmating operation results in less
wear and a longer product life. The unique Hirose active
latch mechanism produces a reliable and durable
connector.
Even after repeated use, the user will experience a
smooth click sensation when mating the connectors.
Note : The statement above only applies when using both
plug and receptacles made by Hirose Electric.
200 mV/div
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
ZX Series
TP2
500ps/div
Fig.3
5. Hirose was the first company to obtain a
Micro-USB certification (TID number).
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.12④
1
ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard
■Product Specifications
Ratings
Current rating
1A (per contact) or
Voltage rating
30V AC
1.8A (contacts No. 1 and 5) and
Operating temperature range
-30°C to +85°C (Note1)
0.5A (contacts No. 2, 3, and 4)
Storage temperature range
-30°C to +60°C
Item
Specification
Conditions
1. Contact resistance
30mø max.
100mA
2. Withstanding voltage
No flashover or insulation breakdown
100V AC / 1 minute
3. Capacitance
2pF max.
Between adjacent contacts at 1,000Hz (AC voltage)
4. Durability
Contact resistance : Rise from initial value of 10mø max. 10,000 cycles
5. Total insertion/removal force
Insertion force : 35N max., Removal force : 8N min.
Mated with corresponding connector
Note1 : Includes temperature rise caused by current flow.
Note2 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications
for a specific part number shown.
■Materials / Finish
●Receptacles
Part
Material
Finish
Remarks
Insulator
LCP
Micro-B: Black, Micro-AB: Gray
UL94V-0
Contacts
Copper alloy
Selective gold plated
Shell
Stainless steel
Tin alloy plating
●Plugs
Part
Material
Finish
Remarks
Insulator
LCP
UL94V-0
Contacts
Copper alloy
Shell
Stainless steel
Tin alloy plating
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacles
ZX 62 RD - B - 5 P * 8
q
w
e
t
r
y
u
i
qSeries name
wTermination style
●Plugs
ZX 40 - B - 5 S * - UNIT
q
w
r
t
y
u
o
ZX 40 - B - SLDA
q
Interface
Micro-A
Micro-B
w
r
Receptacle
o
Plug
eBoard mounting style
(Receptacles)
ZX
10's : Right-angle PCB wire, SMT
20's : Straight, PCB wire
40's : Direct wire
60's : Right-angle, PCB wire
80's : Cradle SMT
Standard (Bottom mount)
Standard (Bottom mount) through hole
Reverse (Top mount)
Reverse (Top mount) through hole
Drop-in (Mid-mount)
Micro-A
Micro-B
Micro-AB
5
Receptacle- Male
Plug – Female
Blank
D
R
RD
M
rMating side configuration A
B
AB
tNumber of contacts
yContact type
P
S
uSerial No.
iShell termination style – Blank SMT
Receptacles
8 Through hole (solder tab length: 0.8mm)
oComponents-plugs
UNIT Assembly (Insulator/contact/lock)
Cover (Note 1)
Note 1 : Classifiers such as A, B, and C are entered for *.
Micro-AB
2
■Configurations
Mating side
configuration
Type
Part No.
3D Image
Page
SMT
ZX62-B-5PA(33)
4
SMT
DIP
ZX62D-B-5PA8(30)
4
Reverse
SMT
ZX62R-B-5P(30)
5
Drop-in
SMT
ZX62M-B-5P(30)
5
SMT
ZX62-AB-5PA(31)
6
SMT
DIP
ZX62D-AB-5P8(30)
6
SMT
ZX62R-AB-5P(30)
7
SMT
DIP
ZX62RD-AB-5P8(30)
7
Standard
R e c e p t a c l e s
Standard
Micro-AB
P l u g s
Reverse
Cradles
Micro-B
Direct wire soldering
Assembly
(insulator/contacts/lock)
Cover-top
Cover-bottom
PCB wire soldering
(straight, through hole)
Assembly
Cover
PCB wire soldering
(SMT)
Assembly
Cover-top
Cover- bottom
PCB wire soldering
(SMT)
Assembly
Cover
Micro-A
Assembly
Cover-top
Cover- bottom
Micro-B
SMT
DIP
Micro-B
: ZX40-B-5S-UNIT(31)
9 and 10
: ZX40-B-SLDA
: ZX40-SLDB
: ZX20-B-5S-UNIT(30)
11
: ZX20-B-SLDC
: ZX64-B-5S-UNIT(31)
12 and 13
: ZX64-B-SLDA
: ZX64-SLDB
12 and 13
: ZX64-B-SLDC
: ZX40-A-5S-UNIT(30)
14 and 15
: ZX40-A-SLDA
: ZX40-SLDB
ZX80-B-5S(30)
With lock
16
ZX80-B-5SA(30)
Without lock
16
Note : 1 Part numbers in the Plugs section of the above table list the Assembly (insulator/contacts/locks) and the corresponding Shields/Covers.
Note : 2 Optional Printed Circuit boards for the Plugs are shown for reference only. Not supplied with applicable connectors.
Note : 3 The color of the insulators body in the Assembly (insulator/contacts/lock) shown in the 3D Image column above is blue for clarity. Refer to
the Materials (Page 2) for correct colors.
3
■Receptacles
●Micro B - Standard (Bottom mount), Shell SMT
Part No.
HRS No.
Packaging
ZX62-B-5PA(33)
242-0033-8 33
3,500pcs/reel
8.3
4.1
2.6
No.5
1.3
0.4
0.6
7.5
4.3
6.2
9.8
2.5
1.45
0.5
5
2.8
1.6
3.35
No.1
NO CONDUCTIVE
TRACES
1.35
1.9
BRecommended PCB mounting pattern
PCB EDGE
No.1
7.9
No.5
2.15
All dimensions : mm
●Micro B - Standard (Bottom mount), Shell through hole
Part No.
HRS No.
Packaging
ZX62D-B-5PA8(30)
242-0056-3 30
2,000pcs/reel
4.85
2.6
0.65
0.4
D) No.1
1.05(LAND)
0.65(TH)
No.5
1.35
AN
7.5
PCB EDGE
5
2.5
0.5
4.1
5.2
7.2
9.4
1.3
R0.325(TH)
0.5(TH)
0.6
2.75
NO CONDUCTIVE TRACES (TH)
.3
R0
1.5(TH)
1.9
2.9
R0.5(LAND)
R0.325(TH)
No.1
4.85
7.2
0.8
5(L
3.35
.52
0.2
0.1
1.25(LAND)
0.85(TH)
R0
2.15
2.9
No.5
All dimensions : mm
4
■Receptacles
Part No.
HRS No.
Packaging
ZX62R-B-5P(30)
242-0028-8 30
2,000pcs/reel
BRecommended PCB8.3 mounting pattern
4.1
2.6
1.3
No.1
No.5
1.35
0.5
2.9
3.9
5.6
6.6
9.8
0.6
No.1
5
2.5
1.45
1.9
2
3.35
0.4
0.43
No.5
2.15
7.5
8.8
All dimensions : mm
●Micro B - Drop-in (Mid-mount), Shell SMT
Part No.
HRS No.
Packaging
ZX62M-B-5P(30)
242-0024-7 30
1,500pcs/reel
11.5
7.5
2.74
4.3
5
5.3
2.4
4.8
1.9
3.6
1.05
0.6
0.4
1.3
2.6
6.9
7.8
8.8
12
PCB EDGE
1.25
2.4
1.4
No.5
3
1.5
4.3
0.
7.15
1.9
7.5
C
.4
R0
No.1
4.7
2
1.23
5.15
●Micro B - Reverse (Top mount) Shell SMT
No.5
No.1
0.25
1.3
2.6
4.7
All dimensions : mm
5
■Receptacles
●Micro AB - Standard (Bottom mount), Shell SMT
Part No.
HRS No.
Packaging
ZX62-AB-5PA(31)
242-0045-7 31
3,500pcs/reel
8.3
4.1
2.6
1.3
No.1
No.5
3.35
1.6
0.4
1.35
0.6
5
1.9
2.5
0.5
4.3
6.2
9.8
1.45
7.5
2.8
PCB EDGE
No.1
No.5
8.8
2.15
All dimensions : mm
●Micro AB - Standard (Bottom mount), Shell through hole
Part No.
HRS No.
Packaging
ZX62D-AB-5P8(30)
242-0027-5 30
2,000pcs/reel
0.4
No.1
1.05(LAND)
0.65(TH) NO CONDUCTIVE TRACES
No.5
1.35
1.5
1.7
(0.325)
(0.5)
0.5
4.1
5.2
7.35(TH)
9(TH)
9.4
0.6
5
2.025
3.125
2.5
1.3
1.5(TH)
1.9
R0.5(LAND)
PCB EDGE
7.5
2.625
R0.25(TH)
2.8
R0.3(TH)
No.1
4.45
8.35
0.6
0.85(TH)
R0.45(LAND)
4.45
2.6
1.3
3.475
3.125
1.25(LAND)
No.5
All dimensions : mm
6
■Receptacles
Part No.
HRS No.
Packaging
ZX62R-AB-5P(30)
242-0035-3 30
2,000pcs/reel
8.3
4.1
2.6
1.3
No.5
No.1
1.45
0.43
0.5
2.9
0.85
4.75
6.6
9.8
7.5
0.6
5
2.5
1.9
3.35
1.6
1.35
0.4
PCB EDGE
No.5
.4
R0
4-
8.8
No.1
2.15
All dimensions : mm
●Micro AB - Reverse (Top mount), Shell through hole
Part No.
HRS No.
Packaging
ZX62RD-AB-5P8(30)
242-0025-0 30
2,000pcs/reel
R0.45(LAND)
No.1
R0.2MAX
1.05(LAND)
0.65(TH)
1.35
1.5
1.7
0.4
3.475
7.5
No.1
0.6
5
2.5
No.5
R0
.5(
LA
ND
4.45
8.35
0.6
1.9
4.75
0.85
1.5(TH)
2.9
1.3
(TH)
(0.325)
R0.3
(0.5)
2.625
No.5
1.25(LAND)
0.85(TH)
R0.25(TH)
9.4
9(TH)
7.35(TH)
6.6
4.45
2.6
1.3
3.125
0.555
●Micro AB - Reverse (Top mount), Shell SMT
2.025
3.125
PCB EDGE
All dimensions : mm
7
Plugs – assembled (not-terminated, without overmold)
Components
ZX40 - Direct wire soldering
ZX40-*-SLDA
Cover-top
ZX40-*-5S-UNIT
contacts/lock)
*No PCB required
ZX40-SLDB
Cover-bottom
ZX20 - PCB wire soldering
ZX20-*-SLDC
Cover
ZX20-*-5S-UNIT
Assembly
*Vertical through hole PCB
termination
ZX64 - PCB wire soldering
ZX64-*-SLDA
Cover-top
ZX64-*-5S-UNIT
contacts/lock)
*Right angle through hole
PCB termination
ZX64-SLDB
Cover-bottom
8
■Plugs
●Micro B - Assembly (insulator/contacts/lock) – Direct wire soldering
Part No.
HRS No.
Packaging
ZX40-B-5S-UNIT(31)
242-0002-4 31
1 piece
7.9
No.5
No.1
4.2
All dimensions : mm
●Micro B - Component, Cover-top - Direct wire soldering
HRS No.
Packaging
ZX40-B-SLDA
242-0003-7
4,000pcs/reel
22.6
Part No.
6.85
8
1.8
14.1
Contact HRS for Cable Termination Procedure Manual.
All dimensions : mm
9
■Plugs
16.2
16.2
●Micro A, Micro B - Component, Cover-bottom - Direct wire soldering
8
8
All dimensions : mm
ZX40-SLDB(3.3)
ZX40-SLDB
Part No.
HRS No.
ZX40-SLDB
242-0004-0
ZX40-SLDB(3.3)
242-0023-4
Packaging
Cable dia.
Ø3.8
4,000pcs/reel
Ø3.3
22.6
●Assembled
6.85
1.8
4.75
8.6
All dimensions : mm
10
■Plugs
●Micro B - Assembly (insulator/contacts/lock) - Vertical through hole PCB wire soldering (non-direct)
Part No.
HRS No.
Packaging
ZX20-B-5S-UNIT(30)
242-0012-8 30
4,000pcs/pks
1
1.4
2.6
1.3
5-0.15
gh
ho
le)
12.2
*PCB required (not supplied)
Max. thickness: 0.6mm
(Th
0.7
No.5
1(Land)
10.25
R0
7.9
No.1
0.35
1.55
No.5
3.975
d)
.3(T
8.2
1.6(Land)
1.55
e)
hol
hro
(Lan
ugh
1.3
2.6
R0.5
1.2(Through hole)
4.2
5-Ø
nd
0.6(Through hole)
La
.1(
No.1
rou
Ø1
5-
All dimensions : mm
●Micro B - Component, Cover - through hole
HRS No.
Packaging
ZX20-B-SLDC
242-0022-1
4,000pcs/reel
12.1
8.2
2-0.2
1.1
Part No.
●Assembled
8.2
2.6
1.3
2-0.2
1
1.4
5-0.15
6.85
6.85
Assembly
0.6
12.2
1.8
8
Cover
1.8
0.35
1.55
8.4
0.6
4.4
All dimensions : mm
11
■Plugs
●Micro B - Assembly (insulator/contacts/lock) - Right angle SMT
Part No.
HRS No.
Packaging
ZX64-B-5S-UNIT(31)
242-0009-3 31
1 piece
2.6
1.3
16.1
5-0.15
1.5
6
Max. thickness: 1.0mm
7.9
1.3
No.5
2.6
No.1
No.1
3.7
0.35
1.1
0.5
No.5
6.8
All dimensions : mm
●Micro B - Component, Cover-top – Right angle SMT
HRS No.
Packaging
ZX64-B-SLDA
242-0013-0
4,000pcs/reel
24.7
Part No.
6.85
1.8
8
All dimensions : mm
12
■Plugs
●Micro B - Component, Cover-bottom - Right angle SMT
HRS No.
Packaging
242-0049-8
4,000pcs/reel
24.7
●Assembled
8
Assembly
Cover-top
1.8
4.1
6.85
8.4
Cover-bottom
All dimensions : mm
●Micro B - Component, Shell/cover – Right angle SMT
Part No.
HRS No.
Packaging
ZX64-B-SLDC
242-0018-4
4,000pcs/reel
6.85
Shell/cover, without cable clamp
This shell/cover does not require ZX64-SLDB.
8
16.1
16.1
1.8
●Assembled
8.4
Assembly
Cover-top
1.8
6.85
4.1
18.25
Part No.
ZX64-SLDB
Cover-bottom
All dimensions : mm
13
■Plugs
●Micro A - Assembly (insulator/contacts/lock) - Direct wire soldering
Part No.
HRS No.
Packaging
ZX40-A-5S-UNIT(30)
242-0010-2 30
1 piece
12.4
Contacts
7.9
No.1
4.2
No.5
Insulator body (color grey)
All dimensions : mm
●Micro A - Component, Cover-top - Direct wire soldering
HRS No.
Packaging
242-0011-5
4,000pcs/reel
22.6
Part No.
ZX40-A-SLDA
6.85
1.8
8
All dimensions : mm
14
■Plugs
16.2
16.2
8
8
All dimensions : mm
ZX40-SLDB
Part No.
ZX40-SLDB(3.3)
HRS No.
ZX40-SLDB
242-0004-0
ZX40-SLDB(3.3)
242-0023-4
Packaging
4,000pcs/reel
Cable dia.
Ø3.8
Ø3.3
22.6
●Assembled
6.85
Assembly
Cover-top
1.8
8.6
4.75
Cover-bottom
All dimensions : mm
15
■Plug-Vertical, cradle mount, Shell through hole
●Micro B, with lock
6.65
2-0.2
2.6
1.3
5-0.15
No.1
Packaging
ZX80-B-5S(30)
242-0017-1 30
100pcs/pks
0.7
3.52
2.32
0.37
HRS No.
6
Part No.
R1.
3.15
No.5
1
1.86
2.78
2.42
1.88
6.85
8.55
2.5
7.1
16.55
20.55
13
1.15
All dimensions : mm
●Micro B, without lock
6.65
2-0.2
2.6
1.3
5-0.15
No.1
HRS No.
Packaging
ZX80-B-5SA(30)
242-0019-7 30
100pcs/pks
BPCB mounting pattern
13
0.5(Through hole)
1.1(Land)
2.6
6.65
16.55
Contact No.5
1.86
.55 0.4
1.3
2.2(Land)
R0
1.6(Through hole)
2.9
2.2
8-
Contact No.1
16
1.15
3.15
0.37
5
e)
ol
.2
R0
H
2(
2.
8-
Ø
2-
1.1(Land)
0.5(Through hole)
0.7
2.5
7.1
16.55
20.55
1.3(Through hole)
1.9(Land)
Part No.
6
R1.
3.52
2.32
0.37
3.15
No.5
1
1.86
2.78
2.42
1.88
6.85
8.55
All dimensions : mm
BPackaging Specifications
●Embossed carrier tape dimensions
Unreeling direction
C
D
0.5
Ø1
.5
E
2
3
Ø1
1.75
4
●Reel Dimensions
Unreeling direction
Ø3
A
B
80
Part No.
Part No.
ZX62-B-5PA(33)
ZX62-AB-5PA(31)
ZX62M-B-5P(30)
Other
A dimension
24
24
24
16
B dimension
11.5
11.5
11.5
7.5
ZX62-B-5PA(33)
ZX62-AB-5PA(31)
ZX62M-B-5P(30)
Other
D dimension
30.4
30.4
30.4
22.4
E dimension
24.4
24.4
24.4
16.4
BRecommended Temperature Profile - Receptacles
●Using lead-free solder paste
The temperature profile is based on the left
conditions.
In individual applications the actual temperature
may vary, depending on solder paste type, volume/
thickness and board size/thickness. Contact your
solder paste and equipment manufacturer for
specific recommendations.
(ç)
240ç
230çmin
250
200
180ç
150
150ç
100
50
60S
30S
Note 1 : Up to 2 cycles of Reflow soldering are
possible under the same conditions, provided
that there is a return to normal temperature
between the first and second cycle.
Note 2 : The temperature profile indicates the board
surface temperature at the point of contacts
with the connector terminals.
BPrecautions
1. Exercise care when handling the connectors. Do not subject them to excessive external forces when mating/un-mating.
2. Mate and un-mate as intended, holding by the overmolded body, in the correct direction. Do not un-mate by pulling on the cable.
3. Some tooling marks may be visible on the surfaces of receptacle (shell/cover). No form/fit or function is affected.
4. Appearance of the surface finishes on the receptacles may vary between production runs. No affect on form, fit or function.
17
MEMO :
18
MEMO :
19
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 12/2017. Contents are subject to change without notice for the purpose of improvements.
